path: root/drivers/net/sfc/Makefile
2011-08-11sfc: Move the Solarflare driversJeff Kirsher
Moves the Solarflare drivers into drivers/net/ethernet/sfc/ and make the necessary Kconfig and Makefile changes. CC: Steve Hodgson <shodgson@solarflare.com> CC: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2010-09-22sfc: Add support for SFE4003 board and TXC43128 PHYBen Hutchings
This board never went into production, but some engineering samples are in use. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-22sfc: Remove support for SFN4111T, SFT9001 and Falcon GMACBen Hutchings
SFN4111T never reached production and is not being used for internal or customer testing. Since we have no production Falcon boards using the SFT9001 or the GMAC, remove support for them as well. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-21sfc: Add filter table managementBen Hutchings
2009-11-29sfc: Add support for SFC9000 family (2)Ben Hutchings
This integrates support for the SFC9000 family of 10G Ethernet controllers and LAN-on-motherboard chips, starting with the SFL9021 'Siena' and SFC9020 'Bethpage'. Credit for this code is largely due to my colleagues at Solarflare: Guido Barzini Steve Hodgson Kieran Mansley Matthew Slattery Neil Turton Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Move shared NIC code from falcon.c to new source file nic.cBen Hutchings
2009-10-24sfc: Rename 'xfp' file and functions to reflect realityBen Hutchings
The 'XFP' driver is really a driver for the QT2022C2 and QT2025C PHYs, covering both more and less than XFP. Rename its functions and constants to reflect reality and to reduce namespace pollution when sfc is a built-in driver. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-24sfc: Merge sfe4001.c into falcon_boards.cBen Hutchings
2009-10-24sfc: Rename Falcon-specific board code and typesBen Hutchings
Siena will require entirely different board code. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-12sfc: Add support for sub-10G speedsBen Hutchings
The SFC4000 has a separate MAC for use at sub-10G speeds. Introduce an efx_mac_operations structure with implementations for the two MACs. Switch between the MACs as necessary. PHY settings are independent of the MAC, so add get_settings() and set_settings() to efx_phy_operations. Also add macs field to indicate which MACs the PHY is connected to. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-06sfc: Expose flash region storing boot code as MTDBen Hutchings
The boot code that appears as a PCI expansion ROM on the SFC4000 is stored in flash. Expose this as a standard MTD device to allow for in-place upgrades. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-30sfc: Use kernel I2C system and i2c-algo-bit driverBen Hutchings
Remove our own implementation of I2C bit-banging. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-13[netdrvr] sfc: sfc: Add self-test supportBen Hutchings
Add a set of self-tests accessible thorugh ethtool. Add hardware loopback and TX disable control code to support them. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29New driver "sfc" for Solarstorm SFC4000 controller.Ben Hutchings
The driver supports the 10Xpress PHY and XFP modules on our reference designs SFE4001 and SFE4002 and the SMC models SMC10GPCIe-XFP and SMC10GPCIe-10BT. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
