path: root/drivers/net/sfc/falcon.h
2009-11-29sfc: Rename falcon.h to nic.hBen Hutchings
nic.h is no longer specific to Falcon. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Remove static PHY data and enumerationsBen Hutchings
New NICs have firmware managing the PHY, and we will discover the PHY capabilities at run-time. Replace the static data with probe() and test_name() operations. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Separate shared NIC code from Falcon-specific and rename accordinglyBen Hutchings
2009-11-29sfc: Add efx_nic_type operation for NVRAM self-testBen Hutchings
2009-11-29sfc: Add efx_nic_type operation for register self-testBen Hutchings
2009-11-29sfc: Refactor link configurationBen Hutchings
Refactor PHY, MAC and NIC configuration operations so that the existing link configuration can be re-pushed with: efx->phy_op->reconfigure(efx); efx->mac_op->reconfigure(efx); and a new configuration with: efx->nic_op->reconfigure_port(efx); (plus locking and error-checking). We have not held the link settings in software (aside from flow control), and have relied on asking the hardware what they are. This is a problem because in some cases the hardware may no longer be in a state to tell us. In particular, if an entire multi-port board is reset through one port, the driver bindings to other ports have no chance to save settings before recovering. We only actually need to keep track of the autonegotiation settings, so add an ethtool advertising mask to struct efx_nic, initialise it in PHY init and update it as necessary. Remove now-unneeded uses of efx_phy_op::{get,set}_settings() and struct ethtool_cmd. Much of this was done by Steve Hodgson <shodgson@solarflare.com>. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29sfc: Move Falcon NIC operations to efx_nic_typeBen Hutchings
This is preparation for adding differing implementations for new NICs. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-28sfc: Decouple NIC revision number from Falcon PCI revision numberBen Hutchings
2009-11-28sfc: Simplify PHY pollingSteve Hodgson
Falcon can generate events for LASI interrupts from the PHY, but in practice we have never implemented this in reference designs. Instead we have polled, inserted the appropriate events, and then handled the events later. This is a waste of time and code. Instead, make PHY poll functions update the link state synchronously and report whether it changed. We can still make use of the LASI registers as a shortcut on the SFT9001. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-26sfc: Change MAC promiscuity and multicast hash at the same timeBen Hutchings
From: Steve Hodgson <shodgson@solarflare.com> Currently we can set multicast hash immediately (in atomic context) but must delay setting MAC promiscuity. There is not that much point in deferring one but not the other, and setting the multicast hash on Siena will involve a firmware request. So process them both in efx_mac_work(). Also, set the broadcast bit in the multicast hash in efx_set_multicast_list(), since this is required for both Falcon and Siena. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-26sfc: Simplify XMAC link pollingBen Hutchings
From: Steve Hodgson <shodgson@solarflare.com> Only the XMAC on Falcon needs help from the driver to poll and reset the MAC-PHY link (XAUI); GMII is a simple parallel bus and on later NICs firmware takes care of the XAUI link. Also, an XMAC interrupt currently schedules a work item which simply clears a flag (efx_nic::mac_up) to be checked by the regular monitor (or the next link reconfiguration, if that is sooner). Rename the flag to xmac_poll_required, changing its sense. Remove the needless indirection and just set the flag immediately. Call falcon_xmac_poll() directly where required. Add a new generic operation mac_op::check_fault to check the link outside of regular monitoring, as required during self-tests. (Note that this leaves us with an unused work item, but we will immediately have another use for it.) Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-26sfc: Move Falcon board/PHY/MAC monitoring code to falcon.cBen Hutchings
2009-11-26sfc: Split MAC stats DMA initiation and completionBen Hutchings
From: Steve Hodgson <shodgson@solarflare.com> Currently we initiate MAC stats DMA and busy-wait for completion when stats are requested. We can improve on this with a periodic timer to initiate and poll for stats, and opportunistically poll when stats are requested. Since efx_nic::stats_disable_count and efx_stats_{disable,enable}() are Falcon-specific, rename them and move them accordingly. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-26sfc: Clean up struct falcon_board and struct falcon_board_dataBen Hutchings
Put all static information in struct falcon_board_type and replace it with a pointer in struct falcon_board. Simplify probing aocordingly. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-26sfc: Comment correctionsBen Hutchings
2009-11-24sfc: Move all I2C stuff into struct falcon_boardBen Hutchings
2009-11-24sfc: Move struct falcon_board into struct falcon_nic_dataBen Hutchings
2009-11-24sfc: Move definition of struct falcon_nic_data into falcon.hBen Hutchings
This is preparation for moving Falcon-specific state required by other Falcon-specific code. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-24sfc: Make board information explicitly Falcon-specificBen Hutchings
Rename struct efx_board to struct falcon_board. Introduce and use inline function to look up board info from struct efx_nic, in preparation for moving it. Move board init and fini calls into NIC probe and remove functions. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-24sfc: Remove declarations of nonexistent functionsBen Hutchings
2009-10-24sfc: Remove boards.h, moving last remaining declaration to falcon.hBen Hutchings
2009-03-21sfc: Implement adaptive IRQ moderationBen Hutchings
Calculate a score for each 1000 IRQs: - TX completions are worth 1 point - RX completions are worth 4 if merged using LRO or 2 otherwise Reduce moderation if the score is less than 10000, down to a minimum of 5 us. Increase moderation if the score is more than 20000, up to the specified maximum. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-12sfc: Add support for sub-10G speedsBen Hutchings
The SFC4000 has a separate MAC for use at sub-10G speeds. Introduce an efx_mac_operations structure with implementations for the two MACs. Switch between the MACs as necessary. PHY settings are independent of the MAC, so add get_settings() and set_settings() to efx_phy_operations. Also add macs field to indicate which MACs the PHY is connected to. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-24sfc: Make queue flushes more reliableBen Hutchings
Increase the potential retry count for RX flushes from 5 to 100. Stop polling the RX_DESC_PTR_TBL to infer that a flush might have happened. Instead absolutely rely on the flush events, unless bug 7803 applies (Falcon rev A only). To keep things quick, request flushes for every TX and RX queue up front, and match up the events to requests. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-03sfc: Extend self-testsBen Hutchings
Include PMA/PMD in loopback self-tests as intended. Add NVRAM checksum validation and include it in self-tests. Add register self-tests. Run PHY self-tests where available. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-03sfc: Remove some unreachable error pathsBen Hutchings
Some functions return an error code which is always 0. Change their return types to void and simplify their callers accordingly. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-03sfc: Cleanup RX event processingBen Hutchings
Make efx_process_channel() and falcon_process_eventq() return the number of packets received rather than updating the quota, consistent with new NAPI. Since channels and RX queues are mapped one-to-one, remove return value from falcon_handle_rx_event() and add a warning for events with the wrong RX queue number. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-03sfc: Use explicit bool for boolean variables, parameters and return valuesBen Hutchings
Replace (cond ? 1 : 0) with cond or !!cond as appropriate, and (cond ? 0 : 1) with !cond. Remove some redundant boolean temporaries. Rename one field that looks like a flag but isn't. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-22sfc: Replaced various macros with inline functionsBen Hutchings
2008-04-29New driver "sfc" for Solarstorm SFC4000 controller.Ben Hutchings
The driver supports the 10Xpress PHY and XFP modules on our reference designs SFE4001 and SFE4002 and the SMC models SMC10GPCIe-XFP and SMC10GPCIe-10BT. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
