path: root/drivers/net/sfc/mdio_10g.h
2009-04-29sfc: Use generic MDIO flow control auto-negotiation functionsBen Hutchings
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-29sfc: Use generic MDIO functions and definitionsBen Hutchings
Make use of the newly-added generic MDIO clause 45 support and remove redundant definitions. Add an 'efx_' prefix to the remaining driver-specific MDIO functions and remove arguments which are redundant with efx->mdio.prtad. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-02sfc: Fix reporting of PHY idBen Hutchings
Shuffle bits of the OUI into the conventional written order. Replace PHY id component macros with functions. Zero-pad PHY id components in log messages. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-30sfc: SFX7101/SFT9001: Fix AN advertisementsBen Hutchings
All 10Xpress PHYs require autonegotiation all the time; enforce this in the set_settings() method and do not treat it as a workaround. Remove claimed support for 100M HD mode since it is not supported by current firmware. Do not set speed override bits when AN is enabled, and do not use register 1.49192 for AN configuration as it can override what we set elsewhere. Always set the AN selector bits to 1 (802.3). Fix confusion between Next Page and Extended Next Page. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-26sfc: Fix unreliable link detection in some loopback modesBen Hutchings
2008-12-12sfc: Add support for Solarflare 10Xpress SFT9001Ben Hutchings
Add type codes for the new PHY and rename the SFX7101 type code. Add definition of clause 22 extension MMD. Adapt the 10Xpress SFX7101 code to support the SFT9001 as well. Clean up register definitions. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-12sfc: Implement auto-negotiationBen Hutchings
Add infrastructure for auto-negotiation of speed, duplex and flow control. When using 10Xpress, auto-negotiate flow control. While we're at it, clean up the code to warn when partner is not 10GBASE-T capable. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-12sfc: Clean up MDIO flag settingBen Hutchings
We often want to set or clear a flag in an MDIO register, but avoid writing if no change is required since this can have side-effects. Encapsulate this in a function, mdio_clause45_set_flag(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-12sfc: Add support for MMDs numbered >15Ben Hutchings
Combine DEVS0 and DEVS1 registers into a 32-bit mask instead of reading just DEVS0. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-06sfc: Use lm87 and lm90 drivers for board temperature/power monitoringBen Hutchings
Add board monitoring to periodic work whenever link is down. For SFE4001, report when a fault has caused the PHY to turn off. For SFE4002, switch XFP PHY into low-power state in case of a fault. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-03sfc: Use explicit bool for boolean variables, parameters and return valuesBen Hutchings
Replace (cond ? 1 : 0) with cond or !!cond as appropriate, and (cond ? 0 : 1) with !cond. Remove some redundant boolean temporaries. Rename one field that looks like a flag but isn't. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-03sfc: Reduce log level for XGXS lane statusBen Hutchings
This was making noise during 10Xpress self-test. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-13[netdrvr] sfc: sfc: Add self-test supportBen Hutchings
Add a set of self-tests accessible thorugh ethtool. Add hardware loopback and TX disable control code to support them. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-13[netdrvr] sfc: Remove garbage from commentBen Hutchings
2008-04-29New driver "sfc" for Solarstorm SFC4000 controller.Ben Hutchings
The driver supports the 10Xpress PHY and XFP modules on our reference designs SFE4001 and SFE4002 and the SMC models SMC10GPCIe-XFP and SMC10GPCIe-10BT. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
