path: root/drivers/net/sgiseeq.c
2011-04-26Merge branch 'master' into for-nextJiri Kosina
Fast-forwarded to current state of Linus' tree as there are patches to be applied for files that didn't exist on the old branch.
2011-04-06update David Miller's old email addressJustin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-26drivers/net: sgiseeq: fix return on errorNicolas Kaiser
If we continue on error, we'd likely free the IRQ that we didn't get, right? Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-26sgiseeq: use free_netdev(netdev) instead of kfree()Kulikov Vasiliy
Freeing netdev without free_netdev() leads to net, tx leaks. I might lead to dereferencing freed pointer. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) @@ struct net_device* dev; @@ -kfree(dev) +free_netdev(dev) Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (37 commits) smc91c92_cs: fix the problem of "Unable to find hardware address" r8169: clean up my printk uglyness net: Hook up cxgb4 to Kconfig and Makefile cxgb4: Add main driver file and driver Makefile cxgb4: Add remaining driver headers and L2T management cxgb4: Add packet queues and packet DMA code cxgb4: Add HW and FW support code cxgb4: Add register, message, and FW definitions netlabel: Fix several rcu_dereference() calls used without RCU read locks bonding: fix potential deadlock in bond_uninit() net: check the length of the socket address passed to connect(2) stmmac: add documentation for the driver. stmmac: fix kconfig for crc32 build error be2net: fix bug in vlan rx path for big endian architecture be2net: fix flashing on big endian architectures be2net: fix a bug in flashing the redboot section bonding: bond_xmit_roundrobin() fix drivers/net: Add missing unlock net: gianfar - align BD ring size console messages net: gianfar - initialize per-queue statistics ...
2010-03-30drivers/net: Add missing unlockJulia Lawall
Unlock the lock before leaving the function. A simplified version of the semantic patch that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r exists@ expression E1; identifier f; @@ f (...) { <+... * spin_lock_irqsave (E1,...); ... when != E1 * return ...; ...+> } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13net: Use netdev_alloc_skb_ip_align()Eric Dumazet
2009-10-01don't use __devexit_p to wrap sgiseeq_removeUwe Kleine-König
The function sgiseeq_remove is defined using __exit, so don't use __devexit_p but __exit_p to wrap it. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: David S. Miller <davem@davemloft.net> Cc: Wang Chen <wangchen@cn.fujitsu.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Patrick McHardy <kaber@trash.net> Cc: netdev@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-23net: move sgiseeq's probe function to .devinit.textUwe Kleine-König
A pointer to sgiseeq_probe is passed to the core via platform_driver_register and so the function must not disappear when the .init sections are discarded. Otherwise (if also having HOTPLUG=y) unbinding and binding a device to the driver via sysfs will result in an oops as does a device being registered late. An alternative to this patch is using platform_driver_probe instead of platform_driver_register plus removing the pointer to the probe function from the struct platform_driver. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Wang Chen <wangchen@cn.fujitsu.com> Cc: David S. Miller <davem@davemloft.net> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jeff Garzik <jgarzik@redhat.com> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-16sgiseeq: convert to net_device_opsAlexander Beregalov
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12netdevice: safe convert to netdev_priv() #part-3Wang Chen
We have some reasons to kill netdev->priv: 1. netdev->priv is equal to netdev_priv(). 2. netdev_priv() wraps the calculation of netdev->priv's offset, obviously netdev_priv() is more flexible than netdev->priv. But we cann't kill netdev->priv, because so many drivers reference to it directly. This patch is a safe convert for netdev->priv to netdev_priv(netdev). Since all of the netdev->priv is only for read. But it is too big to be sent in one mail. I split it to 4 parts and make every part smaller than 100,000 bytes, which is max size allowed by vger. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-25net drivers: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable network platform drivers, to re-enable auto loading. NOTE: didn't change drivers/net/fs_enet/fs_enet-main.c "old binding" support. That looks problematic in the first place (it even uses the ancient "struct device_driver" binding scheme for platform_bus!) and I suspect it will vanish soonish when arch/powerpc rules the world. Also, drivers/net/ne.c would have needed more thought to sort out. [akpm@linux-foundation.org: fix sgiseeq.c] [dbrownell@users.sourceforge.net: more drivers, registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Scott Wood <scottwood@freescale.com> Cc: Vitaly Bordug <vitb@kernel.crashing.org> Cc: Dale Farnsworth <dale@farnsworth.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Andrew Victor <andrew@sanpeople.com> Cc: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-01-28SGISEEQ: fix oops when doing ifconfig down; ifconfig upThomas Bogendoerfer
When doing init_ring checking whether a new skb needs to be allocated was wrong. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-28SGISEEQ: use cached memory access to make driver work on IP28Thomas Bogendoerfer
- Use inline functions for dma_sync_* instead of macros - added Kconfig change to make selection for similair SGI boxes easier Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
SGI IP28 machines would need special treatment (enable adding addtional wait states) when accessing memory uncached. To avoid this pain I changed the driver to use only cached access to memory. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET] drivers/net: statistics cleanup #1 -- save memory and shrink codeJeff Garzik
We now have struct net_device_stats embedded in struct net_device, and the default ->get_stats() hook does the obvious thing for us. Run through drivers/net/* and remove the driver-local storage of statistics, and driver-local ->get_stats() hook where applicable. This was just the low-hanging fruit in drivers/net; plenty more drivers remain to be updated. [ Resolved conflicts with napi_struct changes and fix sunqe build regression... -DaveM ] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10sgiseeq: replace use of dma_cache_wback_invRalf Baechle
The sgiseeq driver is one of the few remaining users of the ancient cache banging DMA API. Replaced with the modern days DMA API. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-08-25sgiseeq: Fix return type of sgiseeq_removeRalf Baechle
The driver remove method needs to return an int not void. This was just never noticed because usually this driver is not being built as a module. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-10[NET]: Kill eth_copy_and_sum().David S. Miller
It hasn't "summed" anything in over 7 years, and it's just a straight mempcy ala skb_copy_to_linear_data() so just get rid of it. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-11Convert SGI IP22 and specific drivers to platform_device.Ralf Baechle
2007-04-28Add support for Seeq 8003 on Challenge S Mezz board.Ladislav Michl
Thanks to Jö Fahlke for donating hardware. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Forward porting of Ladis' 2.4 patch. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-27sgiseeq: Don't include unnecessary headerfiles.Ralf Baechle
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-03-11[PATCH] Sparse: Cleanup sgiseeq sparse warnings.Ralf Baechle
o Make sgiseeq_dump_rings static. o Delete unused sgiseeq_my_reset. o Move DEBUG define to beginning where it's easier to spot and will be seen by <linux/kernel.h> as well. o Use NULL for pointer initialization. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2005-10-18[PATCH] sgiseeq: Configure PIO and DMA timing requests.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> drivers/net/sgiseeq.c | 28 ++++++++++++++-------------- include/asm-mips/sgi/hpc3.h | 40 ++++++++++++++++++++-------------------- 2 files changed, 34 insertions(+), 34 deletions(-) Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-18[PATCH] sgiseeq: Fix resource handling.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> drivers/net/sgiseeq.c | 9 ++++----- 1 files changed, 4 insertions(+), 5 deletions(-) Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
