path: root/drivers/net/slip.h
2010-08-27slip: Use net_device_stats from struct net_deviceTobias Klauser
Use net_device->stats for stats instead of private variable copies in struct slip. Use ndo_get_stat64 so the additions can be performed on a private destination buffer. Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-06trivial: fix then -> than typos in comments and documentationFrederik Schwarzer
- (better, more, bigger ...) then -> (...) than Signed-off-by: Frederik Schwarzer <schwarzerf@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org>
