path: root/drivers/net/smc-mca.c
2009-05-01net: remove driver_data direct access of struct deviceGreg Kroah-Hartman
In the near future, the driver core is going to not allow direct access to the driver_data pointer in struct device. Instead, the functions dev_get_drvdata() and dev_set_drvdata() should be used. These functions have been around since the beginning, so are backwards compatible with all older kernel versions. Cc: netdev@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-11netdev: add missing set_mac_address hookStephen Hemminger
Many drivers lost the ability to set ethernet address accidently during the net_device_ops conversion. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-26smc-mca: Fix build failure due to typo.David S. Miller
ultra_netdev_ops --> ultramca_netdev_ops Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25smc: convert to net_device_opsStephen Hemminger
Convert both eisa and mca versions of this driver, though I doubt anyone still has the hardware. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-09[PATCH] kill eth_io_copy_and_sum()Al Viro
On all targets that sucker boils down to memcpy_fromio(sbk->data, from, len). The function name is highly misguiding (it _never_ does any checksums), the last argument is just a noise and simply expanding the call to memcpy_fromio() gives shorter and more readable source. For a lot of reasons it has almost no remaining users, so it's better to just outright kill it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2005-05-12 [PATCH] drivers/net/smc-mca.c: cleanupsAdrian Bunk
This patch contains the following cleanups: - make a needlessly global function static - make three needlessly global structs static const Since after moving the now-static stucts to smc-mca.c the file smc-mca.h was empty except for two #define's, I've also killed the rest of smc-mca.h . Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
