path: root/drivers/net/smc91x.c
2006-01-08[PATCH] IRQ type flagsRussell King
Some ARM platforms have the ability to program the interrupt controller to detect various interrupt edges and/or levels. For some platforms, this is critical to setup correctly, particularly those which the setting is dependent on the device. Currently, ARM drivers do (eg) the following: err = request_irq(irq, ...); set_irq_type(irq, IRQT_RISING); However, if the interrupt has previously been programmed to be level sensitive (for whatever reason) then this will cause an interrupt storm. Hence, if we combine set_irq_type() with request_irq(), we can then safely set the type prior to unmasking the interrupt. The unfortunate problem is that in order to support this, these flags need to be visible outside of the ARM architecture - drivers such as smc91x need these flags and they're cross-architecture. Finally, the SA_TRIGGER_* flag passed to request_irq() should reflect the property that the device would like. The IRQ controller code should do its best to select the most appropriate supported mode. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-18[PATCH] smc91x: fix bank mismatchRussell King
The smc91x driver relies upon register bank 2 being selected whenever the interrupt handler is called. This isn't always so, especially if we have a link change event during PHY configuration. This results in register bank 0 being selected when the interrupt handler is called, causing the wrong registers to be read for the IRQ mask and status. In turn, this causes us to spin with a permanently asserted IRQ. The patch ensures that smc_phy_configure always exits with register bank 2 selected. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-18[PATCH] smc91x: fix one source of spurious interruptsNicolas Pitre
Not only SMC_ACK_INT(IM_TX_EMPTY_INT) in in smc_hardware_send_pkt) appears to be unnecessary (tested with an SMC91C94 and SMC91C111), but it seems to trigger spurious interrupts on some machines as well. Removed. While at it, let's log any remaining spurious interrupts if any (and clean usage of the max IRQ loop count value). Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-31Merge master.kernel.org:/home/rmk/linux-2.6-drvmodelLinus Torvalds
Manual #include fixups for clashes - there may be some unnecessary
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28Merge branch 'master'Jeff Garzik
2005-10-28[PATCH] smc91x: shut down power after probingNicolas Pitre
If the interface is not used right away after being probed it wastes power needlessly. Noted by Holger Schurig. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28[PATCH] DRIVER MODEL: Get rid of the obsolete tri-level suspend/resume callbacksRussell King
In PM v1, all devices were called at SUSPEND_DISABLE level. Then all devices were called at SUSPEND_SAVE_STATE level, and finally SUSPEND_POWER_DOWN level. However, with PM v2, to maintain compatibility for platform devices, I arranged for the PM v2 suspend/resume callbacks to call the old PM v1 suspend/resume callbacks three times with each level in order so that existing drivers continued to work. Since this is obsolete infrastructure which is no longer necessary, we can remove it. Here's an (untested) patch to do exactly that. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] smc91x needs settable IRQ trigger typeDavid Brownell
For boards that invert the SMC91x IRQ line (maybe an FPGA inverts it), the set_irq_type() call can't assume IRQT_RISING. These particular boards currently use OMAP-specific calls to change the trigger type, but the boards break when set_irq_type() stops being a NOP. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2005-06-27[PATCH] smc91x: plug race between TX tasklet and driver resetNicolas Pitre
The race causes a kernel oops when smc_hardware_send_pkt() tries to dereference pending_tx_skb which would have been freed from one of the driver reset paths just after the tx_task tasklet has been scheduled. This race is possible on SMP but was uncovered by the kernel RT work. Signed-off-by: Nicolas Pitre <nico@cam.org>
2005-05-27[PATCH] smc91x: more tweaks to help with RX overrunsNicolas Pitre
Signed-off-by: Nicolas Pitre <nico@cam.org> Index: linux-2.6/drivers/net/smc91x.c ===================================================================
2005-05-27[PATCH] smc91x: improve diagnostic infoNicolas Pitre
... and remove duplicate status defines. Signed-off-by: Nicolas Pitre <nico@cam.org> Index: linux-2.6/drivers/net/smc91x.c ===================================================================
2005-05-12 [PATCH] smc91x addr config checkNicolas Pitre
The PAGE_SIZE mask is indeed confusing. Use the exact mask for this context which has nothing to do with memory pages at all. Also cast to int since the value to compare with is an int. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-04-16[PATCH] u32 vs. pm_message_t fixes for drivers/netPavel Machek
This fixes remaining u32s in drivers/ net. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
