path: root/drivers/net/smsc9420.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-18net: convert multiple drivers to use netdev_for_each_mc_addr, part2Jiri Pirko
Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-01Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/mac80211/ht.c
2009-11-29smsc9420: prevent BUG() if ethtool is called with interface downSteve Glendinning
This patch fixes a null pointer dereference BUG() if ethtool is used on an smsc9420 interface while it is down, because the phy_dev is only allocated while the interface is up. Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18drivers/net/smsc9420.c: remove exceptional & on function nameJulia Lawall
In this file, function names are otherwise used as pointers without &. A simplified version of the semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ identifier f; @@ f(...) { ... } @@ identifier r.f; @@ - &f + f // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02drivers: Kill now superfluous ->last_rx storesEric Dumazet
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Neil Horman <nhorman@txudriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-20smsc9420: fix big endian rx checksum offloadSteve Glendinning
The cpu_to_le16 here looks suspicious to me, I don't think we need it because put_unaligned_le16 also does this. I don't currently have any big endian hardware with a PCI bus available to test on, so I haven't been able to verify this. Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-24Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2009-02-20smsc9420: handle magic field of ethtool_eepromSteve Glendinning
ethtool.h says the driver should set the magic field in get_eeprom and verify it in set_eeprom. This patch adds this functionality using an arbitary driver-specific magic value constant (0x9420). Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-20smsc9420: fix another postfixed timeoutSteve Glendinning
Roel Kluin recently fixed several instances where variables reach -1, but 0 is tested afterwards. This patch fixes another, so the timeout will be correctly detected and a warning printed. Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/Kconfig
2009-02-02net: variables reach -1, but 0 testedRoel Kluin
while (timeout--) { ... } timeout becomes -1 if the loop isn't ended otherwise, not 0. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-30Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/e1000/e1000_main.c
2009-01-29smsc9420: fix interrupt signalling test failuresSteve Glendinning
smsc9420 performs an interrupt signalling test when the interface is brought up. The current code mistakenly sets its test flag to false AFTER enabling the software interrupt source, making failure quite likely. This patch changes the code to set the test flag BEFORE enabling interrupts. I've also removed an smp_wmb because the following spinlock provides an implicit memory barrier. Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-26net: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21net: Remove redundant NAPI functionsBen Hutchings
Following the removal of the unused struct net_device * parameter from the NAPI functions named *netif_rx_* in commit 908a7a1, they are exactly equivalent to the corresponding *napi_* functions and are therefore redundant. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-11netdev: add missing set_mac_address hookStephen Hemminger
Many drivers lost the ability to set ethernet address accidently during the net_device_ops conversion. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-22net: Remove unused netdev arg from some NAPI interfaces.Neil Horman
When the napi api was changed to separate its 1:1 binding to the net_device struct, the netif_rx_[prep|schedule|complete] api failed to remove the now vestigual net_device structure parameter. This patch cleans up that api by properly removing it.. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-16net: Refactor full duplex flow control resolutionSteve Glendinning
These 4 drivers have identical full duplex flow control resolution functions. This patch changes them all to use one common function. The function in question decides whether a device should enable TX and RX flow control in a standard way (IEEE 802.3-2005 table 28B-3), so this should also be useful for other drivers. Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-15smsc9420: add ethtool register dump supportSteve Glendinning
This patch adds support for SMSC's LAN9420 PCI ethernet controller to ethtool's dump registers (-d) command. This patch is for use with an accompanying ethtool patch, which decodes the register dump. Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-12smsc9420: add ethtool eeprom supportSteve Glendinning
2008-12-12smsc9420: add netpoll supportSteve Glendinning
2008-12-11smsc9420: SMSC LAN9420 10/100 PCI ethernet adapterSteve Glendinning
This patch adds a driver for the LAN9240 PCI ethernet adapter. Changes since initial submission: - debug msg_level has been changed to use standard definitions - convert to use net_device_ops Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
