path: root/drivers/net/sungem_phy.c
2007-05-02[POWERPC] Rename get_property to of_get_property: driversStephen Rothwell
These are all the remaining instances of get_property. Simple rename of get_property to of_get_property. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-27sungem_phy: support bcm5461 phy, autoneg.Jens Osterkamp
This version moves the medium variable to the card specific structure and changes the GMII_* to BCM54XX_* #defines. This patch adds improved version of enable_fiber for both the 5421 and the 5461 phy. It is now possible to specify with these wether you want autonegotiation or not. This is needed for bladecenter switches where some expect autonegotiation and some dont seem to like this at all. Depending on this flag it sets phy->autoneg accordingly for the fiber mode. More importantly it implements proper read_link and poll_link functions for both phys which can handle both copper and fiber mode by determining the medium first and then branching to the required functions. For fiber they all work fine, for copper they are not tested but return the result of the genmii_* function anyway which is supposed to work. The patch moves the genmii_* functions around to avoid foreward declarations. Signed-off-by: Jens Osterkamp <jens@de.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-03[SUNGEM]: PHY updates & pause fixes (#2)Benjamin Herrenschmidt
This patch adds support for a few more PHYs used by Apple and fixes advertising and detecting of Pause (we were missing setting the bit in MII_ADVERTISE and weren't testing in LPA for all PHYs). Note that I currently only advertise pause, not asymetric pause. I don't know for sure the details there, I suppose I should read a bit more 802.3 references, and I don't now what sungem is capable of, but I noticed the PCS code (originated from you) does the same. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-05-26[PATCH] spidernet: replace whitespaces by tabsJens Osterkamp
The original patch was using whitespaces instead of tabs. Signed-off-by: Jens Osterkamp <Jens.Osterkamp@de.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-05-08spidernet: enable support for bcm5461 ethernet phyJens Osterkamp
A newer board revision changed the type of ethernet phy. Moreover, this generalizes the way that a phy gets switched into fiber mode when autodetection is not available. Signed-off-by: Jens Osterkamp <Jens.Osterkamp@de.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
2006-04-19[SUNGEM]: Marvell PHY suspend.Johannes Berg
In a short discussion with Benjamin Herrenschmidt he mentioned that Marvell PHYs are powered down the same way as the other ones we currently handle. Thus actually do that, hopefully saving some power during suspend. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-03Massive net driver const-ification.Arjan van de Ven
2005-07-07[PATCH] ppc64: Add new PHY to sungemBenjamin Herrenschmidt
This patch adds support for some new PHY models to sungem as used on some recent Apple iMac G5 models. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
