path: root/drivers/net/tc35815.c
2011-05-22Add appropriate <linux/prefetch.h> include for prefetch usersPaul Gortmaker
After discovering that wide use of prefetch on modern CPUs could be a net loss instead of a win, net drivers which were relying on the implicit inclusion of prefetch.h via the list headers showed up in the resulting cleanup fallout. Give them an explicit include via the following $0.02 script. ========================================= #!/bin/bash MANUAL="" for i in `git grep -l 'prefetch(.*)' .` ; do grep -q '<linux/prefetch.h>' $i if [ $? = 0 ] ; then continue fi ( echo '?^#include <linux/?a' echo '#include <linux/prefetch.h>' echo . echo w echo q ) | ed -s $i > /dev/null 2>&1 if [ $? != 0 ]; then echo $i needs manual fixup MANUAL="$i $MANUAL" fi done echo ------------------- 8\<---------------------- echo vi $MANUAL ========================================= Signed-off-by: Paul <paul.gortmaker@windriver.com> [ Fixed up some incorrect #include placements, and added some non-network drivers and the fib_trie.c case - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-26drivers/net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-18net: preserve ifreq parameter when calling generic phy_mii_ioctl().Richard Cochran
The phy_mii_ioctl() function unnecessarily throws away the original ifreq. We need access to the ifreq in order to support PHYs that can perform hardware time stamping. Two maverick drivers filter the ioctl commands passed to phy_mii_ioctl(). This is unnecessary since phylib will check the command in any case. Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-13Revert "tc35815: fix iomap leak"David S. Miller
This reverts commit b31fb86815153be3bc94e8ffb9dbf6e9d7694b2d. pcim_*() managed drivers do not need explicit resource releasing like this. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-12tc35815: fix iomap leakKulikov Vasiliy
If tc35815_init_one() fails we must unmap mapped regions. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-26tc35815: Fix double locking on NAPIAtsushi Nemoto
Isolate spinlock for tx and rx to resolve double-locking. This is potential bug while this controller does not exist on any SMP platforms, but lockdep or rt-preempt reveals this bug. Reported-by: Ralf Roesch <ralf.roesch@rw-gmbh.de> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-26net: convert multiple drivers to use netdev_for_each_mc_addr, part6Jiri Pirko
2010-02-25Merge branch 'master' of ↵David S. Miller
2010-02-23tc35815: Remove a wrong netif_wake_queue() call which triggers BUG_ONAtsushi Nemoto
The netif_wake_queue() is called correctly (i.e. only on !txfull condition) from txdone routine. So Unconditional call to the netif_wake_queue() here is wrong. This might cause calling of start_xmit routine on txfull state and trigger BUG_ON. This bug does not happen when NAPI disabled. After txdone there must be at least one free tx slot. But with NAPI, this is not true anymore and the BUG_ON can hits on heavy load. In this driver NAPI was enabled on 2.6.33-rc1 so this is regression from 2.6.32 kernel. Reported-by: Ralf Roesch <ralf.roesch@rw-gmbh.de> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18drivers/net: request_irq - Remove unnecessary leading & from second argJoe Perches
Not as fancy as coccinelle. Checkpatch errors ignored. Compile tested allyesconfig x86, not all files compiled. grep -rPl --include=*.[ch] "\brequest_irq\s*\([^,\)]+,\s*\&" drivers/net | while read file ; do \ perl -i -e 'local $/; while (<>) { s@(\brequest_irq\s*\([^,\)]+,\s*)\&@\1@g ; print ; }' $file ;\ done Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tc35815: Kill unused codeAtsushi Nemoto
- TC35815_DMA_SYNC_ONDEMAND is always enabled. - WORKAROUND_LOSTCAR is always enabled. - WORKAROUND_100HALF_PROMISC is always enabled. - GATHER_TXINT is always enabled. - TC35815_USE_PACKEDBUFFER is always disabled. - NO_CHECK_CARRIER is always disabled. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tc35815: Kill non-napi codeAtsushi Nemoto
2009-10-28tc35815: Enable NAPIAtsushi Nemoto
This driver has NAPI code but it has been disabled. Enable it now. The non-napi code will be removed lator. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-28tc35815: Fix return value of tc35815_do_interrupt when NAPI enabledAtsushi Nemoto
Return received count correctly even if tx completed at the same time. Currently NAPI is disabled for this driver so this patch does not fix any real problem. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-06tc35815: Use 0 RxFragSize.MinFrag value for non-packing modeAtsushi Nemoto
The datasheet say "When not enabling packing, the MinFrag value must remain at 0". Do not set value to RxFragSize register if TC35815_USE_PACKEDBUFFER disabled. This is not a bugfix. No real problem reported on this. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-06tc35815: Fix rx_missed_errors countAtsushi Nemoto
The Miss_Cnt register is cleared by reading. Accumulate its value to rx_missed_errors count. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-06tc35815: Increase timeout for mdioAtsushi Nemoto
The current timeout value is too short for very high-load condition which jiffies might jump up in busy-loop. Also add minimum delay before checking completion of MDIO. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-06tc35815: Improve BLEx / FDAEx handlingAtsushi Nemoto
Clear Int_BLEx / Int_FDAEx after (not before) processing Rx interrupt. This will reduce number of unnecessary interrupts. Also print rx error messages only if netif_msg_rx_err() enabled. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-06tc35815: Disable StripCRCAtsushi Nemoto
It seems Rx_StripCRC cause trouble on recovering from the BLEx (Buffer List Exhaust) or FDAEx (Free Descriptor Area Exhaust) condition. Do not use it. Also bump version number up. Reported-by: Ralf Roesch <ralf.roesch@rw-gmbh.de> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-17drivers/net: Convert #ifdef DEBUG printk(KERN_DEBUG to pr_debug(Joe Perches
2009-04-13tc35815: convert to net_device_opsAlexander Beregalov
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-02tc35815: Fix build error if NAPI enabledAtsushi Nemoto
This driver contains experimental NAPI code disabled by default. The commit bea3348ee ("[NET]: Make NAPI polling independent of struct net_device objects.") converted the NAPI path of this driver but that conversion was not complete. This patch fixes a build error introduced by the commit. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-26net: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21net: Remove redundant NAPI functionsBen Hutchings
Following the removal of the unused struct net_device * parameter from the NAPI functions named *netif_rx_* in commit 908a7a1, they are exactly equivalent to the corresponding *napi_* functions and are therefore redundant. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-22net: Remove unused netdev arg from some NAPI interfaces.Neil Horman
When the napi api was changed to separate its 1:1 binding to the net_device struct, the netif_rx_[prep|schedule|complete] api failed to remove the now vestigual net_device structure parameter. This patch cleans up that api by properly removing it.. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-11tc35815: Enable StripCRC featureAtsushi Nemoto
The chip can strip CRC automatically on receiving. Enable it. Also fix potential RX_BUF_SIZE calculation bug which was obscured by alignment. And use proper symbols (NET_IP_ALIGN, ETH_FCS_LEN, etc.) instead of magic numbers. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31tc35815: Define more Rx status bitsAtsushi Nemoto
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-12net/tc35815.c: fix compilationAdrian Bunk
Fix an obvious typo introduced by commit 298cf9beb9679522de995e249eccbd82f7c51999 (phylib: move to dynamic allocation of struct mii_bus). <-- snip --> ... CC drivers/net/tc35815.o drivers/net/tc35815.c: In function 'tc_mii_init': drivers/net/tc35815.c:799: error: 'err_out_free_mii_bus' undeclared (first use in this function) drivers/net/tc35815.c:799: error: (Each undeclared identifier is reported only once drivers/net/tc35815.c:799: error: for each function it appears in.) drivers/net/tc35815.c:781: error: label 'err_out_free_mii_bus' used but not defined make[3]: *** [drivers/net/tc35815.o] Error 1 <-- snip --> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08phylib: move to dynamic allocation of struct mii_busLennert Buytenhek
This patch introduces mdiobus_alloc() and mdiobus_free(), and makes all mdio bus drivers use these functions to allocate their struct mii_bus'es dynamically. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Andy Fleming <afleming@freescale.com>
2008-10-08phylib: rename mii_bus::dev to mii_bus::parentLennert Buytenhek
In preparation of giving mii_bus objects a device tree presence of their own, rename struct mii_bus's ->dev argument to ->parent, since having a 'struct device *dev' that points to our parent device conflicts with introducing a 'struct device dev' representing our own device. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Andy Fleming <afleming@freescale.com>
2008-07-26dma-mapping: add the device argument to dma_mapping_error()FUJITA Tomonori
Add per-device dma_mapping_ops support for CONFIG_X86_64 as POWER architecture does: This enables us to cleanly fix the Calgary IOMMU issue that some devices are not behind the IOMMU (http://lkml.org/lkml/2008/5/8/423). I think that per-device dma_mapping_ops support would be also helpful for KVM people to support PCI passthrough but Andi thinks that this makes it difficult to support the PCI passthrough (see the above thread). So I CC'ed this to KVM camp. Comments are appreciated. A pointer to dma_mapping_ops to struct dev_archdata is added. If the pointer is non NULL, DMA operations in asm/dma-mapping.h use it. If it's NULL, the system-wide dma_ops pointer is used as before. If it's useful for KVM people, I plan to implement a mechanism to register a hook called when a new pci (or dma capable) device is created (it works with hot plugging). It enables IOMMUs to set up an appropriate dma_mapping_ops per device. The major obstacle is that dma_mapping_error doesn't take a pointer to the device unlike other DMA operations. So x86 can't have dma_mapping_ops per device. Note all the POWER IOMMUs use the same dma_mapping_error function so this is not a problem for POWER but x86 IOMMUs use different dma_mapping_error functions. The first patch adds the device argument to dma_mapping_error. The patch is trivial but large since it touches lots of drivers and dma-mapping.h in all the architecture. This patch: dma_mapping_error() doesn't take a pointer to the device unlike other DMA operations. So we can't have dma_mapping_ops per device. Note that POWER already has dma_mapping_ops per device but all the POWER IOMMUs use the same dma_mapping_error function. x86 IOMMUs use device argument. [akpm@linux-foundation.org: fix sge] [akpm@linux-foundation.org: fix svc_rdma] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix bnx2x] [akpm@linux-foundation.org: fix s2io] [akpm@linux-foundation.org: fix pasemi_mac] [akpm@linux-foundation.org: fix sdhci] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix sparc] [akpm@linux-foundation.org: fix ibmvscsi] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-22netdev: bunch of drivers: avoid WARN at net/core/dev.c:1328Anton Vorontsov
The drivers were touching net queue before it has been started, so without this patch, the drivers will potentially WARN at net/core/dev.c:1328. I don't have the hardware for the drivers below, so this patch is untested, and thus should be carefully peer reviewed. tc35815.c au1000_eth.c bfin_mac.c macb.c ^ The four drivers are using phylib, they're calling netif_start_queue() in open() callback. So trivially remove netif_tx_schedule_all(). Phylib will handle netif_carrier_*(). cpmac.c fec_mpc52xx.c fs_enet/fs_enet-main.c sh_eth.c ^ The same as above, but these were also needlessly calling netif_carrier_*() functions. So removed queue calls and also remove carrier calls, since phylib will handle it. fs_enet-main.c also didn't call netif_start_queue() at open(), this is fixed now. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17netdev: Convert all drivers away from netif_schedule().David S. Miller
They logically all want to trigger a schedule for all device TX queues. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-27tc35815: Fix receiver hangup on Rx FIFO overflowAtsushi Nemoto
On Rx FIFO overflow error, the controller consume a buffer descriptor but currently the driver does not give it back to the controller. This results unrecoverable 'Buffer List Exhausted' condition. This patch fix this problem by moving a "fbl_count--" line to proper place. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-27tc35815: Mark carrier-off before starting PHYAtsushi Nemoto
Call netif_carrier_off() before starting PHY device. This is a behavior before converting to generic PHY layer. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-17tc35815: Statistics cleanupAtsushi Nemoto
On Sat, 12 Apr 2008 05:00:49 -0400, Jeff Garzik <jeff@garzik.org> wrote: > applied 1-6 Thanks. Could you apply this too, or hopufully fold into Andy Fleming's "phy: Change mii_bus id field to a string" patch (commit c69fedae) ? ------------------------------------------------------ Subject: [PATCH] tc35815: build fix Fix build failure caused by Andy Fleming's "phy: Change mii_bus id field to a string" patch. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-16tc35815: Whitespace cleanupAtsushi Nemoto
Cosmetic TAB/whitespace cleanups and some style cleanups. No functional changes. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-16tc35815: Use generic PHY layerAtsushi Nemoto
Convert the tc35815 driver to use the generic PHY layer in drivers/net/phy. Also rename 'boardtype' to 'chiptype' which hould be more appropriate. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-16tc35815: Use managed pci iomap helperAtsushi Nemoto
Use managed pci functions and kill unnecessary volatiles. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-16tc35815: Use netdev_priv()Atsushi Nemoto
Use netdev_priv() instead of dev->priv. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-16tc35815: Use print_mac() helperAtsushi Nemoto
Use print_mac() and DECLARE_MAC_BUF(). Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-16tc35815: Statistics cleanupAtsushi Nemoto
Use struct net_device_stats embedded in struct net_device. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
