path: root/drivers/net/team/team_mode_broadcast.c
2013-03-06team: introduce two default team_modeop functions and use them in modesJiri Pirko
No need to duplicate code for this. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-21team: bcast: convert return value of team_dev_queue_xmit() to bool correctlyJiri Pirko
The thing is that team_dev_queue_xmit() returns NET_XMIT_* or -E*. bc_trasmit() should return true in case all went well. So use ! to get correct retval from team_dev_queue_xmit() result. This bug caused iface statistics to be badly computed. This bug was introduced by: team: add broadcast mode (5fc889911a99043a97da1daa0d010ad72cbc3042) Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-20team: add support for non-ethernet devicesJiri Pirko
This is resolved by two things: 1) allow dev_addr of different length than ETH_ALEN 2) during port add, check for dev->type and change it if necessary Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-17team: add netpoll supportJiri Pirko
It's done in very similar way this is done in bonding and bridge. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-12team: add broadcast modeJiri Pirko
Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
