path: root/drivers/net/tehuti.c
2008-04-29drivers/net/tehuti: use proper capability check for raw IO accessLinus Torvalds
Yeah, in practice they both mean "root", but Alan correctly points out that anybody who gets to do raw IO space accesses should really be using CAP_SYS_RAWIO rather than CAP_NET_ADMIN. Pointed-out-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-25[netdrvr] tehuti: move ioctl perm check closer to function startJeff Garzik
Noticed by davem. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25tehuti: check register sizeFrancois Romieu
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-01-28netdev: ARRAY_SIZE() cleanupsAlejandro Martinez Ruiz
Convert array size calculations to use ARRAY_SIZE(). Signed-off-by: Alejandro Martinez Ruiz <alex@flawedcode.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-28netdev: use ARRAY_SIZE() instead of sizeof(array) / ETH_GSTRING_LENAlejandro Martinez Ruiz
Using ARRAY_SIZE() on arrays of the form array[][K] makes it unnecessary to know the value of K when checking its size. Signed-off-by: Alejandro Martinez Ruiz <alex@flawedcode.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-13[TEHUTI]: Fix incorrect usage of strncat in bdx_get_drvinfo()Roel Kluin
Fix incorrect length for strncat by replacing it with strlcat Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15tehuti: possible leak in bdx_probeFlorin Malita
If pci_enable_device fails, bdx_probe returns without freeing the allocated pci_nic structure. Coverity CID 1908. Signed-off-by: Florin Malita <fmalita@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10network drivers: sparse warning fixesStephen Hemminger
Fix some of the easy warnings in network device drivers. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Add Tehuti network driver.Andy Gospodarek
[ Ported to napi_struct changes... -DaveM ] Signed-off-by: David S. Miller <davem@davemloft.net>
