path: root/drivers/net/tg3.c
2008-06-09tg3: Update version to 3.92.1Matt Carlson
This patch increments the version to 3.92.1. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-09tg3: Fix 5761 WOLMatt Carlson
On 5761 non-e devices, two problems prevent the administrator from overriding the WOL settings in the device's NVRAM. The first problem is that GPIO 0 and GPIO 2 have been swapped. This change prevented the administrator from turning on WOL when it is disabled in NVRAM. The fix is to add a new path for the 5761 that swaps the two GPIOs in the code as well. The second problem is that GPIO 1 could not be toggled by the driver because the GPIO is shared with the debug UART GPIO. This will prevent the administrator from being able to turn WOL off if it was enabled in NVRAM. The fix is to always disable the debug UART after a GRC reset. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-09tg3: Fix a flags typoMatt Carlson
This patch fixes a problem where the TG3_FLAG_10_100_ONLY flag was testing against the wrong flags variable. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-09tg3: Fix 5714S / 5715S / 5780S link failuresMatt Carlson
The git commit ef167e27039eeaea6d3cdd5c547b082e89840bdd entitled "Fix supporting flowctrl code" introduced a bug that prevents 5714S, 5715S and 5780S devices from falling back to a forced link mode. The problem is that the added flow control check will always fail if flow control is set to autoneg and either RX or TX (or both) flow control is enabled. The driver defaults to setting flow control to autoneg and advertises both RX and TX flow control. The fix is to remove the errant check. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02tg3: Update version to 3.92Matt Carlson
This patch updates the version number to 3.92. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02tg3: Add link state reporting to UMP firmwareMatt Carlson
All variants of the 5714, 5715, and 5780 offer a feature called the "Universal Management Port". This feature is implemented in firmware and is largely transparent to the driver, except... It turns out that the UMP firmware needs to know the current status of the link. Because the firmware cannot touch the PHY registers while the driver is in control of the device, it needs the driver to report link status changes through an additional handshaking mechanism. Without this handshake, it has been observed in the field that the UMP firmware will not operate correctly. This patch implements the new handshake with the UMP firmware. Since the handshake uses the same mechanism ASF heartbeats use, code was added to detect and wait for completion of a pending previous event. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02tg3: Fix ethtool loopback test for 5761 BX devicesMatt Carlson
A CPMU related loopback test bug existed for AX revisions of the 5761. While that errata has been fixed, the CPMU still slows down the core clock too far to run the loopback test successfully. This patch disables the CPMU LINK_SPEED mode just like we do with the AX revisions of the 5761 and all revisions of the 5784. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02tg3: Fix 5761 NVRAM sizesMatt Carlson
The 5761 NVRAM sizes assigned to the nvram_size member are half as big as they should be. This patch corrects the NVRAM sizes and replaces the hardcoded constants with preprocessor constants for readability. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02tg3: Use constant 500KHz MI clock on adapters with a CPMUMatt Carlson
The MI clock is not configured correctly on adapters with the CPMU present. The tg3 driver has code which statically sets the MI clock to be a fraction of the speed at which the core clock is running. However, the CPMU can change the adapter's core clock frequency based on operating conditions. Consequently, the MI will run slow when the core's clock has been slowed down. There is a new 500KHz constant frequency clock available on adapters with a CPMU. This patch removes the static core clock scaling and configures the MI clock to use this new 500KHz clock instead. Running the MI clock at slower speeds will not directly result in data corruption, but it does challenge the PHY read and write routine timeouts. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-29Remove duplicated unlikely() in IS_ERR()Hirofumi Nakagawa
Some drivers have duplicated unlikely() macros. IS_ERR() already has unlikely() in itself. This patch cleans up such pointless code. Signed-off-by: Hirofumi Nakagawa <hnakagawa@miraclelinux.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Jeff Garzik <jeff@garzik.org> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Patrick McHardy <kaber@trash.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24tg3: sparse cleanupEric Dumazet
Fix the following sparse warning : drivers/net/tg3.c:4025:3: warning: context imbalance in 'tg3_restart_hw' - unexpected unlock Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-19tg3: 5701 DMA corruption fixMatt Carlson
Herbert Xu's commit fb93134dfc2a6e6fbedc7c270a31da03fce88db9, entitled "[TCP]: Fix size calculation in sk_stream_alloc_pskb", has triggered a bug in the 5701 where the 5701 DMA engine will corrupt outgoing packets. This problem only happens when the starting address of the packet matches a certain range of offsets and only when the 5701 is placed downstream of a particular Intel bridge. This patch detects the problematic bridge and if present, readjusts the starting address of the packet data to a dword aligned boundary. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-12tg3: fix MMIO for PPC 44x platformsSergei Shtylyov
The driver stores the PCI resource addresses into 'unsigned long' variable before calling ioremap_nocache() on them. This warrants kernel oops when the registers are accessed on PPC 44x platforms which (being 32-bit) have PCI memory space mapped beyond 4 GB. The arch/ppc/ kernel has a fixup in ioremap() that creates an illusion that the PCI memory resource is mapped below 4 GB, but arch/powerpc/ code got rid of this trick, having instead CONFIG_RESOURCES_64BIT enabled. [ Bump driver version and release date -DaveM ] Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-03[TG3]: Add PHY workaround for 5784Matt Carlson
The 5784 B step and newer chips require the PHY DSPs to be fine-tuned based on one-time programmable values stored in the chip. This is essential to achieve optimal PHY operations especially when using long cables. We also need to properly handle the 10Mbit RX bit in the CPMU_CTRL register during PHY reset. Update version to 3.89. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-20[TG3]: Fix build warning on sparc32.David S. Miller
Sparc MAC address support should be protected consistently with CONFIG_SPARC, but there was a stray CONFIG_SPARC64 case. Bump driver version and release date. Reported by Andrew Morton. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-23tg3: ethtool phys_id defaultStephen Hemminger
When asked to blink LEDs the tg3 driver behaves when using: ethtool -p ethX The default value for data is zero, and other drivers interpret this as blink forever (or at least a really long time). The tg3 driver interprets this as blink once. All drivers should have the same behaviour. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28NULL noise in drivers/netAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TG3]: Update version to 3.87Matt Carlson
This patch updates the version number to 3.87. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TG3]: Fix supporting flowctrl codeMatt Carlson
This patch does three things. It modifies tg3_setup_flow_control() to use the administrator requested flow control settings if autonegotiation is turned off. It slightly modifies the tg3_setup_fiber_mii_phy() function to account for this new use case. And finally, it does the same for tg3_setup_copper_phy(). The copper modifications are more than a small multi-line change. The new code makes an attempt to avoid a link renegotiation if the link is active at half duplex and the only difference between the current advertised settings and requested advertised settings is the flow control advertisements. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TG3]: Correct sw autoneg flow control advertisementsMatt Carlson
This patch modifies the software autoneg code to use the administrator specified flow control parameters. Since the autonegotiation code uses alternative flow control enumerations, the 1000-BaseX utility functions are used and code was added to convert the definitions to and from the alternate enumerations. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TG3]: Correct 5704S flowctrl advertisementsMatt Carlson
This patch modifies the 5704S hardware autoneg code to use the administrator specified flow control parameters. Since the 5704S uses device specific flow control enumerations, the 1000-BaseX utility functions are used and code was added to convert the definitions to and from the proprietary enumerations. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TG3]: Replace some magic 5704S constantsMatt Carlson
This patch replaces magic values with preprocessor definitions for the sg_dig_ctrl and sg_dig_status registers. This is preparatory work for the next patch. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TG3]: Add 1000T & 1000X flowctl adv helpersMatt Carlson
This patch adds two functions designed to convert abstract TX & RX flow control parameters to 1000-BaseT and 1000-BaseX autonegotiation advertisements. Code that uses standard definitions which statically advertises TX & RX flow control has been replaced with code that configures the advertisements based on administrator dictated preferences. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TG3]: Add 1000T & 1000X flowctrl resolversMatt Carlson
This patch adds two new utility functions to resolve flow control. One function resolves flow control based on 1000-BaseT register definitions. The other resolves flow control based on 1000-Base X register definitions. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TG3]: Separate requested and actual flow control parametersMatt Carlson
This patch removes the TX and RX flow control flags from tg3_flags and adds two new flow control variables, flowctrl and active_flowctrl. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TG3]: Use print_macJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-19[TG3]: Endianness bugfix.Al Viro
tg3_nvram_write_block_unbuffered() is reading data from nvram into allocated buffer before overwriting a part of it with user-supplied data. Then it feeds the entire page back to nvram. It should be storing the words it had read as little-endian, not as host-endian. Note that tg3_set_eeprom() does exactly that for padding the same data to full words before it gets passed down to tg3_nvram_write_block() and then to tg3_nvram_write_block_unbuffered(). Moreover, when we get to sending the entire thing back to nvram, we go through it word-by-word, doing essentially writel(swab32(le32_to_cpu(word)), ...) so if we want them to reach the card in host-independent endianness, we'd better really have all that buffer filled with fixed-endian. For user-supplied part we obviously do have that (it's an array of octets memcpy'd in), ditto for padding of user-supplied part to word boundaries (taken care of in tg3_set_eeprom()). The rest of the buffer gets filled by tg3_nvram_write_block_unbuffered() and it would damn better be consistent with that (and with tg3_get_eeprom(), while we are at it - there we also convert the words read from nvram to little-endian before returning the buffer to user). The bug should get triggered on big-endian boxen when set_eeprom is done for less than entire page. Then the words that should've been unaffected at all will actually get byteswapped in place in nvram. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-19[TG3]: Endianness annotations.Al Viro
Fixed misannotations, introduced a new helper - tg3_nvram_read_le(). It gets __le32 * instead of u32 * and puts there the value converted to little-endian. A lot of callers of tg3_nvram_read() were doing that; converted them to tg3_nvram_read_le(). At that point the driver is practically endian-clean; the only remaining place is an actual bug, AFAICS; will be dealt with in the next patch. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-12[TG3]: Update version to 3.86Matt Carlson
This patch updates the version number to 3.86 Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-12[TG3]: MII => TPMatt Carlson
This patch changes the PHY type reported through ethtool for copper devices from MII to TP. The latter is more accurate. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-12[TG3]: Add A1 revsMatt Carlson
This patch adds the A1 revision of 5784, 5764, and 5761, and applies all previous bugfixes. In places where the list of devices gets too long, the patch uses a new TG3_FLG3_5761_5784_AX_FIXES flag instead. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-12[TG3]: Increase the PCI MRRSMatt Carlson
Previous devices hardcoded the PCI Maximum Read Request Size to 4K. To better comply with the PCI spec, the hardware now defaults the MRRS to 512 bytes. This will yield poor driver performance if left untouched. This patch increases the MRRS to 4K on driver initialization. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-12[TG3]: Prescaler fixMatt Carlson
Internal hardware timers become inaccurate after link events. Clock frequency switches performed by the CPMU fail to adjust timer prescalers. The fix is to detect core clock frequency changes during link events and adjust the timer prescalers accordingly. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-12[TG3]: Limit 5784 / 5764 to MAC LED modeMatt Carlson
Most 5784 / 5764 LED modes do not work as expected because of a hardware bug. This patch forces the LED mode to be in MAC LED mode. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-12[TG3]: Disable GPHY autopowerdownMatt Carlson
New CPMU devices contend with the GPHY for power management. The GPHY autopowerdown feature is enabled by default in the PHY and thus needs to be disabled after every PHY reset. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-12[TG3]: CPMU adjustments for loopback testsMatt Carlson
This patch adds the LINK_SPEED mode to the list of CPMU modes that can cause the loopback tests to fail. These bugs are planned to be fixed in future revisions of the chip, so the patch qualifies the fixes as such. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-12[TG3]: Fix nvram selftest failuresMatt Carlson
Newer devices contain bootcode in the chip's private ROM area. This bootcode is called selfboot. Selfboot can be patched in the device's NVRAM and the patches can have several formats. In one particular format, the checksum calculation needs to be slightly modified. This patch adjusts the NVRAM test code for that case, and add support for the missing formats. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-12[TG3]: 5784 / 5764 DMA engine lockup fixMatt Carlson
5784 and 5764 devices lock up when the link speed is 10Mbps, the CPMU link speed mode is enabled, and the MAC clock is running at 1.5Mhz. The fix is to run the MAC clock at faster speeds. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-12[TG3]: APE flag fixMatt Carlson
This patch corrects a bug where the ENABLE_APE flag was tested against the wrong flag variable. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-12[TG3]: 5784 / 5764 GPHY power down fixMatt Carlson
5784 and 5764 devices fail to link / pass traffic after one load / unload cycle. This happens because of a hardware bug in the new CPMU. During normal operation, the MAC depends on the PHY clock being available. When the PHY is powered down, the clock the MAC depends on is disabled. The fix is to switch the MAC clock to an alternate source before powering down the PHY, and to restore the MAC clock to the PHY source upon device resume. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-12[TG3]: Fix 5761 PXEboot crashMatt Carlson
When 5761 devices boot the machine using PXEboot, PXE leaves the device active when it terminates. The tg3 driver has code to detect this condition and resets the device during initialization. On 5761 devices, device resets involve sending a driver state update message to the APE on the 5761. However, during this initialization stage, communications to the APE registers have not yet been set up. The driver then dereferences a NULL pointer and crashes the machine. The fix is to move the APE register access setup earlier in the initialization code to cover this condition. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-05PCI: Add quirk for devices which disable MSI when INTX_DISABLE is set.David Miller
A reasonably common problem with some devices is that they will disable MSI generation when the INTX_DISABLE bit is set in the PCI_COMMAND register. Quirk this explicitly, guarding the pci_intx() calls in msi.c with this quirk indication. The first entries for this quirk are for 5714 and 5780 Tigon3 chips, and thus we can remove the workaround code from the tg3.c driver. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Michael Chan <mchan@broadcom.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-22[TG3]: Update version to 3.85Matt Carlson
This patch updates the version number to 3.85. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-22[TG3]: PCI command adjustmentMatt Carlson
This patch changes the way the driver works with the PCI command register. It adjusts the access size from dwords to words. This patch is done both as a PCI configuration space cleanup and as preparatory work for PCI error recovery. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-22[TG3]: Add management FW version to ethtool reportMatt Carlson
This patch appends the management firmware version to the bootcode firmware string reported through ethtool. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-22[TG3]: Add 5723 supportMatt Carlson
This patch adds support for upcoming 5723 devices. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15Merge branch 'master' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 * 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (42 commits) [IPV6]: Consolidate the ip6_pol_route_(input|output) pair [TCP]: Make snd_cwnd_cnt 32-bit [TCP]: Update the /proc/net/tcp documentation [NETNS]: Don't panic on creating the namespace's loopback [NEIGH]: Ensure that pneigh_lookup is protected with RTNL [INET]: kmalloc+memset -> kzalloc in frag_alloc_queue [ISDN]: Fix compile with CONFIG_ISDN_X25 disabled. [IPV6]: Replace sk_buff ** with sk_buff * in input handlers [SELINUX]: Update for netfilter ->hook() arg changes. [INET]: Consolidate the xxx_put [INET]: Small cleanup for xxx_put after evictor consolidation [INET]: Consolidate the xxx_evictor [INET]: Consolidate the xxx_frag_destroy [INET]: Consolidate xxx_the secret_rebuild [INET]: Consolidate the xxx_frag_kill [INET]: Collect common frag sysctl variables together [INET]: Collect frag queues management objects together [INET]: Move common fields from frag_queues in one place. [TG3]: Fix performance regression on 5705. [ISDN]: Remove local copy of device name to make sure renames work. ...
2007-10-15netdev: convert non-obvious instances to use ARRAY_SIZE()Alejandro Martinez Ruiz
This will convert remaining non-obvious or naive calculations of array sizes to use ARRAY_SIZE() macro. Signed-off-by: Alejandro Martinez Ruiz <alex@flawedcode.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-15[TG3]: Fix performance regression on 5705.Michael Chan
A performance regression was introduced by the following commit: commit ee6a99b539a50b4e9398938a0a6d37f8bf911550 Author: Michael Chan <mchan@broadcom.com> Date: Wed Jul 18 21:49:10 2007 -0700 [TG3]: Fix msi issue with kexec/kdump. In making that change, the PCI latency timer and cache line size registers were not restored after chip reset. On the 5705, the latency timer gets reset to 0 during chip reset and this causes very poor performance. Update version to 3.84. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-12[TG3]: Refine napi poll loop.Michael Chan
Need to read and store sblk->status_tag before checking for more work. The status tag is later written back to the hardware when enabling interrupts to acknowledge how much work has been processed. If the order is reversed, we can end up acknowledging work we haven't processed. When we detect tx error, it is more correct to return the rx work_done so far instead of 0. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
