path: root/drivers/net/tg3.h
2009-04-21tg3: Limit CLKREQ fix to A[01] of 57780 asic revMatt Carlson
This patch restricts the CLKREQ bugfix to the A0 and A1 revisions of 57780 ASIC rev chips. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-21tg3: Prevent send BD corruptionMatt Carlson
On rare occasions, send BD corruptions can occur. This patch fixes the problem by increasing the L1 entry threshold to 4 milliseconds. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-21tg3: Handle NVRAM absent casesMatt Carlson
Some 57780 ASIC revision parts do not have NVRAM. Code the driver so that it is tolerant of this configuration. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-21tg3: Allow screaming interrupt detectionMatt Carlson
The tg3 driver's ISR is coded to accept interrupts as its own if the status block tag does not equal the last tag the driver has seen. The last_tag field is updated from tg3_poll. In a screaming interrupt situation from another device sharing tg3's IRQ, tg3_poll does not get a chance to be called, so the last_tag will always be out of sync with the status block tag. Consequently, the driver will continually declare the screaming interrupts as its own, thus thwarting the screaming interrupt detection logic. This patch solves the problem by creating a new last_irq_tag member and recording the status block tag in the ISR. The ISR then checks the last_irq_tag for interrupt ownership. Many thanks to John Marvin for the detailed bug report and analysis and Michael Chan for the bugfix. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Tested-by: John Marvin <jsm@fc.hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-26tg3: Add version reporting for hardware selfbootMatt Carlson
This patch adds version reporting for hardware selfboot. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-26tg3: Add DASH firmware version reportingMatt Carlson
This patch adds code to report the DASH firmware version. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-26tg3: Add legacy bootcode version decodingMatt Carlson
This patch adds code to obtain the bootcode version for versions of bootcode that do not use the new method. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-19tg3: Fix firmware loadingMatt Carlson
This patch modifies how the tg3 driver handles device firmware. The patch starts by consolidating David Woodhouse's earlier patch under the same name. Specifically, the patch moves the request_firmware call into a separate tg3_request_firmware() function and calls that function from tg3_open() rather than tg3_init_one(). The patch then goes on to limit the number of devices that will make request_firmware calls. The original firmware patch unnecessarily requested TSO firmware for devices that did not need it. This patch reduces the set of devices making TSO firmware patches to approximately the following device set : 5703, 5704, and 5705. Finally, the patch reduces the effects of a request_firmware() failure. For those devices that are requesting TSO firmware, the driver will turn off the TSO capability. If TSO firmware becomes available at a later time, the device can be closed and then opened again to reacquire the TSO capability. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-04firmware: convert tg3 driver to request_firmware()Jaswinder Singh Rajput
Firmware blob looks like this... u8 firmware_major u8 firmware_minor u8 firmware_fix u8 pad __be32 start_address __be32 length (total, including BSS sections to be zeroed) data... (in __be32 words, which is native for the firmware) Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-21tg3: tg3.h cleanupsMatt Carlson
This patch cleans up the tg3 header file by removing the preprocessor definitions for standard PCI configuration space registers. The driver should be using the standard definitions when needed. The patch continues by removing redundant PHY related definitions and reorganizes some of the remaining entries. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-21tg3: Remove unused cfgspc device membersMatt Carlson
This patch removes the pci_bist and pci_hdr_type members from the device structure and removes the code that references them. They are not really used. The patch rounds out the changes by moving the pci_cmd member to plug a structure hole that would have been created. On 32-bit systems, this movement removes a subsequent structure hole later in the structure. On 64-bit systems though, the movement merely consolidates two holes into one larger hole. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-21tg3: Cleanup IPV6 LSOMatt Carlson
This patch attempts to make the relationship between IPV6 checksum offload and IPV6 LSO more obvious. The patch also toggles a bit needed for IPV6 LSO on 5785 and 57780 devices. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-16net: Move flow control definitions to mii.hSteve Glendinning
flags used within drivers for indicating tx and rx flow control are defined in 4 drivers (and probably more), move these constants to mii.h. The 3 SMSC drivers use the same constants (FLOW_CTRL_TX), but TG3 uses TG3_FLOW_CTRL_TX, so this patch also renames the constants within TG3. Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-21tg3: Add 57780 supportMatt Carlson
This patch adds support for the 57780 ASIC revision. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-21tg3: Extract FW ver from alt NVRAM formatsMatt Carlson
This patch extracts the bootcode firmware version from the alternate selfboot patch NVRAM format. This format is used on the 5784, 5761 and some newer devices. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-21tg3: Enable GPHY APD on select devicesMatt Carlson
GPHY Autopowerdown (APD) is a way to save power when energy is not detected on the wire. At the moment, only the 5784 and 5761 are capable of enabling this mode. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-21tg3: Prevent corruption at 10 / 100Mbps w CLKREQMatt Carlson
This patch disables CLKREQ at 10Mbps and 100Mbps to workaround a TX BD corruption issue. This problem only affects the 5784 and 5761 (and 57780 AX) ASIC revisions. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03tg3: 5785 enhancementsMatt Carlson
This patch refines support for the 5785 device. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03tg3: Allow WOL for phylib controlled Broadcom physMatt Carlson
This patch allows WOL to be enabled for Broadcom phys under phylib control. The only exception is the AC131, which has a completely different register set. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03tg3: Reclaim TG3_FLG3_5761_5784_AX_FIXES flagMatt Carlson
This patch reclaims the TG3_FLG3_5761_5784_AX_FIXES flag. It only used twice in non-fast paths. This patch also consolidates some other places where specific 5784 AX chip revisions can be generalized. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03tg3: Preserve DASH connectivity when WOL enabledMatt Carlson
DASH firmware runs on the APE side of the chip, but it requires a few MAC to be programmed correctly. When WOL is enabled and management firmware is disabled, incoming packets are evaluated and discarded at the chip's rule processor. When management firmware is enabled, the hardware must be informed that there are agents further up the stack that still use the incoming frames. Normally management firmware will configure the MAC correctly on its own, but there can be cases where the setting could get clobbered by the driver. The first hunk of this patch preserves this setting. The second hunk of this patch wipes out the driver present signature of the APE memory space. By doing so, the DASH firmware can assume driver absent behavior. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03tg3: Add 5761S supportMatt Carlson
This patch adds support for the 5761S chip variants. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08phylib: move to dynamic allocation of struct mii_busLennert Buytenhek
This patch introduces mdiobus_alloc() and mdiobus_free(), and makes all mdio bus drivers use these functions to allocate their struct mii_bus'es dynamically. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Andy Fleming <afleming@freescale.com>
2008-09-11tg3: Use SKB DMA helper functions for TX.David S. Miller
2008-08-15tg3: Fix firmware event timeoutsMatt Carlson
The git commit 7c5026aa9b81dd45df8d3f4e0be73e485976a8b6 ("tg3: Add link state reporting to UMP firmware") introduced code that waits for previous firmware events to be serviced before attempting to submit a new event. Unfortunately that patch contained a bug that cause the driver to wait 2.5 seconds, rather than 2.5 milliseconds as intended. This patch fixes that bug. This bug revealed that not all firmware versions service driver events though. Since we do not know which versions of the firmware do and don't service these events, the driver needs some way to minimize the effects of the delay. This patch solves the problem by recording a jiffies timestamp when it submits an event to the hardware. If the jiffies counter shows that 2.5 milliseconds have already passed, a wait is not needed and the driver can proceed to submit a new event. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-15tg3: Preserve register settings for DASHMatt Carlson
Broadcom's DASH (Desktop and mobile Architecture for System Hardware) implementation requires that the driver preserve particular register settings. If the driver does not preserve them, communication with the DASH firmware will be lost. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-15tg3: Add APE register access lockingMatt Carlson
If the driver resets the chip while the APE is performing a register access, that register access will never complete and the APE will hang indefinitely. To prevent this race condition, the driver must acquire an APE mutex before resetting the chip. The APE will not attempt a register access until it acquires this lock. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-29tg3: Add shmem options.Matt Carlson
This patch adds some options obtained through shared memory. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-29tg3: Add 5785 ASIC revisionMatt Carlson
This patch added the 5785 device ID and ASIC revision to the code. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-29tg3: Add libphy support.Matt Carlson
This patch introduces the libphy support. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-29tg3: Add mdio bus registrationMatt Carlson
This patch introduces code to register and unregister the tg3 mdio bus with the system. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-29tg3: Add TG3_FLG3_USE_PHYLIBMatt Carlson
This patch introduces the TG3_FLG3_USE_PHYLIB flag and applies it to some select places. This work makes later patches a little easier to read. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-29tg3: Code cleanup.Matt Carlson
This patch applies cleanups that would otherwise clutter later patches. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02tg3: Add link state reporting to UMP firmwareMatt Carlson
All variants of the 5714, 5715, and 5780 offer a feature called the "Universal Management Port". This feature is implemented in firmware and is largely transparent to the driver, except... It turns out that the UMP firmware needs to know the current status of the link. Because the firmware cannot touch the PHY registers while the driver is in control of the device, it needs the driver to report link status changes through an additional handshaking mechanism. Without this handshake, it has been observed in the field that the UMP firmware will not operate correctly. This patch implements the new handshake with the UMP firmware. Since the handshake uses the same mechanism ASF heartbeats use, code was added to detect and wait for completion of a pending previous event. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02tg3: Fix 5761 NVRAM sizesMatt Carlson
The 5761 NVRAM sizes assigned to the nvram_size member are half as big as they should be. This patch corrects the NVRAM sizes and replaces the hardcoded constants with preprocessor constants for readability. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02tg3: Use constant 500KHz MI clock on adapters with a CPMUMatt Carlson
The MI clock is not configured correctly on adapters with the CPMU present. The tg3 driver has code which statically sets the MI clock to be a fraction of the speed at which the core clock is running. However, the CPMU can change the adapter's core clock frequency based on operating conditions. Consequently, the MI will run slow when the core's clock has been slowed down. There is a new 500KHz constant frequency clock available on adapters with a CPMU. This patch removes the static core clock scaling and configures the MI clock to use this new 500KHz clock instead. Running the MI clock at slower speeds will not directly result in data corruption, but it does challenge the PHY read and write routine timeouts. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-19tg3: 5701 DMA corruption fixMatt Carlson
Herbert Xu's commit fb93134dfc2a6e6fbedc7c270a31da03fce88db9, entitled "[TCP]: Fix size calculation in sk_stream_alloc_pskb", has triggered a bug in the 5701 where the 5701 DMA engine will corrupt outgoing packets. This problem only happens when the starting address of the packet matches a certain range of offsets and only when the 5701 is placed downstream of a particular Intel bridge. This patch detects the problematic bridge and if present, readjusts the starting address of the packet data to a dword aligned boundary. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-03[TG3]: Add PHY workaround for 5784Matt Carlson
The 5784 B step and newer chips require the PHY DSPs to be fine-tuned based on one-time programmable values stored in the chip. This is essential to achieve optimal PHY operations especially when using long cables. We also need to properly handle the 10Mbit RX bit in the CPMU_CTRL register during PHY reset. Update version to 3.89. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TG3]: Replace some magic 5704S constantsMatt Carlson
This patch replaces magic values with preprocessor definitions for the sg_dig_ctrl and sg_dig_status registers. This is preparatory work for the next patch. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TG3]: Separate requested and actual flow control parametersMatt Carlson
This patch removes the TX and RX flow control flags from tg3_flags and adds two new flow control variables, flowctrl and active_flowctrl. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-12[TG3]: Add A1 revsMatt Carlson
This patch adds the A1 revision of 5784, 5764, and 5761, and applies all previous bugfixes. In places where the list of devices gets too long, the patch uses a new TG3_FLG3_5761_5784_AX_FIXES flag instead. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-12[TG3]: Prescaler fixMatt Carlson
Internal hardware timers become inaccurate after link events. Clock frequency switches performed by the CPMU fail to adjust timer prescalers. The fix is to detect core clock frequency changes during link events and adjust the timer prescalers accordingly. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-12[TG3]: Disable GPHY autopowerdownMatt Carlson
New CPMU devices contend with the GPHY for power management. The GPHY autopowerdown feature is enabled by default in the PHY and thus needs to be disabled after every PHY reset. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-12[TG3]: Fix nvram selftest failuresMatt Carlson
Newer devices contain bootcode in the chip's private ROM area. This bootcode is called selfboot. Selfboot can be patched in the device's NVRAM and the patches can have several formats. In one particular format, the checksum calculation needs to be slightly modified. This patch adjusts the NVRAM test code for that case, and add support for the missing formats. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-12[TG3]: 5784 / 5764 DMA engine lockup fixMatt Carlson
5784 and 5764 devices lock up when the link speed is 10Mbps, the CPMU link speed mode is enabled, and the MAC clock is running at 1.5Mhz. The fix is to run the MAC clock at faster speeds. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-12[TG3]: 5784 / 5764 GPHY power down fixMatt Carlson
5784 and 5764 devices fail to link / pass traffic after one load / unload cycle. This happens because of a hardware bug in the new CPMU. During normal operation, the MAC depends on the PHY clock being available. When the PHY is powered down, the clock the MAC depends on is disabled. The fix is to switch the MAC clock to an alternate source before powering down the PHY, and to restore the MAC clock to the PHY source upon device resume. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-22[TG3]: PCI command adjustmentMatt Carlson
This patch changes the way the driver works with the PCI command register. It adjusts the access size from dwords to words. This patch is done both as a PCI configuration space cleanup and as preparatory work for PCI error recovery. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-22[TG3]: Add management FW version to ethtool reportMatt Carlson
This patch appends the management firmware version to the bootcode firmware string reported through ethtool. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[TG3]: WOL defaultsMatt Carlson
This patch enables WOL by default if out-of-box WOL is enabled in the NVRAM. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[TG3]: Add 5761 supportMatt Carlson
This patch adds rest of the miscellaneous code required to support the 5761. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
