path: root/drivers/net/tlan.c
2011-03-03tlan: Use pr_fmt, pr_<level> and netdev_<level>Joe Perches
Neatening and standardization to the current logging mechanisms. Miscellaneous speen/speed typo correction. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-03tlan: Remove changelogJoe Perches
As it isn't necessary nor really useful any longer. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-13tlan: Fix bugs introduced by the last tlan cleanup patchSakari Ailus
Fix two bugs introduced by the commit c659c38b2796578638548b77ef626d93609ec8ac ("tlan: Code cleanup: checkpatch.pl is relatively happy now.") In that change, TLAN_CSTAT_READY was considered as a bit mask containing a single bit set while it was actually had two set instead. Many thanks to Dan Carpenter for finding the mistake. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-24tlan: add suspend/resume supportSakari Ailus
Add suspend/resume support to tlan driver. This allows not unloading the driver over suspend/resume. Also, start (or now, wake) the queue after resetting the adapter --- not the other way around. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-24tlan: Code cleanup: checkpatch.pl is relatively happy now.Sakari Ailus
- Remove CamelCase. - Convert hexadecimals to lower case. - Remove useless comments. Tlan driver contained a name of the function at the end of it in a comment. Remove those comments. - Remove local typedefs. Use real types instead of typedefs in code. - Resolve space issues and reindent. - One warning remain, it's a case where printing a single line involves a number of printk()s. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-26drivers/net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-25drivers/net: Remove address use from assignments of function pointersJoe Perches
"foo = &function" is more commonly written "foo = function" Done with coccinelle script: // <smpl> @r@ identifier f; @@ f(...) { ... } @@ identifier r.f; @@ - &f + f // </smpl> drivers/net/tehuti.c used a function and struct with the same name, the function was renamed. Compile tested x86 only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-24net/various: remove trailing space in messagesFrans Pop
Signed-off-by: Frans Pop <elendil@planet.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-26net: convert multiple drivers to use netdev_for_each_mc_addr, part6Jiri Pirko
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-13drivers/net/tlan: Remove TRUE/FALSE defines, use boolJoe Perches
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13net: Use netdev_alloc_skb_ip_align()Eric Dumazet
2009-09-03netdev: Remove redundant checks for CAP_NET_ADMIN in MDIO implementationsBen Hutchings
dev_ioctl() already checks capable(CAP_NET_ADMIN) before calling the driver's implementation of MDIO ioctls. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13net: use symbolic values for ndo_start_xmit() return codesPatrick McHardy
Convert magic values 1 and -1 to NETDEV_TX_BUSY and NETDEV_TX_LOCKED respectively. 0 (NETDEV_TX_OK) is not changed to keep the noise down, except in very few cases where its in direct proximity to one of the other values. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-07tlan: update to net_device_opsStephen Hemminger
2008-12-16tlan: Remove broken support for big buffersSakari Ailus
The big rx/tx buffer support is broken and unlikely to be very useful as such. Remove it. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-16Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/enc28j60.c
2008-12-16tlan: Fix pci memory unmappingSakari Ailus
Fix pci unmapping problem introduced by commit id 8953f1282793882a5444924f7a273dc72a43d0a3 "tlan: Fix small (< 64 bytes) datagram transmissions". Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-16tlan: Fix small (< 64 bytes) datagram transmissionsSakari Ailus
The TLAN chip does not support tranmissions smaller than 64 bytes. Smaller transfers need to be padded up to that size. This was broken by commit id 41873e9aff0632d80c74380d58a89e8d420151bd ("tlan: get rid of padding buffer"). <URL:http://bugzilla.kernel.org/show_bug.cgi?id=11754> Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-13net: Rationalise email address: Network Specific PartsAlan Cox
Clean up the various different email addresses of mine listed in the code to a single current and valid address. As Dave says his network merges for 2.6.28 are now done this seems a good point to send them in where they won't risk disrupting real changes. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-14tlan: Fix two regressions introduced by 64bit conversion.Robert Fitzsimons
Two regressions were introduced by the recent tlan: 64bit conversion commit (93e16847c9db0093065c98063cfc639cdfccf19a). The first in TLan_GetSKB caused a NULL pointer dereference. With the second causing the link to fail to come up. Signed-off-by: Robert Fitzsimons <robfitz@273k.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-30tlan: wrap source linesStephen Hemminger
Make driver more readable on standard 80 col windows. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-30tlan: proper shared IRQ supportStephen Hemminger
Handle shared IRQ correctly. If IRQ is shared, it typically will show up as an IRQ with an empty status field. So check in driver and handle it without crapping out with invalid interrupt message. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-30tlan: manage rx allocation failure betterStephen Hemminger
Rx allocation failure at runtime is non-fatal. For normal Rx frame, it just reuses the buffer, and during setup it just continues with a smaller receive buffer pool. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-30tlan: 64bit conversionStephen Hemminger
Make this driver compile cleanly on 64 bit platforms. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-30tlan: use netdevice statsStephen Hemminger
Use new netdevice common stats area. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-30tlan: get rid of padding bufferStephen Hemminger
Use skb_padto to pad frames, this avoid allocation of separate buffer just for dma of the extra bytes. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-02-23tlan: add static to function definitionsHarvey Harrison
The forward declarations were already marked static, make the definitions be static as well. Fixes the sparse warnings as well. drivers/net/tlan.c:1403:5: warning: symbol 'TLan_HandleInvalid' was not declared. Should it be static? drivers/net/tlan.c:1435:5: warning: symbol 'TLan_HandleTxEOF' was not declared. Should it be static? drivers/net/tlan.c:1521:5: warning: symbol 'TLan_HandleStatOverflow' was not declared. Should it be static? drivers/net/tlan.c:1557:5: warning: symbol 'TLan_HandleRxEOF' was not declared. Should it be static? drivers/net/tlan.c:1692:5: warning: symbol 'TLan_HandleDummy' was not declared. Should it be static? drivers/net/tlan.c:1722:5: warning: symbol 'TLan_HandleTxEOC' was not declared. Should it be static? drivers/net/tlan.c:1770:5: warning: symbol 'TLan_HandleStatusCheck' was not declared. Should it be static? drivers/net/tlan.c:1845:5: warning: symbol 'TLan_HandleRxEOC' was not declared. Should it be static? drivers/net/tlan.c:1905:6: warning: symbol 'TLan_Timer' was not declared. Should it be static? drivers/net/tlan.c:1986:6: warning: symbol 'TLan_ResetLists' was not declared. Should it be static? drivers/net/tlan.c:2046:6: warning: symbol 'TLan_FreeLists' was not declared. Should it be static? drivers/net/tlan.c:2095:6: warning: symbol 'TLan_PrintDio' was not declared. Should it be static? drivers/net/tlan.c:2130:6: warning: symbol 'TLan_PrintList' was not declared. Should it be static? drivers/net/tlan.c:2166:6: warning: symbol 'TLan_ReadAndClearStats' was not declared. Should it be static? drivers/net/tlan.c:2242:1: warning: symbol 'TLan_ResetAdapter' was not declared. Should it be static? drivers/net/tlan.c:2328:1: warning: symbol 'TLan_FinishReset' was not declared. Should it be static? drivers/net/tlan.c:2451:6: warning: symbol 'TLan_SetMac' was not declared. Should it be static? drivers/net/tlan.c:2493:6: warning: symbol 'TLan_PhyPrint' was not declared. Should it be static? drivers/net/tlan.c:2542:6: warning: symbol 'TLan_PhyDetect' was not declared. Should it be static? drivers/net/tlan.c:2589:6: warning: symbol 'TLan_PhyPowerDown' was not declared. Should it be static? drivers/net/tlan.c:2614:6: warning: symbol 'TLan_PhyPowerUp' was not declared. Should it be static? drivers/net/tlan.c:2635:6: warning: symbol 'TLan_PhyReset' was not declared. Should it be static? drivers/net/tlan.c:2663:6: warning: symbol 'TLan_PhyStartLink' was not declared. Should it be static? drivers/net/tlan.c:2750:6: warning: symbol 'TLan_PhyFinishAutoNeg' was not declared. Should it be static? drivers/net/tlan.c:2906:5: warning: symbol 'TLan_MiiReadReg' was not declared. Should it be static? drivers/net/tlan.c:2996:6: warning: symbol 'TLan_MiiSendData' was not declared. Should it be static? drivers/net/tlan.c:3038:6: warning: symbol 'TLan_MiiSync' was not declared. Should it be static? drivers/net/tlan.c:3077:6: warning: symbol 'TLan_MiiWriteReg' was not declared. Should it be static? drivers/net/tlan.c:3147:6: warning: symbol 'TLan_EeSendStart' was not declared. Should it be static? drivers/net/tlan.c:3187:5: warning: symbol 'TLan_EeSendByte' was not declared. Should it be static? drivers/net/tlan.c:3248:6: warning: symbol 'TLan_EeReceiveByte' was not declared. Should it be static? drivers/net/tlan.c:3306:5: warning: symbol 'TLan_EeReadByte' was not declared. Should it be static? Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-05drivers/net/tlan.c: compilation warning fixLeonardo Potenza
Add a check for the pci_register_driver() return value. Removed unused variable pad_allocated. The aim of this patch is to remove the following warning messages: drivers/net/tlan.c: In function 'tlan_probe': drivers/net/tlan.c:486: warning: ignoring return value of 'pci_register_driver', declared with attribute warn_unused_result Signed-off-by: Leonardo Potenza <lpotenza@inwind.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24[PATCH] drivers/net/tlan.c: #ifdef CONFIG_PCI the PCI specific codeAdrian Bunk
drivers/net/tlan.c compiles with CONFIG_PCI=n only with a warning and due to the dead code elimination of gcc. Additionally, this fixes the only compile error I found with CONFIG_PCI=n and the gcc -Werror-implicit-function-declaration flag on i386. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-01-03s/retreiv/retriev/gMatt Mackall
As everyone knows, the rule is: "i before e.. um.. always." Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-06-26drivers/net/: Use the DMA_{64,32}BIT_MASK constantsDomen Puncer
Use the DMA_{64,32}BIT_MASK constants from dma-mapping.h when calling pci_set_dma_mask() or pci_set_consistent_dma_mask() This patch includes dma-mapping.h explicitly because it caused errors on some architectures otherwise. See http://marc.theaimsgroup.com/?t=108001993000001&r=1&w=2 for details Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Domen Puncer <domen@coderock.org>
