path: root/drivers/net/tokenring/Kconfig
2008-12-27net: Allow dependancies of FDDI & Tokenring to be modular.Dave Jones
I noticed it isn't possible to build token ring & fddi drivers without causing LLC, and a bunch of other things to be forced built-in. For distro kernels, this means carrying a chunk of code in the vmlinuz, even if the user doesn't use those protocols. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-24[TR]: Use menuconfig objects.Jan Engelhardt
Use menuconfigs instead of menus, so the whole menu can be disabled at once instead of going through all options. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-31[PATCH] uml: kconfigsAl Viro
kconfig sanitized around drivers/net Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-24Merge upstream into 'upstream' branch of netdev-2.6.git.Jeff Garzik
Hand fix merge conflict in drivers/net/tokenring/Kconfig.
2005-08-23[PATCH] Kconfig fix (tms380tr and ISA_DMA_API)Al Viro
ISA parts of tms380tr are using ISA DMA helpers and should depend on ISA_DMA_API. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-19[netdrvr] Convert madgemc to new MCA API.Jochen Friedrich
Now that all tms380 devices have a valid struct device with dma_mask, remove dmalimit from tmsdev_init(). Kconfig: depend tms380tr and madgemc on MCA. abyss.c, proteon.c, skisa.c, tmspci.c, tms380tr.h: remove dmalimit parameter from tmsdev_init(). tms380tr.c: use device->dma_mask instead of dmalimit. madgemc.c: move to new MCA API using struct device. Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
