path: root/drivers/net/tokenring
2008-10-13net: Rationalise email address: Network Specific PartsAlan Cox
Clean up the various different email addresses of mine listed in the code to a single current and valid address. As Dave says his network merges for 2.6.28 are now done this seems a good point to send them in where they won't risk disrupting real changes. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-23removed unused #include <linux/version.h>'sAdrian Bunk
This patch lets the files using linux/version.h match the files that #include it. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-01Remove newline from the description of module parametersNiels de Vos
Some module parameters with only one line have the '\n' at the end of the description. This is not needed nor wanted as after the description the type (i.e. int) is followed by a newline. Some modules contain a multi-line description, these are not affected by this patch. Signed-off-by: Niels de Vos <niels.devos@wincor-nixdorf.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: John W. Linville <linville@tuxdriver.com> Cc: Ed L. Cashin <ecashin@coraid.com> Cc: Dave Airlie <airlied@linux.ie> Cc: Roland Dreier <rolandd@cisco.com> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/powerpc/booting-without-of.txt drivers/atm/Makefile drivers/net/fs_enet/fs_enet-main.c drivers/pci/pci-acpi.c net/8021q/vlan.c net/iucv/iucv.c
2008-07-10smctr: use request_firmware()David Woodhouse
2008-05-25Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/cpmac.c net/mac80211/mlme.c
2008-05-22drivers/net/tokenring/olympic.c: fix warningAndrew Morton
When dev_name() is changed to return `const char *': drivers/net/tokenring/olympic.c: In function 'olympic_probe': drivers/net/tokenring/olympic.c:234: warning: assignment discards qualifiers from pointer target type Cc: Jeff Garzik <jeff@garzik.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-22drivers/net/tokenring/3c359.c: squish a warningAndrew Morton
When dev_name() is changed to return `const char *': drivers/net/tokenring/3c359.c: In function 'xl_probe': drivers/net/tokenring/3c359.c:318: warning: assignment discards qualifiers from pointer target type Cc: Jeff Garzik <jeff@garzik.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-133c359: use netstats in net_device structurePaulius Zaleckas
Use net_device_stats from net_device structure instead of local. Kill xl_get_stats function, because by default it is used identical internal_stats function from net/core/dev.c Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-14Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ehea/ehea_main.c drivers/net/wireless/iwlwifi/Kconfig drivers/net/wireless/rt2x00/rt61pci.c net/ipv4/inet_timewait_sock.c net/ipv6/raw.c net/mac80211/ieee80211_sta.c
2008-04-08[NET]: Undo code bloat in hot paths due to print_mac().David S. Miller
If print_mac() is used inside of a pr_debug() the compiler can't see that the call is redundant so still performs it even of pr_debug() ends up being a nop. So don't use print_mac() in such cases in hot code paths, use MAC_FMT et al. instead. As noted by Joe Perches, pr_debug() could be modified to handle this better, but that is a change to an interface used by the entire kernel and thus needs to be validated carefully. This here is thus the less risky fix for 2.6.25 Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-04net/tokenring/olympic.c section fixesAdrian Bunk
My previous section fix only turned one section problem into another section problem. This patch fixes it for real. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-28drivers/net/tokenring/3c359.c: use time_* macrosS.Caglar Onur
The functions time_before, time_before_eq, time_after, and time_after_eq are more robust for comparing jiffies against other values. So use the time_after() macro, defined in linux/jiffies.h, which deals with wrapping correctly. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: S.Caglar Onur <caglar@pardus.org.tr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-25smctr.c: fix logical-bitwise-or confusionJay Schulist
This patch to drivers/net/tokenring/smctr.c fixes a "bitwise vs logical" or error. Signed-off-by: Jay Schulist <jjschlst@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (79 commits) Jesper Juhl is the new trivial patches maintainer Documentation: mention email-clients.txt in SubmittingPatches fs/binfmt_elf.c: spello fix do_invalidatepage() comment typo fix Documentation/filesystems/porting fixes typo fixes in net/core/net_namespace.c typo fix in net/rfkill/rfkill.c typo fixes in net/sctp/sm_statefuns.c lib/: Spelling fixes kernel/: Spelling fixes include/scsi/: Spelling fixes include/linux/: Spelling fixes include/asm-m68knommu/: Spelling fixes include/asm-frv/: Spelling fixes fs/: Spelling fixes drivers/watchdog/: Spelling fixes drivers/video/: Spelling fixes drivers/ssb/: Spelling fixes drivers/serial/: Spelling fixes drivers/scsi/: Spelling fixes ...
2008-02-03MAINTAINERS: remove Adam Fritzler, remove his email address in other sourcesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-03olympic_open() must be __devinitAdrian Bunk
This patch fixes the following section mismatch: <-- snip --> ... WARNING: drivers/net/built-in.o(.text+0x155573): Section mismatch in reference from the function olympic_open() to the function .devinit.text:olympic_init() ... <-- snip --> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28NULL noise in drivers/netAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28endianness annotations and fixes for olympicAl Viro
* missing braces in !readl(...) & ... * trivial endianness annotations * in olympic_arb_cmd() the loop collecting fragments of packet is b0rken on big-endian - we have (next_ptr && (buf_ptr=olympic_priv->olympic_lap + ntohs(next_ptr))) as condition and it should have swab16(), not ntohs() - it's host-endian byteswapped, not big-endian. So if we get more than one fragment on big-endian host, we get screwed. This ntohs() got missed back when the rest of those had been switched to swab16() in 2.4.0-test2-pre1 - at a guess, nobody had hit fragmented packets during the testing of PPC fixes. PS: Ken Aaker cc'd on assumption that he is the same guy who'd done the original set of PPC fixes in olympic Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-223c359 endianness annotations and fixesAl Viro
Same story as with olympic - htons(readw()) when swab16(readw()) is needed, missing conversions to le32 when dealing with shared descriptors, etc. Olympic got those fixes in 2.4.0-test2, 3c359 didn't. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-16tokenring/3c359.c: fixed array index problemMarcus Meissner
The xl_laa array is just 6 bytes long, so we should substract 10 from the index, like is also done some lines above already. Signed-Off-By: Marcus Meissner <meissner@suse.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10Avoid possible NULL pointer deref in 3c359 driverJesper Juhl
In xl_freemem(), if dev_if is NULL, the line struct xl_private *xl_priv =(struct xl_private *)dev->priv; will cause a NULL pointer dereference. (akpm: don't try to fix it: just delete the pointless test-for-null) Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10tms380tr: trivial endianness annotationsAl Viro
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10drivers/net/tokenring: Convert to generic booleanRichard Knutsson
Convert to generic boolean Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10drivers/net/tokenring/3c359.cSurya Prabhakar N
Hi, Replacing kmalloc with kzalloc and cleaning up memset in drivers/net/tokenring/3c359.c Signed-off-by: Surya Prabhakar <surya.prabhakar@wipro.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10dev->priv to netdev_priv(dev), drivers/net/tokenring/Yoann Padioleau
Replacing accesses to dev->priv to netdev_priv(dev). The replacment is safe when netdev_priv is used to access a private structure that is right next to the net_device structure in memory. Cf http://groups.google.com/group/comp.os.linux.development.system/browse_thread/thread/de19321bcd94dbb8/0d74a4adcd6177bd This is the case when the net_device structure was allocated with a call to alloc_netdev or one of its derivative. Here is an excerpt of the semantic patch that performs the transformation @ rule1 @ type T; struct net_device *dev; @@ dev = ( alloc_netdev | alloc_etherdev | alloc_trdev ) (sizeof(T), ...) @ rule1bis @ struct net_device *dev; expression E; @@ dev->priv = E @ rule2 depends on rule1 && !rule1bis @ struct net_device *dev; type rule1.T; @@ - (T*) dev->priv + netdev_priv(dev) PS: I have performed the same transformation on the whole kernel and it affects around 70 files, most of them in drivers/net/. Should I split my patch for each subnet directories ? (wireless/, wan/, etc) Thanks to Thomas Surrel for helping me refining my semantic patch. Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> 3c359.c | 58 +++++++++++++++++++++++++++++----------------------------- ibmtr.c | 38 +++++++++++++++++++------------------- lanstreamer.c | 32 ++++++++++++++++---------------- madgemc.c | 4 ++-- olympic.c | 36 ++++++++++++++++++------------------ tmspci.c | 4 ++-- 6 files changed, 86 insertions(+), 86 deletions(-) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-17drivers/*: mark variables with uninitialized_var()Jeff Garzik
Mark variables in drivers/* with uninitialized_var() if such a warning appears, and analysis proves that the var is initialized properly on all paths it is used. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-10tokenring/3c359.c:xl_init() must be __devinitAdrian Bunk
This patch fixes the following section mismatch: <-- snip --> ... MODPOST vmlinux WARNING: drivers/built-in.o(.text+0x361ef1): Section mismatch: reference to .init.text:xl_init (between 'xl_probe' and 'xl_hw_reset') ... <-- snip --> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-24[TR]: Use menuconfig objects.Jan Engelhardt
Use menuconfigs instead of menus, so the whole menu can be disabled at once instead of going through all options. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-02PCI: Cleanup the includes of <linux/pci.h>Jean Delvare
I noticed that many source files include <linux/pci.h> while they do not appear to need it. Here is an attempt to clean it all up. In order to find all possibly affected files, I searched for all files including <linux/pci.h> but without any other occurence of "pci" or "PCI". I removed the include statement from all of these, then I compiled an allmodconfig kernel on both i386 and x86_64 and fixed the false positives manually. My tests covered 66% of the affected files, so there could be false positives remaining. Untested files are: arch/alpha/kernel/err_common.c arch/alpha/kernel/err_ev6.c arch/alpha/kernel/err_ev7.c arch/ia64/sn/kernel/huberror.c arch/ia64/sn/kernel/xpnet.c arch/m68knommu/kernel/dma.c arch/mips/lib/iomap.c arch/powerpc/platforms/pseries/ras.c arch/ppc/8260_io/enet.c arch/ppc/8260_io/fcc_enet.c arch/ppc/8xx_io/enet.c arch/ppc/syslib/ppc4xx_sgdma.c arch/sh64/mach-cayman/iomap.c arch/xtensa/kernel/xtensa_ksyms.c arch/xtensa/platform-iss/setup.c drivers/i2c/busses/i2c-at91.c drivers/i2c/busses/i2c-mpc.c drivers/media/video/saa711x.c drivers/misc/hdpuftrs/hdpu_cpustate.c drivers/misc/hdpuftrs/hdpu_nexus.c drivers/net/au1000_eth.c drivers/net/fec_8xx/fec_main.c drivers/net/fec_8xx/fec_mii.c drivers/net/fs_enet/fs_enet-main.c drivers/net/fs_enet/mac-fcc.c drivers/net/fs_enet/mac-fec.c drivers/net/fs_enet/mac-scc.c drivers/net/fs_enet/mii-bitbang.c drivers/net/fs_enet/mii-fec.c drivers/net/ibm_emac/ibm_emac_core.c drivers/net/lasi_82596.c drivers/parisc/hppb.c drivers/sbus/sbus.c drivers/video/g364fb.c drivers/video/platinumfb.c drivers/video/stifb.c drivers/video/valkyriefb.c include/asm-arm/arch-ixp4xx/dma.h sound/oss/au1550_ac97.c I would welcome test reports for these files. I am fine with removing the untested files from the patch if the general opinion is that these changes aren't safe. The tested part would still be nice to have. Note that this patch depends on another header fixup patch I submitted to LKML yesterday: [PATCH] scatterlist.h needs types.h http://lkml.org/lkml/2007/3/01/141 Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-25[SK_BUFF]: Introduce skb_copy_to_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying to linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[TR]: Make tr_type_trans set skb->devArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TR]: Use tr_hdr() were appropriateArnaldo Carvalho de Melo
2007-03-14[PATCH] ibmtr probe is __devinit, not __initAl Viro
used by ->attach() in pcmcia analog Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-09ibmtr: Drain rich supply of modpost warnings.Ralf Baechle
Building ibmtr as a module produces a spectacular pile of modpost warnings: WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.text:ibmtr_probe1 from .text between 'ibmtr_probe_card' (at offset 0x450) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.text:ibmtr_probe1 from .text between 'ibmtr_probe_card' (at offset 0x454) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.text:ibmtr_probe1 from .text between 'ibmtr_probe_card' (at offset 0x458) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.text:ibmtr_probe1 from .text between 'ibmtr_probe_card' (at offset 0x45c) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.data:ibmtr_portlist from .text between 'ibmtr_probe_card' (at offset 0x4e8) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.data:ibmtr_portlist from .text between 'ibmtr_probe_card' (at offset 0x4ec) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.data:ibmtr_portlist from .text between 'ibmtr_probe_card' (at offset 0x4f0) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.data:ibmtr_portlist from .text between 'ibmtr_probe_card' (at offset 0x4f4) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.text:find_turbo_adapters from .text between 'ibmtr_probe_card' (at offset 0x500) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.text:find_turbo_adapters from .text between 'ibmtr_probe_card' (at offset 0x504) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.text:find_turbo_adapters from .text between 'ibmtr_probe_card' (at offset 0x508) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.text:find_turbo_adapters from .text between 'ibmtr_probe_card' (at offset 0x50c) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.data:ibmtr_portlist from .text between 'ibmtr_probe_card' (at offset 0x520) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.data:ibmtr_portlist from .text between 'ibmtr_probe_card' (at offset 0x524) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.data:ibmtr_portlist from .text between 'ibmtr_probe_card' (at offset 0x528) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.data:ibmtr_portlist from .text between 'ibmtr_probe_card' (at offset 0x534) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.data: from .text between 'ibmtr_probe_card' (at offset 0x540) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.data: from .text between 'ibmtr_probe_card' (at offset 0x544) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.data: from .text between 'ibmtr_probe_card' (at offset 0x548) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.data: from .text between 'ibmtr_probe_card' (at offset 0x54c) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.text:ibmtr_probe1 from .text between 'ibmtr_probe_card' (at offset 0x558) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.text:ibmtr_probe1 from .text between 'ibmtr_probe_card' (at offset 0x55c) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.text:ibmtr_probe1 from .text between 'ibmtr_probe_card' (at offset 0x560) and 'ibmtr_reset_timer' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.text:ibmtr_probe1 from .text between 'ibmtr_probe_card' (at offset 0x564) and 'ibmtr_reset_timer' Fix by making ibmtr_probe an __init function. While at it, move move ibmtr_probe_card below ibmtr_probe so the protoype for ibmtr_probe can be deleted. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> drivers/net/tokenring/ibmtr.c | 25 ++++++++++++------------- 1 file changed, 12 insertions(+), 13 deletions(-) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-07Merge branch 'master' into upstreamJeff Garzik
Conflicts: drivers/net/netxen/netxen_nic.h drivers/net/netxen/netxen_nic_main.c
2006-12-04[PATCH] remote memory corruptor in ibmtr.cAl Viro
ip_summed changes last summer had missed that one. As the result, we have ip_summed interpreted as CHECKSUM_PARTIAL now. IOW, ->csum is interpreted as offset of checksum in the packet. net/core/* will both read and modify the value as that offset, with obvious reasons. At the very least it's a remote memory corruptor. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[PATCH] trivial missing __init in drivers/net/*Al Viro
2006-12-02[PATCH] pci_module_init() convertion in olympic.cHenrik Kretzschmar
pci_module_init() convertion in olympic.c Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-10-31[PATCH] tokenring: fix module_init error handlingAkinobu Mita
- Call platform_driver_unregister() before return when no cards found. (fixes data corruption when no cards found) - Check platform_device_register_simple() return value Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Mike Phillips <mikep@linuxtr.net> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> drivers/net/tokenring/proteon.c | 9 +++++++-- drivers/net/tokenring/skisa.c | 9 +++++++-- 2 files changed, 14 insertions(+), 4 deletions(-) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-10-06drivers/net: eliminate irq handler impossible checks, needless castsJeff Garzik
- Eliminate check for irq handler 'dev_id==NULL' where the condition never occurs. - Eliminate needless casts to/from void* Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-03BUG_ON cleanup in drivers/net/tokenring/Eric Sesterhenn
This patch converts one if() BUG(); to BUG_ON(); so it can be safely optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-25[PATCH] drivers/net/tokenring/lanstreamer.h Removal of old codeMichal Piotrowski
Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-25[PATCH] drivers/net/tokenring/lanstreamer.c Removal of old codeMichal Piotrowski
2006-08-19drivers/net: Remove deprecated use of pci_module_init()Jeff Garzik
From: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
