path: root/drivers/net/tulip/uli526x.c
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bonding/bond_main.c drivers/net/via-velocity.c drivers/net/wireless/iwlwifi/iwl-agn.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-28tulip: Add missing parens.David S. Miller
As reported by Stephen Rothwell. drivers/net/tulip/uli526x.c: In function 'uli526x_rx_packet': drivers/net/tulip/uli526x.c:861: warning: assignment makes pointer from integer without a cast Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-26tulip: Fix null dereference in uli526x_rx_packet()Kyle McMartin
Acked-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-18tulip: convert to use netdev_for_each_mc_addrJiri Pirko
also bug in de2104x.c was corrected: for (i = 0; i < 32; i++) loop should be outside mc_list iteration. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-31tulip/uli526x.c: Use dev_<level> and pr_<level>Joe Perches
Convert printks to dev_<level> where a dev is available Convert printks to pr_<level> where not Coalesce format strings Change print formats with %d.dx to %0dx Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt Remove DRV_NAME from logging messages Add do {} while(0) to ULI526X_DBUG macro Make SHOW_MEDIA_TYPE macro more readable Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18drivers/net: request_irq - Remove unnecessary leading & from second argJoe Perches
Not as fancy as coccinelle. Checkpatch errors ignored. Compile tested allyesconfig x86, not all files compiled. grep -rPl --include=*.[ch] "\brequest_irq\s*\([^,\)]+,\s*\&" drivers/net | while read file ; do \ perl -i -e 'local $/; while (<>) { s@(\brequest_irq\s*\([^,\)]+,\s*)\&@\1@g ; print ; }' $file ;\ done Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01tulip: convert drivers to netdev_tx_tStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13net: use symbolic values for ndo_start_xmit() return codesPatrick McHardy
Convert magic values 1 and -1 to NETDEV_TX_BUSY and NETDEV_TX_LOCKED respectively. 0 (NETDEV_TX_OK) is not changed to keep the noise down, except in very few cases where its in direct proximity to one of the other values. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-26tulip: get rid of warning for non-const string literalStephen Hemminger
2009-01-07uli526x: convert devices to new APIStephen Hemminger
Convert to net_device_ops and internal net_device_stats Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12netdevice: safe convert to netdev_priv() #part-3Wang Chen
We have some reasons to kill netdev->priv: 1. netdev->priv is equal to netdev_priv(). 2. netdev_priv() wraps the calculation of netdev->priv's offset, obviously netdev_priv() is more flexible than netdev->priv. But we cann't kill netdev->priv, because so many drivers reference to it directly. This patch is a safe convert for netdev->priv to netdev_priv(netdev). Since all of the netdev->priv is only for read. But it is too big to be sent in one mail. I split it to 4 parts and make every part smaller than 100,000 bytes, which is max size allowed by vger. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-22uli526x: add support for netpollAnton Vorontsov
This patch adds netpoll support for the uli526x ethernet driver -- simply call the interrupt handler for polling. To do this without disable_irq()/enable_irq() pair we should fully protect the handler. Luckily, it's already using irqsave spinlock, the only unprotected place is interrupts re-enabling write. It was safe to re-enable interrupts without holding the spinlock, but with netpoll possibility now it doesn't seem so. Patch was tested using netconsole and KGDBoE. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-06uli526x: fix endianness issues in the setup frameAnton Vorontsov
This patch fixes uli526x driver's issues on a PowerPC boards: uli chip is unable to receive the packets. It appears that send_frame_filter prepares the setup frame in the endianness unsafe manner. On a big endian machines we should shift the address nibble by two bytes. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-06uli526x: initialize the hardware prior to requesting interruptsAnton Vorontsov
The firmware on MPC8610HPCD boards enables ULI ethernet and leaves it in some funky state before booting Linux. For drivers, it's always good idea to (re)initialize the hardware prior to requesting interrupts. This patch fixes the following oops: Oops: Kernel access of bad area, sig: 11 [#1] MPC86xx HPCD NIP: c0172820 LR: c017287c CTR: 00000000 [...] NIP [c0172820] allocate_rx_buffer+0x2c/0xb0 LR [c017287c] allocate_rx_buffer+0x88/0xb0 Call Trace: [df82bdc0] [c017287c] allocate_rx_buffer+0x88/0xb0 (unreliable) [df82bde0] [c0173000] uli526x_interrupt+0xe4/0x49c [df82be20] [c0045418] request_irq+0xf0/0x114 [df82be50] [c01737b0] uli526x_open+0x48/0x160 [df82be70] [c0201184] dev_open+0xb0/0xe8 [df82be80] [c0200104] dev_change_flags+0x90/0x1bc [df82bea0] [c035fab0] ip_auto_config+0x214/0xef4 [df82bf60] [c03421c8] kernel_init+0xc4/0x2ac [df82bff0] [c0010834] kernel_thread+0x44/0x60 Instruction dump: 4e800020 9421ffe0 7c0802a6 bfa10014 7c7e1b78 90010024 80030060 83e30054 2b80002f 419d0078 3fa0c039 48000058 <907f0010> 80630088 2f830000 419e0014 Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-02-23uli526x partially recognizing interfaceGrant Grundler
Patch fixes: http://bugzilla.kernel.org/show_bug.cgi?id=5839 Init sequence needs to poll phy until phy reset is complete. This is the same problem that I fixed in 2002 in tulip driver. Thanks to manty@manty.net for testing this patch. Thanks to Pozsar Balazs <pozsy@uhulinux.hu> for posting/testing a similar patch before: http://lkml.org/lkml/2006/8/21/45 Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-19remove asm/bitops.h includesJiri Slaby
remove asm/bitops.h includes including asm/bitops directly may cause compile errors. don't include it and include linux/bitops instead. next patch will deny including asm header directly. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10Fix a potential NULL pointer dereference in uli526x_interrupt() in ↵Micah Gruber
drivers/net/tulip/uli526x.c This patch fixes an apparent potential null dereference bug where we dereference dev before a null check. This patch simply remvoes the can't-happen test for a null pointer. Signed-off-by: Micah Gruber <micah.gruber@gmail.com> Cc: Grant Grundler <grundler@parisc-linux.org> Acked-by: Jeff Garzik <jeff@garzik.org> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10Clean up redundant PHY write line for ULi526x Ethernet driverRoy Zang
Clean up redundant PHY write line for ULi526x Ethernet Driver. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10tulip: endianness annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10uli526x: Add suspend and resume routines (updated)Rafael J. Wysocki
Add suspend/resume support to the uli526x network driver (tested on x86_64, with 'Ethernet controller: ALi Corporation M5263 Ethernet Controller, rev 40'). This patch is based on the suspend/resume code in the tg3 driver. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
2006-07-29[PATCH] initialisation cleanup for ULI526x-net-driverHenrik Kretzschmar
removes the unneeded local variable rc replace pci_module_init() with pci_register_driver() two coding style issues on switch Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-26[netdrvr] trim trailing whitespace: 8139*.c, epic100, forcedeth, tulip/*Jeff Garzik
2006-02-07[PATCH] uli526x warning fixAndrew Morton
drivers/net/tulip/uli526x.c: In function `__check_mode': drivers/net/tulip/uli526x.c:1693: warning: return from incompatible pointer type Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2006-01-12[PATCH] replace MODULE_PARM in tulip/uli526x.cEric Sesterhenn / snakebyte
Replace the MODULE_PARM usage in uli526x.c with module_param. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-05[PATCH] (4/7) missing include (uli526x)viro@ftp.linux.org.uk
added missing include of dma-mapping.h, removed bogus ptrace.h (what the hell was it doing there, in the first place?) Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-20[netdrvr uli526x] fix problems found in reviewPeer Chen
- s/DEVICE/net_device/ - improve formatting - remove dead code - check return value, in several areas
2005-07-29[netdrvr] add 'uli526x' driver (a tulip clone)Peer Chen
We want to extract our LAN card driver from tulip core driver and make a new file uli526x.c at tulip folder, because we have added some ethtool interface support and non-eprom support in our driver and may be other change in the futher. If our controllers support are still contained in the tulip core driver, I think it'll increase the complexity of maintenance, you know, tulip core driver include several files and support so many other controllers. Furthermore, I tested the newest kernel 2.6.12 and I found the tulip driver can not work on our lan controller, and I no time to debug it, so I aspired want to make a single uli526x.c file just for our controllers. Could you help us remove the ULi m5261/m5263 lan controller support from tulip core driver and add the new single uli526x.c file for us? Signed-off-by: Peer Chen <Peer.Chen@uli.com.tw> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
