path: root/drivers/net/tulip
2008-10-27dmfe: check pci_alloc_consistent errorsFUJITA Tomonori
We need to check the address that pci_alloc_consistent() returns since it might fail. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-13net: Rationalise email address: Network Specific PartsAlan Cox
Clean up the various different email addresses of mine listed in the code to a single current and valid address. As Dave says his network merges for 2.6.28 are now done this seems a good point to send them in where they won't risk disrupting real changes. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-13de2104x: wrong MAC address fixMartin Langer
The de2104x returns sometimes a wrong MAC address. The wrong one is like the original one, but it comes with an one byte shift. I found this bug on an older alpha ev5 cpu. More details are available in Gentoo bugreport #240718. It seems the hardware is sometimes a little bit too slow for an immediate access. This patch solves the problem by introducing a small udelay. Signed-off-by: Martin Langer <martin-langer@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-24tulip: Fix dead 21041 ethernet after ifconfig downThomas Bogendoerfer
The de2104x did a pci_disable_device() in it's close function, but the open function never does a pci_enable_device() and assumes that the device is already enabled. Considering that downing the interface is just a temporary thing the pci_disable_device() isn't a pretty good idea and removing it from the close function just fixes the bug. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Acked-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-23de4x5: Use skb_queue_head instead of by-hand implementation.David S. Miller
2008-07-22de4x5: Remove developer debug feature about set/clear promiscWang Chen
IFF_PROMISC flag shouldn't be set or cleared by drivers, because whether device be promisc mode is decided by how many upper layer callers being referenced to it. And the promisc changing feature of de4x5 ioctl is developer debug feature, we can remove it now. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Acked-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-28tulip: remove wrapper around get_unalignedHarvey Harrison
DE_UNALIGNED_16 is always being passed a u16 *, no need to have the wrapper with two casts in it, just call get_unaligned directly. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-24drivers/net/tulip: update first comment in tulip filesGrant Grundler
Three basic changes to the comments at the top of each file: 1) remove stale "Maintained by" line...I prefer people look in MAINTAINERS. 2) Drop reference to stale sf.net/tulip website (I didn't see anything of value there) 3) Point people at bugzilla.kernel.org to submit bugs...will always get tracked regardless of who the maintainer is. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Acked-by-stale-maintainer: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-12net: Eliminate flush_scheduled_work() calls while RTNL is held.David S. Miller
If the RTNL is held when we invoke flush_scheduled_work() we could deadlock. One such case is linkwatch, it is a work struct which tries to grab the RTNL semaphore. The most common case are net driver ->stop() methods. The simplest conversion is to instead use cancel_{delayed_}work_sync() explicitly on the various work struct the driver uses. This is an OK transformation because these work structs are doing things like resetting the chip, restarting link negotiation, and so forth. And if we're bringing down the device, we're about to turn the chip off and reset it anways. So if we cancel a pending work event, that's fine here. Some drivers were working around this deadlock by using a msleep() polling loop of some sort, and those cases are converted to instead use cancel_{delayed_}work_sync() as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-30[netdrvr] tulip: oops in tulip_interrupt when hibernating with swsusp/suspend2Grant Grundler
The following patch is seems to fix the tulip suspend/resume panic: http://bugzilla.kernel.org/show_bug.cgi?id=8952#c46 My attempts at a cleaner patch failed and Pavel thinks this is OK. Original from: kernelbugs@tap.homeip.net Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-22uli526x: add support for netpollAnton Vorontsov
This patch adds netpoll support for the uli526x ethernet driver -- simply call the interrupt handler for polling. To do this without disable_irq()/enable_irq() pair we should fully protect the handler. Luckily, it's already using irqsave spinlock, the only unprotected place is interrupts re-enabling write. It was safe to re-enable interrupts without holding the spinlock, but with netpoll possibility now it doesn't seem so. Patch was tested using netconsole and KGDBoE. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-06uli526x: fix endianness issues in the setup frameAnton Vorontsov
This patch fixes uli526x driver's issues on a PowerPC boards: uli chip is unable to receive the packets. It appears that send_frame_filter prepares the setup frame in the endianness unsafe manner. On a big endian machines we should shift the address nibble by two bytes. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-06uli526x: initialize the hardware prior to requesting interruptsAnton Vorontsov
The firmware on MPC8610HPCD boards enables ULI ethernet and leaves it in some funky state before booting Linux. For drivers, it's always good idea to (re)initialize the hardware prior to requesting interrupts. This patch fixes the following oops: Oops: Kernel access of bad area, sig: 11 [#1] MPC86xx HPCD NIP: c0172820 LR: c017287c CTR: 00000000 [...] NIP [c0172820] allocate_rx_buffer+0x2c/0xb0 LR [c017287c] allocate_rx_buffer+0x88/0xb0 Call Trace: [df82bdc0] [c017287c] allocate_rx_buffer+0x88/0xb0 (unreliable) [df82bde0] [c0173000] uli526x_interrupt+0xe4/0x49c [df82be20] [c0045418] request_irq+0xf0/0x114 [df82be50] [c01737b0] uli526x_open+0x48/0x160 [df82be70] [c0201184] dev_open+0xb0/0xe8 [df82be80] [c0200104] dev_change_flags+0x90/0x1bc [df82bea0] [c035fab0] ip_auto_config+0x214/0xef4 [df82bf60] [c03421c8] kernel_init+0xc4/0x2ac [df82bff0] [c0010834] kernel_thread+0x44/0x60 Instruction dump: 4e800020 9421ffe0 7c0802a6 bfa10014 7c7e1b78 90010024 80030060 83e30054 2b80002f 419d0078 3fa0c039 48000058 <907f0010> 80630088 2f830000 419e0014 Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29net: use get/put_unaligned_* helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Auke Kok <auke-jan.h.kok@intel.com> Cc: John Ronciak <john.ronciak@intel.com> Cc: Jesse Brandeburg <jesse.brandeburg@intel.com> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-16[netdrvr] tulip: Better MWI workaround for 21143 rev 65 chip errataPeter Horton
This patch works around the MWI bug on the DC21143 rev 65 Tulip by ensuring that the receive buffers don't end on a cache line boundary (as documented in the errata). This patch is required for the MIPS based Cobalt Qube/RaQ as supporting the extra PCI commands seems to reduce the chance of a hard lockup between the Tulip and the PCI bridge. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-16[netdrvr] tulip/winbond-840: don't let tulip.h symbol stomp oursJeff Garzik
winbond-840 shares tulip.h with the tulip driver, because they share many (but not all) of the same register definitions. This is useful for the register definitions, but not helpful when it comes to symbols that are shared among the tulip driver's C modules, but not meant to be shared outside that one driver. Thus, PKT_BUF_SZ is a symbol internal to tulip, but it was intruding upon a similar symbol in winbond-840's namespace. This was not a problem as long as the two symbols had the same value, but upcoming patches result in differing symbol values. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-02Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/s2io.c
2008-03-28[netdrvr] tulip_read_eeprom fixes for BUG 4420Grant Grundler
If "location" is > "addr_len" bits, the high bits of location would interfere with the READ_CMD sent to the eeprom controller. A patch was submitted to bug: http://bugzilla.kernel.org/show_bug.cgi?id=4420 which simply truncated the "location", read whatever was in "location modulo addr_len", and returned that value. That avoids confusing the eeprom but seems like the wrong solution to me. Correct would be to not read beyond "1 << addr_len" address of the eeprom. I am submitting two changes to implement this: 1) tulip_read_eeprom will return zero (since we can't return -EINVAL) if this is attempted (defensive programming). 2) In tulip_core.c, fix the tulip_read_eeprom caller so they don't iterate past addr_len bits and make sure the entire tp->eeprom[] array is cleared. I konw we don't strictly need both. I would prefer both in the tree since it documents the issue and provides a second "defense" from the bug from creeping back in. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-22Merge branch 'upstream-net26' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 Conflicts: drivers/s390/net/qeth_main.c
2008-03-172.6.25-rc4 de_stop_rxtx polling wrongGrant Grundler
This untested patch _should_ fix: "(net de2104x) Kernel panic with de2104x tulip driver on boot" http://bugzilla.kernel.org/show_bug.cgi?id=3156 But the bug submitter isn't responding. Same fix has been applied to tulip.c (several years ago) and uli526x.c (Feb 2008) drivers. [ The panic reported in the bug report was removed in a recently (march 2008) accepted patch from Ondrej Zary. ] Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-17remove the obsolete xircom_tulip_cb driverAdrian Bunk
The xircom_tulip_cb driver has been replaced the xircom_cb driver, and since it depended on BROKEN_ON_SMP it e.g. was no longer present in many distribution kernels. This patch therefore removes it. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-05de2104x: remove BUG_ON() when changing media typeOndrej Zary
When the chip dies (probably because of a bug somewhere in the driver), de_stop_rxtx() fails and changing the media type crashes the whole machine. Replace BUG_ON() in de_set_media() with a warning. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-23uli526x partially recognizing interfaceGrant Grundler
Patch fixes: http://bugzilla.kernel.org/show_bug.cgi?id=5839 Init sequence needs to poll phy until phy reset is complete. This is the same problem that I fixed in 2002 in tulip driver. Thanks to manty@manty.net for testing this patch. Thanks to Pozsar Balazs <pozsy@uhulinux.hu> for posting/testing a similar patch before: http://lkml.org/lkml/2006/8/21/45 Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-05xircom_cb should return NETDEV_TX_BUSY when no descriptors availableErik Mouw
Changes in other networking paths uncovered a bug in the xircom_cb driver which made the kernel spew lots of the following error messages: BUG eth1 code -5 qlen 0 It turned out that the driver returned -EIO when there was no descriptor available for sending packets. It should return NETDEV_TX_BUSY instead. This was discussed on the netdev list before, see http://thread.gmane.org/gmane.linux.network/84603 . Signed-off-by: Erik Mouw <mouw@nl.linux.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-28[netdrvr] checkpatch cleanupsJeff Garzik
2008-01-28netdev: ARRAY_SIZE() cleanupsAlejandro Martinez Ruiz
Convert array size calculations to use ARRAY_SIZE(). Signed-off-by: Alejandro Martinez Ruiz <alex@flawedcode.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23[TULIP] DMFE: Fix SROM parsing regression.David S. Miller
Changeset 16b110c3fd760620b4a787db6ed512fe531ab1b5 (dmfe warning fix) bothed up the offsets read from the SROM so that it doesn't read the same datums it used to. The change made transformations like turning: "srom + 34" into "(__le32 *)srom + 34/4" which doesn't work because 4 does not divide evenly into 34 so we're using a different pointer offset than in the original code. I've changed theses cases in dmfe_parse_srom() to consistently use "(type *)(srom + offset)" preserving the offsets from the original code. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-12endianness noise in tulip_coreAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-12de4x5 fixesAl Viro
* (trivial) endianness annotations * don't bother with del_timer() from the inside of timer handler itself * disable_ast() really ought to do del_timer_sync(), not del_timer() * clean the timer handling in general. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-12xircom_cb endianness fixesAl Viro
* descriptors inside the rx and tx rings are l-e * don't cpu_to_le32() the argument of outl() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-08[NET]: Do not check netif_running() and carrier state in ->poll()David S. Miller
Drivers do this to try to break out of the ->poll()'ing loop when the device is being brought administratively down. Now that we have a napi_disable() "pending" state we are going to solve that problem generically. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-08[TULIP]: NAPI full quantum bug.Stephen Hemminger
This should fix the kernel warn/oops reported while routing. The tulip driver has a fencepost bug with new NAPI in 2.6.24 It has an off by one bug if a full quantum is reached. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-23dmfe: checkpatch fix (add whitespace)Jeff Garzik
2007-11-23NET: dmfe: don't access configuration space in D3 stateMaxim Levitsky
Accidently I reversed the order of pci_save_state and pci_set_power_state in .suspend()/.resume() callbacks Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-12[NET]: Remove references to net-modules.txt.Adrian Bunk
When I removed net-modules.txt because it only contained ancient information I missed that many Kconfig entries pointed to this ancient information. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (74 commits) fix do_sys_open() prototype sysfs: trivial: fix sysfs_create_file kerneldoc spelling mistake Documentation: Fix typo in SubmitChecklist. Typo: depricated -> deprecated Add missing profile=kvm option to Documentation/kernel-parameters.txt fix typo about TBI in e1000 comment proc.txt: Add /proc/stat field small documentation fixes Fix compiler warning in smount example program from sharedsubtree.txt docs/sysfs: add missing word to sysfs attribute explanation documentation/ext3: grammar fixes Documentation/java.txt: typo and grammar fixes Documentation/filesystems/vfs.txt: typo fix include/asm-*/system.h: remove unused set_rmb(), set_wmb() macros trivial copy_data_pages() tidy up Fix typo in arch/x86/kernel/tsc_32.c file link fix for Pegasus USB net driver help remove unused return within void return function Typo fixes retrun -> return x86 hpet.h: remove broken links ...
2007-10-19Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (21 commits) Fix build break in tsi108.c qeth: remove header_ops bug ir-functions.c:(.text+0xbce18): undefined reference to `input_event' NAPI: kconfig prompt and deleted doc file phy/bitbang: missing MODULE_LICENSE DM9000 initialization fix [PATCH] rt2x00: Add new rt73usb USB ID [PATCH] rt2x00: Fix residual check in PLCP calculations. [PATCH] iwlwifi: Fix rate setting in probe request for HW sacn [PATCH] b43: Make b43_stop() static [PATCH] drivers/net/wireless/b43/main.c: fix an uninitialized variable [PATCH] iwlwifi: set correct base rate for A band in rs_dbgfs_set_mcs [PATCH] zd1211rw, fix oops when ejecting install media [PATCH] b43legacy: Fix potential return of uninitialized variable [PATCH] iwl4965-base.c: fix off-by-one errors [PATCH] p54: Make filter configuration atomic [PATCH] rtl8187: remove NICMAC setting in configure_filters callback [PATCH] janitorial: fix all double includes in drivers/net/wireless [PATCH] rtl8187: Fix more frag bit checking, rts duration calc [PATCH] ipw2100: send WEXT scan events ...
2007-10-19NAPI: kconfig prompt and deleted doc fileRandy Dunlap
- make the kconfig NAPI option prompt consistent across all net drivers (other than EXPERIMENTAL; can it now be removed also, or is the new napi_struct implementation now EXPERIMENTAL ?) - remove comment about the now-deleted NAPI_HOWTO.txt file - clean up typos in Tulip NAPI & Interrupt Mitigation Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-20Typo: depricated -> deprecatedRolf Eike Beer
Typo: depricated -> deprecated Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19remove asm/bitops.h includesJiri Slaby
remove asm/bitops.h includes including asm/bitops directly may cause compile errors. don't include it and include linux/bitops instead. next patch will deny including asm header directly. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-15netdev: convert non-obvious instances to use ARRAY_SIZE()Alejandro Martinez Ruiz
This will convert remaining non-obvious or naive calculations of array sizes to use ARRAY_SIZE() macro. Signed-off-by: Alejandro Martinez Ruiz <alex@flawedcode.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-14more tulip endianness annotationsAl Viro
2007-10-14more trivial signedness fixes in driversAl Viro
2007-10-10Fix a potential NULL pointer dereference in uli526x_interrupt() in ↵Micah Gruber
drivers/net/tulip/uli526x.c This patch fixes an apparent potential null dereference bug where we dereference dev before a null check. This patch simply remvoes the can't-happen test for a null pointer. Signed-off-by: Micah Gruber <micah.gruber@gmail.com> Cc: Grant Grundler <grundler@parisc-linux.org> Acked-by: Jeff Garzik <jeff@garzik.org> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10Clean up redundant PHY write line for ULi526x Ethernet driverRoy Zang
Clean up redundant PHY write line for ULi526x Ethernet Driver. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10tulip: endianness annotationsAl Viro
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[ETHTOOL] Provide default behaviors for a few ethtool sub-ioctlsJeff Garzik
For the operations get-tx-csum get-sg get-tso get-ufo the default ethtool_op_xxx behavior is fine for all drivers, so we permit op==NULL to imply the default behavior. This provides a more uniform behavior across all drivers, eliminating ethtool(8) "ioctl not supported" errors on older drivers that had not been updated for the latest sub-ioctls. The ethtool_op_xxx() functions are left exported, in case anyone wishes to call them directly from a driver-private implementation -- a not-uncommon case. Should an ethtool_op_xxx() helper remain unused for a while, except by net/core/ethtool.c, we can un-export it at a later date. [ Resolved conflicts with set/get value ethtool patch... -DaveM ] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10drivers/net/: all drivers/net/ cleanup with ARRAY_SIZEDenis Cheng
Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
