commit 2cb80187ba065d7decad7c6614e35e07aec8a974 upstream.
Setting dev->hard_mtu to 0 will cause a divide error in
usbnet_probe. Protect against devices with bogus CDC Ethernet
functional descriptors by ignoring a zero wMaxSegmentSize.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Acked-by: Oliver Neukum <oneukum@suse.com>
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
[ Upstream commit 5b9f57516337b523f7466a53939aaaea7b78141b ]
Another rebranded Novatel E371. qmi_wwan should drive this device, while
cdc_ether should ignore it. Even though the USB descriptors are plain
CDC-ETHER that USB interface is a QMI interface. Ref commit 7fdb7846c9ca
("qmi_wwan/cdc_ether: add device IDs for Dell 5804 (Novatel E371) WWAN
card")
Cc: Dan Williams <dcbw@redhat.com>
commit 29c6dd591bbd592472247441de9fa694acdabae8 upstream.
The union descriptor must be checked. Its usage was conditional
before the parser was introduced. This is important, because
many RNDIS device, which also use the common parser, have
bogus extra descriptors.
Signed-off-by: Oliver Neukum <oneukum@suse.com>
Tested-by: Vasily Galkin <galkin-vv@yandex.ru>
Since Dell DW5580 is a 3G modem, this patch adds the device as a
mobile broadband adapter
Signed-off-by: Daniele Palmas <dnlplm@gmail.com>
This patch uses the common parser to parse extra CDC
headers in order to reduce code duplication.
This device is sold as 'NVIDIA Tegra USB 3.0 Ethernet'.
Chipset is RTL8153 and works with r8152.
Signed-off-by: Zheng Liu <zhliu@nvidia.com>
This device is sold as 'Lenovo Tinkpad USB 3.0 Ethernet 4X90E51405'.
Signed-off-by: Christian Hesse <mail@eworm.de>
Olivier having laid the groundwork this patch transmits the
multicast flag to the device to save some bus traffic.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Promiscuous mode was not supported anymore with my Lenovo adapters
(RTL8153) since commit c472ab68ad67db23c9907a27649b7dc0899b61f9
(cdc-ether: clean packet filter upon probe).
It was not possible to use them in a bridge anymore.
Signed-off-by: Olivier Blin <olivier.blin@softathome.com>
Also-analyzed-by: Loïc Yhuel <loic.yhuel@softathome.com>
This will be used by the set_rx_mode callback.
Also move a comment about multicast filtering in this new function.
There are devices that don't do reset all the way. So the packet filter should
be set to a sane initial value. Failure to do so leads to intermittent failures
of DHCP on some systems under some conditions.
This device provides QMI and ethernet functionality via a standard CDC
ethernet descriptor. But when driven by cdc_ether, the QMI
functionality is unavailable because only cdc_ether can claim the USB
interface. Thus blacklist the device in cdc_ether and add its IDs to
qmi_wwan, which enables both QMI and ethernet simultaneously.
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
There are known issues for switching the drivers between ECM mode and
vendor mode. The interrup transfer may become abnormal. The hardware
may have the opportunity to die if you change the configuration without
unloading the current driver first, because all the control transfers
of the current driver would fail after the command of switching the
configuration.
Although to use the ecm driver and vendor driver independently is fine,
it may have problems to change the driver from one to the other by
switching the configuration. Additionally, now the vendor mode driver
is more powerful than the ECM driver. Thus, disable the ECM mode driver,
and let r8152 to set the configuration to vendor mode and reset the
device automatically.
Signed-off-by: Hayes Wang <hayeswang@realtek.com>
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
This covers everything under drivers/net except for wireless, which
has been submitted separately.
Remove the limitation that the ecm and r8152 drivers couldn't coexist.
- Remove the devices from the blacklist of relative drivers.
- Remove usb_driver_set_configuration() from r8152 driver.
- Modify the id_table of the r8152 driver for the vendor mode only.
Support new chip RTL8153 which is the USB 3.0 giga ethernet adapter.
Several files refer to an old address for the Free Software Foundation
in the file header comment. Resolve by replacing the address with
the URL <http://www.gnu.org/licenses/> so that we do not have to keep
updating the header comments anytime the address changes.
CC: Oliver Neukum <oliver@neukum.org>
CC: Steve Glendinning <steve.glendinning@shawell.net>
CC: Oliver Neukum <oneukum@suse.de>
Use USB_DEVICE_AND_INTERFACE_INFO and USB_VENDOR_AND_INTERFACE_INFO
macros to reduce boilerplate.
Signed-off-by: Fabio Porcedda <fabio.porcedda@gmail.com>
Acked-by: Oliver Neukum <oliver@neukum.org>
Cc: <stable@vger.kernel.org> # 3.0+ as far back as it applies cleanly
Base on cdc_ether, add the mii functions for RTL8152 and RTL8153.
The RTL8152 and RTL8153 support ECM mode which use the driver of
cdc_ether. Add the mii functions. Then, the basic PHY access is
possible.
Some Icera based Huawei modems handled by this driver are not
completely CDC ECM compliant, using the same USB interface for both
control and data. The CDC functional descriptors include a Union
naming this interface as both master and slave, so it is supportable
by relaxing the descriptor parsing in case these interfaces are
identical.
This has been tested on a Huawei K3806 and verified to add support
for that device.
Reported-and-tested-by: Enrico Mioso <mrkiko.rs@gmail.com>
Another QMI speaking Qualcomm based device, which should be
driven by qmi_wwan, while cdc_ether should ignore it.
Like on other Huawei devices, the wwan function can appear
either as a single vendor specific interface or as a CDC ECM
class function using separate control and data interfaces.
The ECM control interface protocol is 0xff, likely in an
attempt to indicate that vendor specific management is
required.
In addition to the near standard CDC class, Huawei also add
vendor specific AT management commands to their firmwares.
This is probably an attempt to support non-Windows systems
using standard class drivers. Unfortunately, this part of
the firmware is often buggy. Linux is much better off using
whatever native vendor specific management protocol the
device offers, and Windows uses, whenever possible. This
means QMI in the case of Qualcomm based devices.
The E1820 has been verified to work fine with QMI.
Matching on interface number is necessary to distiguish the
wwan function from serial functions in the single interface
mode, as both function types will have class/subclass/function
set to ff/ff/ff.
The control interface number does not change in CDC ECM mode,
so the interface number matching rule is sufficient to handle
both modes. The cdc_ether blacklist entry is only relevant in
CDC ECM mode, but using a similar interface number based rule
helps document this as a transfer from one driver to another.
Other Huawei 02/06/ff devices are left with the cdc_ether driver
because we do not know whether they are based on Qualcomm chips.
The Huawei specific AT command management is known to be somewhat
hardware independent, and their usage of these class codes may
also be independent of the modem hardware.
Reported-by: Graham Inggs <graham.inggs@uct.ac.za>
A rebranded Novatel E371 for AT&T's LTE bands. qmi_wwan should drive this
device, while cdc_ether should ignore it. Even though the USB descriptors
are plain CDC-ETHER that USB interface is a QMI interface.
Signed-off-by: Dan Williams <dcbw@redhat.com>
Acked-by: Bjørn Mork <bjorn@mork.no>
Add new driver for supporting Realtek RTL8152 Based USB 2.0 Ethernet Adapters
Cc: Realtek linux nic maintainers <nic_swsd@realtek.com>
Remove warning introduced by commit 418fc57 ("usbnet: cdc-ether: apply
usbnet_link_change"):
CHECK .../drivers/net/usb/cdc_ether.c
.../drivers/net/usb/cdc_ether.c:409:46: warning: incorrect type in argument 2 (different base types)
.../drivers/net/usb/cdc_ether.c:409:46: expected bool [unsigned] [usertype] <noident>
.../drivers/net/usb/cdc_ether.c:409:46: got restricted __le16 [usertype] wValue
Cc: Ming Lei <ming.lei@canonical.com>
Acked-by: Ming Lei <ming.lei@canonical.com>
Use usbnet_link_change to handle link change centrally.
Signed-off-by: Ming Lei <ming.lei@canonical.com>
It advertises a standard CDC-ETHER interface, which actually should be
driven by qmi_wwan.
This covers the drivers that can use a primitive
implementation.
Cc: stable@vger.kernel.org
These devices provide QMI and ethernet functionality via a standard CDC
interface. Thus blacklist the devices in cdc_ether and add their IDs to
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB 3.5-rc1 changes from Greg Kroah-Hartman:
"Here is the big USB 3.5-rc1 pull request for the 3.5-rc1 merge window.
It's touches a lot of different parts of the kernel, all USB drivers,
due to some API cleanups (getting rid of the ancient err() macro) and
some changes that are needed for USB 3.0 power management updates.
There are also lots of new drivers, pimarily gadget, but others as
well. We deleted a staging driver, which was nice, and finally
dropped the obsolete usbfs code, which will make Al happy to never
have to touch that again.
There were some build errors in the tree that linux-next found a few
days ago, but those were fixed by the most recent changes (all were
due to us not building with CONFIG_PM disabled.)
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'usb-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (477 commits)
xhci: Fix DIV_ROUND_UP compile error.
xhci: Fix compile with CONFIG_USB_SUSPEND=n
USB: Fix core compile with CONFIG_USB_SUSPEND=n
brcm80211: Fix compile error for .disable_hub_initiated_lpm.
Revert "USB: EHCI: work around bug in the Philips ISP1562 controller"
MAINTAINERS: Add myself as maintainer to the USB PHY Layer
USB: EHCI: fix command register configuration lost problem
USB: Remove races in devio.c
USB: ehci-platform: remove update_device
USB: Disable hub-initiated LPM for comms devices.
xhci: Add Intel U1/U2 timeout policy.
xhci: Add infrastructure for host-specific LPM policies.
USB: Add macros for interrupt endpoint types.
xhci: Reserve one command for USB3 LPM disable.
xhci: Some Evaluate Context commands must succeed.
USB: Disable USB 3.0 LPM in critical sections.
USB: Add support to enable/disable USB3 link states.
USB: Allow drivers to disable hub-initiated LPM.
USB: Calculate USB 3.0 exit latencies for LPM.
USB: Refactor code to set LPM support flag.
arch/arm/mach-exynos/mach-nuri.c
arch/arm/mach-exynos/mach-universal_c210.c
drivers/net/wireless/ath/ath6kl/usb.c
Some ZTE WWAN devices have generic CDC Ether descriptors. Add those
into the whitelist so that we get FLAG_WWAN on the interface
Signed-off-by: Andrew Bird <ajb@spheresystems.co.uk>
Hub-initiated LPM is not good for USB communications devices. Comms
devices should be able to tell when their link can go into a lower power
state, because they know when an incoming transmission is finished.
Ideally, these devices would slam their links into a lower power state,
using the device-initiated LPM, after finishing the last packet of their
data transfer.
If we enable the idle timeouts for the parent hubs to enable
hub-initiated LPM, we will get a lot of useless LPM packets on the bus
as the devices reject LPM transitions when they're in the middle of
receiving data. Worse, some devices might blindly accept the
hub-initiated LPM and power down their radios while they're in the
middle of receiving a transmission.
The Intel Windows folks are disabling hub-initiated LPM for all USB
communications devices under a xHCI USB 3.0 host. In order to keep
the Linux behavior as close as possible to Windows, we need to do the
same in Linux.
Set the disable_hub_initiated_lpm flag for for all USB communications
drivers. I know there aren't currently any USB 3.0 devices that
implement these class specifications, but we should be ready if they do.
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Gustavo Padovan <gustavo@padovan.org>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
Cc: Hansjoerg Lipp <hjlipp@web.de>
Cc: Tilman Schmidt <tilman@imap.cc>
Cc: Karsten Keil <isdn@linux-pingi.de>
Cc: Peter Korsgaard <jacmet@sunsite.dk>
Cc: Jan Dumon <j.dumon@option.com>
Cc: Petko Manolov <petkan@users.sourceforge.net>
Cc: Steve Glendinning <steve.glendinning@smsc.com>
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: Kalle Valo <kvalo@qca.qualcomm.com>
Cc: "Luis R. Rodriguez" <mcgrof@qca.qualcomm.com>
Cc: Jouni Malinen <jouni@qca.qualcomm.com>
Cc: Vasanthakumar Thiagarajan <vthiagar@qca.qualcomm.com>
Cc: Senthil Balasubramanian <senthilb@qca.qualcomm.com>
Cc: Christian Lamparter <chunkeey@googlemail.com>
Cc: Brett Rudley <brudley@broadcom.com>
Cc: Roland Vossen <rvossen@broadcom.com>
Cc: Arend van Spriel <arend@broadcom.com>
Cc: "Franky (Zhenhui) Lin" <frankyl@broadcom.com>
Cc: Kan Yan <kanyan@broadcom.com>
Cc: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Cc: Ivo van Doorn <IvDoorn@gmail.com>
Cc: Gertjan van Wingerde <gwingerde@gmail.com>
Cc: Helmut Schaa <helmut.schaa@googlemail.com>
Cc: Herton Ronaldo Krzesinski <herton@canonical.com>
Cc: Hin-Tak Leung <htl10@users.sourceforge.net>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: Chaoming Li <chaoming_li@realsil.com.cn>
Cc: Daniel Drake <dsd@gentoo.org>
Cc: Ulrich Kunitz <kune@deine-taler.de>
Needs to be tagged with FLAG_WWAN, which since it has generic
descriptors, won't happen if we don't override the generic
driver info.
Cc: Oliver Neukum <oliver@neukum.org>
Some RNDIS devices include a bogus CDC Union descriptor pointing
to non-existing interfaces. The RNDIS code is already prepared
to handle devices without a CDC Union descriptor by hardwiring
the driver to use interfaces 0 and 1, which is correct for the
devices with the bogus descriptor as well. So we can reuse the
existing workaround.
Cc: Markus Kolb <linux-201011@tower-net.de>
Cc: Iker Salmón San Millán <shaola@esdebian.org>
Cc: Jonathan Nieder <jrnieder@gmail.com>
Cc: 655387@bugs.debian.org
In the current kernel implementation, the Logitech Harmony 900 remote
control is matched to the cdc_ether driver through the generic
USB_CDC_SUBCLASS_MDLM entry. However, this device appears to be of the
pseudo-MDLM (Belcarra) type, rather than the standard one. This patch
blacklists the Harmony 900 from the cdc_ether driver and whitelists it for
the pseudo-MDLM driver in zaurus.
Signed-off-by: Scott Talbert <talbert@techie.net>
This resolves the conflict in the arch/arm/mach-s3c64xx/s3c6400.c file,
and it fixes the build error in the arch/x86/kernel/microcode_core.c
file, that the merge did not catch.
The microcode_core.c patch was provided by Stephen Rothwell
<sfr@canb.auug.org.au> who was invaluable in the merge issues involved
with the large sysdev removal process in the driver-core tree.
This converts the drivers in drivers/net/* to use the
module_usb_driver() macro which makes the code smaller and a bit
simpler.
Added bonus is that it removes some unneeded kernel log messages about
drivers loading and/or unloading.
Cc: Wolfgang Grandegger <wg@grandegger.com>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: Oliver Neukum <oliver@neukum.name>
Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi>
Cc: Roel Kluin <roel.kluin@gmail.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Jiri Pirko <jpirko@redhat.com>
Cc: Pavel Roskin <proski@gnu.org>
Cc: Yoann DI-RUZZA <y.diruzza@lim.eu>
Cc: George <george0505@realtek.com>
Add checking for valid magic values (needed for stability in the event
corrupted packets are received) and remove some other unneeded checks.
Also, fix flagging device as WWAN (Bugzilla bug #39952).
Signed-off-by: Mark Kamichoff <prox@prolixium.com>
Like other mobile broadband device ethernet interfaces, mark the LG
VL600 with the 'wwan' devtype so userspace knows it needs additional
configuration via the AT port before the interface can be used.
Some newer Huawei devices (T-Mobile Rocket, others) have cdc-ether
compatible ports, so recognize and expose them.
Acked-by: Oliver Neukum <oneukum@suse.de>
The documentation for the USB ethernet devices suggests that
only some devices are supposed to use usb0 as the network interface
name instead of eth0. The logic used there, and documented in
Kconfig for CDC is that eth0 will be used when the mac address
is a globally assigned one, but usb0 is used for the locally
managed range that is typically used on point-to-point links.
Unfortunately, this has caused a lot of pain on the smsc95xx
device that is used on the popular pandaboard without an
EEPROM to store the MAC address, which causes the driver to
call random_ether_address().
Obviously, there should be a proper MAC addressed assigned to
the device, and discussions are ongoing about how to solve
this, but this patch at least makes sure that the default
interface naming gets a little saner and matches what the
user can expect based on the documentation, including for
new devices.
The approach taken here is to flag whether a device might be a
point-to-point link with the new FLAG_POINTTOPOINT setting in
the usbnet driver_info. A driver can set both FLAG_POINTTOPOINT
and FLAG_ETHER if it is not sure (e.g. cdc_ether), or just one
of the two. The usbnet framework only looks at the MAC address
for device naming if both flags are set, otherwise it trusts the
flag.
Signed-off-by: Arnd Bergmann <arnd.bergmann@linaro.org>
Tested-by: Andy Green <andy.green@linaro.org>
This adds a driver for the CDC Ethernet part of this modem. The
device's ID is blacklisted in cdc_ether.c and is white-listed in
this new driver because of the quirks needed to make it useful.
The modem's firmware exposes a CDC ACM port for modem control and a
CDC Ethernet port for network data. The descriptors look fine but
both ports actually are some sort of multiplexers requiring non-
standard headers added/removed from every packet or they get
ignored. All information is based on a usb traffic log from a
Windows machine.
On the Verizon 4G network I've seen speeds up to 1.1MB/s so far with
this driver, a speed-o-meter site reports 16.2Mbps/10.5Mbps.
Userspace scripts are required to talk to the CDC ACM port.
Signed-off-by: Andrzej Zaborowski <balrogg@gmail.com>
We already verified that "dev->udev->actconfig->extralen" was non-zero
so "len" is non-zero here as well.
This patch removes vid/pid for Ericsson MBM devices from the whitelist set of
devices. The MBM devices are instead identified by GUID.
In order for cdc_ether to handle these devices the GUID in the MDLM descriptor
is tested. All MBM devices currently handled by cdc_ether as well as future
CDC Ethernet MBM devices can be identified by the GUID.
This is the same solution used in Carl Nordbeck's mbm driver,
http://kerneltrap.org/mailarchive/linux-usb/2008/11/17/4141384/thread
I post this as RFC to get feedback on however cdc_ether is the correct place to
do the binding, or if it should be done in a separate driver, e.g. zaurus.
Signed-off-by: Jonas Sjöquist <jonas.sjoquist@ericsson.com>
Autosuspend works until you bring the wwan interface up, then the
device does not enter autosuspend anymore.
The following patch fixes the problem by setting the .manage_power
field in the mbm_info struct to the same as in the cdc_info struct
(cdc_manager_power).
Signed-off-by: Torgny Johansson <torgny.johansson@ericsson.com>
