Executing cmd 'rmmod rtl8150' does not return(if your device connects
to host), the root cause is tasklet_disable() causes tasklet_kill()
block, remove it from rtl8150_disconnect().
Signed-off-by: Huajun Li <huajun.li.lee@gmail.com>
This updates the network drivers so that they don't access the
ethtool_cmd::speed field directly, but use ethtool_cmd_speed()
instead.
For most of the drivers, these changes are purely cosmetic and don't
fix any problem, such as for those 1GbE/10GbE drivers that indirectly
call their own ethtool get_settings()/mii_ethtool_gset(). The changes
are meant to enforce code consistency and provide robustness with
future larger throughputs, at the expense of a few CPU cycles for each
ethtool operation.
All drivers compiled with make allyesconfig ion x86_64 have been
updated.
Tested: make allyesconfig on x86_64 + e1000e/bnx2x work
Signed-off-by: David Decotigny <decot@google.com>
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss
anything). Used spatch and did small tweaks and conding style changes when
it was suitable.
Jirka
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
drivers/net/benet/be_cmds.h
include/linux/sysctl.h
With `while (i++ < MII_TIMEOUT)' i reaches MII_TIMEOUT + 1 after the loop
This is probably unlikely a problem in practice.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Use the %pM kernel extension to display the MAC address.
sizeof(dev->dev_addr) is the size of a pointer. A few lines above, the
size of this field is obtained using netdev->addr_len for a call to memcpy,
so do the same here.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
expression *x;
expression f;
type T;
*f(...,(T)x,...)
// </smpl>
No need to put ethtool_ops in data, they should be const.
This patch is the result of an automatic spatch transformation to convert
all ndo_start_xmit() return values of 0 to NETDEV_TX_OK.
Some occurences are missed by the automatic conversion, those will be
handled in a seperate patch.
Warning messages coming from rtl8150 driver can flood the console
and make a DTV/set-top-box unable to decode video/audio frames.
'Pegasus' driver handles this situation similarly, preventing this
from happening there.
It happens with a low cost BCM MIPS embedded platform, whenever
timeout errors were coming from usbnet device, making platform
unusable for viewer watching.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
USB is going to switch the signature of the callbacks to
void callback(struct urb *urb, int status)
This patch will ease the transition.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
USB should not be having it's own printk macros, so remove info() and
use the system-wide standard of dev_info() wherever possible.
Cc: Jeff Garzik <jgarzik@pobox.com>
USB should not be having it's own printk macros, so remove warn() and
use the system-wide standard of dev_warn() wherever possible. In the
few places that will not work out, use a basic printk().
The RTL8150 driver uses an MTU of 1540 by default, which causes a
bunch of problems -- it prevents booting from NFS root, for one.
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: Petko Manolov <petkan@nucleusys.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
It's been a useless no-op for long enough in 2.6 so I figured it's time to
remove it. The number of people that could object because they're
maintaining unified 2.4 and 2.6 drivers is probably rather small.
[ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ]
This patch covers something like this:
dev = alloc_*dev(...
priv = netdev_priv(dev);
memset(priv, 0, sizeof(*priv));
The memset() here is superfluous. alloc_netdev() uses kzalloc()
to allocate needed memory so there is no need to zero the priv region
twice.
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl>
It is preferable to group drivers by usage (net, scsi, ATA, ...) than
by bus. When reviewing drivers, the [PCI|USB|PCMCIA|...] maintainer
is probably less qualified on networking issues than a networking
maintainer. Also, from a practical standpoint, chips often
appear on multiple buses, which is why we do not put drivers into
drivers/pci/net.
