[ Upstream commit b530b1930bbd9d005345133f0ff0c556d2a52b19 ]
Initially diagnosed on Ubuntu 11.04 with kernel 2.6.38.
velocity_close is not called during a suspend / resume cycle in this
driver and it has no business playing directly with power states.
Signed-off-by: David Lv <DavidLv@viatech.com.cn>
Acked-by: Francois Romieu <romieu@fr.zoreil.com>
This updates the network drivers so that they don't access the
ethtool_cmd::speed field directly, but use ethtool_cmd_speed()
instead.
For most of the drivers, these changes are purely cosmetic and don't
fix any problem, such as for those 1GbE/10GbE drivers that indirectly
call their own ethtool get_settings()/mii_ethtool_gset(). The changes
are meant to enforce code consistency and provide robustness with
future larger throughputs, at the expense of a few CPU cycles for each
ethtool operation.
All drivers compiled with make allyesconfig ion x86_64 have been
updated.
Tested: make allyesconfig on x86_64 + e1000e/bnx2x work
Signed-off-by: David Decotigny <decot@google.com>
This makes sure the ethtool's set_settings() callback of network
drivers don't ignore the 16 most significant bits when ethtool calls
their set_settings().
All drivers compiled with make allyesconfig on x86_64 have been
updated.
drivers/net/smsc911x.c
Trivial conversion.
This also enables toggling TX VLAN offload and fixes TX checksumming
race with offload changes.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
The VIA velocity card can't be waken up by WOL tool on 1000M full
duplex forced mode. This patch fixes the bug.
Many (but not all) drivers check to see whether there is a vlan
group configured before using a tag stored in the skb. There's
not much point in this check since it just throws away data that
should only be present in the expected circumstances. However,
it will soon be legal and expected to get a vlan tag when no
vlan group is configured, so remove this check from all drivers
to avoid dropping the tags.
Signed-off-by: Jesse Gross <jesse@nicira.com>
Full duplex only. Half duplex 1000 Mbps is not supported.
Tested-by: Seguier Regis <rseguier@e-teleport.net>
net/mac80211/main.c
It causes all kinds of DMA API debugging assertions and
all straight-forward attempts to fix it have failed.
So turn off SG, and we'll tackle making this work
properly in net-next-2.6
Reported-by: Dave Jones <davej@redhat.com>
Tested-by: Dave Jones <davej@redhat.com>
fresh skbs have ip_summed set to CHECKSUM_NONE (0)
We can avoid setting again skb->ip_summed to CHECKSUM_NONE in drivers.
Introduce skb_checksum_none_assert() helper so that we keep this
assertion documented in driver sources.
Change most occurrences of :
skb->ip_summed = CHECKSUM_NONE;
by :
skb_checksum_none_assert(skb);
IRQ and resource[] may not have correct values until
after PCI hotplug setup occurs at pci_enable_device() time.
The semantic match that finds this problem is as follows:
// <smpl>
identifier x;
identifier request ~= "pci_request.*|pci_resource.*";
* x->irq
* x->resource
* request(x, ...)
*pci_enable_device(x)
// </smpl>
Signed-off-by: Kulikov Vasiliy <segooon@gmail.com>
Now that core network takes care of trans_start updates, dont do it
in drivers themselves, if possible. Drivers can avoid one cache miss
(on dev->trans_start) in their start_xmit() handler.
Exceptions are NETIF_F_LLTX drivers
drivers/net/bonding/bond_main.c
drivers/net/via-velocity.c
drivers/net/wireless/iwlwifi/iwl-agn.c
Registers and their bits from mii.h. Courtesy from ed.
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Clear, don't set, ANAR_ASMDIR in this case.
Noticed by Roel Kluin.
Reduces CPU utilization significantly with sendfile for example.
Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
net/mac80211/rate.c
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss
anything). Used spatch and did small tweaks and conding style changes when
it was suitable.
Jirka
This patch fixes two potential races in the velocity driver:
* Move the ACK and error handler to the interrupt handler. This fixes a
potential race with shared interrupts when the other device interrupts
before the NAPI poll handler has finished. As the velocity driver hasn't
acked it's own interrupt, it will then steal the interrupt from the
other device.
* Use spin_lock_irqsave in velocity_poll. In the current code, the
interrupt handler will deadlock if e.g., the NAPI poll handler is
executing when an interrupt (for another device) comes in since it
tries to take the already held lock.
Also unlock the spinlock only after enabling the interrupt in
velocity_poll.
The error path is moved to the interrupt handler since this is where the
ISR is checked now.
Signed-off-by: Anders Grafstrom <anders.grafstrom@netinsight.net>
velocity_set_coalesce touches ISR and some other sensitive registers not
covered by the rtnl lock, so take the velocity spinlock.
drivers/net/benet/be_cmds.h
include/linux/sysctl.h
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section
in every case.
velocity_open() calls velocity_give_many_rx_descs(), which gives RX
descriptors to the NIC, before installing an interrupt handler or
calling velocity_init_registers(). I think this is very unsafe and it
appears to explain the bug report <http://bugs.debian.org/508527>.
On MTU change, velocity_give_many_rx_descs() is again called before
velocity_init_registers(). I'm not sure whether this is unsafe but
it does look wrong.
Therefore, move the calls to velocity_give_many_rx_descs() after
request_irq() and velocity_init_registers().
Tested-by: Jan Ceuleers <jan.ceuleers@computer.org>
Use the %pM kernel extension to display the MAC address.
Only files where David Miller is the primary git-signer.
wireless, wimax, ixgbe, etc are not modified.
Compile tested x86 allyesconfig only
Not all files compiled (not x86 compatible)
Added a few > 80 column lines, which I ignored.
Existing checkpatch complaints ignored.
Defaults to on (as before).
The velocity hardware can handle up to 7 memory segments. This can be
turned on and off via ethtool. The support was removed in commit
83c98a8cd04dd0f848574370594886ba3bf56750
but is re-enabled and cleaned up here. It's off by default.
The VIA driver has changed the default for the DMA_LENGTH_DEF parameter.
Together with adaptive interrupt supression and NAPI support, this
improves performance quite a bit
This patch adds NAPI support for VIA velocity. The new velocity_poll
function also pairs tx/rx handling twice which improves perforamance on
some workloads (e.g., netperf UDP_STREAM) significantly (that part is
from the VIA driver).
(Partially from the upstream VIA driver). Tweaking the number of
frames-per-interrupt and timer-until-interrupt can reduce the amount of
CPU work quite a lot.
(From the VIA driver). The current code does not guarantee 64-byte
alignment since it simply does
int add = skb->data & 63;
skb->data += add;
(via skb_reserve). So for example, if the skb->data address would be
0x10, this would result in 32-byte alignment (0x10 + 0x10).
Correct by adding
64 - (skb->data & 63)
instead.
In this file, function names are otherwise used as pointers without &.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
@r@
identifier f;
f(...) { ... }
identifier r.f;
- &f
+ f
// </smpl>
via-velocity maintains a list of its devices in order to determine
whether a netdev notification applies to one of them. That can be
determined simply by checking the netdev_ops pointer, so the list can
be removed.
Compile-tested only.
dev_ioctl() already checks capable(CAP_NET_ADMIN) before calling the
driver's implementation of MDIO ioctls.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
drivers/net/yellowfin.c
In a couple of cases collapse some extra code like:
int retval = NETDEV_TX_OK;
return retval;
into
return NETDEV_TX_OK;
Test whether VELOCITY_DUPLEX_FULL bit is set in mii_status.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
By moving functions to before their first call, we eliminate
the need to define forward references.
Signed-off-by: Dave Jones <davej@redhat.com>
This code hasn't been enabled in forever.
This patch is the result of an automatic spatch transformation to convert
all ndo_start_xmit() return values of 0 to NETDEV_TX_OK.
Some occurences are missed by the automatic conversion, those will be
handled in a seperate patch.
When a packet is greater than ETH_ZLEN, we end up assigning the
boolean result of a comparison to the size we unmap.
on boot, link is always up.
Signed-off-by: Seguier Regis <rseguier@e-teleport.net>
