path: root/drivers/net/vmxnet3
2010-10-30vmxnet: trivial annotation of protocol constantHarvey Harrison
Noticed by sparse: drivers/net/vmxnet3/vmxnet3_drv.c:876:38: warning: cast from restricted __be16 drivers/net/vmxnet3/vmxnet3_drv.c:876:38: warning: cast from restricted __be16 drivers/net/vmxnet3/vmxnet3_drv.c:876:24: warning: restricted __be16 degrades to integer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-30vmxnet3: remove unnecessary byteswapping in BAR writing macrosHarvey Harrison
readl/writel swap to little-endian internally. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-24vmxnet3: fix typo setting confPAHarvey Harrison
It's a le64, not a le32, typo in one place only. Noticed by sparse: drivers/net/vmxnet3/vmxnet3_drv.c:2668:52: warning: incorrect type in assignment (different base types) drivers/net/vmxnet3/vmxnet3_drv.c:2668:52: expected restricted __le64 [usertype] confPA drivers/net/vmxnet3/vmxnet3_drv.c:2668:52: got restricted __le32 [usertype] <noident> Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Shreyas Bhatewara <sbhatewara@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-24vmxnet3: annotate hwaddr members as __iomem pointersHarvey Harrison
2010-10-24vmxnet3: remove set_flag_le{16,64} helpersHarvey Harrison
It's easier to just annotate the constants as little endian types and set/clear the flags directly. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Shreyas Bhatewara <sbhatewara@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21vmxnet3: make bit twiddle routines inlinestephen hemminger
Gcc doesn't usually handle inline across compilation units, and the functions don't have to be global in scope. Move the set/reset flag functions int the existing vmxnet3 header. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Shreyas Bhatewara <sbhatewara@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21vlan: Rename VLAN_GROUP_ARRAY_LEN to VLAN_N_VID.Jesse Gross
VLAN_GROUP_ARRAY_LEN is simply the number of possible vlan VIDs. Since vlan groups will soon be more of an implementation detail for vlan devices, rename the constant to be descriptive of its actual purpose. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-02drivers/net: avoid some skb->ip_summed initializationsEric Dumazet
fresh skbs have ip_summed set to CHECKSUM_NONE (0) We can avoid setting again skb->ip_summed to CHECKSUM_NONE in drivers. Introduce skb_checksum_none_assert() helper so that we keep this assertion documented in driver sources. Change most occurrences of : skb->ip_summed = CHECKSUM_NONE; by : skb_checksum_none_assert(skb); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-25net-next: Fix an overflow bug in vmxnet3 Tx descriptorBhavesh Davda
Fix an overflow bug in vmxnet3 Tx descriptor This patch fixes a bug where a 16K buffer on a Tx descriptor was overflowing into the 'gen' bit in the descriptor thereby corrupting the descriptor and stalling the transmit ring. Signed-off-by: Bhavesh Davda <bhavesh@vmware.com> Signed-off-by: Shreyas Bhatewara <sbhatewara@vmware.com> Signed-off-by: Matthew Delco <delcoM@vmware.com> Signed-off-by: Ronghua Zhang <ronghua@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-19net-next: vmxnet3 fixes [5/5] Respect the interrupt type in VM configurationShreyas Bhatewara
Respect the interrupt type set in VM configuration. When interrupt type is not auto, do not ignore the interrupt type set from VM configuration. Signed-off-by: Shreyas Bhatewara <sbhatewara@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-19net-next: vmxnet3 fixes [4/5] Do not reset when the device is not openedShreyas Bhatewara
Hold rtnl_lock to get the right link state. While asynchronously resetting the device, hold rtnl_lock to get the right value from netif_running. If a reset is scheduled, and the device goes thru close and open, it may happen that reset and open may run in parallel. Holding rtnl_lock will avoid this. Signed-off-by: Shreyas Bhatewara <sbhatewara@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-18net-next: vmxnet3 fixes [3/5] Initialize link state at probe timeShreyas Bhatewara
This change initializes the state of link at the time when driver is loaded. The ethtool output for 'link detected' and 'link speed' is thus valid even before the interface is brought up. Signed-off-by: Shreyas Bhatewara <sbhatewara@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-15net-next: vmxnet3 fixes [2/5] Interrupt control bitmapRonghua Zang
A new bit map 'intrCtrl' is introduced in the DriverShared area. The driver should update VMXNET3_IC_DISABLE_ALL bit before writing IMR. Signed-off-by: Ronghua Zang <ronghua@vmware.com> Signed-off-by: Shreyas Bhatewara <sbhatewara@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-15net-next: fix LRO feature update in vmxnet3Shreyas Bhatewara
Fix LRO feature update. Signed-off-by: Shreyas Bhatewara <sbhatewara@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-30vmxnet3: Remove incorrect implementation of ethtool_ops::get_flags()Ben Hutchings
Only some netdev feature flags correspond directly to ethtool feature flags. ethtool_op_get_flags() does the right thing. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Bhavesh Davda <bhavesh@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-29vmxnet3: fail when try to setup unsupported featuresStanislaw Gruszka
Return EOPNOTSUPP in ethtool_ops->set_flags. Fix coding style while at it. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17drivers/net/vmxnet3: Use kzallocJulia Lawall
Use kzalloc rather than the combination of kmalloc and memset. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression x,size,flags; statement S; @@ -x = kmalloc(size,flags); +x = kzalloc(size,flags); if (x == NULL) S -memset(x, 0, size); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Bhavesh Davda <bhavesh@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13drivers: net: last_rx eliminationEric Dumazet
Network drivers do not have to update last_rx, unless they need it for their private use. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-26net: convert multiple drivers to use netdev_for_each_mc_addr, part6Jiri Pirko
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-15const: constify remaining dev_pm_opsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-17vmxnet3: using csum_ipv6_magic requires including net/ip6_checksum.hStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-17net: Getting rid of the x86 dependency to built vmxnet3Shreyas Bhatewara
This patch removes config dependency on x86 to build vmxnet3 driver. Thus the driver can be built on big endian architectures now. Although vmxnet3 is not supported on VMs other than x86 architecture, all this code goes in to ensure correctness. If the code is not dependent on x86, it should not assume little endian architecture in any of its operations. Signed-off-by: Shreyas Bhatewara <sbhatewara@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-28vmxnet3: remove duplicate #includeShreyas Bhatewara
Remove duplicate headerfile includes from vmxnet3_int.h Signed-off-by: Shreyas Bhatewara <sbhatewara@vmware.com> Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Bhavesh Davda <bhavesh@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-16vmxnet3: use dev_dbg, fix build for CONFIG_BLOCK=nRandy Dunlap
vmxnet3 was using dprintk() for debugging output. This was defined in <linux/dst.h> and was the only thing that was used from that header file. This caused compile errors when CONFIG_BLOCK was not enabled due to bio* and BIO* uses in the header file, so change this driver to use dev_dbg() for debugging output. include/linux/dst.h:520: error: dereferencing pointer to incomplete type include/linux/dst.h:520: error: 'BIO_POOL_BITS' undeclared (first use in this function) include/linux/dst.h:521: error: dereferencing pointer to incomplete type include/linux/dst.h:522: error: dereferencing pointer to incomplete type include/linux/dst.h:525: error: dereferencing pointer to incomplete type make[4]: *** [drivers/net/vmxnet3/vmxnet3_drv.o] Error 1 Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Bhavesh Davda <bhavesh@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-14vmxnet: fix 2 build problemsRandy Dunlap
vmxnet3 uses in_dev* interfaces so it should depend on INET. Also fix so that the driver builds when CONFIG_PCI_MSI is disabled. vmxnet3_drv.c:(.text+0x2a88cb): undefined reference to `in_dev_finish_destroy' drivers/net/vmxnet3/vmxnet3_drv.c:1335: error: 'struct vmxnet3_intr' has no member named 'msix_entries' drivers/net/vmxnet3/vmxnet3_drv.c:1384: error: 'struct vmxnet3_intr' has no member named 'msix_entries' drivers/net/vmxnet3/vmxnet3_drv.c:2137: error: 'struct vmxnet3_intr' has no member named 'msix_entries' drivers/net/vmxnet3/vmxnet3_drv.c:2138: error: 'struct vmxnet3_intr' has no member named 'msix_entries' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Bhavesh davda <bhavesh@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13net: VMware virtual Ethernet NIC driver: vmxnet3Shreyas Bhatewara
Ethernet NIC driver for VMware's vmxnet3 From: Shreyas Bhatewara <sbhatewara@vmware.com> This patch adds driver support for VMware's virtual Ethernet NIC: vmxnet3 Guests running on VMware hypervisors supporting vmxnet3 device will thus have access to improved network functionalities and performance. Signed-off-by: Shreyas Bhatewara <sbhatewara@vmware.com> Signed-off-by: Bhavesh Davda <bhavesh@vmware.com> Signed-off-by: Ronghua Zhang <ronghua@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
