path: root/drivers/net/wan/Makefile
2013-01-31wanrouter: completely decouple obsolete code from kernel.Paul Gortmaker
The original suggestion to delete wanrouter started earlier with the mainline commit f0d1b3c2bcc5de8a17af5f2274f7fcde8292b5fc ("net/wanrouter: Deprecate and schedule for removal") in May 2012. More importantly, Dan Carpenter found[1] that the driver had a fundamental breakage introduced back in 2008, with commit 7be6065b39c3 ("netdevice wanrouter: Convert directly reference of netdev->priv"). So we know with certainty that the code hasn't been used by anyone willing to at least take the effort to send an e-mail report of breakage for at least 4 years. This commit does a decouple of the wanrouter subsystem, by going after the Makefile/Kconfig and similar files, so that these mainline files that we are keeping do not have the big wanrouter file/driver deletion commit tied into their history. Once this commit is in place, we then can remove the obsolete cyclomx drivers and similar that have a dependency on CONFIG_WAN_ROUTER_DRIVERS. [1] http://www.spinics.net/lists/netdev/msg218670.html Originally-by: Joe Perches <joe@perches.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-11-09Make the wanxl firmware array constDavid Howells
Make the wanxl firmware array const so that it goes in the read-only section. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-09Fix the wanxl firmware to include missing constantsDavid Howells
Fix the wanxl firmware to include missing constants such as PARITY_NONE. It should be #including the linux/hdlc/ioctl.h header. To make this work, we also have to guard parts of ioctl.h with !__ASSEMBLY__. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-09UAPI: Fix compilation of the wanxl firmware blob.David Howells
The wanxl firmware needs access to some bits of UAPI stuff, so the -I flag in the Makefile needs adjusting to point at the UAPI headers. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-13NET: pc300, move to staging as it is brokenJiri Slaby
It was marked as BROKEN back in 2008. It is because the tty handling in the driver is really broken. There was some activity in January 2012 to fix the driver, but the patch was commented to be bogus: https://lkml.org/lkml/2012/1/29/160 and we have not heard back from the author since then: https://lkml.org/lkml/2012/3/28/412 So since nobody stepped in and rewrote the driver, it is time to move it out of line now. And drop it some time later if nobody comes up with patches to fix the driver in staging. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: David S. Miller <davem@davemloft.net> Cc: Alan Cox <alan@linux.intel.com> Cc: Andrea Shepard <andrea@persephoneslair.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2008-12-22WAN: Add IXP4xx HSS HDLC driver.Krzysztof Hałasa
Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2008-11-22WAN: new synchronous PPP implementation for generic HDLC.Krzysztof Hałasa
2008-07-23WAN: Port LMC driver to generic HDLCKrzysztof Hałasa
2008-07-23WAN: Convert Zilog-based drivers to generic HDLCKrzysztof Hałasa
2008-07-23WAN: Port COSA driver to generic HDLC.Krzysztof Hałasa
2008-07-23WAN: farsync driver no longer uses syncppp.c directlyKrzysztof Hałasa
2007-02-05PC300too alternative WAN driverKrzysztof Halasa
The attached patch adds an alternative driver "pc300too" for PCI WAN cards PC300/RSV and PC300/X21 made by Cyclades Corp. (now Avocent Corp). Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-26[PATCH] Modularize generic HDLCKrzysztof Halasa
This patch enables building of individual WAN protocol support routines (parts of generic HDLC) as separate modules. All protocol-private definitions are moved from hdlc.h file to protocol drivers. User-space interface and interface between generic HDLC and underlying low-level HDLC drivers are unchanged. Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[PATCH] remove dead entry in net wan KconfigPaul Fulghum
Remove dead entry from net wan Kconfig and net wan Makefile.. This entry is left over from 2.4 where synclink used syncppp driver directly. synclink drivers now use generic HDLC Signed-off-by: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-11[WAN]: Remove broken and unmaintained Sangoma drivers.Adrian Bunk
The in-kernel Sangoma drivers are both not compiling and marked as BROKEN since at least kernel 2.6.0. Sangoma offers out-of-tree drivers, and David Mandelstam told me Sangoma does no longer maintain the in-kernel drivers and prefers to provide them as a separate installation package. This patch therefore removes these drivers. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
