path: root/drivers/net/wan/cycx_drv.c
2005-09-14[PATCH] drivers/net/wan/: possible cleanupsAdrian Bunk
This patch contains possible cleanups including the following: - make needlessly global code static - #if 0 the following unused global function: - sdladrv.c: sdla_intde - remove the following unused global variable: - lmc_media.c: lmc_t1_cables - remove the following unneeded EXPORT_SYMBOL's: - cycx_drv.c: cycx_inten - sdladrv.c: sdla_inten - sdladrv.c: sdla_intde - sdladrv.c: sdla_intack - sdladrv.c: sdla_intr - syncppp.c: sppp_input - syncppp.c: sppp_change_mtu Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-19[PATCH] net/cycx_drv: replace delay_cycx() with msleep_interruptible()Nishanth Aravamudan
Use msleep_interruptible() instead of delay_cycx() to guarantee the task delays as expected. Remove the prototype and definition of delay_cycx(). Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
