path: root/drivers/net/wan/hdlc_cisco.c
2011-06-27generic_hdlc: Update to current logging formsJoe Perches
Use pr_fmt, pr_<level> and netdev_<level> as appropriate. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15ipv4: ip_ptr cleanupsEric Dumazet
dev->ip_ptr is protected by rtnl and rcu. Yet some places dont use appropriate primitives and/or locking rules. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-03drivers/net: use __packed annotationEric Dumazet
cleanup patch. Use new __packed annotation in drivers/net/ Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-04Coding style correction of some wan driversRudy Matela
Added a space separating some if/switch/while keywords from the following parenthesis to conform to the CodingStyle. Signed-off-by: Rudy Matela <rudy.matela@gmail.com> Acked-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-10-13WAN: fix Cisco HDLC handshaking.Krzysztof Halasa
Cisco HDLC uses keepalive packets and sequence numbers to determine link state. In rare cases both ends could transmit keepalive packets at the same time, causing the received sequence numbers to be treated as incorrect. Now we accept our current sequence number as well as the previous one. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: replace uses of __constant_{endian}Harvey Harrison
Base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21WAN: Convert generic HDLC drivers to netdev_ops.Krzysztof Hałasa
Also remove unneeded last_rx update from Synclink drivers. Synclink part mostly by Stephen Hemminger. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-23WAN: cosmetic changes to generic HDLCKrzysztof Hałasa
2008-07-04WAN: convert drivers to use built-in netdev_statsKrzysztof Halasa
There is no point in using separate net_device_stats structs when the one in struct net_device is present. Compiles. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-22WAN: protect Cisco HDLC state changes with a spinlock.Krzysztof Halasa
2008-02-05Generic HDLC - remove now unneeded hdlc_device_descKrzysztof Halasa
Removes now unneeded struct hdlc_device_desc Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Move hardware header operations out of netdevice.Stephen Hemminger
Since hardware header operations are part of the protocol class not the device instance, make them into a separate object and save memory. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-28Generic HDLC sparse annotationsKrzysztof Halasa
Sparse annotations, including two minor bugfixes. Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-25[SK_BUFF]: Introduce skb_reset_network_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->nh.raw = skb->data' operation, so that we can later turn skb->nh.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-02[HDLC] Fix dev->header_cache_update having a random value.Krzysztof Halasa
Switching HDLC devices from Ethernet-framing mode caused stale ethernet function assignments within net_device. Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: annotate struct in_ifaddrAl Viro
ifa_local, ifa_address, ifa_mask, ifa_broadcast and ifa_anycast are net-endian. Annotated them and variables that are inferred to be net-endian. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-26[PATCH] Modularize generic HDLCKrzysztof Halasa
This patch enables building of individual WAN protocol support routines (parts of generic HDLC) as separate modules. All protocol-private definitions are moved from hdlc.h file to protocol drivers. User-space interface and interface between generic HDLC and underlying low-level HDLC drivers are unchanged. Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-12[WAN]: converting generic HDLC to use netif_dormant*()Krzysztof Halasa
This patch converts generic HDLC (and WAN drivers using it) from hdlc_set_carrier() to netif_dormant*() interface. WAN hardware drivers should now use netif_carrier_on|off() like other network drivers. Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-16[PATCH] Generic HDLC WAN drivers - disable netif_carrier_off()Krzysztof Halasa
As we are currently unable to fix the problem with carrier and protocol state signaling in net core I've to disable netif_carrier_off() calls used by WAN protocol drivers. The attached patch should make them working again. The remaining netif_carrier_*() calls in hdlc_fr.c are fine as they don't touch the physical device. Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2005-09-19[WAN] hdlc_cisco: Fix regression introduced by skb->tail changes.Krzysztof Halasa
The following commit breaks cisco mode with my WAN drivers: author David S. Miller <davem@davemloft.net> Tue, 28 Jun 2005 22:25:31 +0000 (15:25 -0700) commit 689be43945e9ca7dd704522e55af1b8a73a994d3 "[NET]: Remove gratuitous use of skb->tail in network drivers." The following patch fixes it - please apply (cisco_hard_header does skb_push(4 bytes)). Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-12[NET]: __be'ify *_type_trans()Alexey Dobriyan
tr_type_trans(), hippi_type_trans() left as-is. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-28[NET]: Remove gratuitous use of skb->tail in network drivers.David S. Miller
Many drivers use skb->tail unnecessarily. In these situations, the code roughly looks like: dev = dev_alloc_skb(...); [optional] skb_reserve(skb, ...); ... skb->tail ... But even if the skb_reserve() happens, skb->data equals skb->tail. So it doesn't make any sense to use anything other than skb->data in these cases. Another case was the s2io.c driver directly mucking with the skb->data and skb->tail pointers. It really just wanted to do an skb_reserve(), so that's what the code was changed to do instead. Another reason I'm making this change as it allows some SKB cleanups I have planned simpler to merge. In those cleanups, skb->head, skb->tail, and skb->end pointers are removed, and replaced with skb->head_room and skb->tail_room integers. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Jeff Garzik <jgarzik@pobox.com>
