path: root/drivers/net/wimax
2011-10-31drivers/net: Add moduleparam.h to drivers as required.Paul Gortmaker
These files were using moduleparam infrastructure, but were not including anything for it -- which is fine when module.h is being implicitly included in all files, but that is going away. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31drivers/net: Add export.h to files using EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
These were getting the macros from an implicit module.h include via device.h, but we are planning to clean that up. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> drivers/net: Add export.h to wireless/brcm80211/brcmfmac/bcmsdh.c This relatively recently added file uses EXPORT_SYMBOL and hence needs export.h included so that it is compatible with the module.h split up work. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31drivers/net: Add module.h to drivers who were implicitly using itPaul Gortmaker
The device.h header was including module.h, making it present for most of these drivers. But we want to clean that up. Call out the include of module.h in the modular network drivers. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-08-19PM / Runtime: Add macro to test for runtime PM eventsAlan Stern
This patch (as1482) adds a macro for testing whether or not a pm_message value represents an autosuspend or autoresume (i.e., a runtime PM) event. Encapsulating this notion seems preferable to open-coding the test all over the place. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-07Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (144 commits) USB: add support for Dream Cheeky DL100B Webmail Notifier (1d34:0004) USB: serial: ftdi_sio: add support for TIOCSERGETLSR USB: ehci-mxc: Setup portsc register prior to accessing OTG viewport USB: atmel_usba_udc: fix freeing irq in usba_udc_remove() usb: ehci-omap: fix tll channel enable mask usb: ohci-omap3: fix trivial typo USB: gadget: ci13xxx: don't assume that PAGE_SIZE is 4096 USB: gadget: ci13xxx: fix complete() callback for no_interrupt rq's USB: gadget: update ci13xxx to work with g_ether USB: gadgets: ci13xxx: fix probing of compiled-in gadget drivers Revert "USB: musb: pm: don't rely fully on clock support" Revert "USB: musb: blackfin: pm: make it work" USB: uas: Use GFP_NOIO instead of GFP_KERNEL in I/O submission path USB: uas: Ensure we only bind to a UAS interface USB: uas: Rename sense pipe and sense urb to status pipe and status urb USB: uas: Use kzalloc instead of kmalloc USB: uas: Fix up the Sense IU usb: musb: core: kill unneeded #include's DA8xx: assign name to MUSB IRQ resource usb: gadget: g_ncm added ... Manually fix up trivial conflicts in USB Kconfig changes in: arch/arm/mach-omap2/Kconfig arch/sh/Kconfig drivers/usb/Kconfig drivers/usb/host/ehci-hcd.c and annoying chip clock data conflicts in: arch/arm/mach-omap2/clock3xxx_data.c arch/arm/mach-omap2/clock44xx_data.c
2010-12-12i2400m: drop i2400m_schedule_work()Tejun Heo
i2400m implements dynamic work allocation and queueing mechanism in i2400_schedule_work(); however, this is only used for reset and recovery which can be served equally well with preallocated per device works. Replace i2400m_schedule_work() with two work structs in struct i2400m. These works are explicitly canceled when the device is released making calls to flush_scheduled_work(), which is being deprecated, unnecessary. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com> Cc: linux-wimax@intel.com Cc: netdev@vger.kernel.org
2010-12-10fix comment typos concerning "consistent"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-11-17USB: fix leftover references to udev->autosuspend_delayAlan Stern
This patch (as1436) takes care of leftover references to udev->autosuspend_delay that didn't get removed during the earlier conversion to the runtime-PM autosuspend API. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits) bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL. vlan: Calling vlan_hwaccel_do_receive() is always valid. tproxy: use the interface primary IP address as a default value for --on-ip tproxy: added IPv6 support to the socket match cxgb3: function namespace cleanup tproxy: added IPv6 support to the TPROXY target tproxy: added IPv6 socket lookup function to nf_tproxy_core be2net: Changes to use only priority codes allowed by f/w tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled tproxy: added tproxy sockopt interface in the IPV6 layer tproxy: added udp6_lib_lookup function tproxy: added const specifiers to udp lookup functions tproxy: split off ipv6 defragmentation to a separate module l2tp: small cleanup nf_nat: restrict ICMP translation for embedded header can: mcp251x: fix generation of error frames can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set can-raw: add msg_flags to distinguish local traffic 9p: client code cleanup rds: make local functions/variables static ... Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and drivers/net/wireless/ath/ath9k/debug.c as per David
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/core/ethtool.c
2010-10-11NET: wimax, fix use after freeJiri Slaby
Stanse found that i2400m_rx frees skb, but still uses skb->len even though it has skb_len defined. So use skb_len properly in the code. And also define it unsinged int rather than size_t to solve compilation warnings. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com> Cc: linux-wimax@intel.com Acked-by: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05wimax: make functions localstephen hemminger
Make wimax variables and functions local if possible. Compile tested only. This also removes a couple of unused EXPORT_SYMBOL. If this breaks some out of tree code, please fix that by putting the code in the kernel tree. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-08-04Merge branch 'master' into for-nextJiri Kosina
2010-07-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x_main.c Merge bnx2x bug fixes in by hand... :-/ Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-24Merge branch 'wimax-2.6.35.y' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/inaky/wimax
2010-07-22wimax/i2400m: Add PID & VID for Intel WiMAX 6250Alexey Shvetsov
This version of intel wimax device was found in my IBM ThinkPad x201 Signed-off-by: Alexey Shvetsov <alexxy@gentoo.org>
2010-06-16Merge branch 'master' into for-nextJiri Kosina
2010-06-16fix typos concerning "initiali[zs]e"Uwe Kleine-König
2010-06-11Merge branch 'master' of ↵David S. Miller
2010-06-11Merge branch 'wimax-2.6.35.y' of ↵David S. Miller
2010-06-11wimax/i2400m: fix missing endian correction read in fw loaderInaky Perez-Gonzalez
i2400m_fw_hdr_check() was accessing hardware field bcf_hdr->module_type (little endian 32) without converting to host byte sex. Reported-by: Данилин Михаил <mdanilin@nsg.net.ru> Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com>
2010-06-03drivers/net: use __packed annotationEric Dumazet
cleanup patch. Use new __packed annotation in drivers/net/ Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-25Merge branch 'wimax-2.6.35.y' of ↵David S. Miller
2010-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (229 commits) USB: remove unused usb_buffer_alloc and usb_buffer_free macros usb: musb: update gfp/slab.h includes USB: ftdi_sio: fix legacy SIO-device header USB: kl5usb105: reimplement using generic framework USB: kl5usb105: minor clean ups USB: kl5usb105: fix memory leak USB: io_ti: use kfifo to implement write buffering USB: io_ti: remove unsused private counter USB: ti_usb: use kfifo to implement write buffering USB: ir-usb: fix incorrect write-buffer length USB: aircable: fix incorrect write-buffer length USB: safe_serial: straighten out read processing USB: safe_serial: reimplement read using generic framework USB: safe_serial: reimplement write using generic framework usb-storage: always print quirks USB: usb-storage: trivial debug improvements USB: oti6858: use port write fifo USB: oti6858: use kfifo to implement write buffering USB: cypress_m8: use kfifo to implement write buffering USB: cypress_m8: remove unused drain define ... Fix up conflicts (due to usb_buffer_alloc/free renaming) in drivers/input/tablet/acecad.c drivers/input/tablet/kbtab.c drivers/input/tablet/wacom_sys.c drivers/media/video/gspca/gspca.c sound/usb/usbaudio.c
2010-05-20USB: remove leftover references to udev->autosuspend_disabledAlan Stern
This patch (as1373) fixes a couple of drivers outside the USB subtree. Devices are now disabled or enabled for autosuspend by calling a core function instead of setting a flag. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20wimax/i2400m: fix bad race condition check in RX pathInaky Perez-Gonzalez
The i2400m->rx_roq data structure is protected against race conditions with a reference count (i2400m->rx_roq_refcount); the pointer can be read-referenced under the i2400m->rx_lock spinlock. The code in i2400m_rx_edata() wasn't properly following access protocol, performing an invalid check on i2400m->rx_roq (which is cleared to NULL when the refcount drops to zero). As such, it was missing to detect when the data structure is no longer valid and oopsing with a NULL pointer dereference. This commit fixes said check by verifying, under the rx_lock spinlock, that i2400m->rx_roq is non-NULL and then increasing the reference count before dropping the spinlock. Signed-off-by: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
2010-05-17drivers/net: remove useless semicolonsJoe Perches
switch and while statements don't need semicolons at end of statement [ Fixup minor conflicts with recent wimax merge... -DaveM ] Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-15Merge branch 'master' of ↵David S. Miller
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-11wimax/i2400m: driver defaults to firmware v1.5 for i6x60 devicesInaky Perez-Gonzalez
Firmware is available in the linux-firmware package. Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com>
2010-05-11wimax/i2400m: driver defaults to firmware v1.5 for i5x50 devicesInaky Perez-Gonzalez
Updates the i2400m driver to default to firmware versions v1.5 for the Intel Wireless WiMAX Connection 5150 and 5350 devices. Firmware available in linux-firmware. Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com>
2010-05-11wimax/i2400m: Move module params to other file so they can be staticPrasanna S Panchamukhi
This patch moves the module parameters to the file where they can be avoided to be global and allow them to be static. The module param : idle_mode_disabled and power_save_disabled are moved from driver.c to control.c. Also these module parameters are declared to be static as they are not required to be global anymore. The module param : rx_reorder_disabled is moved from driver.c file to rx.c file. Also this parameter is declated as static as it is not required to be global anymore. Signed-off-by: Prasanna S Panchamukhi<prasannax.s.panchamukhi@intel.com>
2010-05-11wimax: wimax_msg_alloc() returns ERR_PTR not nullDan Carpenter
wimax_msg_alloc() returns an ERR_PTR and not null. I changed it to test for ERR_PTR instead of null. I also added a check in front of the kfree() because kfree() can handle null but not ERR_PTR. Signed-off-by: Dan Carpenter <error27@gmail.com>
2010-05-11wimax/i2400m: USB specific TX queue's minimum buffer room required for new ↵Prasanna S. Panchamukhi
message This patch specifies the TX queue's buffer room required by the USB bus driver while allocating header space for a new message. Please refer the documentation in the code. Signed-off-by: Prasanna S. Panchamukhi <prasannax.s.panchamukhi@intel.com>
2010-05-11wimax/i2400m: SDIO specific TX queue's minimum buffer room for new messagePrasanna S. Panchamukhi
This patch specifies the TX queue's minimum buffer room required to accommodate one smallest SDIO payload. Please refer the documentation in the code. Signed-off-by: Prasanna S. Panchamukhi <prasannax.s.panchamukhi@intel.com>
2010-05-11wimax/i2400m: reserve additional space in the TX queue's buffer while ↵Prasanna S. Panchamukhi
allocating space for a new message header Increase the possibilities of including at least one payload by reserving some additional space in the TX queue while allocating TX queue's space for new message header. Please refer the documentation in the code for details. Signed-off-by: Prasanna S. Panchamukhi <prasannax.s.panchamukhi@intel.com>
2010-05-11wimax/i2400m: fix incorrect handling of type 2 and 3 RX messagesPrasanna S. Panchamukhi
According to Intel Wimax i3200, i5x50 and i6x60 device specification documents, the host driver must not reset the device if the normalized sequence numbers are greater than 1023 for type 2 and type 3 RX messages. This patch removes the code that incorrectly used to reset the device. Signed-off-by: Prasanna S. Panchamukhi <prasannax.s.panchamukhi@intel.com>
2010-05-11wimax i2400m: fix race condition while accessing rx_roq by using kref countPrasanna S. Panchamukhi
This patch fixes the race condition when one thread tries to destroy the memory allocated for rx_roq, while another thread still happen to access rx_roq. Such a race condition occurs when i2400m-sdio kernel module gets unloaded, destroying the memory allocated for rx_roq while rx_roq is accessed by i2400m_rx_edata(), as explained below: $thread1 $thread2 $ void i2400m_rx_edata() $ $Access rx_roq[] $ $roq = &i2400m->rx_roq[ro_cin] $ $ i2400m_roq_[reset/queue/update_ws] $ $ $ void i2400m_rx_release(); $ $kfree(rx->roq); $ $rx->roq = NULL; $Oops! rx_roq is NULL This patch fixes the race condition using refcount approach. Signed-off-by: Prasanna S. Panchamukhi <prasannax.s.panchamukhi@intel.com>
2010-05-11wimax/i2400m: increase tx queue length from 5 to 20 [v1]Prasanna S. Panchamukhi
This patch increases the tx_queue_len to 20 so as to minimize the jitter in the throughput. Signed-off-by: Prasanna S. Panchamukhi <prasannax.s.panchamukhi@intel.com>
2010-05-11wimax/i2400m: fix system freeze caused by an infinite loop [v1]Prasanna S. Panchamukhi
This patch fixes an infinite loop caused by i2400m_tx_fifo_push() due to a corner case where there is no tail space in the TX FIFO. Please refer the documentation in the code for details. Signed-off-by: Prasanna S. Panchamukhi <prasannax.s.panchamukhi@intel.com>
2010-05-11wimax/i2400m: modify i2400m_tx_fifo_push() to check for head room space in ↵Prasanna S. Panchamukhi
the TX FIFO [v1] This fixes i2400m_tx_fifo_push(); the check for having enough space in the TX FIFO's tail was obscure and broken in certain corner cases. The new check works in all cases and is way clearer. Please refer the documentation in the code for details. Signed-off-by: Prasanna S. Panchamukhi <prasannax.s.panchamukhi@intel.com>
2010-05-11wimax/i2400m: fix BUILD_BUG_ON() to use the maximum message size constant [v1]Prasanna S. Panchamukhi
The older method of computing the maximum PDU size relied on a method that doesn't work when we prop the maximum number of payloads up to the physical limit, and thus we kill the whole computation and just verify that the constants are congruent. Signed-off-by: Prasanna S. Panchamukhi <prasannax.s.panchamukhi@intel.com>
2010-05-11wimax/i2400m: limit the message size upto 16KiB [v1]Prasanna S. Panchamukhi
According to Intel Wimax i3200, i5x50 and i6x50 specification documents, the maximum size of each TX message can be upto 16KiB. This patch modifies the i2400m_tx() routine to check that the message size does not exceed the 16KiB limit. Please refer the documentation in the code for details. Signed-off-by: Prasanna S. Panchamukhi <prasannax.s.panchamukhi@intel.com>
