path: root/drivers/net/wireless/Makefile
2015-11-18ath: unify Kconfig with other vendorsKalle Valo
Change menuconfig to config to keep the Kconfig entries unified. Part of reorganising wireless drivers directory and Kconfig. Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2015-11-18ti: unify Kconfig with other vendorsKalle Valo
Rename WL_TI to WLAN_VENDOR_TI to match with other vendor configs and make sure that it's enabled by default in new configs. Convert menuconfigs to regular configs to unify the wireless drivers menuconfig. Part of reorganising wireless drivers directory and Kconfig. Also remove WLCORE dependency to WL_TI. It should not be needed as WLCORE is already under if WLAN_VENDOR_TI. Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2015-11-18mediatek: unify Kconfig with other vendorsKalle Valo
2015-11-18rt2x00: move under ralink vendor directoryKalle Valo
2015-11-18rsi: add vendor Kconfig entryKalle Valo
2015-11-18realtek: create separate Kconfig fileKalle Valo
Add new a Kconfig file and a vendor config for realtek. Also update MAINTAINERS which we missed to do when earlier moving rtlwifi. Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2015-11-18prism54: move under intersil vendor directoryKalle Valo
2015-11-18orinoco: move under intersil vendor directoryKalle Valo
2015-11-18p54: move under intersil vendor directoryKalle Valo
2015-11-18hostap: move under intersil vendor directoryKalle Valo
2015-11-18zd1211rw: move under zydas vendor directoryKalle Valo
2015-11-18zd1201: move under zydas vendor directoryKalle Valo
2015-11-18mwl8k: move under marvell vendor directoryKalle Valo
2015-11-18mwifiex: move under marvell vendor directoryKalle Valo
2015-11-18libertas_tf: move under marvell vendor directoryKalle Valo
2015-11-18libertas: move under marvell vendor directoryKalle Valo
2015-11-18iwlwifi: move under intel vendor directoryKalle Valo
2015-11-18iwlegacy: move under intel directoryKalle Valo
2015-11-18ipw2x00: move under intel vendor directoryKalle Valo
2015-11-18cw1200: move under st vendor directoryKalle Valo
2015-11-18brcm80211: move under broadcom vendor directoryKalle Valo
Part of reorganising wireless drivers directory and Kconfig. Note that I had to edit Makefiles from subdirectories to use the new location. Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2015-11-18b43legacy: move under broadcom vendor directoryKalle Valo
2015-11-18b43: move under broadcom vendor directoryKalle Valo
2015-11-18atmel: move under atmel vendor directoryKalle Valo
2015-11-18airo: move under cisco vendor directoryKalle Valo
2015-11-17adm80211: move under admtek vendor directoryKalle Valo
2015-10-14rtlwifi: rtl818x: Move drivers into new realtek directoryLarry Finger
Now that a new mac80211-based driver for Realtek devices has been submitted, it is time to reorganize the directories. Rather than having directories rtlwifi and rtl818x be in drivers/net/wireless/, they will now be in drivers/net/wireless/realtek/. This change simplifies the directory structure, but does not result in any configuration changes that are visable to the user. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2015-05-28add mt7601u driverJakub Kicinski
Add support for the simplest of MediaTek Wi-Fi devices - MT7601U. It is a single stream bgn chip with no bells or whistles. This driver is partially based on Felix's mt76 but IMHO it doesn't make sense to merge the two right now because MT7601U is a design somewhere between old Ralink devices and new Mediatek chips. There wouldn't be all that much code sharing with the devices mt76 supports. Situation may obviously change when someone decides to extend m76 with support for the more recent USB dongles. The driver supports only station mode. I'm hoping to add AP support when time allows. This driver sat on GitHub for quite a while and got some testing there: http://github.com/kuba-moo/mt7601u Signed-off-by: Jakub Kicinski <kubakici@wp.pl> Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2014-03-17rsi: Add RS9113 wireless driverFariya Fatima
This patch adds the Redpine Signals' 91x wireless driver. Signed-off-by: Fariya Fatima <fariyaf@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-05-29cw1200: add driver for the ST-E CW1100 & CW1200 WLAN chipsetsSolomon Peachy
Signed-off-by: Solomon Peachy <pizza@shaftnet.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-12-17wireless: fix Atheros drivers compilationVladimir Kondratiev
Bug introduced in commit: wireless: allow Atheros card to not depend on ath.ko Commit in question changed CONFIG_ATH_COMMON to CONFIG_ATH_CARDS as "Atheros card" indication in drivers/net/wireless/ath/Kconfig but it is used also by drivers/net/wireless/Makefile If there are only Atheros cards that do not require ATH_COMMON, whole Makefile for Atheros cards was not executed; and as result, driver won't compile in this case. Change in CONFIG_ option name should be reflected in the drivers/net/wireless/Makefile Signed-off-by: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com> Tested-by: Kalle Valo <kvalo@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-07-10iwmc3200wifi: remove driver for unavailable hardwareJohn W. Linville
This hardware never became available to normal humans. Leaving this driver imposes unwelcome maintenance costs for no clear benefit. Signed-off-by: John W. Linville <linville@tuxdriver.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com>
2012-04-12wireless/wl12xx/wl1251: move TI WLAN modules to a common ti subdirectoryLuciano Coelho
Move wl12xx and wl1251 modules into a new drivers/net/wireless/ti directory. Add a TI WLAN Kconfig option and Makefile to support this change. Signed-off-by: Luciano Coelho <coelho@ti.com> Cc: John W. Linville <linville@tuxdriver.com>
2011-11-15iwlegacy: rename remaining IWLs to ILsStanislaw Gruszka
Also rename config names IWLWIFI_LEGACY to IWLEGACY Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
2011-11-09wireless: cleanup brcm80211 bits in drivers/net/wireless/MakefileJohn W. Linville
2011-10-11net: wireless: add brcm80211 driversArend van Spriel
Add the brcm80211 tree to drivers/net/wireless, and disable the version that's in drivers/staging. This version includes the sources currently in staging, plus any changes that have been sent out for review. Sources in staging will be deleted in a followup patch. Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-03iwlagn: rename iwlagn module iwlwifi and alias to iwlagn.Don Fry
Rename the iwlagn module as iwlwifi in preparation for future changes. Add an alias to iwlagn for backward compatibility. Signed-off-by: Don Fry <donald.h.fry@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30wireless: mwifiex: initial commit for Marvell mwifiex driverBing Zhao
This driver adds WiFi support for Marvell 802.11n based chipsets with SDIO interface. Currently only SD8787 is supported. More chipsets will be supported later. drivers/net/wireless/mwifiex/ Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Kiran Divekar <dkiran@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: Marc Yang <yangyang@marvell.com> Signed-off-by: Ramesh Radhakrishnan <rramesh@marvell.com> Signed-off-by: Frank Huang <frankh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-23rtlwifi: Fix build when RTL8192CU is selected, but RTL8192CE is notWilly Tarreau
The wireless Makefile does not build rtlwifi for rtl8192cu unless rtl8192ce is selected. Signed-off-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-21iwlwifi: split the drivers for agn and legacy devices 3945/4965Wey-Yi Guy
Intel WiFi devices 3945 and 4965 now have their own driver in the folder drivers/net/wireless/iwlegacy Add support to build these drivers independently of the driver for AGN devices. Selecting the 3945 builds iwl3945.ko and iwl_legacy.ko, and selecting the 4965 builds iwl4965.ko and iwl_legacy.ko. iwl-legacy.ko contains code shared between both devices. The 3945 is an ABG/BG device, with no support for 802.11n. The 4965 is a 2x3 ABGN device. Signed-off-by: Meenakshi Venkataraman <meenakshi.venkataraman@intel.com> Acked-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-02-21Revert "iwlwifi: split the drivers for agn and legacy devices 3945/4965"Wey-Yi Guy
This reverts commit aa833c4b1a928b8d3c4fcc2faaa0d6b81ea02b56.
2010-12-15rtl8192ce: Add new driverLarry Finger
2010-10-11wl1251: move to it's own directoryKalle Valo
wl1271 driver is under heavy development but on the other hand the older wl1251 driver is currently considered more as a legacy driver. To make it easier to develop wl1271 features move wl1251 to it's own directory, drivers/net/wireless/wl1251. There are no functional changes, only moving of files. One regression is that Kconfig won't be updated automatically and user needs to enable wl1251 manually with an older config file. Signed-off-by: Kalle Valo <kvalo@adurom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-09-28wl12xx: fix separate-object-folder buildsJohn W. Linville
Make this go away (happens when building with a separate object directory): Assembler messages: Fatal error: can't create drivers/net/wireless/wl12xx/.tmp_wl12xx_platform_data.o: No such file or directory drivers/net/wireless/wl12xx/wl12xx_platform_data.c: In function 'wl12xx_get_platform_data': drivers/net/wireless/wl12xx/wl12xx_platform_data.c:28: error: cannot open drivers/net/wireless/wl12xx/.tmp_wl12xx_platform_data.gcno drivers/net/wireless/wl12xx/wl12xx_platform_data.c:28: confused by earlier errors, bailing out Signed-off-by: John W. Linville <linville@tuxdriver.com> Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
2010-09-21wl12xx: add platform data passing supportOhad Ben-Cohen
Add a simple mechanism to pass platform data to the SDIO instances of wl12xx. This way there is no confusion over who owns the 'embedded data', typechecking is preserved, and no possibility for the wrong driver to pick up the data. Originally proposed by Russell King. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-30netwave: move driver to stagingJohn W. Linville
Move the netwave driver to drivers/staging. This is another pre-802.11 driver that has seen virtually no non-API-fixup activity in years, and for which no active hardware is likely to still exist. This driver represents unnecessary ongoing maintenance for no clear benefit. This patch brought to you by the "hacking" session at the 2009 Kernel Summit in Tokyo, Japan... Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-30wavelan: move driver to stagingJohn W. Linville
Move the wavelan driver to drivers/staging. This is another pre-802.11 driver that has seen virtually no non-API-fixup activity in years, and for which no active hardware is likely to still exist. This driver represents unnecessary ongoing maintenance for no clear benefit. This patch brought to you by the "hacking" session at the 2009 Kernel Summit in Tokyo, Japan... Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-30arlan: move driver to stagingJohn W. Linville
Move the arlan driver to drivers/staging. This is another pre-802.11 driver that has seen virtually no non-API-fixup activity in years, and for which no active hardware is likely to still exist. This driver represents unnecessary ongoing maintenance for no clear benefit. This patch brought to you by the "hacking" session at the 2009 Kernel Summit in Tokyo, Japan... Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-30strip: move driver to stagingJohn W. Linville
Move the strip ("Starmode Radio IP") driver to drivers/staging. For several years this driver has only seen API "bombing-run" changes, and few people ever had the hardware. This driver represents unnecessary ongoing maintenance for no clear benefit. This patch brought to you by the "hacking" session at the 2009 Kernel Summit in Tokyo, Japan... Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
