* remove interrupt.g inclusion from netdevice.h -- not needed
* fixup fallout, add interrupt.h and hardirq.h back where needed.
The return value of the tx operation is commonly
misused by drivers, leading to errors. All drivers
will drop frames if they fail to TX the frame, and
they must also properly manage the queues (if they
didn't, mac80211 would already warn).
Removing the ability for drivers to return a BUSY
value also allows significant cleanups of the TX
TX handling code in mac80211.
Note that this also fixes a bug in ath9k_htc, the
old "return -1" there was wrong.
Tested-by: Sedat Dilek <sedat.dilek@googlemail.com> [ath5k]
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> [rt2x00]
Acked-by: Larry Finger <Larry.Finger@lwfinger.net> [b43, rtl8187, rtlwifi]
Acked-by: Luciano Coelho <coelho@ti.com> [wl12xx]
Commit c96c31e499b70964cfc88744046c998bb710e4b8
"(drivers/net/wireless: Use wiphy_<level>)"
inadvertently changed some upper case words to
lower case. Restore the original case.
Standardize the logging macros used.
We must free priv->eeprom allocated in adm8211_read_eeprom().
Signed-off-by: Kulikov Vasiliy <segooon@gmail.com>
Acked-by: Luis R. Rodriguez <lrodriguez@atheros.com>
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
get_tx_stats() will be removed from mac80211.
Compile-tested only.
Cc: Michael Wu <flamingice@sourmilk.net>
Signed-off-by: Kalle Valo <kalle.valo@iki.fi>
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section
in every case.
All its members (vif, mac_addr, type) are now available
in the vif struct directly, so we can pass that instead
of the conf struct. I generated this patch (except the
mac80211 and header file changes) with this semantic
patch:
identifier conf, fn, hw;
type tp;
tp fn(struct ieee80211_hw *hw,
-struct ieee80211_if_init_conf *conf)
+struct ieee80211_vif *vif)
-conf->type
+vif->type
-conf->mac_addr
+vif->addr
-conf->vif
+vif
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
In this file, function names are otherwise used as pointers without &.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
@r@
identifier f;
f(...) { ... }
identifier r.f;
- &f
+ f
// </smpl>
Over time, a whole bunch of drivers have come up
with their own scheme to delay the configure_filter
operation to a workqueue. To be able to simplify
things, allow configure_filter to sleep, and add
a new prepare_multicast callback that drivers that
need the multicast address list implement. This new
callback must be atomic, but most drivers either
don't care or just calculate a hash which can be
done atomically and then uploaded to the hardware
non-atomically.
A cursory look suggests that at76c50x-usb, ar9170,
mwl8k (which is actually very broken now), rt2x00,
wl1251, wl1271 and zd1211 should make use of this
new capability.
mac80211 drivers do not need to stop the software queues
or call their own stop() callback upon suspend as we do it
for drivers. Equally drivers don't have to call their own
start() or start the queues as mac80211 will do it for us.
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
Within mac80211, we often need to copy the rx status into
skb->cb. This is wasteful, as drivers could be building it
in there to start with. This patch changes the API so that
drivers are expected to pass the RX status in skb->cb, now
accessible as IEEE80211_SKB_RXCB(skb). It also updates all
drivers to pass the rx status in there, but only by making
them memcpy() it into place before the call to the receive
function (ieee80211_rx(_irqsafe)). Each driver can now be
optimised on its own schedule.
The config_interface method is a little strange, it contains the
BSSID and beacon updates, while bss_info_changed contains most
other BSS information for each interface. This patch removes
config_interface and rolls all the information it previously
passed to drivers into bss_info_changed.
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)
Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com>
Since adm8211 currently doesn't implement IBSS mode anyway,
it can't be using the SSID. And if/when it does implement
IBSS mode, we'll have to see how to make it beacon anyway.
So after the previous changes we were still unhappy with how
convoluted the API is and decided to make things simpler for
everybody. This completely changes the rate control API, now
taking into account 802.11n with MCS rates and more control,
most drivers don't support that though.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
This makes mac80211 notify the driver which configuration
actually changed, e.g. channel etc.
No driver changes, this is just plumbing, driver authors are
expected to act on this if they want to.
Also remove the HW CONFIG debug printk, it's incorrect, often
we configure something else.
This converts pretty much everything to print_mac. There were
a few things that had conflicts which I have just dropped for
now, no harm done.
I've built an allyesconfig with this and looked at the files
that weren't built very carefully, but it's a huge patch.
There's really no reason for mac80211 to be using its
own interface type defines. Use the nl80211 types and
simplify the configuration code a bit: there's no need
to translate them any more now.
It is obviously good for userspace to know up front which
interface modes a given piece of hardware might support (even
if adding such an interface might fail later because of
concurrency issues), so let's make cfg80211 aware of that.
For good measure, disallow adding interfaces in all other
modes so drivers don't forget to announce support for one mode
when they add it.
Signed-off-by: Stephen Blackheath <tramp.enshrine.stephen@blacksapphire.com>
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com>
Removes now unused fc local var and uses the new ieee80211_hdrlen
which directly uses the le16 frame control value.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
This patch converts mac80211 and all drivers to have transmit
information and status in skb->cb rather than allocating extra
memory for it and copying all the data around. To make it fit,
a union is used where only data that is necessary for all steps
is kept outside of the union.
A number of fixes were done by Ivo, as well as the rt2x00 part
of this patch.
This patch modifies struct ieee80211_tx_control to give band
info and the rate index (instead of rate pointers) to drivers.
This mostly serves to reduce the TX control structure size to
make it fit into skb->cb so that the fragmentation code can
put it there and we can think about passing it to drivers that
way in the future.
The rt2x00 driver update was done by Ivo, thanks.
Having drivers start queues is just confusing, their ->start()
callback can block and do whatever is necessary, so let mac80211
start queues and have drivers wake queues when necessary (to get
packets flowing again right away.)
trying to clean up the signal/noise code. the previous code in mac80211 had
confusing names for the related variables, did not have much definition of
what units of signal and noise were provided and used implicit mechanisms from
the wireless extensions.
this patch introduces hardware capability flags to let the hardware specify
clearly if it can provide signal and noise level values and which units it can
provide. this also anticipates possible new units like RCPI in the future.
for signal:
IEEE80211_HW_SIGNAL_UNSPEC - unspecified, unknown, hw specific
IEEE80211_HW_SIGNAL_DB - dB difference to unspecified reference point
IEEE80211_HW_SIGNAL_DBM - dBm, difference to 1mW
for noise we currently only have dBm:
IEEE80211_HW_NOISE_DBM - dBm, difference to 1mW
if IEEE80211_HW_SIGNAL_UNSPEC or IEEE80211_HW_SIGNAL_DB is used the driver has
to provide the maximum value (max_signal) it reports in order for applications
to make sense of the signal values.
i tried my best to find out for each driver what it can provide and update it
but i'm not sure (?) for some of them and used the more conservative guess in
doubt. this can be fixed easily after this patch has been merged by changing
the hardware flags of the driver.
DRIVER SIGNAL MAX NOISE QUAL
adm8211 unspec(?) 100 n/a missing
at76_usb unspec(?) (?) unused missing
ath5k dBm dBm percent rssi
b43legacy dBm dBm percent jssi(?)
b43 dBm dBm percent jssi(?)
iwl-3945 dBm dBm percent snr+more
iwl-4965 dBm dBm percent snr+more
p54 unspec 127 n/a missing
rt2x00 dBm n/a percent rssi+tx/rx frame success
rt2400 dBm n/a
rt2500pci dBm n/a
rt2500usb dBm n/a
rt61pci dBm n/a
rt73usb dBm n/a
rtl8180 unspec(?) 65 n/a (?)
rtl8187 unspec(?) 65 (?) noise(?)
zd1211 dB(?) 100 n/a percent
drivers/net/wireless/ath5k/base.c: Changes-licensed-under: 3-Clause-BSD
Signed-off-by: Bruno Randolf <br1@einfach.org>
The callback takes a ieee80211_tx_queue_stats with a contained
array of ieee80211_tx_queue_stats_data, remove the former, rename
the latter to ieee80211_tx_queue_stats and make tx_stats() take
the array directly.
Remove some commented-out code from adm8211.
Signed-off-by: Pavel Machek <pavel@suse.cz>
Insert a missing band assignment.
Both of these seem to be actual errors, the first is just wrong
and the second is my mistake introduced by the cfg80211 API
update.
This patch creates new cfg80211 wiphy API for channel and bitrate
registration and converts mac80211 and drivers to the new API. The
old mac80211 API is completely ripped out. All drivers (except ath5k)
are updated to the new API, in many cases I expect that optimisations
can be done.
Along with the regulatory code I've also ripped out the
IEEE80211_HW_DEFAULT_REG_DOMAIN_CONFIGURED flag, I believe it to be
unnecessary if the hardware simply gives us whatever channels it wants
to support and we then enable/disable them as required, which is pretty
much required for travelling.
Additionally, the patch adds proper "basic" rate handling for STA
mode interface, AP mode interface will have to have new API added
to allow userspace to set the basic rate set, currently it'll be
empty... However, the basic rate handling will need to be moved to
the BSS conf stuff.
I do expect there to be bugs in this, especially wrt. transmit
power handling where I'm basically clueless about how it should work.
This patch gets rid of the if_id stuff where possible in favour of
a new per-virtual-interface structure "struct ieee80211_vif". This
structure is located at the end of the per-interface structure and
contains a variable length driver-use data area.
This has two advantages:
* removes the need to look up interfaces by if_id, this is better
for working with network namespaces and performance
* allows drivers to store and retrieve per-interface data without
having to allocate own lists/hash tables
Since I cannot convince the lazy driver authors (hello Michael)
to stop (ab)using the MGMT interface type internally in their
drivers, this patch introduces a new _INVALID type especially
for their use and changes all affected drivers to use it.
Interface up/down detection was incorrectly changed during the filter API
update.
Signed-off-by: Michael Wu <flamingice@sourmilk.net>
ieee80211_tx_status_irqsafe can handle the freeing of all TXed frames.
Also, set excessive_retries for failed frames.
No need to load the revision ourselves anymore.
No need to pollute dmesg with copyright info.
The mac address write is broken for big endian and the bssid write can be
simplified. This patch does both.
Looping in the interrupt handler is unnecessary.
Drivers are currently supposed to keep track of monitor
interfaces if they allow so-called "hard" monitor, and
they are also supposed to keep track of multicast etc.
This patch changes that, replaces the set_multicast_list()
callback with a new configure_filter() callback that takes
filter flags (FIF_*) instead of interface flags (IFF_*).
For a driver, this means it should open the filter as much
as necessary to get all frames requested by the filter flags.
Accordingly, the filter flags are named "positively", e.g.
FIF_ALLMULTI.
Multicast filtering is a bit special in that drivers that
have no multicast address filters need to allow multicast
frames through when either the FIF_ALLMULTI flag is set or
when the mc_count value is positive.
At the same time, drivers are no longer notified about
monitor interfaces at all, this means they now need to
implement the start() and stop() callbacks and the new
change_filter_flags() callback. Also, the start()/stop()
ordering changed, start() is now called *before* any
add_interface() as it really should be, and stop() after
any remove_interface().
The patch also changes the behaviour of setting the bssid
to multicast for scanning when IEEE80211_HW_NO_PROBE_FILTERING
is set; the IEEE80211_HW_NO_PROBE_FILTERING flag is removed
and the filter flag FIF_BCN_PRBRESP_PROMISC introduced.
This is a lot more efficient for hardware like b43 that
supports it and other hardware can still set the BSSID
to all-ones.
Driver modifications by Johannes Berg (b43 & iwlwifi), Michael Wu
(rtl8187, adm8211, and p54), Larry Finger (b43legacy), and
Ivo van Doorn (rt2x00).
This is nicer than the MAC_FMT stuff.
This patch adds a mac80211 wireless driver for ADMtek ADM8211 based
wireless cards.
