path: root/drivers/net/wireless/airo.c
2006-01-17airo: Off-by-one channel fixJavier Achirica
2006-01-16[PATCH] drivers/net/wireless: correct reported ssid lengthsDan Williams
ESSIDs can technically include NULL characters. Drivers should not be adjusting the length of the ESSID before reporting it in their SIOCGIWESSID handlers. Breaks stuff like wpa_supplicant. Note that ipw drivers, which seem to currently be the "most correct", don't have this problem. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2005-12-01Merge branch 'upstream-fixes'Jeff Garzik
2005-12-01[PATCH] airo.c: add support for IW_ENCODE_TEMP (i.e. xsupplicant)Dan Streetman
Hello Jeff, this patch changes causes the airo driver to not reset the card when a temporary WEP key is set, when the IW_ENCODE_TEMP flag is used. This is needed for xsupplicant as 802.1x, LEAP, etc. change WEP keys frequently after authentication and resetting the card causes infinite reauthentication. Javier and Jean agree with the patch, Javier suggested I send this to you, can you apply this? Thanks. Signed-off-by: Dan Streetman <ddstreet@ieee.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-12-01[wireless airo] reset card in initMatthieu CASTET
without this patch after an rmmod, modprobe the card won't work anymore until the next reboot. This patch seem safe to apply for all cards as the bsd driver already do that. I had to add a timeout because strange things happen (issuecommand will fail) if the card is already reseted (after a reboot). PS : it seems there are missing reset when leaving monitor mode... Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr>
2005-11-07Merge git://git.tuxdriver.com/git/netdev-jwlJeff Garzik
2005-11-07[PATCH] wireless net: Conversions of kmalloc/memset to kzallocPanagiotis Issaris
More conversions of kmalloc/memset to kzalloc Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2005-11-05[PATCH] airo.c/airo_cs.c: correct prototypesAdrian Bunk
This patch creates a file airo.h containing prototypes of the global functions in airo.c used by airo_cs.c . If you got strange problems with either airo_cs devices or in any other completely unrelated part of the kernel shortly or long after a airo_cs device was detected by the kernel, this might have been caused by the fact that caller and callee disagreed regarding the size of the first argument to init_airo_card()... Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2005-11-05[PATCH] drivers/net/wireless/airo.c unsigned comparasonGabriel A. Devenyi
fid is declared as a u32 (unsigned int), and then a few lines later, it is checked for a value < 0, which is clearly useless. In the two locations this function is used, in one it is *explicitly* given a negative number, which would be ignored with the current definition. Thanks to LinuxICC (http://linuxicc.sf.net). Signed-off-by: Gabriel A. Devenyi <ace@staticwave.ca> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-30[CRYPTO] Simplify one-member scatterlist expressionsHerbert Xu
This patch rewrites various occurences of &sg[0] where sg is an array of length one to simply sg. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2005-10-30[PATCH] Use sg_set_buf/sg_init_one where applicableDavid Hardeman
This patch uses sg_set_buf/sg_init_one in some places where it was duplicated. Signed-off-by: David Hardeman <david@2gen.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2005-10-28drivers/net: Remove pointless checks for NULL prior to calling kfree()Jesper Juhl
2005-10-04airo: fix resumeMichal Schmidt
Cisco Aironet doesn't resume properly from swsusp, because the resume method confuses a PM_EVENT_* for a PCI power state. It thinks that it is resuming from PCI_D1 and doesn't do the necessary initialization of the card. Signed-off-by: Michal Schmidt <xschmi00@stud.feec.vutbr.cz>
2005-09-24[wireless airo] remove needed dma_addr_t obfuscationJeff Garzik
Fixes bus address truncation bug for certain configs.
2005-09-24Remove WIRELESS_EXT ifdefs from several wireless drivers.Jeff Garzik
2005-09-14[PATCH] airo : fix channel number in scanmatthieu castet
this patch display the correct channel number with iwlist scan Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-07[wireless] build fixes after merging WE-19Jeff Garzik
2005-09-06[PATCH] airo : WE-19 supportJean Tourrilhes
Dan Williams already included most parts of my WE-19 patch for the airo driver in the kernel. There was just a few bits he could not do because WE-19 itself was not in the kernel. Those are the missing bits. Tested with 2.6.13 (with real HW). Signed-off-by: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-05Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Linus Torvalds
2005-09-05[PATCH] swsusp: switch pm_message_t to structPavel Machek
This adds type-checking to pm_message_t, so that people can't confuse it with int or u32. It also allows us to fix "disk yoyo" during suspend (disk spinning down/up/down). [We've tried that before; since that cpufreq problems were fixed and I've tried make allyes config and fixed resulting damage.] Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Alexander Nyberg <alexn@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-01[CRYPTO]: crypto_free_tfm() callers no longer need to check for NULLJesper Juhl
Since the patch to add a NULL short-circuit to crypto_free_tfm() went in, there's no longer any need for callers of that function to check for NULL. This patch removes the redundant NULL checks and also a few similar checks for NULL before calls to kfree() that I ran into while doing the crypto_free_tfm bits. I've succesfuly compile tested this patch, and a kernel with the patch applied boots and runs just fine. When I posted the patch to LKML (and other lists/people on Cc) it drew the following comments : J. Bruce Fields commented "I've no problem with the auth_gss or nfsv4 bits.--b." Sridhar Samudrala said "sctp change looks fine." Herbert Xu signed off on the patch. So, I guess this is ready to be dropped into -mm and eventually mainline. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-01[CRYPTO]: Use CRYPTO_TFM_REQ_MAY_SLEEP where appropriateHerbert Xu
This patch goes through the current users of the crypto layer and sets CRYPTO_TFM_REQ_MAY_SLEEP at crypto_alloc_tfm() where all crypto operations are performed in process context. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-30/spare/repo/netdev-2.6 branch 'ieee80211'Jeff Garzik
2005-07-27[PATCH] clean up inline static vs static inlineJesper Juhl
`gcc -W' likes to complain if the static keyword is not at the beginning of the declaration. This patch fixes all remaining occurrences of "inline static" up with "static inline" in the entire kernel tree (140 occurrences in 47 files). While making this change I came across a few lines with trailing whitespace that I also fixed up, I have also added or removed a blank line or two here and there, but there are no functional changes in the patch. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-13Merge /spare/repo/netdev-2.6 branch 'ieee80211'Jeff Garzik
2005-07-08[NET]: Transform skb_queue_len() binary tests into skb_queue_empty()David S. Miller
This is part of the grand scheme to eliminate the qlen member of skb_queue_head, and subsequently remove the 'list' member of sk_buff. Most users of skb_queue_len() want to know if the queue is empty or not, and that's trivially done with skb_queue_empty() which doesn't use the skb_queue_head->qlen member and instead uses the queue list emptyness as the test. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-27Merge /spare/repo/netdev-2.6 branch 'ieee80211'Jeff Garzik
2005-06-26[PATCH] wireless: char* -> char[] conversion in airo.cDomen Puncer
This conversion makes code from line 7101 right: if (copy_to_user(com.data, swversion, sizeof(swversion))) size output (before, after): 55416 2228 160 57804 e1cc drivers/net/wireless/airo.o 55412 2228 160 57800 e1c8 drivers/net/wireless/airo.o more outputs from Alexey Dobriyan: 2.95.3: text data bss dec hex filename before 51118 2156 160 53434 d0ba drivers/net/wireless/airo.o after 51118 2156 160 53434 d0ba drivers/net/wireless/airo.o 3.3.5-20050130: before 46999 2156 160 49315 c0a3 drivers/net/wireless/airo.o after 46994 2156 160 49310 c09e drivers/net/wireless/airo.o 4.1.0-20050522: before 45555 2220 160 47935 bb3f drivers/net/wireless/airo.o after 45550 2220 160 47930 bb3a drivers/net/wireless/airo.o Signed-off-by: Domen Puncer <domen@coderock.org>
2005-06-26Merge /spare/repo/netdev-2.6/ branch 'ieee80211'Jeff Garzik
2005-06-26[PATCH] fix int vs. pm_message_t confusion in airoPavel Machek
Fix int vs. pm_message_t confusion in airo. Should change no code. Signed-off-by: Pavel Machek <pavel@suse.cz> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-06-25[PATCH] Cleanup patch for process freezingChristoph Lameter
1. Establish a simple API for process freezing defined in linux/include/sched.h: frozen(process) Check for frozen process freezing(process) Check if a process is being frozen freeze(process) Tell a process to freeze (go to refrigerator) thaw_process(process) Restart process frozen_process(process) Process is frozen now 2. Remove all references to PF_FREEZE and PF_FROZEN from all kernel sources except sched.h 3. Fix numerous locations where try_to_freeze is manually done by a driver 4. Remove the argument that is no longer necessary from two function calls. 5. Some whitespace cleanup 6. Clear potential race in refrigerator (provides an open window of PF_FREEZE cleared before setting PF_FROZEN, recalc_sigpending does not check PF_FROZEN). This patch does not address the problem of freeze_processes() violating the rule that a task may only modify its own flags by setting PF_FREEZE. This is not clean in an SMP environment. freeze(process) is therefore not SMP safe! Signed-off-by: Christoph Lameter <christoph@lameter.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-27Automatic merge of /spare/repo/netdev-2.6 branch we18-ieee80211
2005-05-15[PATCH] wireless/airo: WEXT and quality correctionsDan Williams
This patch brings the airo driver into line with the current WEXT specification of signal quality. It also fixes the values used to determine signal quality and level for MPI & PCMCIA 350 cards. It turns out that BSSListRid.rssi was actually in dBm for 350 series cards, and that we can use the normalized signal strength reported by the card as our "quality" value, on a scale of 0 - 100. Since signal level values are in dBm for this driver, max_qual->level MUST be 0, as specified in the WEXT spec. This patch also uses the IW_QUAL constants new in WEXT version 17. Signed-off-by: Dan Williams <dcbw@redhat.com>
2005-05-12Add HostAP wireless driver.Jouni Malinen
Includes minor cleanups from Adrian Bunk <bunk@stusta.de>.
2005-04-16[PATCH] u32 vs. pm_message_t fixes for drivers/netPavel Machek
This fixes remaining u32s in drivers/ net. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
