path: root/drivers/net/wireless/arlan-proc.c
2008-03-24arlan: fix warning when PROC_FS=nJohn W. Linville
drivers/net/wireless/arlan-proc.c:1216: warning: 'arlan_root_table' defined but not used Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] dev->priv to netdev_priv(dev), for drivers/net/wirelessYoann Padioleau
Replacing accesses to dev->priv to netdev_priv(dev). The replacment is safe when netdev_priv is used to access a private structure that is right next to the net_device structure in memory. Cf http://groups.google.com/group/comp.os.linux.development.system/browse_thread/thread/de19321bcd94dbb8/0d74a4adcd6177bd This is the case when the net_device structure was allocated with a call to alloc_netdev or one of its derivative. Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: mcgrof@gmail.com Cc: linux-wireless@vger.kernel.org Cc: akpm@linux-foundation.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-02-14[PATCH] sysctl: remove insert_at_head from register_sysctlEric W. Biederman
The semantic effect of insert_at_head is that it would allow new registered sysctl entries to override existing sysctl entries of the same name. Which is pain for caching and the proc interface never implemented. I have done an audit and discovered that none of the current users of register_sysctl care as (excpet for directories) they do not register duplicate sysctl entries. So this patch simply removes the support for overriding existing entries in the sys_sysctl interface since no one uses it or cares and it makes future enhancments harder. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Neil Brown <neilb@suse.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jan Kara <jack@ucw.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: register the sysctl number used by the arlan driverEric W. Biederman
Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
