path: root/drivers/net/wireless/at76c50x-usb.c
2009-06-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/forcedeth.c
2009-05-29at76c50x-usb: avoid mutex deadlock in at76_dwork_hw_scanJohn W. Linville
http://bugzilla.kernel.org/show_bug.cgi?id=13312 at76_dwork_hw_scan holds a mutex while calling ieee80211_scan_completed, which then calls at76_config which needs the same mutex. This reworks the ordering to not hold the lock while calling ieee80211_scan_completed. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-06mac80211: unify config_interface and bss_info_changedJohannes Berg
The config_interface method is a little strange, it contains the BSSID and beacon updates, while bss_info_changed contains most other BSS information for each interface. This patch removes config_interface and rolls all the information it previously passed to drivers into bss_info_changed. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22cfg80211: introduce scan IE limit attributeJohannes Berg
This patch introduces a new attribute for a wiphy that tells userspace how long the information elements added to a probe request frame can be at most. It also updates the at76 to advertise that it cannot support that, and, for now until I can fix that, iwlwifi too. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-21Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/core/dev.c
2009-04-16at76c50x-usb: Add device ID for OQO model 01+Jamie Lentin
Add USB device ID for OQO 01+'s internal wireless LAN An OQO employee mentions the chip's true identity here:- ftp://ftp.oqo.com/unsupported/linux/OQOLinux.html Signed-off-by: Jamie Lentin <jm@lentin.co.uk> Acked-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-13at76c50x-usb: remove pointless conditional before kfree_skb()Wei Yongjun
Remove pointless conditional before kfree_skb(). Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-27at76c50x-usb: use dev_name() instead of struct device.bus_idKalle Valo
Stephen Rothwell reported that bus_id from struct device will be removed, use dev_name() instead. Signed-off-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27at76c50x-usb: add link to the TODO listKalle Valo
It's easier to have the TODO list in wiki, so add a link to the list. Signed-off-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27at76c50x-usb: additional disconnect fixesJason Andryuk
Additional attempts to fix Oops on disconnect, that appear to be successful. However, some may be extraneous. The cancel_delayed_work call is probably the most necessary. The device_unplugged check may not be necessary. del_timer_sync may not be necessary either, but the Oops I was receiving was related to timers. Hence the addition. Signed-off-by: Jason Andryuk <jandryuk@gmail.com> Signed-off-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27at76c50x-usb: clean up DMA on stackJason Andryuk
Cleanup dma on stack issues: - no DMA on stack - cleanup unclear endianness issue Corrected version of Oliver Neukum's original patch for at76_usb. Signed-off-by: Jason Andryuk <jandryuk@gmail.com> Signed-off-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27at76c50x-usb: fix oops on disconnectJason Andryuk
flush_workqueue needs to be called instead of the generic one and the associated functions need to be modified to prevent re-adding themselves to the workqueue. The rx_tasklet is also killed in the small (?) chance it is scheduled. Signed-off-by: Jason Andryuk <jandryuk@gmail.com> Signed-off-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27at76c50x-usb: convert at76_debug to an unsigned intJason Andryuk
at76_debug should be an unsigned int as it used as a bit field. In fact, modprobe fails when trying to set at76_debug's high bit. Signed-off-by: Jason Andryuk <jandryuk@gmail.com> Signed-off-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27at76c50x-usb: update to latest mac80211 hw scan apiJason Andryuk
With the latest mac80211 stack, the driver needs to be updated for cfg80211 scanning. I based the changes off of modifications for at76_usb found here: http://johannes.sipsolutions.net/patches/old/all/2008-09-19-13:35/020-cfg80211-scan.patch The trick was that max_signal also needs to be set to avoid a divide by zero Oops. I just guessed and used the value 100 for now. kvalo: handpicked the change from two different patches Signed-off-by: Jason Andryuk <jandryuk@gmail.com> Signed-off-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27at76c50x-usb: add driverKalle Valo
This is a driver for usb devices based on at76c50x chipset. This is a mac80211 port of the original at76_usb driver. Signed-off-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
