commit 315cee426f87658a6799815845788fde965ddaad upstream.
memcpy() call with "idata == NULL && ilen == 0" results in undefined
behavior in ar5523_cmd(). For example, NULL is passed in callchain
"ar5523_stat_work() -> ar5523_cmd_write() -> ar5523_cmd()". This patch
adds ilen check before memcpy() call in ar5523_cmd() to prevent an
undefined behavior.
Cc: Pontus Fuchs <pontus.fuchs@gmail.com>
Cc: Kalle Valo <kvalo@codeaurora.org>
Cc: David Laight <David.Laight@ACULAB.COM>
Cc: stable@vger.kernel.org
Signed-off-by: Denis Efremov <efremov@linux.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
usb_device_id are not supposed to change at runtime. All functions
working with usb_device_id provided by <linux/usb.h> work with
const usb_device_id. So mark the non-const structs as const.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions return void * and remove all the casts across
the tree, adding a (u8 *) cast only where the unsigned char pointer
was used directly, all done with the following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = { skb_push, __skb_push, skb_push_rcsum };
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
- fn(SKB, LEN)[0]
Note that the last part there converts from push(...)[0] to the
more idiomatic *(u8 *)push(...).
Set the NL80211_EXT_FEATURE_CQM_RSSI_LIST wiphy extended feature
wholesale in all mac80211-based drivers that do not set the
IEEE80211_VIF_BEACON_FILTER flags on their interfaces. mac80211 will
be processing supplied RSSI values in ieee80211_rx_mgmt_beacon and
will detect when the thresholds set by
ieee80211_set_cqm_rssi_range_config are crossed. Remaining (few)
drivers need code to enable the firmware to monitor the thresholds.
This is mostly only compile-tested.
Signed-off-by: Andrew Zaborowski <andrew.zaborowski@intel.com>
kmalloc will print enough information in case of failure.
Signed-off-by: Wolfram Sang <wsa-dev@sang-engineering.com>
This enum is already perfectly aliased to enum nl80211_band, and
the only reason for it is that we get IEEE80211_NUM_BANDS out of
it. There's no really good reason to not declare the number of
bands in nl80211 though, so do that and remove the cfg80211 one.
As we're running out of hardware capability flags pretty quickly,
convert them to use the regular test_bit() style unsigned long
bitmaps.
This introduces a number of helper functions/macros to set and to
test the bits, along with new debugfs code.
The occurrences of an explicit __clear_bit() are intentional, the
drivers were never supposed to change their supported bits on the
fly. We should investigate changing this to be a per-frame flag.
This support is essentially useless as typically networks are encrypted,
frames will be filtered by hardware, and rate scaling will be done with
the intended recipient in mind. For real monitoring of the network, the
monitor mode support should be used instead.
Removing it removes a lot of corner cases.
If we want to shrink skb->cb then we'd have to see about
reducing struct ieee80211_tx_info, which gets embedded inside
skb->cb[].
It provides a scratch space to be used by wireless drivers.
ar5523 uses the maximum space available today (40 bytes), but it seems
we don't need this -- data->skb pointer seems to always point back to the
skb whose cb buffer the data structure resides, iow, given a pointer to the
embedded control buffer we can infer the skb address.
Tested-by: Pontus Fuchs <pontus.fuchs@gmail.com>
This will allow the low level driver to make decision based
on the vif such as queues etc...
Since the vif might be NULL, we can't add it to the tracing
functions.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
[fix staging rtl8821ae driver]
Raw id and FW id should be switched.
Tested-by: Oleksij Rempel <linux@rempel-privat.de>
Signed-off-by: Oleksij Rempel <linux@rempel-privat.de>
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com>
Signed-off-by: Albert Pool <albertpool@solcon.nl>
Reported-by: Michael Landrum <landrummd@gmail.com>
Acked-by: Pontus Fuchs <pontus.fuchs@gmail.com>
Drivers that don't use chanctxes cannot perform VHT association because
they still use a "backward compatibility" pair of {ieee80211_channel,
nl80211_channel_type} in ieee80211_conf and ieee80211_local.
Signed-off-by: Karl Beldan <karl.beldan@rivierawaves.com>
[fix kernel-doc]
There are a number of situations in which mac80211 only
really needs to flush queues for one virtual interface,
and in fact during this frames might be transmitted on
other virtual interfaces. Calculate and pass a queue
bitmap to the driver so it knows which queues to flush.
A missing else caused a potential NULL dereference.
Reported-by: Yuanhan Liu <yuanhan.liu@linux.intel.com>
Signed-off-by: Pontus Fuchs <pontus.fuchs@gmail.com>
__be32 variables where used a little careless leading to sparse warnings.
Treat them a little more gentle.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Use the module_usb_driver() macro to make the code simpler
by eliminating module_init and module_exit calls.
dpatch engine is used to auto generate this patch.
(https://github.com/weiyj/dpatch)
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
This driver is for the AR5523 chipset from Atheros. It was created
in 2007 by Christoph Hellwig but it was never finished. I found it a
couple of months ago and after some polishing it's working pretty
fine.
The driver was written with the FreeBSD driver (uath) as reference,
which was written with the reverse-engineered windows driver as
reference, hence the feature set is very limited. Station mode
only, no HW crypto offload.
