Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
The combined firmware ar9170.fw is preferred and supports all devices.
References to the older two-stage firmware are unnecessary.
Commit "ar9170: wait for asynchronous firmware loading"
introduced a bug, which is triggered by fatal errors
while the driver is initializing the device.
BUG: unable to handle kernel paging request at 6b6b6bf7
IP: [<c117b567>] kobject_put+0x7/0x70
*pde = 00000000
Oops: 0000 [#1] PREEMPT
last sysfs file: /sys/devices/platform/hdaps/position
Modules linked in: ar9170usb [...]
Pid: 6246, comm: firmware/ar9170 Not tainted 2.6.34-wl #54
EIP: 0060:[<c117b567>] EFLAGS: 00010206 CPU: 0
EIP is at kobject_put+0x7/0x70
EAX: 6b6b6bd7 EBX: f4d3d0e0 ECX: f5ba9124 EDX: f6af2a7c
ESI: 00000000 EDI: f4d3d0e0 EBP: 00000000 ESP: f5e98f9c
DS: 007b ES: 007b FS: 0000 GS: 0000 SS: 0068
Process firmware/ar9170 (pid: 6246)
Stack:
c12532ed 00000246 f5bfaa70 f8487353 f4d3d0e0
Call Trace:
[<c12532ed>] ? device_release_driver+0x1d/0x30
[<f8487353>] ? ar9170_usb_firmware_failed+0x43/0x70 [ar9170usb]
[<c125983c>] ? request_firmware_work_func+0x2c/0x70
[<c1259810>] ? request_firmware_work_func+0x0/0x70
[<c10413f4>] ? kthread+0x74/0x80
[<c1041380>] ? kthread+0x0/0x80
[<c1003136>] ? kernel_thread_helper+0x6/0x10
Code: 40 d3 f2 ff 85 c0 89 c3 74 0a ba 44 86 4c c1 e8 [...]
EIP: [<c117b567>] kobject_put+0x7/0x70 SS:ESP 0068:f5e98f9c
CR2: 000000006b6b6bf7
---[ end trace e81abb992434b410 ]---
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (229 commits)
USB: remove unused usb_buffer_alloc and usb_buffer_free macros
usb: musb: update gfp/slab.h includes
USB: ftdi_sio: fix legacy SIO-device header
USB: kl5usb105: reimplement using generic framework
USB: kl5usb105: minor clean ups
USB: kl5usb105: fix memory leak
USB: io_ti: use kfifo to implement write buffering
USB: io_ti: remove unsused private counter
USB: ti_usb: use kfifo to implement write buffering
USB: ir-usb: fix incorrect write-buffer length
USB: aircable: fix incorrect write-buffer length
USB: safe_serial: straighten out read processing
USB: safe_serial: reimplement read using generic framework
USB: safe_serial: reimplement write using generic framework
usb-storage: always print quirks
USB: usb-storage: trivial debug improvements
USB: oti6858: use port write fifo
USB: oti6858: use kfifo to implement write buffering
USB: cypress_m8: use kfifo to implement write buffering
USB: cypress_m8: remove unused drain define
Fix up conflicts (due to usb_buffer_alloc/free renaming) in
drivers/input/tablet/acecad.c
drivers/input/tablet/kbtab.c
drivers/input/tablet/wacom_sys.c
drivers/media/video/gspca/gspca.c
sound/usb/usbaudio.c
For more clearance what the functions actually do,
usb_buffer_alloc() is renamed to usb_alloc_coherent()
usb_buffer_free() is renamed to usb_free_coherent()
They should only be used in code which really needs DMA coherency.
All call sites have been changed accordingly, except for staging
drivers.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Pedro Ribeiro <pedrib@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
USB Network Adapter
* add support for the Qwest/Actiontec 802AIN Wireless N USB Network Adapter.
lsusb identifies the device as: "ID 1668:1200 Actiontec Electronics, Inc. [hex]"
usb_modeswitch package and appropriate rules are required to switch
the device from "ID 0ace:20ff ZyDas"
Changes-licensed-under: GPL
Signed-off-by: Steve Tanner <steve.tanner@gmail.com>
Documentation/feature-removal-schedule.txt
drivers/net/wireless/ath/ar9170/usb.c
drivers/scsi/iscsi_tcp.c
net/ipv4/ipmr.c
drivers/net/wireless/iwlwifi/iwl-dev.h
This patch fixes a regression introduced by the following patch:
"ar9170: load firmware asynchronously"
When we kick off a firmware loading request and then unbind,
or disconnect the usb device right away, we get into trouble:
> ------------[ cut here ]------------
> WARNING: at lib/kref.c:44 kref_get+0x1c/0x20()
> Hardware name: 18666GU
> Pid: 6588, comm: firmware/ar9170 Not tainted 2.6.34-rc5-wl #43
> Call Trace:
> [<c102b05e>] ? warn_slowpath_common+0x6e/0xb0
> [<c117c93c>] ? kref_get+0x1c/0x20
> [<c102b0b3>] ? warn_slowpath_null+0x13/0x20
> [<c117bb2f>] ? kobject_get+0xf/0x20
> [<c124d630>] ? get_device+0x10/0x20
> [<c124e5a0>] ? device_add+0x60/0x530
> [<c117b8b5>] ? kobject_init+0x25/0xa0
> [<c12569f9>] ? _request_firmware+0x139/0x3e0
> [<c1256cc0>] ? request_firmware_work_func+0x20/0x70
> [<c1256ca0>] ? request_firmware_work_func+0x0/0x70
> [<c103ff24>] ? kthread+0x74/0x80
> [<c103feb0>] ? kthread+0x0/0x80
>---[ end trace 2d50bd818f64a1b7 ]---
- followed by a random Oops -
Avoid that by waiting for the firmware loading to finish
(whether successfully or not) before the unbind in
ar9170_usb_disconnect.
Reported-by: Johannes Berg <johannes@sipsolutions.net>
Bug-fixed-by: Johannes Berg <johannes@sipsolutions.net>
drivers/net/wireless/ath/ath5k/phy.c
drivers/net/wireless/wl12xx/wl1271_main.c
This patch adds the following 5 entries to the usbid device table:
* Netgear WNA1000
* Proxim ORiNOCO Dual Band 802.11n USB Adapter
* 3Com Dual Band 802.11n USB Adapter
* H3C Dual Band 802.11n USB Adapter
* WNC Generic 11n USB dongle
CC: <stable@kernel.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (37 commits)
smc91c92_cs: fix the problem of "Unable to find hardware address"
r8169: clean up my printk uglyness
net: Hook up cxgb4 to Kconfig and Makefile
cxgb4: Add main driver file and driver Makefile
cxgb4: Add remaining driver headers and L2T management
cxgb4: Add packet queues and packet DMA code
cxgb4: Add HW and FW support code
cxgb4: Add register, message, and FW definitions
netlabel: Fix several rcu_dereference() calls used without RCU read locks
bonding: fix potential deadlock in bond_uninit()
net: check the length of the socket address passed to connect(2)
stmmac: add documentation for the driver.
stmmac: fix kconfig for crc32 build error
be2net: fix bug in vlan rx path for big endian architecture
be2net: fix flashing on big endian architectures
be2net: fix a bug in flashing the redboot section
bonding: bond_xmit_roundrobin() fix
drivers/net: Add missing unlock
net: gianfar - align BD ring size console messages
net: gianfar - initialize per-queue statistics
An int urb is constructed but we fill it in with a bulk pipe type.
Commit f661c6f8c67bd55e93348f160d590ff9edf08904 implemented a pipe type
check when CONFIG_USB_DEBUG is enabled. The check failed for all the ar9170
usb transfers and the driver could not configure the wifi dongle.
This went unnoticed until now because most people don't have
CONFIG_USB_DEBUG enabled.
Signed-off-by: Valentin Longchamp <valentin.longchamp@epfl.ch>
Cc: Stable <stable@kernel.org>
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
This patch adds support for the NEC WL300NU-G USB wifi dongle.
Signed-off-by: Ben Konrath <ben@bagu.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This converts ar9170 to load firmware asynchronously
out of ->probe() and only register with mac80211 when
all firmware has been loaded successfully. If, on the
other hand, any firmware fails to load, it will now
unbind from the device.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Stefan Seyfried <seife@sphairon.com>
At least two revisions of the D-Link DWA 160 exist, called A1 and A2. A1
(USB-ID 07d1:3c10) is already listed in usb.c as D-Link DWA 160A. A2
(USB-ID 07d1:3a09) works if added to ar9170_usb_ids. I didn't do much
testing until now, but I was able to connect to APs using WPA or WEP and
transmit data.
Summary:
* Add model revision number to the comment for D-Link DWA 160 A1 (07d1:3c10)
* Add support for D-Link DWA 160 A2 (07d1:3a09)
Signed-off-by: Thomas Klute <thomas2.klute@uni-dortmund.de>
This patch follows "ar9170: atomic pending A-MPDU counter"
idea and converts another critical counter to atomic_*.
This patch adds the usbid for TP-Link TL-WN821N v2.
Cc: stable@kernel.org
Reported-by: Fabian Lenz <lenz_fabian@yahoo.de>
arch/microblaze/include/asm/socket.h
When ar9170-2.fw was missing, the driver erroneously complained
about missing the initialization values file ar9170-1.fw...
Signed-off-by: Christian Lamparter <chunkeey@web.de>
Andrey Yurovsky reported that the driver forwarded erroneously the
parent device structure instead of the real thing, which of course
led to some dodgy sysfs links (at least?).
This patch is a back-port from aggregation testing code.
In the past, we didn't limit the amount of active tx urbs.
However, ar9170 only has a limited buffer reserved for
pending data frames.
This wasn't much of a problem with the slower 802.11b/g.
We simply stopped the full queue and moved on to something different
in the mean time. But - as you guessed it - this simple approach
stands in way for a decent aggregation implementation.
This patch contains a few more mostly random fixes for the USB front-end.
1. handle irq command response, instead of printing it to the console.
2. remove fixed FIXME.
(real fix: "ar9170usb: reset device on resume". )
3. some more one-liner.
- get rid of a useless "return;"
- add a few branch prediction hints in hot-paths
etc.
This adds:
USB 0x057C:0x8401 AVM FRITZ!WLAN USB Stick N
USB 0x057C:0x8402 AVM FRITZ!WLAN USB Stick N 2.4
These devices require the 1-stage firmware, if not present we
don't continue.
Cc: Peter Grabienski <Peter.Grabienski@Atheros.com>
Cc: Stephen Chen <Stephen.Chen@Atheros.com>
Cc: Michael Fortin <Michael.Fortin@Atheros.com>
Cc: Johnny Cheng <Johnny.Cheng@Atheros.com>
Cc: Yuan-Gu Wei <Yuan-Gu.Wei@atheros.com>
Cc: Joerg Albert <jal2@gmx.de>
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
You can get the stage 1 firmware from here:
http://www.kernel.org/pub/linux/kernel/people/mcgrof/firmware/ar9170/ar9170.fw
md5sum: 34feec4ec0eae3bb92c7c1ea2dfb4530
sha1sum: 6e5250498b815c2940d97242de31e054ae44e079
Its license:
http://www.kernel.org/pub/linux/kernel/people/mcgrof/firmware/ar9170/LICENSE
This is a new firmware, tested with WNDA3100.
Fix this build error when CONFIG_PM is not set:
drivers/net/wireless/ath/ar9170/usb.c: In function 'ar9170_usb_probe':
drivers/net/wireless/ath/ar9170/usb.c:692:
error: 'struct usb_device' has no member named 'reset_resume'
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
remove redundant test: outlen is unsigned
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Acked-by: Christian Lamparter <chunkeey@web.de>
This patch takes care of an outstanding comment in
"[PATCH] ar9170usb: fix hang on resume" commit message.
>However, the device does not accept the firmware on resume.
>and it will exit with:
>> firmware part 1 upload failed (-71).
>> device is in a bad state. please reconnect it!
Tested-by: Johannes Berg <johannes@sipsolutions.net>
