git://git.kernel.org/pub/scm/linux/kernel/git/kvalo/wireless-drivers-next
Kalle Valo says:
wireless-drivers-next patches for 4.13
New features and bug fixes to quite a few different drivers, but
nothing really special standing out.
What makes me happy that we have now more vendors actively
contributing to upstream drivers. In this pull request we have patches
from Broadcom, Intel, Qualcomm, Realtek and Redpine Signals, and I
still have patches from Marvell and Quantenna pending in patchwork. Now
that's something comparing to how things looked 11 years ago in Jeff
Garzik's "State of the Union: Wireless" email:
https://lkml.org/lkml/2006/1/5/671
Major changes:
wil6210
* add low level RF sector interface via nl80211 vendor commands
* add module parameter ftm_mode to load separate firmware for factory
testing
* support devices with different PCIe bar size
* add support for PCIe D3hot in system suspend
* remove ioctl interface which should not be in a wireless driver
ath10k
* go back to using dma_alloc_coherent() for firmware scratch memory
* add per chain RSSI reporting
brcmfmac
* add support multi-scheduled scan
* add scheduled scan support for specified BSSIDs
* add support for brcm43430 revision 0
wlcore
* add wil1285 compatible
rsi
* add RS9113 USB support
iwlwifi
* FW API documentation improvements (for tools and htmldoc)
* continuing work for the new A000 family
* bump the maximum supported FW API to 31
* improve the differentiation between 8000, 9000 and A000 families
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions return void * and remove all the casts across
the tree, adding a (u8 *) cast only where the unsigned char pointer
was used directly, all done with the following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = { skb_push, __skb_push, skb_push_rcsum };
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
- fn(SKB, LEN)[0]
Note that the last part there converts from push(...)[0] to the
more idiomatic *(u8 *)push(...).
Make these functions (skb_put, __skb_put and pskb_put) return void *
and remove all the casts across the tree, adding a (u8 *) cast only
where the unsigned char pointer was used directly, all done with the
following spatch:
typedef u8;
identifier fn = { skb_put, __skb_put };
- *(fn(SKB, LEN))
type T;
+ E = fn(SKB, LEN)
which actually doesn't cover pskb_put since there are only three
users overall.
A handful of stragglers were converted manually, notably a macro in
drivers/isdn/i4l/isdn_bsdcomp.c and, oddly enough, one of the many
instances in net/bluetooth/hci_sock.c. In the former file, I also
had to fix one whitespace problem spatch introduced.
Trivial fix to spelling mistake in ath6kl_dbg debug message
Reviewed-by: Steve deRosier <derosier@gmail.com>
Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
Fix fallout too.
rx flush was not implemented for htc pipe, add that now. Doesn't fix any known
issues.
Also free the skb if htc control messages get canceled.
Signed-off-by: Jessica Wu <wjessica@qca.qualcomm.com>
Fixes checkpatch warnings:
CHECK: Blank lines aren't necessary after an open brace '{'
CHECK: Blank lines aren't necessary before a close brace '}'
Julien reported that ar6004 usb device fails to initialise
after host has been rebooted and power is still on for the ar6004 device. He
found out that doing a cold reset fixes the issue.
I wasn't sure what would be the best way to detect if target needs a reset so I
settled on checking a timeout from htc_wait_recv_ctrl_message().
Reported-by: Julien Massot <jmassot@aldebaran-robotics.com>
Tested-by: Julien Massot <jmassot@aldebaran-robotics.com>
It was annoying to debug usb warm reboot initialisation problems as many usb
related functions just ignored errors and it wasn't obvious from the kernel
logs what was failing. Fix all that so that error messages are printed and
errors are handled properly.
It's harmless, but Smatch complains if we use "htc_hdr->eid" before
doing the bounds check.
On continuous loading and unloading of AR6004 ath6kl USB
driver it triggers a panic due to NULL pointer dereference of
'target' pointer.
while true; do sudo modprobe -v ath6kl_core;
sudo modprobe -v ath6kl_usb; sudo modprobe -r usb;
sudo modprobe -r ath6kl_core; done
ar->htc_target can be NULL due to a race condition that can occur
during driver initialization(we do 'ath6kl_hif_power_on' before
initializing 'ar->htc_target' via 'ath6kl_htc_create').
'ath6kl_hif_power_on' assigns 'ath6kl_recv_complete' as
usb_complete_t/callback function for 'usb_fill_bulk_urb'.
Thus the possibility of ar->htc_target being NULL
via ath6kl_recv_complete -> ath6kl_usb_io_comp_work
before even 'ath6kl_htc_create' is finished to initialize
ar->htc_create.
Worth noting is the obvious solution of doing 'ath6kl_hif_power_on'
later(i.e after we are done with 'ath6kl_htc_create', causes a
h/w bring up failure in AR6003 SDIO, as 'ath6kl_hif_power_on' is a
pre-requisite to get the target version 'ath6kl_bmi_get_target_info'.
So simply check for NULL pointer for 'ar->htc_target' and bail out.
[23614.518282] BUG: unable to handle kernel NULL pointer dereference at
00000904
[23614.518463] IP: [<c012e7a6>] __ticket_spin_trylock+0x6/0x30
[23614.518570] *pde = 00000000
[23614.518664] Oops: 0000 [#1] SMP
[23614.518795] Modules linked in: ath6kl_usb(O+) ath6kl_core(O)
[23614.520012] EIP: 0060:[<c012e7a6>] EFLAGS: 00010286 CPU: 0
[23614.520012] EIP is at __ticket_spin_trylock+0x6/0x30
Call Trace:
[<c03f2a44>] do_raw_spin_trylock+0x14/0x40
[<c06daa12>] _raw_spin_lock_bh+0x52/0x80
[<f85464b4>] ? ath6kl_htc_pipe_rx_complete+0x3b4/0x4c0 [ath6kl_core]
[<f85464b4>] ath6kl_htc_pipe_rx_complete+0x3b4/0x4c0 [ath6kl_core]
[<c05bc272>] ? skb_dequeue+0x22/0x70
[<f855bb32>] ath6kl_core_rx_complete+0x12/0x20 [ath6kl_core]
[<f848771a>] ath6kl_usb_io_comp_work+0xaa/0xb0 [ath6kl_usb]
[<c015b863>] process_one_work+0x1a3/0x5e0
[<c015b7e7>] ? process_one_work+0x127/0x5e0
[<f8487670>] ? ath6kl_usb_reset_resume+0x30/0x30 [ath6kl_usb]
[<c015bfde>] worker_thread+0x11e/0x3f0
Kernel panic - not syncing: Fatal exception in interrupt
Signed-off-by: Mohammed Shafi Shajakhan <mohammed@qca.qualcomm.com>
dev_kfree_skb kernel API itself takes for checking for NULL
skb, so an explicit check is not required.
Assign 'true' to the bool variable instead of needless typecasting.
Using list_move_tail() instead of list_del() + list_add_tail().
spatch with a semantic match is used to found this problem.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
On the htc mbox layer, it will assign each endpoint (AC) with a
different Tx-packet-drop threshold, so lower priority AC is more
likely to drop packets and the cookies become more available to higher
priority AC.
On the htc pipe layer, assign the tx packet drop threshold as well, it
will let AC to drop packets when cookies below the tx packet drop
threshold.
Signed-off-by: Kevin Fang <kevin.fang@qca.qualcomm.com>
We can remove the NULL check here. It triggers a Smatch warning because
list_first_entry() never is NULL and people who check for it normally
intend to check for list_empty() instead. In these cases however,
we've already verified that the lists are not empty.
This is needed for USB.
Based on code by Kevin Fang.
