commit b25bfda38236f349cde0d1b28952f4eea2148d3f upstream.
don't do aggregation related stuff for 'AP mode client power save
handling' if aggregation is not enabled in the driver, otherwise it
will lead to panic because those data structures won't be never
intialized in 'ath_tx_node_init' if aggregation is disabled
EIP is at ath_tx_aggr_wakeup+0x37/0x80 [ath9k]
EAX: e8c09a20 EBX: f2a304e8 ECX: 00000001 EDX: 00000000
ESI: e8c085e0 EDI: f2a304ac EBP: f40e1ca4 ESP: f40e1c8c
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
Process swapper/1 (pid: 0, ti=f40e0000 task=f408e860
task.ti=f40dc000)
Stack:
0001e966 e8c09a20 00000000 f2a304ac e8c085e0 f2a304ac
f40e1cb0 f8186741
f8186700 f40e1d2c f922988d f2a304ac 00000202 00000001
c0b4ba43 00000000
0000000f e8eb75c0 e8c085e0 205b0001 34383220 f2a304ac
f2a30000 00010020
Call Trace:
[<f8186741>] ath9k_sta_notify+0x41/0x50 [ath9k]
[<f8186700>] ? ath9k_get_survey+0x110/0x110 [ath9k]
[<f922988d>] ieee80211_sta_ps_deliver_wakeup+0x9d/0x350
[mac80211]
[<c018dc75>] ? __module_address+0x95/0xb0
[<f92465b3>] ap_sta_ps_end+0x63/0xa0 [mac80211]
[<f9246746>] ieee80211_rx_h_sta_process+0x156/0x2b0
[mac80211]
[<f9247d1e>] ieee80211_rx_handlers+0xce/0x510 [mac80211]
[<c018440b>] ? trace_hardirqs_on+0xb/0x10
[<c056936e>] ? skb_queue_tail+0x3e/0x50
[<f9248271>] ieee80211_prepare_and_rx_handle+0x111/0x750
[mac80211]
[<f9248bf9>] ieee80211_rx+0x349/0xb20 [mac80211]
[<f9248949>] ? ieee80211_rx+0x99/0xb20 [mac80211]
[<f818b0b8>] ath_rx_tasklet+0x818/0x1d00 [ath9k]
[<f8187a75>] ? ath9k_tasklet+0x35/0x1c0 [ath9k]
[<f8187b33>] ath9k_tasklet+0xf3/0x1c0 [ath9k]
[<c0151b7e>] tasklet_action+0xbe/0x180
Cc: Senthil Balasubramanian <senthilb@qca.qualcomm.com>
Cc: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
Reported-by: Ashwin Mendonca <ashwinloyal@gmail.com>
Tested-by: Ashwin Mendonca <ashwinloyal@gmail.com>
Signed-off-by: Mohammed Shafi Shajakhan <mohammed@qca.qualcomm.com>
Change-Id: I3cd9332f9e8fc79020b34c3f8cfb1a1a5f8a9bf4
Reviewed-on: http://git-master/r/74234
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
commit 10636bc2d60942254bda149827b922c41f4cb4af upstream.
The stations always chooses 1Mbps for all trasmitting frames,
whenever the AP is configured to lock the supported rates.
As the max phy rate is always set with the 4th from highest phy rate,
this assumption might be wrong if we have less than that. Fix that.
Cc: Paul Stewart <pstew@google.com>
Reported-by: Ajay Gummalla <agummalla@google.com>
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
Change-Id: I240606b385bb9d0a5c4dec19dfd364289bf478ab
Reviewed-on: http://git-master/r/74189
commit 52d6d4ef5e6d1517688e27c11c01ab303ec681dd upstream.
My recent commits (3782c69d, 324c74a) introduced regression
for register offset selection that based on the macversion.
Not using parentheses in proper manner for ternary operator
leads to select wrong offset for the registers.
This issue was observed with AR9462 chip that immediate disconnect
after the association with the following message
ieee80211 phy3: wlan0: Failed to send nullfunc to AP 00:23:69:12:ea:47
after 500ms, disconnecting.
commit 98fb2cc115b4ef1ea0a2d87a170c183bd395dd6c upstream.
This patch fixes system hang when resuming from S3 state
and lower rate sens failure issue.
commit ac06697c79bad09e44a8b1d52104014016fb90de upstream.
PHY errors relevant for ANI are always tracked by hardware counters, the
bits that allow them to pass through the rx filter are independent of that.
Enabling PHY errors in the rx filter often creates lots of useless DMA traffic
and might be responsible for some of the rx dma stop failure warnings.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
commit 6321eb0977b011ac61dfca36e7c69b2c4325b104 upstream.
this patch fixes the assumption of maximum number of GPIO pins present
in AR9287/AR9300. this fix is essential as we might encounter some
functionality issues involved in accessing the status of GPIO pins which
are all incorrectly assumed to be not within the range of max_num_gpio
of AR9300/AR9287 chipsets
commit 8c34559b4a6df32e4af1b073397fa4dc189a5485 upstream.
This was reported and tested by Martin Walter over at AVM GmbH Berlin.
This also applies to 3.0.1 so sendint to stable.
Cc: s.kirste@avm.de
Cc: d.friedel@avm.de
Cc: Martin Walter <m.walter@avm.de>
Cc: Peter Grabienski <pgrabien@qca.qualcomm.com>
Tested-by: Martin Walter <m.walter@avm.de>
Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com>
commit e9c10469cf3c71bc1c6b0f01319161e277d6ac9b upstream.
Do the magnitude/phase coeff correction only if the outlier
is detected. Updating wrong magnitude/phase coeff factor
impacts not only tx gain setting but also leads to poor
performance in congested networks. In the clear environment
the impact is very minimal because the outlier happens
very rarely according to the past experiment. It occured
less than once every 1000 calibrations.
commit 2a15b394f8e46dd3e2ab365ab41cfa701d92fa77 upstream.
proper dma_unmapping and freeing of skb's has to be done in the rx
cleanup for EDMA chipsets when the device is unloaded and this also
seems to address the following warning which shows up occasionally when
Call Trace:
[<c0148cd2>] warn_slowpath_common+0x72/0xa0
[<c03b669c>] ? dma_debug_device_change+0x19c/0x200
[<c0148da3>] warn_slowpath_fmt+0x33/0x40
[<c03b669c>] dma_debug_device_change+0x19c/0x200
[<c0657f12>] notifier_call_chain+0x82/0xb0
[<c0171370>] __blocking_notifier_call_chain+0x60/0x90
[<c01713bf>] blocking_notifier_call_chain+0x1f/0x30
[<c044f594>] __device_release_driver+0xa4/0xc0
[<c044f647>] driver_detach+0x97/0xa0
[<c044e65c>] bus_remove_driver+0x6c/0xe0
[<c029af0b>] ? sysfs_addrm_finish+0x4b/0x60
[<c0450109>] driver_unregister+0x49/0x80
[<c0299f54>] ? sysfs_remove_file+0x14/0x20
[<c03c3ab2>] pci_unregister_driver+0x32/0x80
[<f92c2162>] ath_pci_exit+0x12/0x20 [ath9k]
[<f92c8467>] ath9k_exit+0x17/0x36 [ath9k]
[<c06523cd>] ? mutex_unlock+0xd/0x10
[<c018e27f>] sys_delete_module+0x13f/0x200
[<c02139bb>] ? sys_munmap+0x4b/0x60
[<c06547c5>] ? restore_all+0xf/0xf
[<c0657a20>] ? spurious_fault+0xe0/0xe0
[<c01832f4>] ? trace_hardirqs_on_caller+0xf4/0x180
[<c065b863>] sysenter_do_call+0x12/0x38
---[ end trace 16e1c1521c06bcf9 ]---
Mapped at:
[<c03b7938>] debug_dma_map_page+0x48/0x120
[<f92ba3e8>] ath_rx_init+0x3f8/0x4b0 [ath9k]
[<f92b5ae4>] ath9k_init_device+0x4c4/0x7b0 [ath9k]
[<f92c2813>] ath_pci_probe+0x263/0x330 [ath9k]
During the endurance testing, rx frames are not getting DMAd from
MAC whereas pcu rx frame counters are getting updated properly.
As per systems team input updated the initval to fix rx dma stuck
issue.
Cc: stable@kernel.org
when the device is yanked out ath_pci_remove starts doing the cleanups,
unregistering the hardware etc. so we should bail out immediately when
we get drv_flush callback from mac80211 when the card is being unplugged.
the panic occurs after we had associated to an AP.
EIP: 0060:[<fb315b00>] EFLAGS: 00010246 CPU: 0
EIP is at ath_reset+0xa0/0x1c0 [ath9k]
EAX: 00000000 EBX: 000697c0 ECX: 00000002 EDX: f3c3ccf0
ESI: 00000000 EDI: 00000000 EBP: f43e7b78 ESP: f43e7b50
Process kworker/u:2 (pid: 182, ti=f43e6000 task=f3c3c7c0
task.ti=f43e6000)
Stack:
0000002a 00000000 00000000 003e7b78 0000000f eaaa8500
ffffffea eaaa97c0
eaaaa000 00000001 f43e7ba8 fb315d23 f99e7721 ecece680
eaaac738 eaaa8500
eaaaa020 000000c8 000000c8 00000000 eaaa8d58 eaaa8500
f43e7bd0 fb080b29
Call Trace:
[<fb315d23>] ath9k_flush+0x103/0x170 [ath9k]
[<fb080b29>] __ieee80211_recalc_idle+0x2c9/0x400
[mac80211]
[<fb080c8e>] ieee80211_recalc_idle+0x2e/0x60 [mac80211]
[<fb07aa73>] ieee80211_mgd_deauth+0x173/0x210 [mac80211]
[<fb084559>] ieee80211_deauth+0x19/0x20 [mac80211]
[<f99dda53>] __cfg80211_mlme_deauth+0xf3/0x140
[cfg80211]
[<c0633d00>] ? __mutex_lock_common+0x1f0/0x380
[<f99e1b5d>] __cfg80211_disconnect+0x18d/0x1f0
[cfg80211]
[<f99c8199>] cfg80211_netdev_notifier_call+0x159/0x5c0
[cfg80211]
[<c0608a64>] ? packet_notifier+0x174/0x1f0
[<c0639202>] notifier_call_chain+0x82/0xb0
[<c0170d8f>] raw_notifier_call_chain+0x1f/0x30
[<c053b86c>] call_netdevice_notifiers+0x2c/0x60
[<c0182184>] ? trace_hardirqs_on_caller+0xf4/0x180
[<c053b8ec>] __dev_close_many+0x4c/0xd0
[<c053ba2d>] dev_close_many+0x6d/0xc0
[<c053bb53>] rollback_registered_many+0x93/0x1c0
[<c018221b>] ? trace_hardirqs_on+0xb/0x10
[<c053bc95>] unregister_netdevice_many+0x15/0x50
[<fb07f83b>] ieee80211_remove_interfaces+0x7b/0xb0
[mac80211]
[<fb06a14b>] ieee80211_unregister_hw+0x4b/0x110
[mac80211]
[<fb311a4a>] ath9k_deinit_device+0x3a/0x60 [ath9k]
[<fb31eed6>] ath_pci_remove+0x46/0x90 [ath9k]
[<c03b4ac4>] pci_device_remove+0x44/0x100
[<c043eb54>] __device_release_driver+0x64/0xb0
[<c043ec67>] device_release_driver+0x27/0x40
[<c043deeb>] bus_remove_device+0x7b/0xa0
[<c043c491>] device_del+0xf1/0x180
[<c043c530>] device_unregister+0x10/0x20
[<c03afafe>] pci_stop_bus_device+0x6e/0x80
[<c03afb72>] pci_remove_bus_device+0x12/0xa0
[<c03c2f29>] pciehp_unconfigure_device+0x89/0x180
[<c0181e54>] ? mark_held_locks+0x64/0x100
[<c063390f>] ? __mutex_unlock_slowpath+0xaf/0x140
[<c03c1f84>] pciehp_disable_slot+0x64/0x1b0
[<c03c2850>] pciehp_power_thread+0xd0/0x100
[<c0164ad0>] ? process_one_work+0x100/0x4d0
[<c0164b4c>] process_one_work+0x17c/0x4d0
[<c03c2780>] ? queue_interrupt_event+0xa0/0xa0
[<c01662bb>] worker_thread+0x13b/0x320
[<c0166180>] ? manage_workers+0x1e0/0x1e0
[<c016a654>] kthread+0x84/0x90
[<c016a5d0>] ? __init_kthread_worker+0x60/0x60
[<c063d106>] kernel_thread_helper+0x6/0x10
ADC calibrations cannot run on 5 GHz with fast clock enabled. They
need to be disabled, otherwise they'll hang and IQ mismatch calibration
will not be run either.
Reported-by: Adrian Chadd <adrian@freebsd.org>
The commit 172805ad46b78717a738ca5c7908c68f0326d3a9
overwirtes additional clock settings of AR9330 to
all AR9300 chips.
this callback is called during suspend/resume and also via iw command.
it configures parameters like sifs, slottime, acktimeout in
ath9k_hw_init_global_settings where few REG_READ, REG_RMW are also done
and hence the need for PS wrappers
Due to some recent optimization done in the way the mac address
bytes are written into the OTP memory, some AR9485 chipsets were
forced to use the first byte from the eeprom template and the
remaining bytes are read from OTP.
AR9485 happens to use generic eeprom template which has 0x1 as
the first byte causes issues in bringing up the card.
So fixed the eeprom template accordingly to address the issue.
Signed-off-by: Senthil Balasubramanian <senthilb@qca.qualcomm.com>
This patch addresses an issue with incorrect HW register
AR_PHY_TX_IQCAL_CORR_COEFF_B1 definition which leads to incorrect clibration.
Signed-off-by: Alex Hacker <hacker@epn.ru>
The commit ebefce3d13f8b5a871337ff7c3821ee140c1ea8a failed
to set proper PMU value to address ripple issue for AR9485.
CTL power data incorrect in ctlPowerData_2G field of ar9300_eeprom.
Setting incorrect CTL power in calibration is causing lower tx power.
Tx power was reported as 3dBm while operating in channel 6 HT40+/
in channel 11 HT40- due to CTL powers in the calibration is set to
zero.
into for-davem
We receive many bug reports about system hang during suspend/resume
when ath9k driver is in use. Adrian Chadd remarked that this problem
happens on systems that have ASPM disabled.
To do not hit the bug, skip doing ->config_pci_powersave magic if PCIe
downstream port device, which ath9k device is connected to, has ASPM
disabled.
Bug was introduced by:
commit 53bc7aa08b48e5cd745f986731cc7dc24eef2a9f
Author: Vivek Natarajan <vnatarajan@atheros.com>
Date: Mon Apr 5 14:48:04 2010 +0530
ath9k: Add support for newer AR9285 chipsets.
Patch should address:
https://bugzilla.kernel.org/show_bug.cgi?id=37462
https://bugzilla.kernel.org/show_bug.cgi?id=37082
https://bugzilla.redhat.com/show_bug.cgi?id=697157
however I did not receive confirmation about that, except from Camilo
Mesias, whose system stops hang regularly with this patch (but still
hangs from time to time, but this is probably some other bug).
Tested-by: Camilo Mesias <camilo@mesias.co.uk>
Cc: stable@kernel.org # 2.6.35+
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
With an uninitialized chainmask, the per-channel power will only contain
the power limits for a single chain instead of the combined tx power.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
Some devices (e.g. Ubiquiti AirRouter) ship with broken EEPROM chainmask
data, which breaks the initial calibration after a hardware reset.
To fix this, mask the eeprom chainmask with the chainmask of the chip,
and use the chip chainmask if the result is zero.
Cc: "Luis R. Rodriguez" <lrodriguez@atheros.com>
Cc: ath9k-devel@lists.ath9k.org
drivers/net/wireless/ath/ath9k/hif_usb.c +135 hif_usb_mgmt_cb(6) warn:
variable dereferenced before check 'cmd'
drivers/net/wireless/ath/ath9k/btcoex.c +77 ath9k_hw_init_btcoex_hw(38)
error: buffer overflow 'ah->hw_gen_timers.gen_timer_index' 32 <=
2009813776
drivers/net/wireless/ath/ath9k/init.c:199:21: warning: context imbalance
in 'ath9k_reg_rmw' - different lock contexts for basic block
drivers/net/wireless/ath/ath9k/xmit.c:1175:31: warning: context
imbalance in 'ath_drain_txq_list' - unexpected unlock
drivers/net/wireless/ath/ath9k/xmit.c:2047:23: warning: context
imbalance in 'ath_tx_process_buffer' - unexpected unlock
drivers/net/wireless/ath/ath9k/ar9003_eeprom.c:3041:24: warning: cast to
restricted __le32
Signed-off-by: Pavel Roskin <proski@gnu.org>
For unicast the hardware sometimes reports MIC errors even though the
frame that it received actually contains a valid MIC - on some chips this
can happen frequently enough to trigger TKIP countermeasures.
Fix this issue by not reporting MIC errors for unicast frames with a
valid key, letting mac80211 validate the MIC instead.
Additionally, strip the MIC for all frames that the hardware considers
valid to avoid wasting CPU cycles re-validating it.
net/bluetooth/l2cap_core.c
Decryping frames on key_miss handling shouldn't be done for Michael
MIC failed frames as h/w would have already decrypted such frames
successfully anyway.
Also leaving CRC and PHY error(where the frame is going to be dropped
anyway), we are left to prcoess Decrypt error for which s/w decrypt is
selected anway and so having key_miss as a separate check doesn't serve
anything. So making key_miss handling mutually exlusive with other RX
status handling makes much more sense.
This patch addresses an issue with STA not reporting MIC failure events
resulting in STA being disconnected immediately.
AR_AN_SYNTH9 is in the analog shift register range and thus needs to be
written using the ath9k_hw_analog_shift_rmw function.
The radio needs twice / four times as much time to stabilize for half/quarter
channels.
The radio seems to perform better that way
Now that the clock rate is initialized properly and SIFS, EIFS, USEC,
slot time and ACK timeout are properly calculated by the generic code,
the 'async FIFO' register hacks are no longer necessary.
Initialize the the clock-to-TSF field of AR_USEC and the SIFS and EIFS time
registers based on the clock rate instead of relying on initvals.
With those changes, some of the hardcoded AR9287 1.3+ specific overrides
can be dropped.
This chip uses the async FIFO feature and runs the MAC at 117 MHz
Enabling half/quarter rate makes the MAC run at half/quarter clock speed.
All devices support this, but some disable it using an EEPROM flag
for some reason. Improves 5 GHz performance on those devices.
Use the proper masks for the register instead.
Fixes adding the (still unused) half/quarter PLL flags.
drivers/net/wireless/ath/ath5k/sysfs.c
net/mac80211/wpa.c
Recent firmware changes report tx ack status properly
to driver. Hence updating ath9k_htc driver capabilities.
This patch removes read only registers that cause invalid
address access and also updates index for measurement filter
calibration window size.
The power detector calibration is disabled because this block
doesn't exist in AR9003 based chips and also parallel
calibration is enabled otherwise the calibration will never stop.
The number of temperature reading samples to average
during a Tx packet is decreased to 1 from 2 to improve
5G Tx EVM with chain 0-only mode.
