commit 66cb54bd24086b2d871a03035de9b0e79b2b725e upstream.
If is_main_vif(ar, vif) reports that we have to fall back
to software encryption, we goto err_softw; before locking ar->mutex.
As a result, we have unprotected call to carl9170_set_operating_mode
and unmatched mutex_unlock.
The patch fix the issue by adding mutex_lock before goto.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Acked-By: Christian Lamparter <chunkeey@googlemail.com>
In order to provide multiple interfaces for a single device,
the driver will be required to advertise all possible
interface configurations to the stack.
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
Currently, the driver only disable multicast filtering when the
FIF_ALLMULTI driver flag has been just set (ie,
if changed_flags& FIF_ALLMULTI and *new_flags& FIF_ALLMULTI) or else
it will reenable multicast filtering.
But next time, this condition will be false and multicast filtering
will be reenabled, even through FIF_ALLMULTI is still set.
This mean that allmulticast only works for less than two minutes in
ad-hoc mode. This patch fixes that to disable multicast filtering
as long as FIF_ALLMULTI is set.
Signed-off-by: Nicolas Cavallari <cavallar@lri.fr>
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
Using the ieee80211_sta_block allows the PS code
to handle awake->doze->awake transitions of our
clients in a race-free manner.
Some clients seem to rely upon the reception of BlockAckReqs to flush
their rx reorder buffer. In order to fix aggregation for these clients
carl9170 should set IEEE80211_TX_STAT_AMPDU_NO_BACK to generate a
BlockAckReq if the transmission of an AMPDU subframe fails.
This fixes aggregation problems with Intel 5100 Windows STAs (and maybe
others as well).
"mac80211 will properly assign sequence numbers to QoS-data
frames but cannot do so correctly for non-QoS-data and
management frames because beacons need them from that counter
as well and mac80211 cannot guarantee proper sequencing."
The aggregation code currently doesn't implement the
buffer size negotiation. It will always request a max
buffer size (which is fine, if a little pointless, as
the mac80211 code doesn't know and might just use 0
instead), but if the peer requests a smaller size it
isn't possible to honour this request.
In order to fix this, look at the buffer size in the
addBA response frame, keep track of it and pass it to
the driver in the ampdu_action callback when called
with the IEEE80211_AMPDU_TX_OPERATIONAL action. That
way the driver can limit the number of subframes in
aggregates appropriately.
Note that this doesn't fix any drivers apart from the
addition of the new argument -- they all need to be
updated separately to use this variable!
drivers/net/wireless/ath/ath9k/ar9003_eeprom.c
net/llc/af_llc.c
With some upcoming changes we'd like to use
the interface types for P2P capability tests.
Enable them now so that when we add those
tests in wpa_supplicant, nothing will break.
This patch fixes a faulty bound check which caused a
crash when too many virtual interface were brought up.
BUG: unable to handle kernel NULL pointer dereference at 00000004
IP: [<f8125f67>] carl9170_op_add_interface+0x1d7/0x2c0 [carl9170]
*pde = 00000000
Oops: 0002 [#1] PREEMPT
Modules linked in: carl9170 [...]
Pid: 4720, comm: wpa_supplicant Not tainted 2.6.37-rc2-wl+
EIP: 0060:[<f8125f67>] EFLAGS: 00210206 CPU: 0
EIP is at carl9170_op_add_interface+0x1d7/0x2c0 [carl9170]
EAX: 00000000 ...
Process wpa_supplicant
Stack:
f4f88f34 fffffff4 ..
Call Trace:
[<f8f4e666>] ? ieee80211_do_open+0x406/0x5c0 [mac80211]
Code: <89> 42 04 ...
EIP: [<f8125f67>] carl9170_op_add_interface+0x1d7/0x2c0 [carl9170]
CR2: 0000000000000004
RX Stress tests of unidirectional bulk traffic with
bitrates of up to 220Mbit/s have revealed that the
fatal-event recovery logic [which was solely triggered
by an out-of-rx-buffer situation] is too aggressive.
The new method now "pings" the device and then
decides - based on the response - whenever
a restart is needed or not.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
This patch fixes the following mishap:
BUG: scheduling while atomic: wpa_supplicant/4164/0x00000002
Modules linked in: carl9170 mac80211 [...]
Pid: 4164, comm: wpa_supplicant Not tainted 2.6.36-wl+ #119
Call Trace:
[<c13779a9>] ? schedule+0x349/0x4c0
[<c13780d6>] ? schedule_timeout+0x106/0x1e0
[<c1037f50>] ? process_timeout+0x0/0x10
[<c1377e8d>] ? wait_for_common+0x9d/0x140
[<c1029110>] ? default_wake_function+0x0/0x10
[<f80c6080>] ? carl9170_exec_cmd+0xf0/0x250 [carl9170]
[<f80c695e>] ? carl9170_set_mac_reg+0x5e/0x70 [carl9170]
[<f80c3f76>] ? carl9170_op_add_interface+0x176/0x310 [carl9170]
rcu_read_unlock() call was erroneously placed after the
sync. function carl9170_mod_virtual_mac.
The hardware rx-filter was essentially disabled, because
of a serve, yet unidentifiable problem with iwlagn.
Due to these circumstances the driver and mac80211 were
left with the job of filtering.
This is very unfortunate and has proven to be expensive
in terms of latency, memory and load.
Therefore the new 1.8.8.3 firmware introduces a flexible
filtering infrastructure which allows the driver to
offload some of the checks (FCS & PLCP crc check,
RA match, control frame filter, etc...) whenever possible.
Note:
This patch also includes all changes to the
shared headers files since the inclusion.
Broadcom's Windows driver for the 4313 advertises
an ampdu density of 7 => 16 us. The AR9170 MAC on
the other hand only supports densities up to 8 us.
This patch removes the noisy WARN_ON, because
there is nothing we can do about it.
tx_ampdu_upload was not decreased when an a-MPDU
frame had to be kicked out from the tx_pending
queues.
This broke ampdu aggregation, because the scheduler
waits until tx_ampdu_upload drops to zero, before
making the next aggregate.
802.11n-2009 demands in 11.2.1: "
When a STA enters normal (non-APSD) PS mode, any downlink
Block ACK agreement without an associated schedule is
suspended for the duration of this PS mode."
The operative word is "suspended" and not terminated.
This is a obvious bug, skb_queue_walk does not
work if the iterator gets removed from the queue.
