commit feb09b2933275a70917a869989ea2823e7356be8 upstream.
This patch follows Alan Stern's recent patch:
"p54: Fix race between disconnect and firmware loading"
that overhauled carl9170 buggy firmware loading and driver
unbinding procedures.
Since the carl9170 code was adapted from p54 it uses the
same functions and is likely to have the same problem, but
it's just that the syzbot hasn't reproduce them (yet).
a summary from the changes (copied from the p54 patch):
* Call usb_driver_release_interface() rather than
device_release_driver().
* Lock udev (the interface's parent) before unbinding the
driver instead of locking udev->parent.
* During the firmware loading process, take a reference
to the USB interface instead of the USB device.
* Don't take an unnecessary reference to the device during
probe (and then don't drop it during disconnect).
and
* Make sure to prevent use-after-free bugs by explicitly
setting the driver context to NULL after signaling the
completion.
Cc: <stable@vger.kernel.org>
Cc: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Christian Lamparter <chunkeey@gmail.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
usb_device_id are not supposed to change at runtime. All functions
working with usb_device_id provided by <linux/usb.h> work with
const usb_device_id. So mark the non-const structs as const.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions return void * and remove all the casts across
the tree, adding a (u8 *) cast only where the unsigned char pointer
was used directly, all done with the following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = { skb_push, __skb_push, skb_push_rcsum };
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
- fn(SKB, LEN)[0]
Note that the last part there converts from push(...)[0] to the
more idiomatic *(u8 *)push(...).
A common pattern with skb_put() is to just want to memcpy()
some data into the new space, introduce skb_put_data() for
this.
An spatch similar to the one for skb_put_zero() converts many
of the places using it:
identifier p, p2;
expression len, skb, data;
type t, t2;
-p = skb_put(skb, len);
+p = skb_put_data(skb, data, len);
-p = (t)skb_put(skb, len);
p2 = (t2)p;
-memcpy(p2, data, len);
-memcpy(p, data, len);
type t, t2;
identifier p, p2;
expression skb, data;
t *p;
-p = skb_put(skb, sizeof(t));
+p = skb_put_data(skb, data, sizeof(t));
-p = (t *)skb_put(skb, sizeof(t));
p2 = (t2)p;
-memcpy(p2, data, sizeof(*p));
-memcpy(p, data, sizeof(*p));
expression skb, len, data;
-memcpy(skb_put(skb, len), data, len);
+skb_put_data(skb, data, len);
(again, manually post-processed to retain some comments)
Reviewed-by: Stephen Hemminger <stephen@networkplumber.org>
We currently use a lot of flags that are mutually incompatible,
separate this out into actual encoding and bandwidth enum values.
Much of this again done with spatch, with manual post-editing,
mostly to add the switch statements and get rid of the conversions.
expression status;
-status->enc_flags |= RX_ENC_FLAG_80MHZ
+status->bw = RATE_INFO_BW_80
expression status;
-status->enc_flags |= RX_ENC_FLAG_40MHZ
+status->bw = RATE_INFO_BW_40
expression status;
-status->enc_flags |= RX_ENC_FLAG_20MHZ
+status->bw = RATE_INFO_BW_20
expression status;
-status->enc_flags |= RX_ENC_FLAG_160MHZ
+status->bw = RATE_INFO_BW_160
expression status;
-status->enc_flags |= RX_ENC_FLAG_5MHZ
+status->bw = RATE_INFO_BW_5
expression status;
-status->enc_flags |= RX_ENC_FLAG_10MHZ
+status->bw = RATE_INFO_BW_10
expression status;
-status->enc_flags |= RX_ENC_FLAG_VHT
+status->encoding = RX_ENC_VHT
expression status;
-status->enc_flags |= RX_ENC_FLAG_HT
+status->encoding = RX_ENC_HT
expression status;
-status.enc_flags |= RX_ENC_FLAG_VHT
+status.encoding = RX_ENC_VHT
expression status;
-status.enc_flags |= RX_ENC_FLAG_HT
+status.encoding = RX_ENC_HT
expression status;
-(status->enc_flags & RX_ENC_FLAG_HT)
+(status->encoding == RX_ENC_HT)
expression status;
-(status->enc_flags & RX_ENC_FLAG_VHT)
+(status->encoding == RX_ENC_VHT)
expression status;
-(status->enc_flags & RX_ENC_FLAG_5MHZ)
+(status->bw == RATE_INFO_BW_5)
expression status;
-(status->enc_flags & RX_ENC_FLAG_10MHZ)
+(status->bw == RATE_INFO_BW_10)
expression status;
-(status->enc_flags & RX_ENC_FLAG_40MHZ)
+(status->bw == RATE_INFO_BW_40)
expression status;
-(status->enc_flags & RX_ENC_FLAG_80MHZ)
+(status->bw == RATE_INFO_BW_80)
expression status;
-(status->enc_flags & RX_ENC_FLAG_160MHZ)
+(status->bw == RATE_INFO_BW_160)
In preparation for adding support for HE rates, clean up
the driver report encoding for rate/bandwidth reporting
on RX frames.
Much of this patch was done with the following spatch:
expression status;
-status->flag & (RX_FLAG_HT | RX_FLAG_VHT)
+status->enc_flags & (RX_ENC_FLAG_HT | RX_ENC_FLAG_VHT)
assignment operator op;
expression status;
-status->flag op RX_FLAG_SHORTPRE
+status->enc_flags op RX_ENC_FLAG_SHORTPRE
expression status;
-status->flag & RX_FLAG_SHORTPRE
+status->enc_flags & RX_ENC_FLAG_SHORTPRE
expression status;
-status->flag op RX_FLAG_HT
+status->enc_flags op RX_ENC_FLAG_HT
expression status;
-status->flag & RX_FLAG_HT
+status->enc_flags & RX_ENC_FLAG_HT
expression status;
-status->flag op RX_FLAG_40MHZ
+status->enc_flags op RX_ENC_FLAG_40MHZ
expression status;
-status->flag & RX_FLAG_40MHZ
+status->enc_flags & RX_ENC_FLAG_40MHZ
expression status;
-status->flag op RX_FLAG_SHORT_GI
+status->enc_flags op RX_ENC_FLAG_SHORT_GI
expression status;
-status->flag & RX_FLAG_SHORT_GI
+status->enc_flags & RX_ENC_FLAG_SHORT_GI
expression status;
-status->flag op RX_FLAG_HT_GF
+status->enc_flags op RX_ENC_FLAG_HT_GF
expression status;
-status->flag & RX_FLAG_HT_GF
+status->enc_flags & RX_ENC_FLAG_HT_GF
expression status;
-status->flag op RX_FLAG_VHT
+status->enc_flags op RX_ENC_FLAG_VHT
expression status;
-status->flag & RX_FLAG_VHT
+status->enc_flags & RX_ENC_FLAG_VHT
expression status;
-status->flag op RX_FLAG_STBC_MASK
+status->enc_flags op RX_ENC_FLAG_STBC_MASK
expression status;
-status->flag & RX_FLAG_STBC_MASK
+status->enc_flags & RX_ENC_FLAG_STBC_MASK
expression status;
-status->flag op RX_FLAG_LDPC
+status->enc_flags op RX_ENC_FLAG_LDPC
expression status;
-status->flag & RX_FLAG_LDPC
+status->enc_flags & RX_ENC_FLAG_LDPC
expression status;
-status->flag op RX_FLAG_10MHZ
+status->enc_flags op RX_ENC_FLAG_10MHZ
expression status;
-status->flag & RX_FLAG_10MHZ
+status->enc_flags & RX_ENC_FLAG_10MHZ
expression status;
-status->flag op RX_FLAG_5MHZ
+status->enc_flags op RX_ENC_FLAG_5MHZ
expression status;
-status->flag & RX_FLAG_5MHZ
+status->enc_flags & RX_ENC_FLAG_5MHZ
expression status;
-status->vht_flag op RX_VHT_FLAG_80MHZ
+status->enc_flags op RX_ENC_FLAG_80MHZ
expression status;
-status->vht_flag & RX_VHT_FLAG_80MHZ
+status->enc_flags & RX_ENC_FLAG_80MHZ
expression status;
-status->vht_flag op RX_VHT_FLAG_160MHZ
+status->enc_flags op RX_ENC_FLAG_160MHZ
expression status;
-status->vht_flag & RX_VHT_FLAG_160MHZ
+status->enc_flags & RX_ENC_FLAG_160MHZ
expression status;
-status->vht_flag op RX_VHT_FLAG_BF
+status->enc_flags op RX_ENC_FLAG_BF
expression status;
-status->vht_flag & RX_VHT_FLAG_BF
+status->enc_flags & RX_ENC_FLAG_BF
expression status, STBC;
-status->flag op STBC << RX_FLAG_STBC_SHIFT
+status->enc_flags op STBC << RX_ENC_FLAG_STBC_SHIFT
expression status;
-status.flag op RX_FLAG_SHORTPRE
+status.enc_flags op RX_ENC_FLAG_SHORTPRE
expression status;
-status.flag & RX_FLAG_SHORTPRE
+status.enc_flags & RX_ENC_FLAG_SHORTPRE
expression status;
-status.flag op RX_FLAG_HT
+status.enc_flags op RX_ENC_FLAG_HT
expression status;
-status.flag & RX_FLAG_HT
+status.enc_flags & RX_ENC_FLAG_HT
expression status;
-status.flag op RX_FLAG_40MHZ
+status.enc_flags op RX_ENC_FLAG_40MHZ
expression status;
-status.flag & RX_FLAG_40MHZ
+status.enc_flags & RX_ENC_FLAG_40MHZ
expression status;
-status.flag op RX_FLAG_SHORT_GI
+status.enc_flags op RX_ENC_FLAG_SHORT_GI
expression status;
-status.flag & RX_FLAG_SHORT_GI
+status.enc_flags & RX_ENC_FLAG_SHORT_GI
expression status;
-status.flag op RX_FLAG_HT_GF
+status.enc_flags op RX_ENC_FLAG_HT_GF
expression status;
-status.flag & RX_FLAG_HT_GF
+status.enc_flags & RX_ENC_FLAG_HT_GF
expression status;
-status.flag op RX_FLAG_VHT
+status.enc_flags op RX_ENC_FLAG_VHT
expression status;
-status.flag & RX_FLAG_VHT
+status.enc_flags & RX_ENC_FLAG_VHT
expression status;
-status.flag op RX_FLAG_STBC_MASK
+status.enc_flags op RX_ENC_FLAG_STBC_MASK
expression status;
-status.flag & RX_FLAG_STBC_MASK
+status.enc_flags & RX_ENC_FLAG_STBC_MASK
expression status;
-status.flag op RX_FLAG_LDPC
+status.enc_flags op RX_ENC_FLAG_LDPC
expression status;
-status.flag & RX_FLAG_LDPC
+status.enc_flags & RX_ENC_FLAG_LDPC
expression status;
-status.flag op RX_FLAG_10MHZ
+status.enc_flags op RX_ENC_FLAG_10MHZ
expression status;
-status.flag & RX_FLAG_10MHZ
+status.enc_flags & RX_ENC_FLAG_10MHZ
expression status;
-status.flag op RX_FLAG_5MHZ
+status.enc_flags op RX_ENC_FLAG_5MHZ
expression status;
-status.flag & RX_FLAG_5MHZ
+status.enc_flags & RX_ENC_FLAG_5MHZ
expression status;
-status.vht_flag op RX_VHT_FLAG_80MHZ
+status.enc_flags op RX_ENC_FLAG_80MHZ
expression status;
-status.vht_flag & RX_VHT_FLAG_80MHZ
+status.enc_flags & RX_ENC_FLAG_80MHZ
expression status;
-status.vht_flag op RX_VHT_FLAG_160MHZ
+status.enc_flags op RX_ENC_FLAG_160MHZ
expression status;
-status.vht_flag & RX_VHT_FLAG_160MHZ
+status.enc_flags & RX_ENC_FLAG_160MHZ
expression status;
-status.vht_flag op RX_VHT_FLAG_BF
+status.enc_flags op RX_ENC_FLAG_BF
expression status;
-status.vht_flag & RX_VHT_FLAG_BF
+status.enc_flags & RX_ENC_FLAG_BF
-status.flag op STBC << RX_FLAG_STBC_SHIFT
+status.enc_flags op STBC << RX_ENC_FLAG_STBC_SHIFT
-RX_FLAG_STBC_SHIFT
+RX_ENC_FLAG_STBC_SHIFT
Set the NL80211_EXT_FEATURE_CQM_RSSI_LIST wiphy extended feature
wholesale in all mac80211-based drivers that do not set the
IEEE80211_VIF_BEACON_FILTER flags on their interfaces. mac80211 will
be processing supplied RSSI values in ieee80211_rx_mgmt_beacon and
will detect when the thresholds set by
ieee80211_set_cqm_rssi_range_config are crossed. Remaining (few)
drivers need code to enable the firmware to monitor the thresholds.
This is mostly only compile-tested.
Signed-off-by: Andrew Zaborowski <andrew.zaborowski@intel.com>
Pull networking updates from David Miller:
1) BBR TCP congestion control, from Neal Cardwell, Yuchung Cheng and
co. at Google. https://lwn.net/Articles/701165/
2) Do TCP Small Queues for retransmits, from Eric Dumazet.
3) Support collect_md mode for all IPV4 and IPV6 tunnels, from Alexei
Starovoitov.
4) Allow cls_flower to classify packets in ip tunnels, from Amir Vadai.
5) Support DSA tagging in older mv88e6xxx switches, from Andrew Lunn.
6) Support GMAC protocol in iwlwifi mwm, from Ayala Beker.
7) Support ndo_poll_controller in mlx5, from Calvin Owens.
8) Move VRF processing to an output hook and allow l3mdev to be
loopback, from David Ahern.
9) Support SOCK_DESTROY for UDP sockets. Also from David Ahern.
10) Congestion control in RXRPC, from David Howells.
11) Support geneve RX offload in ixgbe, from Emil Tantilov.
12) When hitting pressure for new incoming TCP data SKBs, perform a
partial rathern than a full purge of the OFO queue (which could be
huge). From Eric Dumazet.
13) Convert XFRM state and policy lookups to RCU, from Florian Westphal.
14) Support RX network flow classification to igb, from Gangfeng Huang.
15) Hardware offloading of eBPF in nfp driver, from Jakub Kicinski.
16) New skbmod packet action, from Jamal Hadi Salim.
17) Remove some inefficiencies in snmp proc output, from Jia He.
18) Add FIB notifications to properly propagate route changes to
hardware which is doing forwarding offloading. From Jiri Pirko.
19) New dsa driver for qca8xxx chips, from John Crispin.
20) Implement RFC7559 ipv6 router solicitation backoff, from Maciej
Żenczykowski.
21) Add L3 mode to ipvlan, from Mahesh Bandewar.
22) Support 802.1ad in mlx4, from Moshe Shemesh.
23) Support hardware LRO in mediatek driver, from Nelson Chang.
24) Add TC offloading to mlx5, from Or Gerlitz.
25) Convert various drivers to ethtool ksettings interfaces, from
Philippe Reynes.
26) TX max rate limiting for cxgb4, from Rahul Lakkireddy.
27) NAPI support for ath10k, from Rajkumar Manoharan.
28) Support XDP in mlx5, from Rana Shahout and Saeed Mahameed.
29) UDP replicast support in TIPC, from Richard Alpe.
30) Per-queue statistics for qed driver, from Sudarsana Reddy Kalluru.
31) Support BQL in thunderx driver, from Sunil Goutham.
32) TSO support in alx driver, from Tobias Regnery.
33) Add stream parser engine and use it in kcm.
34) Support async DHCP replies in ipconfig module, from Uwe
Kleine-König.
35) DSA port fast aging for mv88e6xxx driver, from Vivien Didelot.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1715 commits)
mlxsw: switchx2: Fix misuse of hard_header_len
mlxsw: spectrum: Fix misuse of hard_header_len
net/faraday: Stop NCSI device on shutdown
net/ncsi: Introduce ncsi_stop_dev()
net/ncsi: Rework the channel monitoring
net/ncsi: Allow to extend NCSI request properties
net/ncsi: Rework request index allocation
net/ncsi: Don't probe on the reserved channel ID (0x1f)
net/ncsi: Introduce NCSI_RESERVED_CHANNEL
net/ncsi: Avoid unused-value build warning from ia64-linux-gcc
net: Add netdev all_adj_list refcnt propagation to fix panic
net: phy: Add Edge-rate driver for Microsemi PHYs.
vmxnet3: Wake queue from reset work
i40e: avoid NULL pointer dereference and recursive errors on early PCI error
qed: Add RoCE ll2 & GSI support
qed: Add support for memory registeration verbs
qed: Add support for QP verbs
qed: PD,PKEY and CQ verb support
qed: Add support for RoCE hw init
qede: Add qedr framework
Ben Greear reported:
> I see lots of instability as soon as I load up the carl9710 NIC.
> My application is going to be poking at it's debugfs files...
> BUG: KASAN: slab-out-of-bounds in carl9170_debugfs_read+0xd5/0x2a0
> [carl9170] at addr 0xffff8801bc1208b0
> Read of size 8 by task btserver/5888
> BUG kmalloc-256 (Tainted: G W ): kasan: bad access detected
> INFO: Allocated in seq_open+0x50/0x100 age=2690 cpu=2 pid=772
This breakage was caused by the introduction of intermediate
fops in debugfs by commit 9fd4dcece43a
("debugfs: prevent access to possibly dead file_operations at file open")
Thankfully, the original/real fops are still available in d_fsdata.
Reported-by: Ben Greear <greearb@candelatech.com>
Cc: stable <stable@vger.kernel.org> # 4.7+
carl9170_usb_stop() is used from several places to flush and cleanup any
pending work. The normal pattern is to send a request and wait for the
irq handler to call complete(). The completion is not reinitialized
during normal operation and as the old comment indicates it is important
to keep calls to wait_for_completion_timeout() and complete() balanced.
Calling complete_all() brings this equilibirum out of balance and needs
to be fixed by a reinit_completion(). But that opens a small race
window. It is possible that the sequence of complete_all(),
reinit_completion() is faster than the wait_for_completion_timeout() can
do its work. The wake up is not lost but the done counter test is after
reinit_completion() has been executed. The only reason we don't see
carl9170_exec_cmd() hang forever is we use the timeout version of
wait_for_copletion().
Let's fix this by reinitializing the completion (that is just setting
done counter to 0) just before we send out an request. Now,
carl9170_usb_stop() can be sure a complete() call is enough to make
progess since there is only one waiter at max. This is a common pattern
also seen in various drivers which use completion.
Signed-off-by: Daniel Wagner <daniel.wagner@bmw-carit.de>
Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
The previous text was confusing, leading readers to think this
driver was a duplicate, and so didn't need to be enabled.
After the removal of the older staging driver, this is the only
driver in mainline for these devices.
Signed-off-by: Lauri Kasanen <cand@gmx.com>
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
This enum is already perfectly aliased to enum nl80211_band, and
the only reason for it is that we get IEEE80211_NUM_BANDS out of
it. There's no really good reason to not declare the number of
bands in nl80211 though, so do that and remove the cfg80211 one.
Import new headers from my firmware branch:
<https://github.com/chunkeey/carl9170fw>
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
Currently mac80211 does not inform the driver of the session
block ack timeout when starting a rx aggregation session.
Drivers that manage the reorder buffer need to know this
parameter.
Seeing that there are now too many arguments for the
drv_ampdu_action() function, wrap them inside a structure.
Signed-off-by: Sara Sharon <sara.sharon@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvalo/wireless-drivers-next
Kalle Valo says:
Major changes:
iwlwifi
* some debugfs improvements
* fix signedness in beacon statistics
* deinline some functions to reduce size when device tracing is enabled
* filter beacons out in AP mode when no stations are associated
* deprecate firmwares version -12
* fix a runtime PM vs. legacy suspend race
* one-liner fix for a ToF bug
* clean-ups in the rx code
* small debugging improvement
* fix WoWLAN with new firmware versions
* more clean-ups towards multiple RX queues;
* some rate scaling fixes and improvements;
* some time-of-flight fixes;
* other generic improvements and clean-ups;
brcmfmac
* rework code dealing with multiple interfaces
* allow logging firmware console using debug level
* support for BCM4350, BCM4365, and BCM4366 PCIE devices
* fixed for legacy P2P and P2P device handling
* correct set and get tx-power
ath9k
* add support for Outside Context of a BSS (OCB) mode
mwifiex
* add USB multichannel feature
Fix rssi calculation error which was introduced in otus to ar9170
porting.
Signed-off-by: Hiroaki KAWAI <hiroaki.kawai@gmail.com>
Advertise the capability to send A-MSDU within A-MPDU
in the AddBA request sent by mac80211. Let the driver
know about the peer's capabilities.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
As we're running out of hardware capability flags pretty quickly,
convert them to use the regular test_bit() style unsigned long
bitmaps.
This introduces a number of helper functions/macros to set and to
test the bits, along with new debugfs code.
The occurrences of an explicit __clear_bit() are intentional, the
drivers were never supposed to change their supported bits on the
fly. We should investigate changing this to be a per-frame flag.
Return type of wait_for_completion_timeout is unsigned long not int.
An appropriately named unsigned long is added, and the assignments
as well as error checking fixed up.
API conformance testing for completions with coccinelle spatches are being
used to locate API usage inconsistencies:
./drivers/net/wireless/ath/carl9170/usb.c:675
int return assigned to unsigned long
Patch was compile tested with x86_64_defconfig + CONFIG_ATH_CARDS=m,
CONFIG_CARL9170=m
Patch is against 4.1-rc3 (localversion-next is -next-20150512)
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
This is just a code cleanup, make the LED trigger names const
as they're not expected to be modified by drivers.
This support is essentially useless as typically networks are encrypted,
frames will be filtered by hardware, and rate scaling will be done with
the intended recipient in mind. For real monitoring of the network, the
monitor mode support should be used instead.
Removing it removes a lot of corner cases.
printk and friends can now format bitmaps using '%*pb[l]'. cpumask
and nodemask also provide cpumask_pr_args() and nodemask_pr_args()
respectively which can be used to generate the two printf arguments
necessary to format the specified cpu/nodemask.
Cc: "John W. Linville" <linville@tuxdriver.com>
All of the survey data is (currently) per channel anyway,
so having the word "channel" in the name does nothing. In
the next patch I'll introduce global data to the survey,
where the word "channel" is actually confusing.
Use the inline function instead of directly indexing the array.
This allows some architectures with hardware instructions
for bit reversals to eliminate the array.
According to RCU_INIT_POINTER()'s block comment 3.a, it can be used if
"3. The referenced data structure has already been exposed to readers either
at compile time or via rcu_assign_pointer() -and-
a. You have not made -any- reader-visible changes to this structure since
then".
This case fulfills the conditions above because between the rcu_dereference()
call (cvif = rcu_dereference(ar->beacon_iter);) and the rcu_assign_pointer()
call there is no update of the "cvif" variable.
Therefore, this patch makes the replacement.
The following Coccinelle semantic patch was used:
identifier v;
v = rcu_dereference(...);
... when != rcu_dereference(...);
when != v = ...;
when != (<+...v...+>)++;
when != \(memcpy\|memset\)(...);
- rcu_assign_pointer
+ RCU_INIT_POINTER
(..., v);
if(...) {
... when != v = ...;
+ RCU_INIT_POINTER
(..., v);
... when any
Because there are cases where between a “rcu_dereference()” call and a
“rcu_assign_pointer()” call might be updates of the value that interests us,
the Coccinelle semantic patch ignores them and replaces with
"RCU_INIT_POINTER()" only when the update is not happening.
Signed-off-by: Andreea-Cristina Bernat <bernat.ada@gmail.com>
The carl9170_op_ampdu_action() function is used only by the mac80211
framework.
Since the mac80211 already takes care of checks and properly serializing
calls to the driver's function there is no need for the driver to do the same
thing.
The driver assumes that endpoint 4 is always an interrupt endpoint.
Unfortunately the type differs between high-speed and full-speed
configurations while in the former case it is indeed an interrupt
endpoint this is not true for the latter case - here it is a bulk
endpoint. When sending URBs with the wrong type the kernel will
generate a warning message including backtrace. In this specific
case there will be a huge amount of warnings which can bring the system
to freeze.
To fix this we are now sending URBs to endpoint 4 using the type
found in the endpoint descriptor.
A side note: The carl9170 firmware currently specifies endpoint 4 as
interrupt endpoint even in the full-speed configuration but this has
no relevance because before this firmware is loaded the endpoint type
is as described above and after the firmware is running the stick is not
reenumerated and so the old descriptor is used.
Signed-off-by: Ronald Wahl <ronald.wahl@raritan.com>
Signed-off-by: Fabian Frederick <fabf@skynet.be>
carl9170_usb_probe() does not handle request_firmware_nowait() failure
that leads to several leaks in this case.
The patch adds all required deallocations.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
This will allow the low level driver to make decision based
on the vif such as queues etc...
Since the vif might be NULL, we can't add it to the tracing
functions.
[fix staging rtl8821ae driver]
Casting a pointer to a pointer of the same type is pointless,
so remove these unnecessary casts.
Done via coccinelle script:
$ cat typecast_2.cocci
type T;
T *foo;
- (T *)foo
+ foo
Signed-off-by: Oleksij Rempel <linux@rempel-privat.de>
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
This value is no longer used by mac80211, and practically no
driver ever set it to a correct value anyway, so remove it.
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com>
Ether_addr_equal_64bits is more efficient than ether_addr_equal, and can be
used when each argument is an array within a structure that contains at
least two bytes of data beyond the array.
The structures involved are:
ieee80211_hdr defined in include/linux/ieee80211.h,
ieee80211_bar defined in include/linux/ieee80211.h and
ath_common defined in drivers/net/wireless/ath/ath.h
This was done using Coccinelle (http://coccinelle.lip6.fr/).
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Use this new function to make code more comprehensible, since we are
reinitialzing the completion, not initializing.
[akpm@linux-foundation.org: linux-next resyncs]
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13)
Use the new bool function ether_addr_equal to add
some clarity and reduce the likelihood for misuse
of compare_ether_addr for sorting.
Done via cocci script: (and a little typing)
$ cat compare_ether_addr.cocci
expression a,b;
- !compare_ether_addr(a, b)
+ ether_addr_equal(a, b)
expression a,b;
- compare_ether_addr(a, b)
+ !ether_addr_equal(a, b)
expression a,b;
- !ether_addr_equal(a, b) == 0
expression a,b;
- !ether_addr_equal(a, b) != 0
expression a,b;
- ether_addr_equal(a, b) == 0
expression a,b;
- ether_addr_equal(a, b) != 0
expression a,b;
- !!ether_addr_equal(a, b)
brcm80211 cannot handle sending frames with CCK rates as part of an
A-MPDU session. Other drivers may have issues too. Set the flag in all
drivers that have been tested with CCK rates.
This fixes a reported brcmsmac regression introduced in
commit ef47a5e4f1aaf1d0e2e6875e34b2c9595897bef6
"mac80211/minstrel_ht: fix cck rate sampling"
Cc: stable@vger.kernel.org # 3.10
Reported-by: Tom Gundersen <teg@jklm.no>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
With the new rate control API, the driver can now apply the
tx rate to outgoing frames just before they are uploaded to
the device. This is important because the rate control can
now react to fading or improving links a bit sooner.
Also, the driver no longer needs to sort the outgoing frames
for sample attempts (which affected the size of A-MPDUs and
the throughput of the link). For aggregated data frames, the
driver (and rate control) needs only to calculate and apply
a single set of tx rates to every subframe of the whole
aggregate.
drivers/net/wireless/ath/carl9170/debug.c
drivers/net/wireless/ath/carl9170/main.c
net/mac80211/ieee80211_i.h
Marco Fonseca reported a issue with his carl9170 device:
"I'm seeing a problem with the carl driver. If I change channels
repeatedly on the 2.4ghz band, monitoring (e.g. tcpdump) will
eventually halt. I've seen this on various versions of the carl
driver/firmware (both from 1.9.4 to 1.9.7)"
<http://marc.info/?l=linux-wireless&m=136381302428113>
The culprit was identified as "fast channel change feature" which
according to Adrian Chadd is: "... notoriously unreliable and
really only fully debugged on some very later chips."
<http://marc.info/?l=linux-wireless&m=136416984531380>
Therefore, this patch removes the fast channel change feature.
The phy will now always have to go through a cold reset when
changing channels, but it should no longer become deaf.
Cc: Marco Fonseca <marco@tampabay.rr.com>
Drivers that don't use chanctxes cannot perform VHT association because
they still use a "backward compatibility" pair of {ieee80211_channel,
nl80211_channel_type} in ieee80211_conf and ieee80211_local.
Signed-off-by: Karl Beldan <karl.beldan@rivierawaves.com>
[fix kernel-doc]
There are a number of situations in which mac80211 only
really needs to flush queues for one virtual interface,
and in fact during this frames might be transmitted on
other virtual interfaces. Calculate and pass a queue
bitmap to the driver so it knows which queues to flush.
With "mac80211/minstrel_ht: add support for using CCK rates"
minstrel_ht selects legacy CCK rates as viable rates for
outgoing frames which might be sent as part of an A-MPDU
[IEEE80211_TX_CTL_AMPDU is set].
This behavior triggered the following WARN_ON in the driver:
> WARNING: at carl9170/tx.c:995 carl9170_op_tx+0x1dd/0x6fd
The driver assumed that the rate control algorithm made a
mistake and dropped the frame.
This patch removes the noisy warning altogether and allows
said A-MPDU frames with CCK sample and/or fallback rates to
be transmitted seamlessly.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core patches from Greg Kroah-Hartman:
"Here is the big driver core merge for 3.9-rc1
There are two major series here, both of which touch lots of drivers
all over the kernel, and will cause you some merge conflicts:
- add a new function called devm_ioremap_resource() to properly be
able to check return values.
- remove CONFIG_EXPERIMENTAL
Other than those patches, there's not much here, some minor fixes and
updates"
Fix up trivial conflicts
* tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits)
base: memory: fix soft/hard_offline_page permissions
drivercore: Fix ordering between deferred_probe and exiting initcalls
backlight: fix class_find_device() arguments
TTY: mark tty_get_device call with the proper const values
driver-core: constify data for class_find_device()
firmware: Ignore abort check when no user-helper is used
firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER
firmware: Make user-mode helper optional
firmware: Refactoring for splitting user-mode helper code
Driver core: treat unregistered bus_types as having no devices
watchdog: Convert to devm_ioremap_resource()
thermal: Convert to devm_ioremap_resource()
spi: Convert to devm_ioremap_resource()
power: Convert to devm_ioremap_resource()
mtd: Convert to devm_ioremap_resource()
mmc: Convert to devm_ioremap_resource()
mfd: Convert to devm_ioremap_resource()
media: Convert to devm_ioremap_resource()
iommu: Convert to devm_ioremap_resource()
drm: Convert to devm_ioremap_resource()
Currently, when the driver requires the DTIM period,
mac80211 will wait to hear a beacon before association.
This behavior is suboptimal since some drivers may be
able to deal with knowing the DTIM period after the
association, if they get it at all.
To address this, notify the drivers with bss_info_changed
with the new BSS_CHANGED_DTIM_PERIOD flag when the DTIM
becomes known. This might be when changing to associated,
or later when the entire association was done with only
probe response information.
Rename the hardware flag for the current behaviour to
IEEE80211_HW_NEED_DTIM_BEFORE_ASSOC to more accurately
reflect its behaviour. IEEE80211_HW_NEED_DTIM_PERIOD is
no longer accurate as all drivers get the DTIM period
now, just not before association.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
drivers/net/wireless/ath/ath9k/main.c
drivers/net/wireless/iwlwifi/dvm/tx.c
