path: root/drivers/net/wireless/atmel.c
2011-06-06net: remove interrupt.h inclusion from netdevice.hAlexey Dobriyan
* remove interrupt.g inclusion from netdevice.h -- not needed * fixup fallout, add interrupt.h and hardirq.h back where needed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-22atmel: Use static constJoe Perches
Using static const generally increases object text and decreases data size. It also generally decreases overall object size. text data bss dec hex filename 42578 720 8528 51826 ca72 drivers/net/wireless/atmel.o.old 42578 720 8528 51826 ca72 drivers/net/wireless/atmel.o.new Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-11atmel: declare MODULE_FIRMWAREBen Hutchings
Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-09-21trivial: fix typos "man[ae]g?ment" -> "management"Uwe Kleine-Koenig
Signed-off-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-01wireless: convert drivers to netdev_tx_tStephen Hemminger
Mostly just simple conversions: * ray_cs had bogus return of NET_TX_LOCKED but driver was not using NETIF_F_LLTX * hostap and ipw2x00 had some code that returned value from a called function that also had to change to return netdev_tx_t Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13net: use symbolic values for ndo_start_xmit() return codesPatrick McHardy
Convert magic values 1 and -1 to NETDEV_TX_BUSY and NETDEV_TX_LOCKED respectively. 0 (NETDEV_TX_OK) is not changed to keep the noise down, except in very few cases where its in direct proximity to one of the other values. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-21atmel: fix netdev ops conversionJohannes Berg
sparse says: drivers/net/wireless/atmel.c:1501:3: warning: Initializer entry defined twice drivers/net/wireless/atmel.c:1505:3: also defined here and it's correct; atmel has its own ndo_change_mtu and shouldn't use eth_change_mtu. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-21atmel: convert to net_device_opsStephen Hemminger
2009-03-16atmel: checkpatch.pl cleanupsJohn Daiker
Before: 881 errors, 265 warnings, 4507 lines checked After: 114 errors, 273 warnings, 4548 lines checked This was mostly "space required after that ',' (ctx:VxV)". Also a fair number of whitespace, code indent, and C99 comment cleanups. New warnings introduced are all "line over 80 character" md5sums are identical, as I skipped any fixes which may have altered the resulting binary. Signed-off-by: John Daiker <daikerjohn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29wireless: Add channel/frequency conversions to ieee80211.hDavid Kilroy
Added mappings for FHSS, DSSS and OFDM channels - with macros to point HR DSSS and ERP to the DSSS mappings. Currently just static inline functions. Use the new functions in the older fullmac drivers. This eliminates a number of const static buffers and removes a couple of range checks that are now redundant. Signed-off-by: David Kilroy <kilroyd@googlemail.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Richard Farina <sidhayn@gmail.com> Acked-by: Jeroen Vreeken <pe1rxq@amsat.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-06trivial: Fix misspelling of "firmware" in atmel.cNick Andrew
Fix misspelling of "firmware" in atmel.c It's spelled "firmware". Signed-off-by: Nick Andrew <nick@nick-andrew.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-12-26drivers/net/wireless: fix sparse warnings: make symbols staticHannes Eder
Fix this sparse warnings: drivers/net/wireless/airo.c:3610:6: warning: symbol 'mpi_receive_802_11' was not declared. Should it be static? drivers/net/wireless/atmel.c:3183:6: warning: symbol 'atmel_join_bss' was not declared. Should it be static? drivers/net/wireless/ray_cs.c:831:5: warning: symbol 'ray_dev_init' was not declared. Should it be static? Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-10don't use net/ieee80211.hJohannes Berg
Convert all the drivers using net/ieee80211.h to use linux/ieee80211.h. Contains a bugfix in libertas where the SSID parsing could overrun the buffer when the AP sends invalid information. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Dan Williams <dcbw@redhat.com> [airo, libertas] Acked-by: Pavel Roskin <proski@gnu.org> [orinoco] Acked-by: David Kilroy <kilroyd@googlemail.com> [orinoco] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-24wireless: Read scan flags correctly on x86-64David Kilroy
The SIOCSIWSCAN handler is passed data in an iw_point structure. Some drivers erronously use an iw_param instead. On 32 bit architectures the difference isn't noticed as the flags parameter tends to be the only one used by scan handlers and is at the same offset. On 64 bit architectures the pointer in the iw_point structure means the flag parameter is at different offsets in these structures. Thanks to Jean Tourrilhes for tracking this down for orinoco, and Pavel Roskin for confirming the fix and identifying other suspect handlers. Signed-off-by: David Kilroy <kilroyd@googlemail.com> Acked-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-26atmel: try open system authentication tooDan Williams
When the AP rejects a Shared Key authentication request, try Open System auth too. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-26atmel: return ENOENT on request_firmware failureDan Williams
Return errors from request_firmware() (like other drivers that do firmware load on device open) and make up plausible codes for other error conditions. Gives userspace tools like NetworkManager a clue that firmware may be missing when the result of setting IFF_UP is ENOENT. Signed-off-by: Dan Williams <dcbw@redhat.com> v2: fix reversed check of atmel_wakeup_firmware() in probe_atmel_card() Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/powerpc/booting-without-of.txt drivers/atm/Makefile drivers/net/fs_enet/fs_enet-main.c drivers/pci/pci-acpi.c net/8021q/vlan.c net/iucv/iucv.c
2008-07-10atmel: treat firmware data as constDavid Woodhouse
2008-06-16wext: Emit event stream entries correctly when compat.David S. Miller
Three major portions to this change: 1) Add IW_EV_COMPAT_LCP_LEN, IW_EV_COMPAT_POINT_OFF, and IW_EV_COMPAT_POINT_LEN helper defines. 2) Delete iw_stream_check_add_*(), they are unused. 3) Add iw_request_info argument to iwe_stream_add_*(), and use it to size the event and pointer lengths correctly depending upon whether IW_REQUEST_FLAG_COMPAT is set or not. 4) The mechanical transformations to the drivers and wireless stack bits to get the iw_request_info passed down into the routines modified in #3. Also, explicit references to IW_EV_LCP_LEN are replaced with iwe_stream_lcp_len(info). With a lot of help and bug fixes from Masakazu Mokuno. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-10Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/tg3.c drivers/net/wireless/rt2x00/rt2x00dev.c net/mac80211/ieee80211_i.h
2008-05-16byteorder: don't directly include linux/byteorder/generic.hHarvey Harrison
Use asm/byteorder.h instead. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14atmel: use netstats in net_device structurePaulius Zaleckas
Use net_device_stats from net_device structure instead of local. Kill atmel_get_stats function, because by default it is used identical internal_stats function from net/core/dev.c No need to memset stats to 0, because they are allocated by kzalloc. P.S. Someone should cleanup init_atmel_card function from unneeded initializations to 0/NULL. Out of scope for this patch. Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29drivers/net/wireless/atmel.c: Use time_* macrosS.Çağlar Onur
The functions time_before, time_before_eq, time_after, and time_after_eq are more robust for comparing jiffies against other values. So following patch implements usage of the time_after() macro, defined at linux/jiffies.h, which deals with wrapping correctly Cc: linux-wireless@vger.kernel.org Signed-off-by: S.Çağlar Onur <caglar@pardus.org.tr> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28misc wireless annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28wireless: checkpatch cleanupsJeff Garzik
2008-01-28wireless: fix '!x & y' typo'sRoel Kluin
Fix priority mistakes similar to '!x & y' Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[PATCH] atmel: output signal strength informationHolden Karau
Output signal strength information as part of iwlist scan - before it did not output any signal strength related information. Signed-off-by: Holden Karau <holden@pigscanfly.ca> Cc: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-02[PATCH] atmel: whitespace cleanupDmitry Torokhov
NET: atmel: whitespace cleanup Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-02[PATCH] atmel: use ARRAY_SIZE()Dmitry Torokhov
NET: atmel - switch to using ARRAY_SIZE() Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-02[PATCH] atmel: save on array initializationDmitry Torokhov
NET: atmel - do not initialize array over and over again Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-10-16[PATCH] wireless: More WE-21 potential overflows...Jean Tourrilhes
After the Orinoco issue, I did an audit of other drivers for the same issue. Three drivers were NULL terminating the ESSID, which could cause an overflow in WE-21 when the ESSID has maximum size. Signed-off-by: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-25[PATCH] WE-21 for atmelJean Tourrilhes
Signed-off-by: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-19[PATCH] wireless/atmel: send WEXT scan completion eventsDan Williams
Send scan completion events to user space when a scan completes. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-02-17[PATCH] wireless/atmel: convert constants to ieee80211 layer equivalentsDan Williams
This patch converts the Atmel driver-only IEEE 802.11 constants to their equivalents from the kernel's ieee80211 layer headers. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-02-17[PATCH] wireless/atmel: fix Open System authentication process bugsDan Williams
This patch fixes a number of bugs in the authentication process: 1) When falling back to Shared Key authentication mode from Open System, a missing 'return' would cause the auth request to be sent, but would drop the card into Management Error state. When falling back, the driver should also indicate that it is switching to Shared Key mode by setting exclude_unencrypted. 2) Initial authentication modes were apparently wrong in some cases, causing the driver to attempt Shared Key authentication mode when in fact the access point didn't support that mode or even had WEP disabled. The driver should set the correct initial authentication mode based on wep_is_on and exclude_unencrypted. 3) Authentication response packets from the access point in Open System mode were getting ignored because the driver was expecting the sequence number of a Shared Key mode response. The patch separates the OS and SK mode handling to provide the correct behavior. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-02-17[PATCH] wireless/atmel: fix setting TX key only in ENCODEEXTDan Williams
The previous patch that added ENCODEEXT and AUTH support to the atmel driver contained a slight error which would cause just setting the TX key index to also set the encryption key again. This patch allows any combination of setting the TX key index and setting an encryption key. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-01-16[PATCH] drivers/net/wireless: correct reported ssid lengthsDan Williams
ESSIDs can technically include NULL characters. Drivers should not be adjusting the length of the ESSID before reporting it in their SIOCGIWESSID handlers. Breaks stuff like wpa_supplicant. Note that ipw drivers, which seem to currently be the "most correct", don't have this problem. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
