Use the built-in function instead of memset.
Miscellanea:
Add #include <linux/etherdevice.h> where appropriate
Use ETH_ALEN instead of 6
The kernel's string library does in fact have strcasecmp, at least
since ded220bd8f08 ("[STRING]: Move strcasecmp/strncasecmp to
lib/string.c"). Moreover, this open-coded version is in fact wrong: If
the strings only differ in their last character, a and b have already
been incremented to point to the terminating NUL bytes, so they would
wrongly be treated as equal.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
The Linux kernel coding style guidelines suggest not using typedefs
for structure types. This patch gets rid of the typedef for
atmel_priv_ioctl.
The following Coccinelle semantic patch detects the case:
@tn@
identifier i;
type td;
-typedef
struct i { ... }
-td
type tn.td;
identifier tn.i;
-td
+ struct i
Signed-off-by: Himangi Saraogi <himangi774@gmail.com>
Acked-by: Julia Lawall <julia.lawall@lip6.fr>
Replace ieee80211_{dsss_chan_to_freq, freq_to_dsss_chan} with more
generic ieee80211_{channel_to_frequency, frequency_to_channel}.
Include <net/cfg80211.h> for the defination of IEEE80211_BAND_2GHZ.
Because <net/cfg80211.h> includes <linux/ieee80211.h>, so we can
replace <linux/ieee80211.h> with <net/cfg80211.h>.
This change is a preparation for the removal of function
ieee80211_{dsss_chan_to_freq, freq_to_dsss_chan}.
Cc: Simon Kelley <simon@thekelleys.org.uk>
Signed-off-by: Zhao, Gang <gamerh2o@gmail.com>
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com>
Several files refer to an old address for the Free Software Foundation
in the file header comment. Resolve by replacing the address with
the URL <http://www.gnu.org/licenses/> so that we do not have to keep
updating the header comments anytime the address changes.
CC: linux-wireless@vger.kernel.org
CC: Simon Kelley <simon@thekelleys.org.uk>
CC: Christian Lamparter <chunkeey@googlemail.com>
CC: Jussi Kivilinna <jussi.kivilinna@iki.fi>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
drivers/net/wireless/brcm80211/brcmfmac/sdio_host.h
There is a typo where the checking for priv->ReAssociationRequestRetryCnt must
be, it was checking for priv->AssociationRequestRetryCnt instead.
Signed-off-by: Felipe Pena <felipensp@gmail.com>
Convert the memset/memcpy uses of 6 to ETH_ALEN
where appropriate.
Also convert some struct definitions and u8 array
declarations of [6] to ETH_ALEN.
Acked-by: Arend van Spriel <arend@broadcom.com>
There was an extra ';' character added to the end of the if statement
which means that it always prints that the /proc entry wasn't created
even though it was.
Cc: stable@vger.kernel.org
Don't use create_proc_read_entry() as that is deprecated, but rather use
proc_create_data() and seq_file instead.
cc: Simon Kelley <simon@thekelleys.org.uk>
cc: John W. Linville <linville@tuxdriver.com>
cc: linux-wireless@vger.kernel.org
cc: netdev@vger.kernel.org
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Adding casts of objects to the same type is unnecessary
and confusing for a human reader.
For example, this cast:
int y;
int *p = (int *)&y;
I used the coccinelle script below to find and remove these
unnecessary casts. I manually removed the conversions this
script produces of casts with __force, __iomem and __user.
type T;
T *p;
- (T *)p
+ p
Neatened the mwifiex_deauthenticate_infra function which
was doing odd things with array pointers and not using
is_zero_ether_addr.
release_firmware() does its own test. Explicitly checking before the
call is redundant.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
alloc_etherdev has a generic OOM/unable to alloc message.
Remove the duplicative messages after alloc_etherdev calls.
* remove interrupt.g inclusion from netdevice.h -- not needed
* fixup fallout, add interrupt.h and hardirq.h back where needed.
Using static const generally increases object text and decreases data size.
It also generally decreases overall object size.
42578 720 8528 51826 ca72 drivers/net/wireless/atmel.o.old
42578 720 8528 51826 ca72 drivers/net/wireless/atmel.o.new
Now that core network takes care of trans_start updates, dont do it
in drivers themselves, if possible. Drivers can avoid one cache miss
(on dev->trans_start) in their start_xmit() handler.
Exceptions are NETIF_F_LLTX drivers
Signed-off-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de>
Mostly just simple conversions:
* ray_cs had bogus return of NET_TX_LOCKED but driver
was not using NETIF_F_LLTX
* hostap and ipw2x00 had some code that returned value
from a called function that also had to change to return netdev_tx_t
This patch is the result of an automatic spatch transformation to convert
all ndo_start_xmit() return values of 0 to NETDEV_TX_OK.
Some occurences are missed by the automatic conversion, those will be
handled in a seperate patch.
Convert magic values 1 and -1 to NETDEV_TX_BUSY and NETDEV_TX_LOCKED respectively.
0 (NETDEV_TX_OK) is not changed to keep the noise down, except in very few cases
where its in direct proximity to one of the other values.
sparse says:
drivers/net/wireless/atmel.c:1501:3: warning: Initializer entry defined twice
drivers/net/wireless/atmel.c:1505:3: also defined here
and it's correct; atmel has its own ndo_change_mtu and
shouldn't use eth_change_mtu.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Before: 881 errors, 265 warnings, 4507 lines checked
After: 114 errors, 273 warnings, 4548 lines checked
This was mostly "space required after that ',' (ctx:VxV)".
Also a fair number of whitespace, code indent, and C99 comment cleanups.
New warnings introduced are all "line over 80 character"
md5sums are identical, as I skipped any fixes which may have altered the resulting binary.
Signed-off-by: John Daiker <daikerjohn@gmail.com>
Added mappings for FHSS, DSSS and OFDM channels - with macros to point
HR DSSS and ERP to the DSSS mappings. Currently just static inline
functions.
Use the new functions in the older fullmac drivers. This eliminates a
number of const static buffers and removes a couple of range checks that
are now redundant.
Signed-off-by: David Kilroy <kilroyd@googlemail.com>
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Acked-by: Richard Farina <sidhayn@gmail.com>
Acked-by: Jeroen Vreeken <pe1rxq@amsat.org>
Fix misspelling of "firmware" in atmel.c
It's spelled "firmware".
Signed-off-by: Nick Andrew <nick@nick-andrew.net>
Fix this sparse warnings:
drivers/net/wireless/airo.c:3610:6: warning: symbol 'mpi_receive_802_11' was not declared. Should it be static?
drivers/net/wireless/atmel.c:3183:6: warning: symbol 'atmel_join_bss' was not declared. Should it be static?
drivers/net/wireless/ray_cs.c:831:5: warning: symbol 'ray_dev_init' was not declared. Should it be static?
Signed-off-by: Hannes Eder <hannes@hanneseder.net>
Convert all the drivers using net/ieee80211.h to use linux/ieee80211.h.
Contains a bugfix in libertas where the SSID parsing could overrun the
buffer when the AP sends invalid information.
Acked-by: Dan Williams <dcbw@redhat.com> [airo, libertas]
Acked-by: Pavel Roskin <proski@gnu.org> [orinoco]
Acked-by: David Kilroy <kilroyd@googlemail.com> [orinoco]
The generic packet receive code takes care of setting
netdev->last_rx when necessary, for the sake of the
bonding ARP monitor.
Drivers need not do it any more.
Some cases had to be skipped over because the drivers
were making use of the ->last_rx value themselves.
This converts pretty much everything to print_mac. There were
a few things that had conflicts which I have just dropped for
now, no harm done.
I've built an allyesconfig with this and looked at the files
that weren't built very carefully, but it's a huge patch.
The SIOCSIWSCAN handler is passed data in an iw_point structure. Some
drivers erronously use an iw_param instead.
On 32 bit architectures the difference isn't noticed as the flags
parameter tends to be the only one used by scan handlers and is at the
same offset.
On 64 bit architectures the pointer in the iw_point structure means the
flag parameter is at different offsets in these structures.
Thanks to Jean Tourrilhes for tracking this down for orinoco, and Pavel
Roskin for confirming the fix and identifying other suspect handlers.
When the AP rejects a Shared Key authentication request, try Open System
auth too.
Signed-off-by: Dan Williams <dcbw@redhat.com>
Return errors from request_firmware() (like other drivers that do
firmware load on device open) and make up plausible codes for other
error conditions. Gives userspace tools like NetworkManager a clue that
firmware may be missing when the result of setting IFF_UP is ENOENT.
v2: fix reversed check of atmel_wakeup_firmware() in probe_atmel_card()
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Documentation/powerpc/booting-without-of.txt
drivers/atm/Makefile
drivers/net/fs_enet/fs_enet-main.c
drivers/pci/pci-acpi.c
net/8021q/vlan.c
net/iucv/iucv.c
Three major portions to this change:
1) Add IW_EV_COMPAT_LCP_LEN, IW_EV_COMPAT_POINT_OFF,
and IW_EV_COMPAT_POINT_LEN helper defines.
2) Delete iw_stream_check_add_*(), they are unused.
3) Add iw_request_info argument to iwe_stream_add_*(), and use it to
size the event and pointer lengths correctly depending upon whether
IW_REQUEST_FLAG_COMPAT is set or not.
4) The mechanical transformations to the drivers and wireless stack
bits to get the iw_request_info passed down into the routines
modified in #3. Also, explicit references to IW_EV_LCP_LEN are
replaced with iwe_stream_lcp_len(info).
With a lot of help and bug fixes from Masakazu Mokuno.
drivers/net/tg3.c
drivers/net/wireless/rt2x00/rt2x00dev.c
net/mac80211/ieee80211_i.h
Use asm/byteorder.h instead.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Use net_device_stats from net_device structure instead of local.
Kill atmel_get_stats function, because by default it is used
identical internal_stats function from net/core/dev.c
No need to memset stats to 0, because they are allocated by kzalloc.
P.S. Someone should cleanup init_atmel_card function from unneeded
initializations to 0/NULL. Out of scope for this patch.
Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt>
The functions time_before, time_before_eq, time_after, and time_after_eq are more robust for comparing jiffies against other values.
So following patch implements usage of the time_after() macro, defined at linux/jiffies.h, which deals with wrapping correctly
Cc: linux-wireless@vger.kernel.org
Signed-off-by: S.Çağlar Onur <caglar@pardus.org.tr>
Fix priority mistakes similar to '!x & y'
Signed-off-by: Roel Kluin <12o3l@tiscali.nl>
This is nicer than the MAC_FMT stuff.
It's been a useless no-op for long enough in 2.6 so I figured it's time to
remove it. The number of people that could object because they're
maintaining unified 2.4 and 2.6 drivers is probably rather small.
[ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ]
Signed-off-by: Jeff Garzik <jeff@garzik.org>
