Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
cleanup patch.
Use new __packed annotation in drivers/net/
This makes the b43 driver just automatically fall back to PIO mode when
DMA doesn't work.
The driver already told the user to do it, so rather than have the user
reload the module with a new flag, just make the driver do it
automatically. We keep the message as an indication that something is
wrong, but now just automatically fall back to the hopefully working PIO
case.
(Some post-2.6.33 merge fixups by Larry Finger <Larry.Finger@lwfinger.net>
and yours truly... -- JWL)
net/mac80211/scan.c
Commit c7ab5ef9bcd281135c21b4732c9be779585181be entitled "b43: implement
short slot and basic rate handling" reduced the transmit throughput for
my BCM4311 device from 18 Mb/s to 0.7 Mb/s. The basic rate handling
portion is OK, the problem is in the short slot handling.
Prior to this change, the short slot enable/disable routines were never
called. Experimentation showed that the critical part was changing the
value at offset 0x0010 in the shared memory. This is supposed to contain
the 802.11 Slot Time in usec, but if it is changed from its initial value
of zero, performance is destroyed. On the other hand, changing the value
in the MMIO register corresponding to the Interframe Slot Time increased
performance from 18 to 22 Mb/s. A BCM4306/3 also shows dramatic
improvement of the transmit rate from 5.3 to 19.0 Mb/s.
Other changes in the patch include removal of the magic number for the
MMIO register, and allowing the slot time to be set for any PHY operating
in the 2.4 GHz band. Previously, the routine was executed only for G PHYs.
Cc: Stable <stable@kernel.org> [Any stable version back through 2.6.28]
If userencounter the "Fatal DMA Problem" with a BCM43XX device, and
still wish to use b43 as the driver, their only option is to rebuild
the kernel with CONFIG_B43_FORCE_PIO. This patch removes this option and
allows PIO mode to be selected with a load-time parameter for the module.
Note that the configuration variable CONFIG_B43_PIO is also removed.
Once the DMA problem with the BCM4312 devices is solved, this patch will
likely be reverted.
Tested-by: John Daiker <daikerjohn@gmail.com>
With the deprecation of the qual member of ieee80211_rx_status, that
calculation and an associated constant can be removed.
This optimizes the PIO scratchbuffer usage.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
The DMA-API debugging facility complains about b43 mapping memory from
stack for SDIO-based cards.
Indeed, b43 currently allocates the PIO RX/TX header and tail buffers
from stack. The solution here is to use heap-allocated buffers instead.
Signed-off-by: Albert Herranz <albert_herranz@yahoo.es>
This adds support for verbose runtime statistics.
It defaults to off and must be enabled in debugfs, if desired.
The first measurement may be incorrect, because statistics are not cleared
after they got enabled through debugfs.
This removes most of the b43 suspend/resume code (it's handled by mac80211)
and moves the registration of devices to the attachment phase. This is
required, because we must not register/unregister devices on suspend/resume.
This removes the SHM spinlock.
SHM is protected by wl->mutex.
Tested-by: Larry Finger <Larry.Finger@lwfinger.net>
This removes the TX spinlock and defers TX to a workqueue to allow
locking wl->mutex instead and to allow sleeping for register accesses.
Use a threaded IRQ handler to allow locking the mutex and
sleeping while executing an interrupt.
This removes usage of the irq_lock spinlock, but introduces
a new hardirq_lock, which is _only_ used for the PCI/SSB lowlevel
hard-irq handler. Sleeping busses (SDIO) will use mutex instead.
This fixes the hardware encryption keys index and array size handling.
Thanks to Gregor Kowski for reporting this issue.
Update a comment that still says IEEE80211_IF_TYPE instead of NL80211_IFTYPE.
Signed-off-by: Gábor Stefanik <netrolller.3d@gmail.com>
Make use of HostFlags defines in the LP-PHY code.
Fix fallout from the IEEE80211_IF_TYPE to NL80211_IFTYPE change.
Implement baseband init for rev.0 and rev.1 LP PHYs. Convert boardflags_hi values to defines.
Implement b43_phy_copy for easier copying between registers, as needed by LP-PHY init.
Signed-off-by: Gábor Stefanik<netrolller.3d@gmail.com>
Cc: Michael Buesch<mb@bu3sch.de>
Cc: Larry Finger<larry.finger@lwfinger.net>
Fix condition in which radio LED did not initialize correctly, and remove
4 compilation warnings.
After the recent changes in rfkill, the radio LED used by b43/b43legacy
did not always initialize correctly.
Both b43 and b43legacy used the deprecated variable radio_enabled in
struct ieee80211_conf.
Add automagic feature flags, so the firmware can tell the driver
about supported features and the driver can switch features on/off as
needed.
Signed-off-by: Stefan Lippers-Hollmann <s.l-h@gmx.de>
Tested-by: Stefan Lippers-Hollmann <s.l-h@gmx.de>
This ports the b43/legacy rfkill code to the new API offered
by cfg80211 and thus removes a lot of useless stuff.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Cc: Michael Buesch <mb@bu3sch.de>
This removes unnecessary MMIO accesses in the interrupt hotpath.
Auto-depend on HW_RANDOM, rather than "select"ing it.
This way the user has the choice to enable or disable HWRNG support.
This changes the RX handler to pass more status flags to mac80211.
It also changes part of the drop policy, if bad frames were requested. (Note that
currently mac80211 will throw a WARN_ON in that case. But nothing bad will happen).
This also removes some obsolete unused timestamping code.
This adds the initial parts of the LP-PHY TX power control.
This also adds helper functions for bulk access of LP tables.
Dynamically control the log verbosity with a module parameter.
This enables us to dynamically enable debugging messages (or disable
info, warn, error messages) via module parameter or /sys/module/b43/parameters/verbose.
This increases the module size by about 3k. But in practice it reduces the
module size for the user, because some distributions ship the b43 module
with CONFIG_B43_DEBUG set, which increases the module by about 15k.
So with this patch applied, distributions should really _disable_ CONFIG_B43_DEBUG.
There is no reason to keep it in a production-release kernel.
So we have a net reduction in size by about 12k.
This patch also adds a printk of the wireless core revision, so people
don't have to enable SSB debugging to get the wireless core revision.
First probe for proprietary firmware and then probe for opensource firmware.
This way around it's a win-win situation.
1) If proprietary fw is available, it will work.
2) If opensource firmware is available, but no proprietary (Distros can only ship open fw)
it might work.
3) If both open and proprietary are available, it will work, because it selects
the proprietary. We currently don't prefer the open fw in this case, because it doesn't
work on all devices. It would introduce a regression otherwise.
The remaining FIXMEs in this patch are harmless, because they only matter on multiband
devices, which are not implemented yet anyway.
This implements proper short slot handling and adds code to
program the hardware for the correct response rates derived
from the basic rate set for the current BSS.
This fixes the initialization of QoS parameters.
Reported-by: Lorenzo Nava, Francesco Gringoli
Signed-off-by: Francesco Gringoli <francesco.gringoli@ing.unibs.it>
We don't need the workqueue anymore, as we can now sleep in the callback.
This patch rewrites the TX power recalculation algorithms to scale better
with changed enviromnent. If there's low
TX traffic, the power will be checked against the desired values
every 60 seconds.
If there is high TX traffic, the check is redone every 2 seconds. This improves
the reaction times a lot and confuses the rate control less.
It will also reduce the time it initially takes to tune to a new TX power
value. With the old algorithm it could take about 30 to 45 seconds to settle to
a new power value. This will happen in about two to four seconds now.
This patch implements a dynamic "ops" based PHY API.
This is needed in order to conveniently support future PHY types
to avoid the "switch"-hell.
This patch does not change any functionality. It just moves lots
of code from one place to another and adjusts it for the changed
data structures.
This adds a simple firmware watchdog for the opensource firmware.
This will check every 15 seconds, if the firmware zeroed out the watchdog
register. The firmware will do this in its eventloop.
drivers/net/wireless/rt2x00/Kconfig
drivers/net/wireless/rt2x00/rt2x00usb.c
net/sctp/protocol.c
This removes a WARN_ON that is responsible for the following koops:
http://www.kerneloops.org/searchweek.php?search=b43_generate_noise_sample
The comment in the patch describes why it's safe to simply remove
the check.
drivers/net/tg3.c
drivers/net/wireless/rt2x00/rt2x00dev.c
net/mac80211/ieee80211_i.h
This updates the beacon template code to upload both templates,
if we never uploaded one before.
This adds support for firmware markers.
With firmware markers it's easily possible to check whether the
firmware runs some codepath or not. The driver will throw a message
when the firmware executes a MARKER(x).
Add a firmware panic reason code that doesn't trigger a restart.
This is useful for firmware debugging and avoiding endless
restart loops. We can use FWPANIC_DIE to halt the firmware at a
well defined point.
This patch adds code to allow running the device without PCM firmware loaded.
Without PCM firmware we don't have hardware accelerated crypto on
devices with a core rev <= 10.
This patch adds some hooks for firmware debugging.
This patch converts mac80211 and all drivers to have transmit
information and status in skb->cb rather than allocating extra
memory for it and copying all the data around. To make it fit,
a union is used where only data that is necessary for all steps
is kept outside of the union.
A number of fixes were done by Ivo, as well as the rt2x00 part
of this patch.
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com>
kernel-provided clamp_val is identical, delete the private limit_value helper.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: "John W. Linville" <linville@tuxdriver.com>
This patch removes the IRQ-disable from mac_suspend.
The main advantage of this is to get rid of the IRQ-sync call in mac_suspend.
We need to remove the MAC suspend bit from the IRQ service mask, as otherwise
the IRQ handler would race with us.
This fixes some TX/RX related locking issues.
With this patch applied, some of the PHY transmission errors are fixed.
This fixes the initialization of the PHY TX control words in
shared memory. These control words are used for management frames
like beacons.
This fixes beacon updating in the bottomhalf.
In case the device is busy, we will defer to later in the IRQ handler.
These are some beaconing related fixes. Basically it prevents
the card from triggering the beacon IRQ over and over again.
