Many users of debugfs copy the implementation of default_open() when
they want to support a custom read/write function op. This leads to a
proliferation of the default_open() implementation across the entire
tree.
Now that the common implementation has been consolidated into libfs we
can replace all the users of this function with simple_open().
This replacement was done with the following semantic patch:
<smpl>
@ open @
identifier open_f != simple_open;
identifier i, f;
-int open_f(struct inode *i, struct file *f)
-if (i->i_private)
-f->private_data = i->i_private;
-return 0;
@ has_open depends on open @
identifier fops;
identifier open.open_f;
struct file_operations fops = {
-.open = open_f,
+.open = simple_open,
</smpl>
[akpm@linux-foundation.org: checkpatch fixes]
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Signed-off-by: Michael Buesch <m@bues.ch>
The default llseek operation is changing from
default_llseek to no_llseek, so all code relying on
the current behaviour needs to make that explicit.
The wireless driver infrastructure and some of the drivers
make use of generated debugfs files, so they cannot
be converted by our script that automatically determines
the right operation.
All these files use debugfs and they typically rely
on simple_read_from_buffer, so the best llseek operation
here is generic_file_llseek.
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: linux-wireless@vger.kernel.org
Cc: netdev@vger.kernel.org
This adds support for verbose runtime statistics.
It defaults to off and must be enabled in debugfs, if desired.
The first measurement may be incorrect, because statistics are not cleared
after they got enabled through debugfs.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
This removes the SHM spinlock.
SHM is protected by wl->mutex.
Tested-by: Larry Finger <Larry.Finger@lwfinger.net>
Use a threaded IRQ handler to allow locking the mutex and
sleeping while executing an interrupt.
This removes usage of the irq_lock spinlock, but introduces
a new hardirq_lock, which is _only_ used for the PCI/SSB lowlevel
hard-irq handler. Sleeping busses (SDIO) will use mutex instead.
Keeping this one simple.
Changing a few "foo * bar" to "foo *bar"
Removes 22 checkpatch.pl errors, with no introduced warnings.
Signed-off-by: John Daiker <daikerjohn@gmail.com>
Dynamically control the log verbosity with a module parameter.
This enables us to dynamically enable debugging messages (or disable
info, warn, error messages) via module parameter or /sys/module/b43/parameters/verbose.
This increases the module size by about 3k. But in practice it reduces the
module size for the user, because some distributions ship the b43 module
with CONFIG_B43_DEBUG set, which increases the module by about 15k.
So with this patch applied, distributions should really _disable_ CONFIG_B43_DEBUG.
There is no reason to keep it in a production-release kernel.
So we have a net reduction in size by about 12k.
This patch also adds a printk of the wireless core revision, so people
don't have to enable SSB debugging to get the wireless core revision.
This allows the mac80211 high level code to access the TSF. This is e.g. needed for BSSID merges in the IBSS mode.
The second version adds locking and removes the now unnecessary debugfs entries.
Thanks to Michael Buesch! :)
Signed-off-by: Alina Friedrichsen <x-alina@gmx.net>
This adds an option to dump all crypto related memory to
the kernel log.
Obviously, it should not be enabled on productive systems. ;)
This patch implements a dynamic "ops" based PHY API.
This is needed in order to conveniently support future PHY types
to avoid the "switch"-hell.
This patch does not change any functionality. It just moves lots
of code from one place to another and adjusts it for the changed
data structures.
This adds a firmware debugging knob to debugfs.
With this knob it's possible to enable advanced runtime firmware
checks.
For now it only implements one sanity check for the mac-suspend.
In future there'll probably be more.
If CONFIG_B43_DEBUG is disabled, these checks will collapse to nothing.
We don't need these two dump-files anymore, as we can easily do this
in userspace now.
Use b43-fwdump from the b43-tools repository to dump microcode registers.
Use "b43-fwdump -s" to dump SHM (or use -S to do a binary dump)
This adds an atomic mask/set capability to the debugfs MMIO interface.
This is needed to support mask and/or set operations from the userspace
debugging tools.
This adds debugfs files for random SHM access.
This is needed in order to implement firmware and driver debugging
scripts in userspace.
This adds debugfs files for reading and writing arbitrary
wireless core registers. This is useful for debugging.
This patch distributes the Local Oscillator calibration bursts over time,
so that calibration only happens when it's actually needed.
Currently we periodically perform a recalibration of the whole table.
The table is huge and this takes lots of time. Additionally only small bits
of the table are actually needed at a given time. So instead of maintaining
a huge table with all possible calibration values, we create dynamic calibration
settings that
a) We only calibrate when they are actually needed.
b) Are cached for some time until they expire.
So a recalibration might happen if we need a calibration setting that's not
cached, or if the active calibration setting expires.
Currently the expire timeout is set to 30 seconds. We may raise that in future.
This patch reduces overall memory consumption by nuking the
huge static calibration tables.
This patch has been tested on several 4306, 4311 and 4318 flavours.
Remove all irqs_disabled() sanity checks, as they are not safe on
a RT-enabled kernel and will trigger bogus warnings.
This fixes a sparse warning about weird locking.
The spinlock is not needed, so simply remove it.
This also adds some sanity checks to the PHY and radio locking
to protect against recursive locking.
Remove b43 PIO support.
DMA works well on all supported devices. There's no reason to use PIO.
Additionally, new devices don't support PIO in hardware anymore.
b43 PIO support is dead and unused code.
After applying this patch please do
git rm drivers/net/wireless/b43/pio.h
git rm drivers/net/wireless/b43/pio.c
to remove the main PIO support code.
use uninitialized_var() to avoid the following bogus warning:
CC [M] drivers/net/wireless/b43/debugfs.o
drivers/net/wireless/b43/debugfs.c: In function ‘b43_debugfs_read’:
drivers/net/wireless/b43/debugfs.c:355: warning: ‘ret’ may be used uninitialized in this function
Signed-off-by: Frank Lichtenheld <frank@lichtenheld.de>
Fix possible buffer overrun.
It's not required and the txpower adjustment must not be in atomic.
The remaining warning in phy.c will be fixed later.
