[This patch is supposed to be applied in 3.1 (and maybe older) branches only.]
New kernels support newer firmware that users may try to incorrectly use
with older kernels. Display error and explain the problem in such a case
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
In ad-hoc mode, driver b43 does not issue beacons.
Signed-off-by: Manual Munz <freifunk@somakoma.de>
Tested-by: Larry Finger <Larry.Finger@lwfinger.net>
Cc: Stable <stable@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
wldev is freed in b43_one_core_detach() and should not be accessed after
that call. Keep wldev->dev in a local variable.
Signed-off-by: Pavel Roskin <proski@gnu.org>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
Some of the newer Broadcom chipsets have longe names like BCM43224,
BCM43225, etc. However Broadcom decided to keep using u16 for storing
them. Use %X or %d depending on chip_id value to avoid BCMA8D8, etc.
Acked-by: Pavel Roskin <proski@gnu.org>
BCMA_IOCTL is register in agent (AKA wrapper) core, we need to use
special R/W ops for it.
net/bluetooth/l2cap_core.c
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
We were uploading different firmwares to the hardware until finding
responding one.
LCN-PHY was found in 14e4:4727 card. It uses LCN/1 and 0x2064/1 radio.
Newer ones need separated way
Older cores had unique PHY. This is not true anymore for newer ones.
For example core rev 16 can be LP, SSLPN or N (PHY).
Signed-off-by: Michael Buesch <m@bues.ch>
drivers/net/wireless/rtlwifi/pci.c
include/linux/netlink.h
It is always "y" for now, b43 will not compile without CONFIG_SSB yet.
This is just a first step of dropping SSB dependency.
This is totally broken plus we do not have specs for HT PHY yet. Just
introduce place for writing driver if we discover anything.
Add some error handling if the allocation fails.
Semicolons are not necessary after switch/while/for/if braces
so remove them.
It does nothing useful yet, so it is matched as BROKEN.
For now this is just an option for b43, in future we may want to make
b43 support SSB or BCMA (note: or, not xor).
Luckily the only flag we use when calling core reset is GMODE one.
Thanks to that we can just switch to single bool and make function calls
bus generic.
Tested on my BCM4312 (LP-PHY) and early tested with BCM43224.
SPROM is another frequently used struct. We decided to share SPROM
struct between ssb na bcma as long as we will not need any hacks.
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
We risk reading TMSHIGH register twice, but PHY-A are really rare and we
do not support them at the moment.
drivers/net/wireless/iwlwifi/iwl-agn-tx.c
net/mac80211/sta_info.h
We free name "dev" for something generic (like dev abstraction layer).
Additionaly code is cleaner now, especially magic dev->dev-dev chains.
Documented in: <4DCA7E40.9070709@lwfinger.net>
