Currently, mac80211 translates the cfg80211
cipher suite selectors into ALG_* values.
That isn't all too useful, and some drivers
benefit from the distinction between WEP40
and WEP104 as well. Therefore, convert it
all to use the cipher suite selectors.
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com>
...and unregistration to core shutdown. Previously, the driver
remained registered even when the hardware was shutdown. That
causes the driver to return -ENODEV if the b43 device is IFF_DOWN.
This change causes the driver to disappear in that case, allowing
/dev/hwrng to still function if another hwrng device is available.
This makes the information available through ethtool...
CHECK drivers/net/wireless/b43/main.c
drivers/net/wireless/b43/main.c:111:5: warning: symbol 'b43_modparam_pio' was not declared. Should it be static?
CHECK drivers/net/wireless/b43/phy_g.c
drivers/net/wireless/b43/phy_g.c:975:56: warning: cast truncates bits from constant value (ffff7fff becomes 7fff)
CHECK drivers/net/wireless/b43/phy_lp.c
drivers/net/wireless/b43/phy_lp.c:2701:6: warning: symbol 'b43_lpphy_op_switch_analog' was not declared. Should it be static?
drivers/net/wireless/b43/phy_lp.c:1148:30: warning: cast truncates bits from constant value (ffff1fff becomes 1fff)
drivers/net/wireless/b43/phy_lp.c:1525:30: warning: cast truncates bits from constant value (ffff1fff becomes 1fff)
drivers/net/wireless/b43/phy_lp.c:1529:30: warning: cast truncates bits from constant value (ffff1fff becomes 1fff)
CHECK drivers/net/wireless/b43/wa.c
drivers/net/wireless/b43/wa.c:385:60: warning: cast truncates bits from constant value (ffff00ff becomes ff)
drivers/net/wireless/b43/wa.c:403:55: warning: cast truncates bits from constant value (ffff00ff becomes ff)
drivers/net/wireless/b43/wa.c:405:55: warning: cast truncates bits from constant value (ffff00ff becomes ff)
drivers/net/wireless/b43/wa.c:415:71: warning: cast truncates bits from constant value (ffff0fff becomes fff)
AFAICT, none of these amount to real bugs. But this reduces warning
spam from sparse w/o significantly affecting readability of the code (IMHO).
The message following fatal DMA errors fails to indicate properly that the
driver has switched to PIO mode.
Signed-off-by: Larry Finger <Larry.Finger@wfinger.net>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
drivers/net/wireless/libertas_tf/cmd.c
drivers/net/wireless/libertas_tf/main.c
Also remove associated IEEE80211_HW_NOISE_DBM from ieee80211_hw_flags.
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
WARNING: braces {} are not necessary for any arm of this statement
Signed-off-by: Daniel Ngu <daniel.dy.ngu@gmail.com>
This makes the b43 driver just automatically fall back to PIO mode when
DMA doesn't work.
The driver already told the user to do it, so rather than have the user
reload the module with a new flag, just make the driver do it
automatically. We keep the message as an indication that something is
wrong, but now just automatically fall back to the hopefully working PIO
case.
(Some post-2.6.33 merge fixups by Larry Finger <Larry.Finger@lwfinger.net>
and yours truly... -- JWL)
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
get_tx_stats() will be removed from mac80211.
Compile-tested only.
Cc: Stefano Brivio <stefano.brivio@polimi.it>
Cc: Michael Buesch <mb@bu3sch.de>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Signed-off-by: Kalle Valo <kalle.valo@iki.fi>
If b43 or b43legacy are deauthenticated or disconnected, there is a
possibility that a reconnection is tried with the queues stopped in
mac80211. To prevent this, start the queues before setting
STAT_INITIALIZED.
In b43, a similar change has been in place (twice) in the
wireless_core_init() routine. Remove the duplicate and add similar
code to b43legacy.
Cc: Stable <stable@kernel.org> [2.6.32]
net/mac80211/scan.c
Commit c7ab5ef9bcd281135c21b4732c9be779585181be entitled "b43: implement
short slot and basic rate handling" reduced the transmit throughput for
my BCM4311 device from 18 Mb/s to 0.7 Mb/s. The basic rate handling
portion is OK, the problem is in the short slot handling.
Prior to this change, the short slot enable/disable routines were never
called. Experimentation showed that the critical part was changing the
value at offset 0x0010 in the shared memory. This is supposed to contain
the 802.11 Slot Time in usec, but if it is changed from its initial value
of zero, performance is destroyed. On the other hand, changing the value
in the MMIO register corresponding to the Interframe Slot Time increased
performance from 18 to 22 Mb/s. A BCM4306/3 also shows dramatic
improvement of the transmit rate from 5.3 to 19.0 Mb/s.
Other changes in the patch include removal of the magic number for the
MMIO register, and allowing the slot time to be set for any PHY operating
in the 2.4 GHz band. Previously, the routine was executed only for G PHYs.
Cc: Stable <stable@kernel.org> [Any stable version back through 2.6.28]
The TKIP key update callback is called from the RX path, where the driver
mutex is already locked. This results in a circular locking bug.
Avoid this by removing the lock.
Johannes noted that there is a separate bug: The callback still breaks on SDIO
hardware, because SDIO hardware access needs to sleep, but we are not allowed
to sleep in the callback due to mac80211's RCU locking.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
Tested-by: Larry Finger <Larry.Finger@lwfinger.net>
Reported-by: kecsa@kutfo.hit.bme.hu
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: stable <stable@kernel.org>
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
When a TKIP key is updated, we should pass the station
pointer instead of just the address, since drivers can
use that to store their own data. We also need to pass
the virtual interface pointer.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
drivers/net/wireless/iwlwifi/iwl-core.h
Following line shows my BCM4328 detected on SSB. We didn't include 0x0C rev.
ssb: Core 1 found: IEEE 802.11 (cc 0x812, rev 0x0C, vendor 0x4243)
BugLink: http://bugs.launchpad.net/bugs/488636
Enhances module information with the names of the firmware files
that could be used by this driver. This helps tools like Jockey to
correctly detect and/or install the firmware files relevant to
this driver.
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
All its members (vif, mac_addr, type) are now available
in the vif struct directly, so we can pass that instead
of the conf struct. I generated this patch (except the
mac80211 and header file changes) with this semantic
patch:
identifier conf, fn, hw;
type tp;
tp fn(struct ieee80211_hw *hw,
-struct ieee80211_if_init_conf *conf)
+struct ieee80211_vif *vif)
-conf->type
+vif->type
-conf->mac_addr
+vif->addr
-conf->vif
+vif
If userencounter the "Fatal DMA Problem" with a BCM43XX device, and
still wish to use b43 as the driver, their only option is to rebuild
the kernel with CONFIG_B43_FORCE_PIO. This patch removes this option and
allows PIO mode to be selected with a load-time parameter for the module.
Note that the configuration variable CONFIG_B43_PIO is also removed.
Once the DMA problem with the BCM4312 devices is solved, this patch will
likely be reverted.
Tested-by: John Daiker <daikerjohn@gmail.com>
include/net/tcp.h
As shown in Kernel Bugzilla #14761, doing a controller restart after a
fatal DMA error does not accomplish anything other than consume the CPU
on an affected system. Accordingly, substitute a meaningful message for
the restart.
Cc: Stable <stable@vger.kernel.org> [2.6.32]
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits)
tree-wide: fix misspelling of "definition" in comments
reiserfs: fix misspelling of "journaled"
doc: Fix a typo in slub.txt.
inotify: remove superfluous return code check
hdlc: spelling fix in find_pvc() comment
doc: fix regulator docs cut-and-pasteism
mtd: Fix comment in Kconfig
doc: Fix IRQ chip docs
tree-wide: fix assorted typos all over the place
drivers/ata/libata-sff.c: comment spelling fixes
fix typos/grammos in Documentation/edac.txt
sysctl: add missing comments
fs/debugfs/inode.c: fix comment typos
sgivwfb: Make use of ARRAY_SIZE.
sky2: fix sky2_link_down copy/paste comment error
tree-wide: fix typos "couter" -> "counter"
tree-wide: fix typos "offest" -> "offset"
fix kerneldoc for set_irq_msi()
spidev: fix double "of of" in comment
comment typo fix: sybsystem -> subsystem
kernel/irq/chip.c
drivers/net/wireless/iwlwifi/iwl-1000.c
drivers/net/wireless/iwlwifi/iwl-6000.c
ops->set_tim() must be atomic, so b43 trying to acquire a mutex leads
to a kernel crash. This patch trades an easy to trigger crash in AP
mode for an unlikely race condition. According to Michael, the real
fix would be to allow set_tim() to sleep, since b43 is not the only
driver that needs to sleep in all callbacks.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
This patch was generated by
git grep -E -i -l '[Aa]quire' | xargs -r perl -p -i -e 's/([Aa])quire/$1cquire/'
and the cumsumed was found by checking the diff for aquire.
While there may be a case for a driver adding its
own bits of radiotap information, none currently
does. Also, drivers would have to copy the code
to generate the radiotap bits that now mac80211
generates. If some driver in the future needs to
add some driver-specific information I'd expect
that to be in a radiotap vendor namespace and we
can add a different way of passing such data up
and having mac80211 include it.
Additionally, rename IEEE80211_CONF_RADIOTAP to
IEEE80211_CONF_MONITOR since it's still used by
b43(legacy) to obtain per-frame timestamps.
The purpose of this patch is to simplify the RX
code in mac80211 to make it easier to add paged
skb support.
We must check the bustype before using the host_pci pointer.
"b43: Fix PPC crash in rfkill polling on unload" fixed the bug reported
in Bugzilla No. 14181; however, it introduced a new bug. Whenever the
radio switch was turned off, it was necessary to unload and reload
the driver for it to recognize the switch again.
This patch fixes both the original bug in #14181 and the bug introduced by
the previous patch. It must be stated, however, that if there is a BCM4306/3
with an rfkill switch (not yet proven), then the driver will need an
unload/reload cycle to turn the device back on.
In Bugzilla No. 14181, a PowerMac G4 crashes on ifdown or
module unload because the rfkill polling has not been stopped.
For the x86 architectures, the attempt to reach a now unmapped
register is not fatal as it is on PPC.
(Includes "b43: Fix locking problem when stopping rfkill polling". -- JWL)
Fix IRQ mask sanity check for physically pulled device.
Tested-by: Andrew Price <andy@andrewprice.me.uk>
Don't use struct wldev after detach. This fixes an oops on access.
drivers/net/wireless/iwlwifi/iwl-rx.c
Fix the following build error when CONFIG_B43_LEDS is not selected:
drivers/net/wireless/b43/main.c: In function 'b43_remove':
drivers/net/wireless/b43/main.c:4990: error: 'struct b43_leds' has no member named 'stop'
drivers/net/wireless/b43/main.c:4991: error: 'struct b43_leds' has no member named 'work'
make[4]: *** [drivers/net/wireless/b43/main.o] Error 1
Signed-off-by: Albert Herranz <albert_herranz@yahoo.es>
Don't abuse wl->current_dev in the LED work for checking whether we're
going down. Add an explicit variable.
This fixes a crash on rmmod dereferencing the wl->current_dev NULL pointer
in various other places of the driver.
This reduces IRQ pressure by about one third on a saturated link
by disabling the PMQ mechanism. We currently don't use that mechanism.
This adds support for verbose runtime statistics.
It defaults to off and must be enabled in debugfs, if desired.
The first measurement may be incorrect, because statistics are not cleared
after they got enabled through debugfs.
synchronize_irq is meaningless for SDIO. sdio_release_irq will
sync the IRQ thread for us.
We need to release the SDIO host before locking the driver mutex.
This adds support for Soft-MAC SDIO devices to b43.
The driver still lacks some fixes for SDIO devices, so it's currently
marked as BROKEN.
