path: root/drivers/net/wireless/b43/phy_g.c
2011-12-19net: fix assignment of 0/1 to bool variables.Rusty Russell
DaveM said: Please, this kind of stuff rots forever and not using bool properly drives me crazy. Joe Perches <joe@perches.com> gave me the spatch script: @@ bool b; @@ -b = 0 +b = false @@ bool b; @@ -b = 1 +b = true I merely installed coccinelle, read the documentation and took credit. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-07Update my e-mail addressMichael Büsch
Signed-off-by: Michael Buesch <m@bues.ch> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-03b43: do not use SSB specific flags when calling core reset functionRafał Miłecki
Luckily the only flag we use when calling core reset is GMODE one. Thanks to that we can just switch to single bool and make function calls bus generic. Tested on my BCM4312 (LP-PHY) and early tested with BCM43224. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-01b43: bus: abstract board infoRafał Miłecki
2011-06-01b43: bus: abstract chip infoRafał Miłecki
2011-06-01b43: bus: abstract SPROMRafał Miłecki
SPROM is another frequently used struct. We decided to share SPROM struct between ssb na bcma as long as we will not need any hacks. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16b43: rename b43_wldev's field with ssb_device to sdevRafał Miłecki
We free name "dev" for something generic (like dev abstraction layer). Additionaly code is cleaner now, especially magic dev->dev-dev chains. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-21b43: silence most sparse warningsJohn W. Linville
CHECK drivers/net/wireless/b43/main.c drivers/net/wireless/b43/main.c:111:5: warning: symbol 'b43_modparam_pio' was not declared. Should it be static? CHECK drivers/net/wireless/b43/phy_g.c drivers/net/wireless/b43/phy_g.c:975:56: warning: cast truncates bits from constant value (ffff7fff becomes 7fff) CHECK drivers/net/wireless/b43/phy_lp.c drivers/net/wireless/b43/phy_lp.c:2701:6: warning: symbol 'b43_lpphy_op_switch_analog' was not declared. Should it be static? drivers/net/wireless/b43/phy_lp.c:1148:30: warning: cast truncates bits from constant value (ffff1fff becomes 1fff) drivers/net/wireless/b43/phy_lp.c:1525:30: warning: cast truncates bits from constant value (ffff1fff becomes 1fff) drivers/net/wireless/b43/phy_lp.c:1529:30: warning: cast truncates bits from constant value (ffff1fff becomes 1fff) CHECK drivers/net/wireless/b43/wa.c drivers/net/wireless/b43/wa.c:385:60: warning: cast truncates bits from constant value (ffff00ff becomes ff) drivers/net/wireless/b43/wa.c:403:55: warning: cast truncates bits from constant value (ffff00ff becomes ff) drivers/net/wireless/b43/wa.c:405:55: warning: cast truncates bits from constant value (ffff00ff becomes ff) drivers/net/wireless/b43/wa.c:415:71: warning: cast truncates bits from constant value (ffff0fff becomes fff) AFAICT, none of these amount to real bugs. But this reduces warning spam from sparse w/o significantly affecting readability of the code (IMHO). Signed-off-by: John W. Linville <linville@tuxdriver.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-09-08b43: Use a threaded IRQ handlerMichael Buesch
Use a threaded IRQ handler to allow locking the mutex and sleeping while executing an interrupt. This removes usage of the irq_lock spinlock, but introduces a new hardirq_lock, which is _only_ used for the PCI/SSB lowlevel hard-irq handler. Sleeping busses (SDIO) will use mutex instead. Signed-off-by: Michael Buesch <mb@bu3sch.de> Tested-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-31b43: Refactor and update antenna diversity for A/G-PHYGábor Stefanik
-Make use of the b43_phy_set/mask/maskset helpers. -Fix a few errors in the code. -Make the code more readable. Signed-off-by: Gábor Stefanik <netrolller.3d@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-28b43: Implement antenna diversity support for LP-PHYGábor Stefanik
The A/G-PHY changes are fallout fixes from the enum change, which in turn allows the LP-PHY code to be much simpler. The antenna_to_phyctl change is a fix for a potential existing bug that this patch may otherwise trigger. Signed-off-by: Gábor Stefanik <netrolller.3d@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-20b43: Update dummy transmission to match V4 specsGábor Stefanik
The V4 dummy transmission has two extra bools in its prototype, so update all callers with the 2 bools. Signed-off-by: Gábor Stefanik <netrolller.3d@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03rfkill: rewriteJohannes Berg
This patch completely rewrites the rfkill core to address the following deficiencies: * all rfkill drivers need to implement polling where necessary rather than having one central implementation * updating the rfkill state cannot be done from arbitrary contexts, forcing drivers to use schedule_work and requiring lots of code * rfkill drivers need to keep track of soft/hard blocked internally -- the core should do this * the rfkill API has many unexpected quirks, for example being asymmetric wrt. alloc/free and register/unregister * rfkill can call back into a driver from within a function the driver called -- this is prone to deadlocks and generally should be avoided * rfkill-input pointlessly is a separate module * drivers need to #ifdef rfkill functions (unless they want to depend on or select RFKILL) -- rfkill should provide inlines that do nothing if it isn't compiled in * the rfkill structure is not opaque -- drivers need to initialise it correctly (lots of sanity checking code required) -- instead force drivers to pass the right variables to rfkill_alloc() * the documentation is hard to read because it always assumes the reader is completely clueless and contains way TOO MANY CAPS * the rfkill code needlessly uses a lot of locks and atomic operations in locked sections * fix LED trigger to actually change the LED when the radio state changes -- this wasn't done before Tested-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> [thinkpad] Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27b43: checkpatch.pl cleanupsJohn Daiker
Keeping this one simple. Changing a few "foo * bar" to "foo *bar" Removes 22 checkpatch.pl errors, with no introduced warnings. Signed-off-by: John Daiker <daikerjohn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27b43: Remove bogus integer truncation warningsMichael Buesch
"warning: large integer implicitly truncated to unsigned type" Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27b43: Convert usage of b43_radio_maskset()Michael Buesch
This patch converts code to use the new b43_radio_maskset() API. The semantic patch that makes this change is as follows: // <smpl> @@ expression dev, addr, mask, set; @@ -b43_radio_write16(dev, addr, (b43_radio_read16(dev, addr) & mask) | set); +b43_radio_maskset(dev, addr, mask, set); // </smpl> Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27b43: Convert usage of b43_radio_mask()Michael Buesch
This patch converts code to use the new b43_radio_mask() API. The semantic patch that makes this change is as follows: // <smpl> @@ expression dev, addr, mask; @@ -b43_radio_write16(dev, addr, b43_radio_read16(dev, addr) & mask); +b43_radio_mask(dev, addr, mask); // </smpl> Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27b43: Convert usage of b43_radio_set()Michael Buesch
This patch converts code to use the new b43_radio_set() API. The semantic patch that makes this change is as follows: // <smpl> @@ expression dev, addr, set; @@ -b43_radio_write16(dev, addr, b43_radio_read16(dev, addr) | set); +b43_radio_set(dev, addr, set); // </smpl> Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27b43: Convert usage of b43_phy_maskset()Michael Buesch
This patch converts code to use the new b43_phy_maskset() API. The semantic patch that makes this change is as follows: // <smpl> @@ expression dev, addr, mask, set; @@ -b43_phy_write(dev, addr, (b43_phy_read(dev, addr) & mask) | set); +b43_phy_maskset(dev, addr, mask, set); // </smpl> Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27b43: Convert usage of b43_phy_mask()Michael Buesch
This patch converts code to use the new b43_phy_mask() API. The semantic patch that makes this change is as follows: // <smpl> @@ expression dev, addr, mask; @@ -b43_phy_write(dev, addr, b43_phy_read(dev, addr) & mask); +b43_phy_mask(dev, addr, mask); // </smpl> Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27b43: Convert usage of b43_phy_set()Michael Buesch
This patch converts code to use the new b43_phy_set() API. The semantic patch that makes this change is as follows: // <smpl> @@ expression dev, addr, set; @@ -b43_phy_write(dev, addr, b43_phy_read(dev, addr) | set); +b43_phy_set(dev, addr, set); // </smpl> Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29b43: Fix phy_g.c compiler warningMichael Buesch
Fix compile warning for non-debug builds: drivers/net/wireless/b43/phy_g.c: In function ‘b43_gphy_op_recalc_txpower’: drivers/net/wireless/b43/phy_g.c:3195: warning: unused variable ‘dbm’ Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-12-26drivers/net/wireless/b43: fix sparse warnings: make symbols staticHannes Eder
Fix this sparse warnings: drivers/net/wireless/b43/phy_a.c:80:6: warning: symbol 'b43_radio_set_tx_iq' was not declared. Should it be static? drivers/net/wireless/b43/phy_a.c:150:6: warning: symbol 'b43_radio_init2060' was not declared. Should it be static? drivers/net/wireless/b43/phy_g.c:57:10: warning: symbol 'b43_radio_channel_codes_bg' was not declared. Should it be static? drivers/net/wireless/b43/phy_g.c:218:6: warning: symbol 'b43_set_txpower_g' was not declared. Should it be static? drivers/net/wireless/b43/phy_g.c:386:6: warning: symbol 'b43_nrssi_hw_write' was not declared. Should it be static? drivers/net/wireless/b43/phy_g.c:393:5: warning: symbol 'b43_nrssi_hw_read' was not declared. Should it be static? drivers/net/wireless/b43/phy_g.c:404:6: warning: symbol 'b43_nrssi_hw_update' was not declared. Should it be static? drivers/net/wireless/b43/phy_g.c:418:6: warning: symbol 'b43_nrssi_mem_update' was not declared. Should it be static? drivers/net/wireless/b43/phy_g.c:592:6: warning: symbol 'b43_calc_nrssi_slope' was not declared. Should it be static? drivers/net/wireless/b43/phy_g.c:1357:5: warning: symbol 'b43_radio_init2050' was not declared. Should it be static? Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-19b43: Fix some MAC lockingMichael Buesch
This fixes some locking w.r.t. the lower MAC (firmware). It also removes a lot of ancient IRQ-locking that's not needed anymore. We simply suspend the MAC. That's easier and causes less trouble. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-11b43 G-PHY: Remove mmiowb()Michael Buesch
It causes compile errors on m68k and it is not needed. Remove it. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-08b43: Move Analog switching into phy codeMichael Buesch
This moves the Analog switching code into the PHY files. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-05b43: Split PHY alloc and initMichael Buesch
This splits the PHY allocation from the PHY init. This is needed in order to properly support Analog handling. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-05b43: Don't use memcpy for overlapping areasMichael Buesch
It is valid to pass &gphy->rfatt and &gphy->bbatt as rfatt and bbatt pointer arguments to the function. So we have to use memmove for the possibly overlapping memory areas. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-29b43: Rewrite TX power adjustmentMichael Buesch
This patch rewrites the TX power recalculation algorithms to scale better with changed enviromnent. If there's low TX traffic, the power will be checked against the desired values every 60 seconds. If there is high TX traffic, the check is redone every 2 seconds. This improves the reaction times a lot and confuses the rate control less. It will also reduce the time it initially takes to tune to a new TX power value. With the old algorithm it could take about 30 to 45 seconds to settle to a new power value. This will happen in about two to four seconds now. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-29b43: Implement dynamic PHY APIMichael Buesch
This patch implements a dynamic "ops" based PHY API. This is needed in order to conveniently support future PHY types to avoid the "switch"-hell. This patch does not change any functionality. It just moves lots of code from one place to another and adjusts it for the changed data structures. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
