This adds some minor stuff for N-PHY support. Nothing special.
Adds Analog switching and some TODOs for RSSI processing.
Just a patch I had floating around for quite some time now.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
This adds PIO support back (D'oh!) for PCMCIA devices.
This is a complete rewrite of the old PIO code. It does actually work
and we get reasonable performance out of it on a modern machine.
On a PowerBook G4 I get a few MBit for TX and a few more for RX.
So it doesn't work as well as DMA (of course), but it's a _lot_ faster
than the old PIO code (only got a few kBit with that).
The limiting factor is the host CPU speed. So it will generate 100%
CPU usage when the network interface is heavily loaded. A voluntary preemption
point in the RX path makes sure Desktop Latency isn't hurt.
PIO is needed for 16bit PCMCIA devices, as we really don't want to poke with
the braindead DMA mechanisms on PCMCIA sockets. Additionally, not all
PCMCIA sockets do actually support DMA in 16bit mode (mine doesn't).
This adds QOS support to the b43 driver.
QOS can be disabled on driver level with a module parameter for debugging purposes.
Having the full RX timestamp in beacons is necessary for IBSS
merge to work properly so extend the 16-bit timestamp to the
full 64 bits for beacon frames (as well as when monitor mode
is active.)
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it>
This patch creates new cfg80211 wiphy API for channel and bitrate
registration and converts mac80211 and drivers to the new API. The
old mac80211 API is completely ripped out. All drivers (except ath5k)
are updated to the new API, in many cases I expect that optimisations
can be done.
Along with the regulatory code I've also ripped out the
IEEE80211_HW_DEFAULT_REG_DOMAIN_CONFIGURED flag, I believe it to be
unnecessary if the hardware simply gives us whatever channels it wants
to support and we then enable/disable them as required, which is pretty
much required for travelling.
Additionally, the patch adds proper "basic" rate handling for STA
mode interface, AP mode interface will have to have new API added
to allow userspace to set the basic rate set, currently it'll be
empty... However, the basic rate handling will need to be moved to
the BSS conf stuff.
I do expect there to be bugs in this, especially wrt. transmit
power handling where I'm basically clueless about how it should work.
We must not transmit packets we're not able to encrypt.
This fixes a bug where in a tiny timeframe after machine resume
packets can get sent unencrypted and might leak information.
This also fixes three small resource leakages I spotted while fixing
the security problem. Properly deallocate the DMA slots in any DMA
allocation error path.
This fixes suspend/resume.
We must not overwrite the MAC addresses on resume. Otherwise
the card won't ACK any packets anymore.
This patch adds support for new firmware.
Old firmware is still supported until July 2008.
To get new firmware, go to
ftp://ftp.linksys.com/opensourcecode/wrt150nv11/1.51.3/
and download the tarball. We don't have a smaller tarball, yet.
That will be fixed later.
You can extract firmware out of the "wl_ap.o" file contained
in this tarball using latest fwcutter. You must pass the option
--unsupported to fwcutter.
Fwcutter-010 with official support for a new firmware image will
be released soon.
This patch gets rid of the if_id stuff where possible in favour of
a new per-virtual-interface structure "struct ieee80211_vif". This
structure is located at the end of the per-interface structure and
contains a variable length driver-use data area.
This has two advantages:
* removes the need to look up interfaces by if_id, this is better
for working with network namespaces and performance
* allows drivers to store and retrieve per-interface data without
having to allocate own lists/hash tables
Remove b43 PIO support.
DMA works well on all supported devices. There's no reason to use PIO.
Additionally, new devices don't support PIO in hardware anymore.
b43 PIO support is dead and unused code.
After applying this patch please do
git rm drivers/net/wireless/b43/pio.h
git rm drivers/net/wireless/b43/pio.c
to remove the main PIO support code.
This fixes antenna selection in b43. It adds a sanity check
for the antenna numbers we get from mac80211.
This patch depends on
ssb: Fix extraction of values from SPROM
Sometimes it can be useful to see the FCS, especially when
bad-FCS frames are shown. Pass the FCS to mac80211 and let
it worry about snipping it off when required.
The b43 driver is modified to use the new SPROM structure.
Fix my copyright notices in b43 and b43legacy.
Cc: Michael Buesch <mb@bu3sch.de>
Use the limits provided by mac80211.
Cc: Larry Finger <Larry.Finger@lwfinger.net>
These drivers pass full mactime information to the stack, make them
indicate this via the new RX_FLAG_TSFT to get mac80211 to show this
information in monitor mode.
This patch fixes the parsing of the RX data header channel field.
The current code parses the header incorrectly and passes a wrong
channel number and frequency for each frame to mac80211.
The FIXMEs added by this patch don't matter for now as the code
where they live won't get executed anyway. They will be fixed later.
The remaining warning in phy.c will be fixed later.
