path: root/drivers/net/wireless/b43legacy/pio.c
2011-07-07Update my e-mail addressMichael Büsch
Signed-off-by: Michael Buesch <m@bues.ch> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-08b43legacy: remove get_tx_stats() mac80211 opKalle Valo
get_tx_stats() will be removed from mac80211. Compile-tested only. Cc: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20b43legacy: Remove unnecessary MMIO in interrupt hotpathStefano Brivio
This removes unnecessary MMIO accesses in the interrupt hotpath. The patch by Michael Buesch for b43 has been ported to b43legacy. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Tested-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31mac80211/drivers: rewrite the rate control APIJohannes Berg
So after the previous changes we were still unhappy with how convoluted the API is and decided to make things simpler for everybody. This completely changes the rate control API, now taking into account 802.11n with MCS rates and more control, most drivers don't support that though. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21mac80211: move TX info into skb->cbJohannes Berg
This patch converts mac80211 and all drivers to have transmit information and status in skb->cb rather than allocating extra memory for it and copying all the data around. To make it fit, a union is used where only data that is necessary for all steps is kept outside of the union. A number of fixes were done by Ivo, as well as the rt2x00 part of this patch. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-07mac80211: clean up get_tx_stats callbackJohannes Berg
The callback takes a ieee80211_tx_queue_stats with a contained array of ieee80211_tx_queue_stats_data, remove the former, rename the latter to ieee80211_tx_queue_stats and make tx_stats() take the array directly. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-05b43legacy: drop packets we are not able to encryptStefano Brivio
We must drop any packets we are not able to encrypt. We must not send them unencrypted or with an all-zero-key (which basically is the same as unencrypted, from a security point of view). This might only trigger shortly after resume before mac80211 reassociated and reconfigured the keys. It is safe to drop these packets, as the association they belong to is not guaranteed anymore anyway. This is a security fix in the sense that it prevents information leakage. This patch by Michael Buesch has been ported to b43legacy. Cc: Michael Buesch <mb@bu3sch.de> Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-05b43legacy: fix PIO crashStefano Brivio
Fix the crash reported below, which seems to happen on bcm4306 rev. 2 devices only while using PIO: Oops: 0000 [#1] PREEMPT Modules linked in: b43(F) rfkill(F) led_class(F) input_polldev(F) arc4 b43legacy mac80211 cfg80211 i915 drm snd_seq_oss snd_seq_midi_event snd_seq snd_seq_device ohci1394 ieee1394 ssb pcmcia snd_intel8x0m ehci_hcd uhci_hcd evdev Pid: 0, comm: swapper Tainted: GF (2.6.24st3 #2) EIP: 0060:[<f90f667b>] EFLAGS: 00010002 CPU: 0 EIP is at b43legacy_pio_handle_txstatus+0xbb/0x210 [b43legacy] EAX: 0000049b EBX: f11f8044 ECX: 00000001 EDX: 00000000 ESI: f1ff8000 EDI: 00000000 EBP: f11f8040 ESP: c04f4ef4 DS: 007b ES: 007b FS: 0000 GS: 0000 SS: 0068 Process swapper (pid: 0, ti=c04f4000 task=c0488300 task.ti=c04b8000) Stack: f90f2788 c05009f0 c0500900 000010f7 f1053823 c04f4f24 dfb8e800 00000003 f1368000 00000007 00000296 f90f1975 00001000 010c0800 01000000 00000007 f90f6391 f11f8000 00000082 c04f4f4a 00000000 00004fd0 10f70000 8c061000 Call Trace: [<f90f2788>] b43legacy_debugfs_log_txstat+0x48/0xb0 [b43legacy] [<f90f1975>] b43legacy_handle_hwtxstatus+0x75/0x80 [b43legacy] [<f90f6391>] b43legacy_pio_rx+0x201/0x280 [b43legacy] [<f90e4fa3>] b43legacy_interrupt_tasklet+0x2e3/0x870 [b43legacy] [<c0123567>] tasklet_action+0x27/0x60 [<c01237b4>] __do_softirq+0x54/0xb0 [<c010686b>] do_softirq+0x7b/0xe0 [<c01457c0>] handle_level_irq+0x0/0x110 [<c01457c0>] handle_level_irq+0x0/0x110 [<c0123758>] irq_exit+0x38/0x40 [<c0106953>] do_IRQ+0x83/0xd0 [<c011812f>] __update_rq_clock+0x4f/0x180 [<c0104b4f>] common_interrupt+0x23/0x28 [<c011007b>] wakeup_code+0x7b/0xde [<c02b1039>] acpi_processor_idle+0x24a/0x3c9 [<c01025c7>] cpu_idle+0x47/0x80 [<c04b9ad5>] start_kernel+0x205/0x290 [<c04b9360>] unknown_bootoption+0x0/0x1f0 ======================= Code: 0f 00 00 81 fb ff 00 00 00 0f 87 36 01 00 00 8d 04 db 85 ff 8d 6c c6 40 8d 5d 04 0f 85 ef 00 00 00 fe 4e 0e 0f b7 46 0c 8b 53 04 <8b> 4a 50 29 c8 83 e8 52 66 89 46 0c 8b 54 24 14 80 7a 0b 00 74 EIP: [<f90f667b>] b43legacy_pio_handle_txstatus+0xbb/0x210 [b43legacy] SS:ESP 0068:c04f4ef4 Kernel panic - not syncing: Fatal exception in interrupt Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-31b43legacy: fix MAC control and microcode initStefano Brivio
This zeros out all microcode related memory before loading the microcode. This also fixes initialization of the MAC control register. The _only_ place where we overwrite the contents of the MAC control register is at the beginning of b43_chip_init(). All other places must do read() -> mask/set -> write() to not overwrite existing bits. This also adds a longer delay for waiting for the microcode to initialize itself. It seems that the current timeout is sufficient on all available devices, but there's no real reason why we shouldn't wait for up to one second. Slow embedded devices might exist. Better safe than sorry. While at it, fix naming of MACCTL values. This patch by Michael Buesch has been ported to b43legacy. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Acked-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[B43LEGACY]: add mac80211-based driver for legacy BCM43xx devicesLarry Finger
Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
