path: root/drivers/net/wireless/b43legacy/rfkill.c
2011-07-07Update my e-mail addressMichael Büsch
Signed-off-by: Michael Buesch <m@bues.ch> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-11-15b43legacy: rfkill: use status register based on core revision (not PHY's)Rafał Miłecki
Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-04b43legacy: avoid PPC fault during resumeLarry Finger
For PPC architecture with PHY Revision < 3, a read of the register B43_MMIO_HWENABLED_LO will cause a CPU fault unless b43legacy_status() returns a value of 2 (B43legacy_STAT_STARTED); however, one finds that the driver is unable to associate after resuming from hibernation unless this routine returns 1. To satisfy both conditions, the routine is rewritten to return TRUE whenever b43legacy_status() returns a value < 2. This patch fixes the second problem listed in the postings for Red Hat Bugzilla #538523. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@vger.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10b43/legacy: port to cfg80211 rfkillJohannes Berg
This ports the b43/legacy rfkill code to the new API offered by cfg80211 and thus removes a lot of useless stuff. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03rfkill: rewriteJohannes Berg
This patch completely rewrites the rfkill core to address the following deficiencies: * all rfkill drivers need to implement polling where necessary rather than having one central implementation * updating the rfkill state cannot be done from arbitrary contexts, forcing drivers to use schedule_work and requiring lots of code * rfkill drivers need to keep track of soft/hard blocked internally -- the core should do this * the rfkill API has many unexpected quirks, for example being asymmetric wrt. alloc/free and register/unregister * rfkill can call back into a driver from within a function the driver called -- this is prone to deadlocks and generally should be avoided * rfkill-input pointlessly is a separate module * drivers need to #ifdef rfkill functions (unless they want to depend on or select RFKILL) -- rfkill should provide inlines that do nothing if it isn't compiled in * the rfkill structure is not opaque -- drivers need to initialise it correctly (lots of sanity checking code required) -- instead force drivers to pass the right variables to rfkill_alloc() * the documentation is hard to read because it always assumes the reader is completely clueless and contains way TOO MANY CAPS * the rfkill code needlessly uses a lot of locks and atomic operations in locked sections * fix LED trigger to actually change the LED when the radio state changes -- this wasn't done before Tested-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> [thinkpad] Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22rfkill: remove user_claim stuffJohannes Berg
Almost all drivers do not support user_claim, so remove it completely and always report -EOPNOTSUPP to userspace. Since userspace cannot really drive rfkill _anyway_ (due to the odd restrictions imposed by the documentation) having this code is just pointless. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-16Revert "b43/b43legacy: add RFKILL_STATE_HARD_BLOCKED support"Linus Torvalds
This reverts commit bc19d6e0b74ef03a3baf035412c95192b54dfc6f, which as Larry Finger reports causes the radio LED on his system to no longer respond to rfkill switch events. Reported-by: Larry Finger <Larry.Finger@lwfinger.net> Requested-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-30b43/b43legacy: add RFKILL_STATE_HARD_BLOCKED supportAdel Gadllah
This patch sets the rfkill state to RFKILL_STATE_HARD_BLOCKED when the radio is killed by the hardware switch. Signed-off-by: Adel Gadllah <adel.gadllah@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-30b43/b43legacy: use RFKILL_STATE_UNBLOCKED instead of RFKILL_STATE_ONAdel Gadllah
This patch removes the usage RFKILL_STATE_ON and uses RFKILL_STATE_UNBLOCKED instead. Signed-off-by: Adel Gadllah <adel.gadllah@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-27wireless: remove RFKILL_STATE_HARD_BLOCKED warningsJohn W. Linville
CC [M] drivers/net/wireless/b43/rfkill.o drivers/net/wireless/b43/rfkill.c: In function ‘b43_rfkill_soft_toggle’: drivers/net/wireless/b43/rfkill.c:90: warning: enumeration value ‘RFKILL_STATE_HARD_BLOCKED’ not handled in switch CC [M] drivers/net/wireless/b43legacy/rfkill.o drivers/net/wireless/b43legacy/rfkill.c: In function ‘b43legacy_rfkill_soft_toggle’: drivers/net/wireless/b43legacy/rfkill.c:92: warning: enumeration value ‘RFKILL_STATE_HARD_BLOCKED’ not handled in switch CC [M] drivers/net/wireless/iwlwifi/iwl-rfkill.o drivers/net/wireless/iwlwifi/iwl-rfkill.c: In function ‘iwl_rfkill_soft_rf_kill’: drivers/net/wireless/iwlwifi/iwl-rfkill.c:56: warning: enumeration value ‘RFKILL_STATE_HARD_BLOCKED’ not handled in switch Also handle RFKILL_STATE_{ON,OFF} -> RFKILL_STATE_{UNBLOCKED,SOFT_BLOCKED} conversion since I'm already here... Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28b43legacy: fix use-after-free rfkill bugStefano Brivio
Fix rfkill code which caused a use-after-free bug. Thanks to David Woodhouse for spotting this out. Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28b43legacy: Fix rfkill radio LEDLarry Finger
This fixes Bug #9414 for b43legacy. This patch is the equivalent of one submitted earlier for b43. Since addition of the rfkill callback, the LED associated with the off switch on the radio has not worked for several reasons: (1) Essential data in the rfkill structure were missing. (2) The rfkill structure was initialized after the LED initialization. (3) There was a minor memory leak if the radio LED structure was inited. Once the above problems were fixed, additional difficulties were noted: (4) The radio LED was in the wrong state at startup. (5) The radio switch had to be manipulated twice for each state change. (6) A circular mutex locking situation existed. (7) If rfkill-input is built as a module, it is not automatically loaded. This patch fixes all of the above and removes a couple of sparse warnings. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28b43legacy: rewrite and fix rfkill initializationStefano Brivio
The rfkill subsystem doesn't like code like that rfkill_allocate(); rfkill_register(); rfkill_unregister(); rfkill_register(); /* <- This will crash */ This sequence happens with modprobe b43 ifconfig wlanX up ifconfig wlanX down ifconfig wlanX up Fix this by always re-allocating the rfkill stuff before register. The patch to b43 by Michael Buesch <mb@bu3sch.de> has been ported to b43legacy. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28wireless: checkpatch cleanupsJeff Garzik
2008-01-28b43legacy: Use input-polldev for the rfkill switchLarry Finger
This removes the direct call to rfkill on an rfkill event and replaces it with an input device. This way userspace is also notified about the event. This patch is the port to b43legacy of a patch for b43 by Michael Buesch <mb@bu3sch.de>. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28b43legacy: RF-kill supportLarry Finger
This adds full support for the RFKILL button and the RFKILL LED trigger. This is a port to b43legacy of a patch by Michael Buesch <mb@bu3sch.de> for b43. Signed-off-by: Larry Finger<Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
