path: root/drivers/net/wireless/b43legacy
2011-02-25mac80211: make tx() operation return voidJohannes Berg
The return value of the tx operation is commonly misused by drivers, leading to errors. All drivers will drop frames if they fail to TX the frame, and they must also properly manage the queues (if they didn't, mac80211 would already warn). Removing the ability for drivers to return a BUSY value also allows significant cleanups of the TX TX handling code in mac80211. Note that this also fixes a bug in ath9k_htc, the old "return -1" there was wrong. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Tested-by: Sedat Dilek <sedat.dilek@googlemail.com> [ath5k] Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> [rt2x00] Acked-by: Larry Finger <Larry.Finger@lwfinger.net> [b43, rtl8187, rtlwifi] Acked-by: Luciano Coelho <coelho@ti.com> [wl12xx] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-23mac80211: rename RX_FLAG_TSFTJohannes Berg
The flag isn't very descriptive -- the intention is that the driver provides a TSF timestamp at the beginning of the MPDU -- make that clearer by renaming the flag to RX_FLAG_MACTIME_MPDU. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2010-11-16drivers/net/wireless/b43legacy/main.c: Use printf extension %pVJoe Perches
Using %pV reduces the number of printk calls and eliminates any possible message interleaving from other printk calls. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-15b43legacy: rfkill: use status register based on core revision (not PHY's)Rafał Miłecki
Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits) bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL. vlan: Calling vlan_hwaccel_do_receive() is always valid. tproxy: use the interface primary IP address as a default value for --on-ip tproxy: added IPv6 support to the socket match cxgb3: function namespace cleanup tproxy: added IPv6 support to the TPROXY target tproxy: added IPv6 socket lookup function to nf_tproxy_core be2net: Changes to use only priority codes allowed by f/w tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled tproxy: added tproxy sockopt interface in the IPV6 layer tproxy: added udp6_lib_lookup function tproxy: added const specifiers to udp lookup functions tproxy: split off ipv6 defragmentation to a separate module l2tp: small cleanup nf_nat: restrict ICMP translation for embedded header can: mcp251x: fix generation of error frames can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set can-raw: add msg_flags to distinguish local traffic 9p: client code cleanup rds: make local functions/variables static ... Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and drivers/net/wireless/ath/ath9k/debug.c as per David
2010-09-16net/wireless: use generic_file_llseek in debugfsArnd Bergmann
The default llseek operation is changing from default_llseek to no_llseek, so all code relying on the current behaviour needs to make that explicit. The wireless driver infrastructure and some of the drivers make use of generated debugfs files, so they cannot be converted by our script that automatically determines the right operation. All these files use debugfs and they typically rely on simple_read_from_buffer, so the best llseek operation here is generic_file_llseek. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: linux-wireless@vger.kernel.org Cc: netdev@vger.kernel.org
2010-08-16b43legacy: update hw/fw version info in wiphy structJohn W. Linville
This makes the information available through ethtool... Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-11Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 Conflicts: drivers/net/wireless/wl12xx/wl1271.h drivers/net/wireless/wl12xx/wl1271_cmd.h
2010-06-04b43legacy: replace the ssb_dma API with the generic DMA APIFUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stefano Brivio <stefano.brivio@polimi.it> Cc: John W. Linville <linville@tuxdriver.com> Acked-by: Michael Buesch <mb@bu3sch.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-03drivers/net: use __packed annotationEric Dumazet
cleanup patch. Use new __packed annotation in drivers/net/ Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-05Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/libertas_tf/cmd.c drivers/net/wireless/libertas_tf/main.c
2010-05-03b43legacy: Added get_survey callback in order to get channel noiseJohn W. Linville
2010-04-30mac80211: remove deprecated noise field from ieee80211_rx_statusJohn W. Linville
Also remove associated IEEE80211_HW_NOISE_DBM from ieee80211_hw_flags. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-04-28b43legacy: remove usage of deprecated noise valueJohn W. Linville
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-25Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-core.h drivers/net/wireless/rt2x00/rt2800pci.c
2010-02-15b43legacy: fix typo in ifdef commentHauke Mehrtens
Cc: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-14Merge branch 'master' of ↵David S. Miller
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2010-02-08b43legacy: remove get_tx_stats() mac80211 opKalle Valo
get_tx_stats() will be removed from mac80211. Compile-tested only. Cc: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-08b43/b43legacy: Wake queues in wireless_core_startLarry Finger
If b43 or b43legacy are deauthenticated or disconnected, there is a possibility that a reconnection is tried with the queues stopped in mac80211. To prevent this, start the queues before setting STAT_INITIALIZED. In b43, a similar change has been in place (twice) in the wireless_core_init() routine. Remove the duplicate and add similar code to b43legacy. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@kernel.org> [2.6.32] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-19Merge branch 'master' of ↵David S. Miller
2010-01-14Remove config option B43_LEGACY_RFKILL completelyChristoph Egger
In f41f3f373dd72344c65d801d6381fe83ef3a2c54 the B43 driver was ported to use the cfg80211 API for rfkill and consequently the config option was dropped (RFKILL is now unconditionally enabled). However in the Kernel Info the feature is still checked and reported missing. This patch just removes the conditional and the relevant code blocks while still reporting that feature unconditionally would be another option (it's always there). Signed-off-by: Christoph Egger <siccegge@stud.informatik.uni-erlangen.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-14b43legacy: Declare all possible ucodeX.fw filesTim Gardner
Enhance module information with the names of the firmware files that could be used by this driver. This helps tools like Jockey to correctly detect and/or install the firmware files relevant to this driver. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-30Merge branch 'master' of ↵David S. Miller
2009-12-28mac80211: remove struct ieee80211_if_init_confJohannes Berg
All its members (vif, mac_addr, type) are now available in the vif struct directly, so we can pass that instead of the conf struct. I generated this patch (except the mac80211 and header file changes) with this semantic patch: @@ identifier conf, fn, hw; type tp; @@ tp fn(struct ieee80211_hw *hw, -struct ieee80211_if_init_conf *conf) +struct ieee80211_vif *vif) { <... ( -conf->type +vif->type | -conf->mac_addr +vif->addr | -conf->vif +vif ) ...> } Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-04b43legacy: avoid PPC fault during resumeLarry Finger
For PPC architecture with PHY Revision < 3, a read of the register B43_MMIO_HWENABLED_LO will cause a CPU fault unless b43legacy_status() returns a value of 2 (B43legacy_STAT_STARTED); however, one finds that the driver is unable to associate after resuming from hibernation unless this routine returns 1. To satisfy both conditions, the routine is rewritten to return TRUE whenever b43legacy_status() returns a value < 2. This patch fixes the second problem listed in the postings for Red Hat Bugzilla #538523. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@vger.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sfc/sfe4001.c drivers/net/wireless/libertas/cmd.c drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/rtl8187se/Kconfig drivers/staging/rtl8192e/Kconfig
2009-11-09tree-wide: fix typos "aquire" -> "acquire", "cumsumed" -> "consumed"Uwe Kleine-König
This patch was generated by git grep -E -i -l '[Aa]quire' | xargs -r perl -p -i -e 's/([Aa])quire/$1cquire/' and the cumsumed was found by checking the diff for aquire. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-06b43legacy: Remove deprecated 'qual' from returned RX statusLarry Finger
With the deprecation of the qual member of ieee80211_rx_status, that calculation and an associated constant can be removed. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-30b43legacy: Fix DMA TX bounce buffer copyingLarry Finger
This patch is adapted from the submission by Michael Buesch <mb@bu3sch.de> for a bounce-buffer copying problem with b43. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-30wireless: remove WLAN_80211 and WLAN_PRE80211 from KconfigJohn W. Linville
With the WLAN_PRE80211 drivers moved to drivers/staging, this distinction becomes unnecessary. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-30mac80211: remove RX_FLAG_RADIOTAPJohannes Berg
While there may be a case for a driver adding its own bits of radiotap information, none currently does. Also, drivers would have to copy the code to generate the radiotap bits that now mac80211 generates. If some driver in the future needs to add some driver-specific information I'd expect that to be in a radiotap vendor namespace and we can add a different way of passing such data up and having mac80211 include it. Additionally, rename IEEE80211_CONF_RADIOTAP to IEEE80211_CONF_MONITOR since it's still used by b43(legacy) to obtain per-frame timestamps. The purpose of this patch is to simplify the RX code in mac80211 to make it easier to add paged skb support. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-27b43/legacy: Fix usage of host_pci pointerMichael Buesch
We must check the bustype before using the host_pci pointer. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-09-09b44/b43/b43legacy: Fix switch warnings introduced by SSB-SDIOMichael Buesch
This fixes some gcc warnings for switch statements. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-09-02drivers: Kill now superfluous ->last_rx storesEric Dumazet
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Neil Horman <nhorman@txudriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-20mac80211: allow configure_filter callback to sleepJohannes Berg
Over time, a whole bunch of drivers have come up with their own scheme to delay the configure_filter operation to a workqueue. To be able to simplify things, allow configure_filter to sleep, and add a new prepare_multicast callback that drivers that need the multicast address list implement. This new callback must be atomic, but most drivers either don't care or just calculate a hash which can be done atomically and then uploaded to the hardware non-atomically. A cursory look suggests that at76c50x-usb, ar9170, mwl8k (which is actually very broken now), rt2x00, wl1251, wl1271 and zd1211 should make use of this new capability. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-04b43legacy: Work around mac80211 race conditionLarry Finger
As shown in http://thread.gmane.org/gmane.linux.kernel.wireless.general/36497, mac80211 has a bug that allows a call to the TX routine after the queues have been stopped. This situation will only occur under extreme stress. Although b43legacy does not crash when this condition occurs, it does generate a WARN_ON and also logs a queue overrun message. This patch recognizes b43legacy is not at fault and logs a message only when the most verbose debugging mode is enabled. In the unlikely event that the queue is not stopped when the DMA queue becomes full, then a warning is issued. This patch is based on the one used by b43. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-04mac80211: redefine usage of the mac80211 workqueueLuis R. Rodriguez
The mac80211 workqueue exists to enable mac80211 and drivers to queue their own work on a single threaded workqueue. mac80211 takes care to flush the workqueue during suspend but we never really had requirements on drivers for how they should use the workqueue in consideration for suspend. We extend mac80211 to document how the mac80211 workqueue should be used, how it should not be used and finally move raw access to the workqueue to mac80211 only. Drivers and mac80211 use helpers to queue work onto the mac80211 workqueue: * ieee80211_queue_work() * ieee80211_queue_delayed_work() These helpers will now warn if mac80211 already completed its suspend cycle and someone is trying to queue work. mac80211 flushes the mac80211 workqueue prior to suspend a few times, but we haven't taken the care to ensure drivers won't add more work after suspend. To help with this we add a warning when someone tries to add work and mac80211 already completed the suspend cycle. Drivers should ensure they cancel any work or delayed work in the mac80211 stop() callback. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10mac80211: push rx status into skb->cbJohannes Berg
Within mac80211, we often need to copy the rx status into skb->cb. This is wasteful, as drivers could be building it in there to start with. This patch changes the API so that drivers are expected to pass the RX status in skb->cb, now accessible as IEEE80211_SKB_RXCB(skb). It also updates all drivers to pass the rx status in there, but only by making them memcpy() it into place before the call to the receive function (ieee80211_rx(_irqsafe)). Each driver can now be optimised on its own schedule. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-07b43/b43legacy: fix radio LED initializationLarry Finger
Fix condition in which radio LED did not initialize correctly, and remove 4 compilation warnings. After the recent changes in rfkill, the radio LED used by b43/b43legacy did not always initialize correctly. Both b43 and b43legacy used the deprecated variable radio_enabled in struct ieee80211_conf. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10b43/legacy: port to cfg80211 rfkillJohannes Berg
This ports the b43/legacy rfkill code to the new API offered by cfg80211 and thus removes a lot of useless stuff. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03rfkill: rewriteJohannes Berg
This patch completely rewrites the rfkill core to address the following deficiencies: * all rfkill drivers need to implement polling where necessary rather than having one central implementation * updating the rfkill state cannot be done from arbitrary contexts, forcing drivers to use schedule_work and requiring lots of code * rfkill drivers need to keep track of soft/hard blocked internally -- the core should do this * the rfkill API has many unexpected quirks, for example being asymmetric wrt. alloc/free and register/unregister * rfkill can call back into a driver from within a function the driver called -- this is prone to deadlocks and generally should be avoided * rfkill-input pointlessly is a separate module * drivers need to #ifdef rfkill functions (unless they want to depend on or select RFKILL) -- rfkill should provide inlines that do nothing if it isn't compiled in * the rfkill structure is not opaque -- drivers need to initialise it correctly (lots of sanity checking code required) -- instead force drivers to pass the right variables to rfkill_alloc() * the documentation is hard to read because it always assumes the reader is completely clueless and contains way TOO MANY CAPS * the rfkill code needlessly uses a lot of locks and atomic operations in locked sections * fix LED trigger to actually change the LED when the radio state changes -- this wasn't done before Tested-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> [thinkpad] Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20b43/legacy: fix beacon change processingJohannes Berg
Process beacon change even if the BSSID doesn't change at the same time. Also fix what I think is a small locking error in b43legacy, there's a spin_unlock_irqrestore that looks out of place. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20b43legacy: Remove unnecessary MMIO in interrupt hotpathStefano Brivio
This removes unnecessary MMIO accesses in the interrupt hotpath. The patch by Michael Buesch for b43 has been ported to b43legacy. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Tested-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-06mac80211: unify config_interface and bss_info_changedJohannes Berg
The config_interface method is a little strange, it contains the BSSID and beacon updates, while bss_info_changed contains most other BSS information for each interface. This patch removes config_interface and rolls all the information it previously passed to drivers into bss_info_changed. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-06mac80211: clean up beacon interval settingsJohannes Berg
We currently have two beacon interval configuration knobs: hw.conf.beacon_int and vif.bss_info.beacon_int. This is rather confusing, even though the former is used when we beacon ourselves and the latter when we are associated to an AP. This just deprecates the hw.conf.beacon_int setting in favour of always using vif.bss_info.beacon_int. Since it touches all the beaconing IBSS code anyway, we can also add support for the cfg80211 IBSS beacon interval configuration easily. NOTE: The hw.conf.beacon_int setting is retained for now due to drivers still using it -- I couldn't untangle all drivers, some are updated in this patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
