path: root/drivers/net/wireless/b43legacy
2008-06-04b43legacy: Fix controller restart crashMichael Buesch
This fixes a kernel crash on rmmod, in the case where the controller was restarted before doing the rmmod. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21missing dependencies on HAS_DMAAl Viro
2008-04-29wireless: use get/put_unaligned_* helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: John W. Linville <linville@tuxdriver.com> Cc: Michael Buesch <mb@bu3sch.de> Cc: Daniel Drake <dsd@gentoo.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
2008-04-16b43legacy: fix TBTT and PU timingsStefano Brivio
This fixes some timings for pre-TBTT and synthetic PU. The patch by Michael Buesch has been ported to b43legacy. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-15b43legacy: fix DMA mapping leakageStefano Brivio
This fixes a DMA mapping leakage in the case where we reject a DMA buffer because of its address. The patch by Michael Buesch has been ported to b43legacy. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Cc: Christian Casteyde <casteyde.christian@free.fr> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-15b43legacy: Fix usage of struct device used for DMAingMichael Buesch
This fixes b43legacy for the SSB DMA API change. Signed-off-by: Michael Buesch <mb@bu3sch.de> Cc: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-15b43legacy: fix initvals loading on bcm4303Stefano Brivio
This allows for the correct initial values to be uploaded to bcm4303 devices. It should be correct, but I can't reliably test this as I suspect there's something going wrong with an hardware rfkill switch on my laptop. Please test. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-05Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/mac80211/rc80211_pid_algo.c
2008-03-04b43legacy: Fix module init messageMichael Buesch
This fixes the module init message to tell that the legacy driver loaded. This makes it less confusing, in case both drivers are loaded. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29b43legacy: Fix nondebug buildMichael Buesch
Fix a typo. Signed-off-by: Michael Buesch <mb@bu3sch.de> Acked-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29b43(legacy): include full timestamp in beacon framesJohannes Berg
Having the full RX timestamp in beacons is necessary for IBSS merge to work properly so extend the 16-bit timestamp to the full 64 bits for beacon frames (as well as when monitor mode is active.) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29b43legacy: fix B43legacy_WARN_ON macroStefano Brivio
Fix the B43legacy_WARN_ON macro so that it will evaluate expressions. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29b43legacy: fix upload of beacon packets to the hardwareStefano Brivio
This fixes uploading of the beacon data and writing of the TIM and DTIM offsets. The patch by Michael Buesch has been ported to b43legacy. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29b43legacy: add definitions for MAC control registerStefano Brivio
This adds some definitions for the MAC control register and uses them. This is basically no functional change. The patch by Michael Buesch has been ported to b43legacy. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29cfg80211 API for channels/bitrates, mac80211 and driver conversionJohannes Berg
This patch creates new cfg80211 wiphy API for channel and bitrate registration and converts mac80211 and drivers to the new API. The old mac80211 API is completely ripped out. All drivers (except ath5k) are updated to the new API, in many cases I expect that optimisations can be done. Along with the regulatory code I've also ripped out the IEEE80211_HW_DEFAULT_REG_DOMAIN_CONFIGURED flag, I believe it to be unnecessary if the hardware simply gives us whatever channels it wants to support and we then enable/disable them as required, which is pretty much required for travelling. Additionally, the patch adds proper "basic" rate handling for STA mode interface, AP mode interface will have to have new API added to allow userspace to set the basic rate set, currently it'll be empty... However, the basic rate handling will need to be moved to the BSS conf stuff. I do expect there to be bugs in this, especially wrt. transmit power handling where I'm basically clueless about how it should work. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-28Use a separate config option for the b43 pci to ssb bridge.Alexey Zaytsev
The bridge code was unnecessary enabled by the b44 driver, but it prevents the bcm43xx driver from being loaded, as the bridge claims the same pci ids. Now we enable the birdge only if the b43{legacy} drivers are selected. Signed-off-by: Alexey Zaytsev <alexey.zaytsev@gmail.com> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-15b43legacy: Add driver load messagesStefano Brivio
This adds printk messages with basic information about the driver being loaded. This information includes a summary of the compiled-in features, which simplifies bug-reporting and debugging a lot. Also a firmware ID is printed. This is a unique identifier blob for a specific version of the firmware. This ID is attached to a specific version of the firmware blob in b43-fwcutter (see fwcutter git). This helps users to select the right firmware for their device. This also makes it possible to use automated scripts to fetch and extract the right firmware for the driver. (The script will grep the .ko for the "Firmware-ID: xxx" string.) While the driver might still support other versions of the firmware for backward compatibility, this will always print out the officially supported version, which people _should_ use. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-15b43legacy: fix firmware load message levelStefano Brivio
The firmware version information should always get printed. Not only on a debug build. The patch by Michael Buesch has been ported to b43legacy. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-15b43legacy: add firmware information to modinfoStefano Brivio
This adds the firmware ID to modinfo. The patch by Michael Buesch has been ported to b43legacy. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-15b43legacy: fix DMA for 30/32-bit DMA enginesStefano Brivio
This checks if the DMA address is bigger than what the controller can manage. It will reallocate the buffers in the GFP_DMA zone in that case. The patch by Michael Buesch has been ported to b43legacy. Thanks to Matti Viljanen for reporting this. Cc: Matti Viljanen <viljanen.matti@gmail.com> Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-05b43legacy: fix DMA slot resource leakageStefano Brivio
This fixes four resource leakages. In any error path we must deallocate the DMA frame slots we previously allocated by request_slot(). This is done by storing the ring pointers before doing any ring allocation and restoring the old pointers in case of an error. This patch by Michael Buesch has been ported to b43legacy. Cc: Michael Buesch <mb@bu3sch.de> Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-05b43legacy: drop packets we are not able to encryptStefano Brivio
We must drop any packets we are not able to encrypt. We must not send them unencrypted or with an all-zero-key (which basically is the same as unencrypted, from a security point of view). This might only trigger shortly after resume before mac80211 reassociated and reconfigured the keys. It is safe to drop these packets, as the association they belong to is not guaranteed anymore anyway. This is a security fix in the sense that it prevents information leakage. This patch by Michael Buesch has been ported to b43legacy. Cc: Michael Buesch <mb@bu3sch.de> Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-05b43legacy: fix suspend/resumeStefano Brivio
This patch makes suspend/resume work with the b43legacy driver. We must not overwrite the MAC addresses in the init function, as this would also overwrite the MAC on resume. With an all-zero MAC the device firmware is not able to ACK any received packets anymore. Fix this by moving the initializion stuff that must be done on init but not on resume to the start function. Also zero out filter_flags to make sure we don't have some flags from a previous instance for a tiny timeframe until mac80211 reconfigures them. This patch by Michael Buesch has been ported to b43legacy. Cc: Michael Buesch <mb@bu3sch.de> Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-05b43legacy: fix PIO crashStefano Brivio
Fix the crash reported below, which seems to happen on bcm4306 rev. 2 devices only while using PIO: Oops: 0000 [#1] PREEMPT Modules linked in: b43(F) rfkill(F) led_class(F) input_polldev(F) arc4 b43legacy mac80211 cfg80211 i915 drm snd_seq_oss snd_seq_midi_event snd_seq snd_seq_device ohci1394 ieee1394 ssb pcmcia snd_intel8x0m ehci_hcd uhci_hcd evdev Pid: 0, comm: swapper Tainted: GF (2.6.24st3 #2) EIP: 0060:[<f90f667b>] EFLAGS: 00010002 CPU: 0 EIP is at b43legacy_pio_handle_txstatus+0xbb/0x210 [b43legacy] EAX: 0000049b EBX: f11f8044 ECX: 00000001 EDX: 00000000 ESI: f1ff8000 EDI: 00000000 EBP: f11f8040 ESP: c04f4ef4 DS: 007b ES: 007b FS: 0000 GS: 0000 SS: 0068 Process swapper (pid: 0, ti=c04f4000 task=c0488300 task.ti=c04b8000) Stack: f90f2788 c05009f0 c0500900 000010f7 f1053823 c04f4f24 dfb8e800 00000003 f1368000 00000007 00000296 f90f1975 00001000 010c0800 01000000 00000007 f90f6391 f11f8000 00000082 c04f4f4a 00000000 00004fd0 10f70000 8c061000 Call Trace: [<f90f2788>] b43legacy_debugfs_log_txstat+0x48/0xb0 [b43legacy] [<f90f1975>] b43legacy_handle_hwtxstatus+0x75/0x80 [b43legacy] [<f90f6391>] b43legacy_pio_rx+0x201/0x280 [b43legacy] [<f90e4fa3>] b43legacy_interrupt_tasklet+0x2e3/0x870 [b43legacy] [<c0123567>] tasklet_action+0x27/0x60 [<c01237b4>] __do_softirq+0x54/0xb0 [<c010686b>] do_softirq+0x7b/0xe0 [<c01457c0>] handle_level_irq+0x0/0x110 [<c01457c0>] handle_level_irq+0x0/0x110 [<c0123758>] irq_exit+0x38/0x40 [<c0106953>] do_IRQ+0x83/0xd0 [<c011812f>] __update_rq_clock+0x4f/0x180 [<c0104b4f>] common_interrupt+0x23/0x28 [<c011007b>] wakeup_code+0x7b/0xde [<c02b1039>] acpi_processor_idle+0x24a/0x3c9 [<c01025c7>] cpu_idle+0x47/0x80 [<c04b9ad5>] start_kernel+0x205/0x290 [<c04b9360>] unknown_bootoption+0x0/0x1f0 ======================= Code: 0f 00 00 81 fb ff 00 00 00 0f 87 36 01 00 00 8d 04 db 85 ff 8d 6c c6 40 8d 5d 04 0f 85 ef 00 00 00 fe 4e 0e 0f b7 46 0c 8b 53 04 <8b> 4a 50 29 c8 83 e8 52 66 89 46 0c 8b 54 24 14 80 7a 0b 00 74 EIP: [<f90f667b>] b43legacy_pio_handle_txstatus+0xbb/0x210 [b43legacy] SS:ESP 0068:c04f4ef4 Kernel panic - not syncing: Fatal exception in interrupt Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-31b43legacy: fix MAC control and microcode initStefano Brivio
This zeros out all microcode related memory before loading the microcode. This also fixes initialization of the MAC control register. The _only_ place where we overwrite the contents of the MAC control register is at the beginning of b43_chip_init(). All other places must do read() -> mask/set -> write() to not overwrite existing bits. This also adds a longer delay for waiting for the microcode to initialize itself. It seems that the current timeout is sufficient on all available devices, but there's no real reason why we shouldn't wait for up to one second. Slow embedded devices might exist. Better safe than sorry. While at it, fix naming of MACCTL values. This patch by Michael Buesch has been ported to b43legacy. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Acked-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31b43legacy: Fix rfkill allocation leakage in error pathsMichael Buesch
We must kill rfkill in any error paths that trigger after rfkill init. Signed-off-by: Michael Buesch <mb@bu3sch.de> Acked-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28b43legacy: Remove the PHY spinlockMichael Buesch
This fixes a sparse warning about weird locking. The spinlock is not needed, so simply remove it. This also adds some sanity checks to the PHY and radio locking to protect against recursive locking. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28b43legacy: fix use-after-free rfkill bugStefano Brivio
Fix rfkill code which caused a use-after-free bug. Thanks to David Woodhouse for spotting this out. Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28mac80211: dont use interface indices in driversJohannes Berg
This patch gets rid of the if_id stuff where possible in favour of a new per-virtual-interface structure "struct ieee80211_vif". This structure is located at the end of the per-interface structure and contains a variable length driver-use data area. This has two advantages: * removes the need to look up interfaces by if_id, this is better for working with network namespaces and performance * allows drivers to store and retrieve per-interface data without having to allocate own lists/hash tables Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28ssb: Fix extraction of values from SPROMMichael Buesch
This fixes extraction of some values from the SPROM. It mainly fixes extraction of antenna related values, which is needed for another b43 fix sent later. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28wireless: cleanup some merge errorsJohn W. Linville
2008-01-28b43legacy: Fix rfkill radio LEDLarry Finger
This fixes Bug #9414 for b43legacy. This patch is the equivalent of one submitted earlier for b43. Since addition of the rfkill callback, the LED associated with the off switch on the radio has not worked for several reasons: (1) Essential data in the rfkill structure were missing. (2) The rfkill structure was initialized after the LED initialization. (3) There was a minor memory leak if the radio LED structure was inited. Once the above problems were fixed, additional difficulties were noted: (4) The radio LED was in the wrong state at startup. (5) The radio switch had to be manipulated twice for each state change. (6) A circular mutex locking situation existed. (7) If rfkill-input is built as a module, it is not automatically loaded. This patch fixes all of the above and removes a couple of sparse warnings. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28b43legacy: reinit on too many PHY TX errorsStefano Brivio
Restart the hardware on too many PHY TX errors. A thousand PHY TX errors per 15 seconds means we won't be able to recover for sure. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28b43legacy: include full 64-bit timestamp in monitor modeJohannes Berg
When monitor mode is enabled, this will make b43legacy read out the full 64-bit MAC time from the chip for each received packet. This patch has been ported from b43. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28b43legacy: properly fix a bogus gcc warningFrank Lichtenheld
Use initialized_var() to properly fix a bogus gcc warning. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Cc: Frank Lichtenheld <frank@lichtenheld.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28b43legacy: Convert to use of the new SPROM structureLarry Finger
The b43legacy driver is modified to use the new SPROM structure. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28b43legacy: fix kconfig dependecies for rfkill and ledsStefano Brivio
Fix dependencies for built-in b43legacy. The patch to b43 by Michael Buesch <mb@bu3sch.de> has been ported to b43legacy. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28b43/b43legacy: fix my copyright noticesStefano Brivio
Fix my copyright notices in b43 and b43legacy. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Cc: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28b43legacy: rewrite and fix rfkill initializationStefano Brivio
The rfkill subsystem doesn't like code like that rfkill_allocate(); rfkill_register(); rfkill_unregister(); rfkill_register(); /* <- This will crash */ This sequence happens with modprobe b43 ifconfig wlanX up ifconfig wlanX down ifconfig wlanX up Fix this by always re-allocating the rfkill stuff before register. The patch to b43 by Michael Buesch <mb@bu3sch.de> has been ported to b43legacy. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28b43legacy: use a consistent naming scheme for the opsStefano Brivio
Use a consistent naming scheme for the ops. The patch to b43 by Michael Buesch <mb@bu3sch.de> has been ported to b43legacy. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28b43legacy: use the retry limits provided by mac80211Stefano Brivio
Use the retry limits provided by mac80211. The patch to b43 by Michael Buesch <mb@bu3sch.de> has been ported to b43legacy. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28wireless: checkpatch cleanupsJeff Garzik
2008-01-28b43legacy: Remove set_key callbackMichael Buesch
We don't need the set_key callback, as we don't do hw crypto. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28b43legacy: Rewrite pwork lockingLarry Finger
Implement much easier and more lightweight locking for the periodic work. This also removes the last big busywait loop and replaces it by a sleeping loop. This patch for b43legacy is patterned aftar the same patch for b43 by Michael Buesch <mb@bu3sch.de>. Signed-off-by: Larry Finger <larry.finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28b43legacy: Use input-polldev for the rfkill switchLarry Finger
This removes the direct call to rfkill on an rfkill event and replaces it with an input device. This way userspace is also notified about the event. This patch is the port to b43legacy of a patch for b43 by Michael Buesch <mb@bu3sch.de>. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28b43legacy: RF-kill supportLarry Finger
This adds full support for the RFKILL button and the RFKILL LED trigger. This is a port to b43legacy of a patch by Michael Buesch <mb@bu3sch.de> for b43. Signed-off-by: Larry Finger<Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28b43legacy: LED triggers supportLarry Finger
Drive the LEDs through the generic LED triggers. The patch to b43 by Michael Buesch <mb@bu3sch.de> has been ported to b43legacy. Signed-off-by: Larry Finger <larry.finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28wireless: make drivers include the TSF RX flag where appropriateJohannes Berg
These drivers pass full mactime information to the stack, make them indicate this via the new RX_FLAG_TSFT to get mac80211 to show this information in monitor mode. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-29drivers/net/wireless: Add missing "space"Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
